Värmepumpar - Luft/luft
Märkesspecifikt luft/luft
DAIKIN
(Moderatorer:
Bosse-värmepumpsdo
Turn off or permanent on?
Ämne: Turn off or permanent on? (läst 2362 gånger)
mcbota
Lär mig om värmepumpar
Antal inlägg: 25
Värmepump eller värmepumpar?
mcbota
30 oktober 2014, 20:02:28 »
Now when the winter is coming again, and being only the second year using air to air heat pump, I want to ask you which is the best method to use it: turn off when I am not at home and during the nightm or just setback to lower temperature in these moments? The house is well insulated! Thanks
Lussebulle
Kan värmepumpar
Antal inlägg: 176
Ururu-Sarara Emura Nexura Caldo Origo Altherma
Lussebulle
SV: Turn off or permanent on?
31 oktober 2014, 07:06:25 »
During the season I'd recomend on and no setbacks. For comfort reasons. If you leave home for a period of time a setback can cut of some extra $£€
regards
Daikin, vad annars?
mcbota
Antal inlägg: 25
mcbota
31 oktober 2014, 11:05:50 »
Thanks for the answer. During the day, when we are at work, it is most efficient to let the heat pump on to not be necessary to work too much when we will be back? Regarding from consumption-confort, which is the best method?
DAIKIN
(Moderatorer:
Bosse-värmepumpsdo
gäster: 2236
användare: 7
krambriw
BiggerDigger
tomasbjork
toen
Smurfen.
Jisse
Börje__
