Författare Ämne: Turn off or permanent on?  (läst 2359 gånger)
Utloggad mcbota
  • Antal inlägg: 25
« skrivet: 30 oktober 2014, 20:02:28 »
Now when the winter is coming again, and being only the  second year using air to air heat pump, I want to ask you which is the best method to use it: turn off when I am not at home  and during the nightm or just setback to lower temperature in these moments? The house is well insulated! Thanks
Utloggad Lussebulle
  • Antal inlägg: 176
  • Ururu-Sarara Emura Nexura Caldo Origo Altherma
SV: Turn off or permanent on?
« Svar #1 skrivet: 31 oktober 2014, 07:06:25 »
During the season I'd recomend on and no setbacks. For comfort reasons. If you leave home for a period of time a setback can cut of some extra $£€
regards
Daikin, vad annars?
Utloggad mcbota
  • Antal inlägg: 25
« Svar #2 skrivet: 31 oktober 2014, 11:05:50 »
Thanks for the answer. During the day, when we are at work, it is most efficient to let the heat pump on to not be necessary to work too much when we will be back? Regarding from consumption-confort, which is the best method?
