Författare Ämne: Nibe 1255 , Officiell tråd.  (läst 965628 gånger)
Utloggad sollner
  • Antal inlägg: 3
SV: Nibe 1255 , Officiell tråd.
« Svar #90 skrivet: 20 april 2015, 13:48:44 »
thanks ...
This is what Nibe writes on there hompage, http://www.nibe.se/Produkter/Bergvarmepumpar/NIBE-F1255
yes i know this site
but this really is even so ...  in real conditions ( or experience )
and why there will be a 3-12 Nibe ?
and when? ;-)
ps:
Current needs, electricity *   20000 kWh/year = electricity means 20.000 kWh thermal, or?
(20.000 th. / 5 (JAZ) = 4.000 el.)
« Senast ändrad: 20 april 2015, 13:50:46 av sollner »
Utloggad SUNE73
  • Stad/land: STOCKHOLM
  • Antal inlägg: 1043
  • KUNSKAP ÄR MAKT!
    • Temp mätning
« Svar #91 skrivet: 20 april 2015, 17:17:30 »
thanks ...
and when? ;-)
ps:
Yes it means your electricity consuming for heating your house incl hot water excl lights etc.
Example,
Your house are heated with electrical heating "immersion heater" and consuming 20000 kwh/year.
With the Nibe 1255 6kw installed you save 14500 kwh/year. 20000-14500=5500  tummenupp
You now consume 5500 kwh/year instead together with your heating pump.  8)
Note it is just a example!
Often saves typically between 50 - 70% of total consuming with heatpump in real life!
Mitt fritidshus by.år -00 1 1/2 plan total golvyta  ca 160kvm ca 18 grader året runt - IVT C5 100m BORRA, GOLVVÄRME I SPÅRADE SPÅNSKIVOR 100m2, TOTAL FÖRBRUKNING 4-5000kwh/år 2000-2018 inkl HH EL
Nuvarande bostadshus by.år -77 1 plan i suterräng total golvyta 267m2 - Nibe F1255 4-16kw installerad 20150311, VVB Carrier 300/180 seriekopplad som volymförstorare, Borrdjup 180 m, 8 Radiatorer 1-rörs ca 80W/m2, ca 100m2 Golvvärme, Pool 20m3, Total förbrukning tidigare ägare ca 15000kwh, FTX Heru 130 EC startad 150715, Total förbrukning 10060 kwh 2019 inkl HH el.
Mitt fd bostadshus by.år -58 1 1/2 plan total golvyta 127m2 ca 21,8 grader året runt - NIBE 1215 7kw, 181M BORRA Ca 175 AKTIVT, 12 RADIATORER 80W/m2, ACC.TANK NIBE UKV100, FTX HERU 75, TOTAL FÖRBRUKNING 8-10000kwh/ÅR 2005-2013 INKL HUSHÅLLSEL
Utloggad sollner
  • Antal inlägg: 3
« Svar #92 skrivet: 20 april 2015, 20:15:40 »
ok ,
i have now  2000 liter oil consumption per year ,
these are 2000x10x0,85 = 17.000 kWh ,
(max. 200 kWh/per day)
a Nibe 1255 /1.5-6 is enough for me?
Utloggad SUNE73
  • KUNSKAP ÄR MAKT!
    • Temp mätning
« Svar #93 skrivet: 20 april 2015, 21:22:01 »
Yes, that should be great.
I encourage you to speak with a technician who can make a correct calculation where you live.
Depending on type of rock, if you will drill?
Utloggad Flinta
  • Antal inlägg: 628
« Svar #94 skrivet: 22 april 2015, 01:14:11 »
Du ska nog inte räkna med att anslutningspunkterna sitter på samma ställe när du ev ska byta vp men det går ju rätt fort att flytta dom nån cm eller så men din vp ska väl gå länge än.
Efter mycket planering fick jag ihop det bra. Pannrummet är ganska litet så det är trångt och man kan inte dra allting hur som helst och ändå få det optimalt. Nu är det liksom "perfekt", kan man ju säga, men om jag måste göra om allt om sådär 10-15 år så lär jag ju slita ut mitt hår. Och om jag lejer bort arbetet så kommer rörmokaren bara fördärva allting med underdimensionerade ledningar och VP placerat helt åt skogen. Alla jag har haft här för offert har kommit med olika, helt sjuka, lösningar om hur de vill placera VP och acktank. Ni skulle sett lösningarna alltså, helt sjuka var de. De tänker inte en sekund på att resultatet skall bli bra, det märks. Bara det går snabbt.
Sedan tog det ju lite extra tid att planera in allt perfekt, men det blev så bra så det är inte klokt :)
Allt är nu väldigt platsbesparande och optimalt vad gäller flödesmotstånd osv. Allting är mjuklödat så det går att ta isär, men så klart inte roligt.
Intressant fråga, och egentligen kanske en bra idé om alla tillverkare  följde den, dvs om det var en norm. Man kan nog tänka sig flera fördelar, t exvid behov av snabbt byte
Det borde definitivt ligga i tillverkarnas intresse att efterföljande modeller följer samma anslutningsupplägg, så när man köper nytt så skruvar man bara bort det gamla och sätter dit det nya, utan att behöva röra mer än nödvändigt. Alla tjänar ju på det. Kunden tjänar på det, då arbetet blir smidigare och därmed billigare. Röris tjänar på det, då han slipper jobba massa extra med det och slipper slita sitt hår. VP tillverkaren tjänar på det, för det kanske rent av är en avgörande faktor för kunden kanske i ett fall där det är trångt osv. (som i mitt fall) och är man van vid ett märke, så är det lättare att fortsätta med det om man bara kan byta helt smärtfritt.
Skall man planera om halva pannrummet vid ett byte, så kan man ju lika gärna byta märke när man ändå håller på liksom, och det förlorar ju tillverkaren på :)
Utloggad Flinta
  • Antal inlägg: 628
« Svar #95 skrivet: 25 april 2015, 18:20:49 »
Rickard, kan du klistra tråden? Blir lättare o hitta den då :)
Utloggad tellus
  • Antal inlägg: 80
« Svar #96 skrivet: 26 april 2015, 07:04:30 »
Håller med , har i veckan sagt ja till en offert på en 6kw . Gjorde jag rätt ?
fick några alt på Nibe :
1255 150 m borr 145tkr
1245 120 m borr 133 tkr
inkl/exkl samma grejer f.ö.
valde 1255,tror det blir bra. Jag kommer nog vara klistrad vid denna tråd !
  • Antal inlägg: 36598
« Svar #97 skrivet: 26 april 2015, 08:55:13 »
Klistrad.
Utloggad Flinta
  • Antal inlägg: 628
« Svar #98 skrivet: 29 april 2015, 02:24:09 »
Utloggad Flinta
  • Antal inlägg: 628
« Svar #99 skrivet: 29 april 2015, 02:31:37 »
Jag har 16kW så jag kan ej svara för 6kW, men om den täcker ditt energibehov samt är lika effektiv som 16kW, så kan jag inte annat att tycka att du gjorde helt rätt.
Jag är så supernöjd med min så.
Hittills (och då har mätningen inte pågått ett år ännu), så har jag sänkt från ca. 28.000kWh tror jag det var? till drygt 11.000kWh. Och då är inte mätningen över än! Får reda på årsresultatet först om ett par veckor, så det kan hända att det t.o.m hamnar under 11.000kWh. Och då skall man också räkna in att jag nu har dragit på rejält med värmen jämfört med innan, från ca. 15-18 grader på ca. 145 m2, där vi just nu inte bor, till 20-21 grader! Även i delen där vi nu bor, ca. 80m2, har jag ökat värmen, från 18-19 grader till 21 ca. bara för att verkligen testa.
Hade endast elpatron förut kan tilläggas.
Utloggad tellus
  • Antal inlägg: 80
« Svar #100 skrivet: 06 maj 2015, 16:04:08 »
Min1255 ska installeras i sommar , vad göra rätt innan ?
Har idag vedpanna med 2 acc x 500 den ena med vvb ock el-patroner , laddomat ,effektvakt , exp-kärl , en 55-liters vvb , motorshunt med innetermostat . Inget av detta behövs , men är det smart att använda något för att förbättra nyinstallationen ?
Sitter idag 4 stora och 2 små rad på markplan , 1 på övervån och 2 i källare som får värme via shunten .Sitter en rad i duschen i källaren som får sitt från stigarledn , oshuntat , den ska bort . Övriga skall kopplas in .
Har beställt 4 nya raddar som ska monteras i källaren , gör detta själv innan för att få det inkopplat i samb. med pumpinst. Fick paket från Rinkaby med 15 mm cu och kopplingar som jag ska dra åt olik håll från pannrummet , med ballofixer på flera ställen . Vid en titt i ballofixerna så är det väldigt små hål i dessa - spelar det roll ?
1: Dra  dessa rör åt 3 olika håll med ballofixer i början för att enkelt kunna ändra/lägga till senare ? Eller stryper de viktigt flöde ?
2: Ändra till 22mm med ballofixer i början för att sen gå ner till 15 mm ?
3: Byta ut 15mm ballofixerna till något annat som har bättre flöde ?
  Fler frågor kommer säkert !
« Svar #101 skrivet: 06 maj 2015, 18:09:07 »
15 mm rör känns FÖR klent, men det är svårt att avgöra utifrån din förklaring, en ritning är bättre, här kan du läsa lite om hur man schablonmässigt kan dimensionera stammarna: https://www.varmepumpsforum.com/vpforum/index.php?topic=72471.0
Ballofixarna stryper lite, men stypningen har ju även med sträckan att göra, jag kan inte svara på hur stort problemet är.
Känns som att du snålat lite väl mycket när du beställde från Rinkaby...
Max 3 radiatorer på en 15 mm stam kan man väl säga rent generellt, beroende på storlek förstås.
Jag drog själv 22 mm i hela stammarna och 15 mm avstick till varje radiator, utom på två ställen där två radiatorer delar på flödet från en 15 mm matning.
Du skulle kunna använda 500 liters tanken som har den inbyggda förrådsberedaren som volymtank och till förvärmning av tappvarmvatten.
Koppla alltså kallvattnet på inkommande till vvb, och ut från vvb till "inkommande" på värmepumpens vvb, kör sedan flödet från radiatorerna (framledningen) genom tanken så att det vatten som skall fylla på värmepumpens beredare förvärms av "radiatorvattnet" i tanken.
Dock hade det varit bättre med slingor i tanken, en 50 liters vvb som bara värms till 20-45 grader riskerar få tillväxt av legionella.
« Senast ändrad: 07 december 2020, 09:27:35 av Rickard »
Utloggad tellus
  • Antal inlägg: 80
« Svar #102 skrivet: 07 maj 2015, 07:11:43 »
Snålat? :) Kunskapsbrist , vilket nog är värre !
15mm är nog på gränsen till litet , vill hellre ta 22 i pannrummet så blir 15 bra till resten .
Hur gör man när rör ska korsa överliggande vid en t-koppling med 22 åt alla håll ?
15 bockar jag själv ( finns även färdiga bitar) men 22?
« Svar #103 skrivet: 07 maj 2015, 07:45:35 »
Förklara "korsa överliggande"
Utloggad Sanntos
  • Antal inlägg: 950
« Svar #104 skrivet: 07 maj 2015, 11:16:25 »
Kanske tänker han på S-böj 22 mm rinkaby 7668
  • Dot gäster: 1364
