Frånluftsvärmepumpar
Isolated exhaust ventilation
Ämne: Isolated exhaust ventilation (läst 1690 gånger)
Throwback
Nybörjare
Antal inlägg: 3
Värmepump eller värmepumpar?
Throwback
06 oktober 2022, 11:29:21 »
I live in a villa built in 2006 and we have a Nibe 310P. We are thinking of changing to F730, but not sure if we have insulated exhaust ventilation - the plans say we do but I am not sure if it is so in the walls and at the pump. I have a visual confirmation in the cat vind, however.
Here is higher resolution picture of the plan, i have seen that some plans contain the word the whole way up, which our doesn't which also make me suspicious.
https://www.dropbox.com/s/dy3m0tfipzue26x/2022-10-04%2021.47.50.jpg?dl=0
What do you think?
Senast ändrad: 06 oktober 2022, 11:33:13 av Throwback
Västerhaninge 17
Expert på värmepump
Stad/land: Stockholm (Haninge)
Antal inlägg: 620
Västerhaninge 17
SV: Isolated exhaust ventilation
06 oktober 2022, 13:08:32 »
You need at least a PE30 (30 mm insulating) insulating sock for the Nibe 730 .
https://www.ventilationsbutiken.se/sv/artiklar/isolerstrumpa-pe30-160mm-m.html
Stockholm,Byggår 2008,1.5 pl,84 m2 nere, tot 161 m2 ,värmeslang i betongplattan (pålad) Garage 35 m2
IVT490 FLVP (Dec 2008 - Sep 2026) Daikin Caldo XRH30 (inst Dec 2019) Nibe S735-7 (Sep 2026 -)
2010: 15439kwh (total förbr)Ö-våning ej isolerad
2011: 11777kwh (t.f) Ö-våning isolerad
2012: 12049kwh (t.f)
2013: 11973kwh (t.f)
2014: 11522kwh (t.f) luftvärmepump inst. November
2015: 10367kwh (t.f)
2016: 12227kwh (t.f)
2017: 13424kwh (t.f) 700 w Byggfläkt inkopplad i garaget
2018: 15182kwh (t.f)
2019: 15752kwh (t.f)
2020: 12472kwh (t.f) LLVP mont i garaget Augusti + Braskamin i huset (600 kg täljsten)
2021: 13699kwh (t.f) Har haft +20 gr i garaget och eldat mindre .
2022: 12249kwh (t.f) Eldat som en tokig , 20gr i garaget .
2023: 11806kwh (t.f)
2024: 11566kwh (t.f)Ngt lägre temp i garaget 16-18 gr .
2025: 11502kwh (t.f)
Throwback
Nybörjare
Antal inlägg: 3
Throwback
06 oktober 2022, 13:43:51 »
Thanks for your answer, I went up in the attic now and it is just aluminum foil around it, no insulation, so it must be done.
I read about armaflex also, would that be easier to use, than the one you linked?
Should I measure the pipe width or will it be 160mm that you linked me to?
Perhaps someone has a guide on how to terminate in the roof and at the heatpump?
Västerhaninge 17
Expert på värmepump
Antal inlägg: 620
Västerhaninge 17
06 oktober 2022, 13:58:10 »
Armaflex is condensation safe, but expensive. Hard to tell if you have 160mm or 125mm vent pipes.
There is insulation for both variants.
Throwback
Nybörjare
Antal inlägg: 3
Throwback
06 oktober 2022, 15:13:33 »
Thanks, I will measure to be sure - I also see that I have a sound muffler/silence above the hallway, i suppose it is larger than the rest of the ventilation pipe. How do you insulate that?
Västerhaninge 17
Expert på värmepump
Antal inlägg: 620
Västerhaninge 17
07 oktober 2022, 15:54:40 »
Sound muffler on the exhaust air
strange .
The plastic around the insulation must be 100% airtight .
gäster: 2003
användare: 5
jantijanti
husse
tyke
Zyberdude
flat7
