Författare Ämne: Nibe 1255 , Officiell tråd.  (läst 919619 gånger)
Utloggad Flinta
  • Antal inlägg: 628
« skrivet: 20 september 2013, 20:49:19 »
NYA NIBE F1255 4-16kW med frekvensstyrd kompressor, bättre än F1245?
Hittade följande info (ser ju onekligen bra ut på papper, men verkligheten då?):
HEAT PUMPS WIH INVERTER -CONTROLLED COMPRESSOR
FOR RESIDENTIAL AND COMMERCIAL BUILDINGS
NIBE F1155/F1255 is an intelligent heat pump fitted with invertercontrolled
compressor and speed-controlled circulation pumps.
Suitable for use in residental and commercial buildings. The heat
pump adjusts itself automatically to the power demand of the
house. This results in optimal savings as the heat pump always
runs at the correct performance all year round without the addition
of extra electrical peaks.
The integrated coil water heater (NIBE F1255) is available in three
different corrosion protections (stainless steel, enamel and copper).
It is prepared for connection to several different products and
accessories, for example, hot water heater, ventilation recovery,
pool, free cooling, active cooling and heating systems with different
temperatures.
Technical Data
Type: NIBE™ F1155 F1255
Delivered Power kW 4-16 4-16
EN 14511
Supplied power at 0/35 °C1) 46 Hz kW 1.68 1.68
Delivered power at 0/35 °C1) 46 Hz kW 7.96 7.96
COP 0/35 °C1) 4.72 4.72
EN 14825
Pdesign kW 15 15
SCOP2) on 5.08 5.08
Volume water heater litres – appr 180
Immersion heater, max kW 9 9
Max temperature heating medium
(flow/return circuit)
°C 70/58 70/58
Net weight (without water) kg 178 335
Height mm 1500 1800
Width mm 600 600
Depth mm 620 620
1) At Nominal power
2) Cold climate, low temperature
Källa: http://www.friorka.is/Pdf/NIBE_NEW_2013.pdf
Uppdatering: 2013-09-23
Nibe F1255 nu uppe på Nibe's webbsida:
Nibe F1255 produktsida
Produktblad pdf-fil
Framledningstemp enl. produktblad är 70 °C, till skillnad från vad teknisk info visar på produktsidan.
« Senast ändrad: 23 september 2013, 17:22:19 av Flinta »
  • Antal inlägg: 19463
SV: Nibe 1255 , Officiell tråd.
« Svar #1 skrivet: 20 september 2013, 21:10:57 »
Den har ju lite bättre cop vid 35 grader framledning  tummenupp Den gamla 1250 har känts gammal sen 1245an kom så det var verkligen dags för en nyare inverter med modern beredare och display hoppas bara att dom sätter priset så att det finns köpare till den. Den gamla 1250 var ju alldeles för högt pris satt förutom möjligen för dom med riktigt stort energibehov.
Utloggad Flinta
  • Antal inlägg: 628
« Svar #2 skrivet: 20 september 2013, 21:19:53 »
Blir bättre pris än 1250, men högre än 1245. Något mittemellan skulle man kunna säga.
Undrar hur livslängden på kompressorn ser ut i denna? Har för mig att det på F1250 bara är 7 år, som jag hade jag läst för ett tag sedan?
Sedan kan man ju undra om de kör med köldmedium R410A eller R407C?
« Svar #3 skrivet: 20 september 2013, 21:26:13 »
Var har du hört att 1250 skulle hålla 7 år ? Även om en inverter får många drift timmar borde den hålla längre än så annars blir det nog en dålig affär. Gissar att dom kör vidare med 407 eftersom den verkar klara samma framledning som 1245.
Utloggad Flinta
  • Antal inlägg: 628
« Svar #4 skrivet: 20 september 2013, 21:32:22 »
Lyckades hitta snabbt var jag läste det om 7 år, men jag minndes tydligen fel. Det stod ej att just 1250 hade en livslängd på 7 år, utan snarare inverter kompressorer. Sen läste jag ju det på forumet så det vet man ju aldrig om det är sant eller ej :D
Här är länk.
http://www.varmepumpsforum.com/vpforum/index.php?topic=41906.msg401356#msg401356
Utloggad Flinta
  • Antal inlägg: 628
« Svar #5 skrivet: 23 september 2013, 16:00:34 »
Nibe F1255 uppe på Nibe's webbsida:
http://www.nibe.se/Produkter/Bergvarmepumpar/Sortimentslista/NIBE-FIGHTER-12501/
Produktblad (lite annan info än i nedan tabell, undrar vilket som stämmer): http://www.nibeonline.com/pdf/639574-1.pdf
Nominell avgiven/tillförd effekt vid 0/35 °C 50 Hz *    8,89/1,83 kW
COP *    4,85
SCOP **    5,5
Avgiven effekt *    4 - 16 kW
Vattenvolym beredare    180 liter
Höjd    1800 mm
Bredd    600 mm
Djup    620 mm
Nettovikt    180 kg
Driftspänning    400 V (3-fas+N)
Köldmediemängd (R407C)    2,2 kg
RSK nr    624 70 08
Dimensionering och besparing
Nuvarande totalbehov, olja    4 m³/år    5 m³/år
Nuvarande totalbehov, el ***    32000 kWh/år    40000 kWh/år
Bergvärme, borrdjup (aktivt) ****    160 - 2x115 m    160 - 2x115 m
Markvärme, slanglängd ****    2x250 - 2x400 m    2x250 - 2x400 m
Besparing****    23700-23900 kWh/år    29800-30000 kWh/år
Nuvarande totalbehov, olja    6 m³/år
Nuvarande totalbehov, el ***    48000 kWh/år
Besparing****    35700-35900 kWh/år
*    Effektuppgifterna vid 0/35 °C 50 Hz är angiven enl. EN 14511. (Eltillsats ej medräknad).
**    Effektuppgifterna vid 0/35 °C 50 Hz, Pdesign 12 kW, är angivenenligt EN 14825 Cold climate
***    Nuvarande totalt elbehov är exklusive hushållsel (ca 5.000 kWh/år)
****    Angivna värden är endast grova riktvärden. För korrekt dimensionering, rådgör alltid med din installatör.
Mer information:
    Optimal årsvärmefaktor tack vare den inverterstyrda kompressorn.
    Inverterstyrd köldbärarpump som förser värmepumpen med för driftfallet anpassat köldbärarflöde.
    Integrerad varmvattenberedare.
    Minimala driftskostnader, ingen dyr elspets när det blir kallt ute. Kompressorn varvar upp/ner efter rådande behov.
    Högt temperaturområde
    – Framledningstemperatur 65 °C
    – Returledningstemperatur 56 °C.
    Styrning med kommunikationsmöjligheter
    – Se status och gör inställningar över Internet och SMS med tillbehöret RCU.
    Effektvakt som standard.
    Inbyggd klocka för schemaläggning av extra varmvatten och sänkning/höjning av framledningstemperaturen.
    Förberedd för pooluppvärmning.
    Förberedd för styrning av två värmesystem.
« Senast ändrad: 23 september 2013, 16:49:45 av Flinta »
  • Antal inlägg: 4484
« Svar #6 skrivet: 23 september 2013, 16:30:37 »
Den hade varit perfekt i huset i Dalarna, 4-16kW. Låg effekt när lilla stugan inte är fullt uppvärmd och hög effekt när det är svinkallt.  tummenupp
Min F1245-12 är lite stor när det inte behövs så mycket värme, och lite liten när det drar ner mot -30⁰. Det händer att tillskottet går fast pumpen står i semesterläge med +15⁰ inomhus.  :P
Utloggad Flinta
  • Antal inlägg: 628
« Svar #7 skrivet: 23 september 2013, 16:32:43 »
Ja den ser ju onekligen bra ut på papper! :)
« Svar #8 skrivet: 23 september 2013, 18:03:05 »
Är det endast kalla cp som har automatiskt hastighet ?
« Svar #9 skrivet: 23 september 2013, 21:56:00 »
Verkar ha auto hastighet även på varma sidan med möjlighet att max begränsa i övrigt mycket lika som 1245 har finns en del att läsa http://www.nibeonline.com/pdf/231513-2.pdf
« Svar #10 skrivet: 24 september 2013, 16:45:26 »
Verkar vara lite dåligt med inställnings möjligheter tex beträffande deltat och även vilken fart kompressorn ska ha vid vv beredning har för mig att man kan justera sånt på  Ivt x11/x15 spelar säkert ingen roll men det är ju kul om det går att påverka driften.
Utloggad haddirajan
  • Stad/land: Motala
  • Antal inlägg: 89
« Svar #11 skrivet: 20 december 2013, 09:16:08 »
Anledningen till att du inte kan mecka med detta är att beredaren inte klarar av att ta emot större vv-laddning. Den laddar alltså varmvatten med drygt 9 kW. För större effekter får man satsa på en 1155 och en VPB300, men det är inte säkert att du kan ändra frekvensen för vv-laddning ändå.
Det är bra att Nibe inte släppt alla inställningar, många knappar bort sig och ringer serviceombudet när maskinen larmar sedan. Och tror ni de vill betala för hembesök och återställning av inställningar?
Ju mer auto desto bättre drift för gemene man :-)
Installerade i första huset:
Nibe 1230-8 + ES210 VVB i östgötska Motala
Frikyla via Veneto FST 44+1.
Andra huset:
NYTT PROJEKT:
Bygger nytt hus hösten 2007, det skall bli jordvärme och en IVT 495 Twin.
Golvvärme i huset 135 kvm samt garaget 55 kvm. Ska bli kul att se vad den pallar med!
2011- IVT 495 blev dyr i drift, nu är det istället en 1235-6 och en FLM på 220 m jordslinga.
Tredje huset:
220 kvm byggt -69. Ut med vedpanna, bort med solpaneler och luft/vatten. Borrat 220m och en Nibe 1255.
Utloggad Sanntos
  • Antal inlägg: 950
« Svar #12 skrivet: 22 mars 2014, 23:38:57 »
Funderar på det här med arbetstank... behovet av sådana måste ju minska nu, med styrda cirkulationspumpar och kompressorer. Även om man har golvvärmesystem och radiatorer med termostater som stänger och öppnar så anpassar sig ju vp:n efter behovet...?
Utloggad Flinta
  • Antal inlägg: 628
« Svar #13 skrivet: 23 mars 2014, 02:23:31 »
Det är alldeles riktigt att behovet av arbetstank minskar, ganska rejält också. Man behöver helt enkelt ingen acktank till en 1255:a för att den skall gå lugnt och bra. Däremot är det ingen nackdel heller om man har pengarna och det extra utrymmet som acktank kräver. Den kan minska eller eliminera eventuella knäppningar, samt även sänka antal start/stopp även om 1255:an är en inverter.
Jag har en 1255:a med extra 100 liters acktank och t.o.m nu blir det några start/stopp per dag, så jag är trots den extra kostnaden nöjd ändå.
Tänk på att om du paralellkopplar tanken, dvs med 3 eller 4 anslutningar, så måste du ha en extra cirk.pump. Kopplar du acktanken med 2 anslutningar, dvs i serie, så räcker det oftast med den inbyggda cirkpumpen.
Men återigen, en 1255:a funkar nog alldeles utmärkt utan acktank också.
Ang. termostater så bör du nog låta VP sköta det mesta och låta termostaterna vara fullt öppna, men den frågan överlåter jag till någon annan att svara på.
« Senast ändrad: 23 mars 2014, 02:27:33 av Flinta »
Utloggad Flinta
  • Antal inlägg: 628
« Svar #14 skrivet: 02 april 2014, 00:16:30 »
Energimyndigheten har nu testat Nibe 1255.
Bergvärmepumpar - jämförelsetabell
Tyvärr syns inte Daikin's maskin i den tabellen utan den får man titta på här separat:
Dakin's siffror
« Senast ändrad: 02 april 2014, 00:22:07 av Flinta »
  • Dot gäster: 1023
