Författare Ämne: Energicentrapumpen Officiell tråd!  (läst 1917956 gånger)
Utloggad johnny2d
  • Antal inlägg: 309
SV: Energicentrapumpen Officiell tråd!
« Svar #1950 skrivet: 28 oktober 2009, 13:34:19 »
Yo!
Is there any HW-controller cards with updated SW available nowadays? Is there any indoor panel vid newer/better SW available than those we have installed? Or, is it final version we have of them after that many of us updated the HW-card in the outdoor part..?
BR!
-Johnny2d
Utloggad greven1
  • Vd
  • Stad/land: örnsköldsvik
  • Antal inlägg: 1020
  • Fri energi
    • energicentra.se
« Svar #1951 skrivet: 28 oktober 2009, 15:41:39 »
Here is Tony, the sales manager from Zhongshan Amitime Electric Co.,Ltd. writting to you. The visit we paid to Krister this time is only a business visit so we didnot bring any engineers here. When we backed to China or when our chief engineer Joe comes Sweden sometime, we will try to answer some questions. Sorry....''
Regarding the defrosting issue, I should say that it is really hard to let the unit know when it should defrost and when it should stop defrost, as the unit can only clarify this through some simple datas, like the Temp. And, we have to ensure the unit will defrost all ice away even in the hardest condition (when the air Temp is a little bit higher than 0, not the lowest air Temp). This is why sometimes the unit defrost more time than necessary.
Now the unit starts and stops the defrosting mainly according to the Temp of the condensor pipe. Do you have any good suggestion about defrosting? If yes, hope you are willing to share with us, so we can apply this better solution to our future products. Thank you!
följ strömmen  stäng av den !!
12 kw solceller. nulite 35 kw bergvärmepump. 700 m borrhål /4 hål
Utloggad Teltur
  • Antal inlägg: 834
« Svar #1952 skrivet: 28 oktober 2009, 17:50:53 »
Hello Mr Tony
I hope you can take back the question about the time delays in the defrosting cycle back to Mr Joe.
If we get down the time on the defrosting cycle it would increase the energy output a lot.
I have also a another question
I have seen in the Swedish market a new pump with a upgraded indoor heat exchanger.
Would it be possible to upgrade our old pumps with this new exchanger ?
Best Regards
Teltur
Utloggad greven1
  • Vd
  • Fri energi
    • energicentra.se
« Svar #1953 skrivet: 28 oktober 2009, 21:39:40 »
tjeena.
som det ser ut nu kommer tecknikern hit den 8 nov. han stannar ca 1.5 vecka. så frågorna teltur mfl har kommer han själv att få besvara då han är här.
tony o hans chef åker tillbaka i morron bitti.
den nya iden med dc inwerter split unit utan gas rör är nu i drift. den har även numera elektronisk exp ventil.
så tanken min har varit att få till en maskin utan söl med gas o vacum trams med påföljd att bryta mot köld medie förordningen.
nu är maskinen klar !!  cop o övrig data vet jag inte ännu Thumbsup & jag vill nog köra denna en stund innan jag ropar hej.
krister
Utloggad zibrosc1235
  • Antal inlägg: 508
  • Karma +5/-29
    • Budgetvärmepumpar
« Svar #1954 skrivet: 28 oktober 2009, 21:46:42 »
krister
*vinkar* Den lösningen håller jag tummarna för! Blir den bra har Du åtminstone en kund på ingång...
Suterränghus
Ventilation: Självdrag
Söder om Mälaren
Utloggad whynot
  • Antal inlägg: 323
« Svar #1955 skrivet: 28 oktober 2009, 22:57:27 »
Så det är en split med en extra växlare för vatten som sitter inne för att slippa ha så mycket glykol men det går åt en extra pump?
Utloggad greven1
  • Vd
  • Fri energi
    • energicentra.se
« Svar #1956 skrivet: 29 oktober 2009, 11:29:56 »
hej.
yes helt riktigt !! lite sämre cop med denna lösning men jag tror den är knappt mätbar. cop ökar lite med elektroniska exp ventilen så det blir helt godkännt i alla fall.
rör mellan inne del o ute del blir typ pex rör färdig isolerade som man kapar i rätt längd . på med muttern in med en stöd hylsa dra fast o fyll glykol = klart.
krister
Utloggad Thomas S
  • Stad/land: Kungälv
  • Antal inlägg: 248
« Svar #1957 skrivet: 29 oktober 2009, 21:14:37 »
Låter som något för mig också! Ser fram emot resultatet av "provkörningen".  studs
__________
Mvh Thomas
ca 150 kvm (suterräng, i Kungälv/Kode) med inredd källare
Daikin Caldo X25 (övre plan) & Mitsubishi KJ25 (källarplan)
Utloggad johnny2d
  • Antal inlägg: 309
« Svar #1958 skrivet: 30 oktober 2009, 07:55:17 »
Funderar litet kring den nya pumpen.. Blir det en annan typ av vämepaket på utedelen än den som är på EC/FOMA-pumpen? Den gamla varianten frostar igen nått så hopplöst så det spelar ingen roll om pumpen så är på 9kw så skulle det ändå inte fungera.. Eller löses detta genom att man har vatten/glykol som media på nått sätt?
Spännande att följa testerna!!
-Johnny
Utloggad greven1
  • Vd
  • Fri energi
    • energicentra.se
« Svar #1959 skrivet: 30 oktober 2009, 23:41:24 »
-Johnny
sitter en helt ny förångare med större lamell avstånd . sedan är lamellerna utformade som vågor så ytan ökar markant.
Utloggad Berga_Kungen
  • Antal inlägg: 124
« Svar #1960 skrivet: 31 oktober 2009, 18:53:54 »
God afton!
Jag undrar om det är någon annan som har noterat att kompressorn sänker pga. hög gastemp?
I min logg kan man se att pumpen sänker farten när den nått strax över 94 ºC för att sedan öka igen.
Troligen mäter min givare några grader fel, ska montera om den när det blir roligare väder :), för det är vid 97 ºC grader som den ska sänka "If the gas discharge temp is between 97℃ and 110℃, compressor speed drops by 1Hz/3s"
Vi har inget trevligt väder för luft värmepumpar, fuktigt och kring nollan.
Någon som har en bra idé varför den ska nå så höga temperaturer under rådande omständigheter 2-3 ºC utomhus 29-30 ºC ut pumpen?
Uppdaterat:
Jag har inte observerat något läckage.
/B_K
« Senast ändrad: 31 oktober 2009, 19:03:59 av Berga_Kungen »
Utloggad whynot
  • Antal inlägg: 323
« Svar #1961 skrivet: 31 oktober 2009, 19:36:52 »
hej.
krister
Är väl inte bara,,,,, måste väl till ett expansionskärl också och vad ska styra pumpen? finns nog en hel del att fundera på tror det kan bli en ny 200 sidors serie här.
Utloggad zx12r
  • Antal inlägg: 262
« Svar #1962 skrivet: 31 oktober 2009, 20:19:10 »
Blir spännade att se om de klarar av att fylla rätt mängd kylmedia i alla pumpar av den nya modellen då... Eftersom att folk kommer att installera den utan kyltekniker och med möjligen än mindre kompetens än de som installerat den gamla EC-pumpen. Kineserna har ju inte visat sig vara speciellt noga med detta tidigare.
Mvh Thomas
Utloggad johnny2d
  • Antal inlägg: 309
« Svar #1963 skrivet: 31 oktober 2009, 21:51:07 »
-Johnny
Låter jättebra det. Du, det skulle inte möjligen gå att fixa utbytesförångare till de EC eller foma pumpar som är ute på marknaden idag? Jag lider nått så fruktansvärt av frost så det är nästan inte sant efterssom vi har så lång höst och vår här i jämtland. Pumpen ger pga ständig igenfrostning ingen vinst alls september till november  :(  Den går faktiskt på full effekt i 3 månader i sträck hela hösten (utom de varmaste dagarna såklart) och håller bara precis vårt lilla hus varmt, men det är kallt inne varje morgon.
Har provat allt, men det fungerar verkligen inte.. och snart är det riktig vinter och då när frostproblemet ger sig vid -7 så är det inte så mycket COP kvar så det blir så mycket vinst.
Kan du inte trolla fram nya förångare som fungerar bättre som man kan anlita en kylis som kommer och löder på??
Ha de bra!!
-Johnny
Utloggad greven1
  • Vd
  • Fri energi
    • energicentra.se
« Svar #1964 skrivet: 31 oktober 2009, 23:45:14 »
hej.
njaa denna förångare är en hel del större så den passar inte i de mindre maskinerna sorry !!
men så här ser den ut efter 40 minuter i minus 1 grad ute
