Författare Ämne: Issue with conumption  (läst 4724 gånger)
Utloggad Matteo_Bocci
  • Antal inlägg: 8
« skrivet: 02 januari 2024, 21:37:54 »
Good evening,
My name is Matteo and I am writing from Tygelsjö, Skåne. I live in a two floor parhus, 133 square meters. We have floor heating on the ground floor, with the opportunity to regulate the temperature in three rooms, and heaters on the upper floor. It is a brand new house with good insulation, and our total electricity consumption in 2022 was 5160 kWh. In 2023 we used up approximately 10% more, as we had colder months in October and November.
I have recently noticed that especially during milder days, our electricity consumption has spiked to levels never seen before. This has peaed during our recent Christmas break, when temeprature outsides were always way above zero, even at night. For example, we were away during the Christmas week, and set an indoor temperature of 20 degrees before leaving. As we did not use any appliances while away, the consumption was only dependent on the heating. We used up 40-45 kWh per day, while in normal days before our vacation, we would use 20-30 kWh max but that included cooking, washing, and using appliances.
When I look at the consumption, I see that our pump uses up a whole lot of energy at night, with peas of 3-kWh for many hours between midnight and 6 AM. Sometimes I have used up already 10-15 kWh by the time we wake up in the morning.
I have tried modifying some parameters but nothing has changed. I will try and perform a factory reset tomorrow but then I think I will call in the service, as we are wasting a lot of energy, and we have to pay for it.
Is there anything you can recommend I can do?
Thank you in advance,
Matteo
Utloggad kWhalp
  • Försöker bli
  • Stad/land: Umeå
  • Antal inlägg: 2144
  • Energi- och VP-nörd
SV: Issue with conumption
« Svar #1 skrivet: 02 januari 2024, 21:46:27 »
Good evening,
Matteo
Hello!
Have you activated SMART PRICE ADAPTATION (SPA)?
That gives this kind of behaviour.
Also, please post all data, regarding temperatures, and percentages from the info display.
« Senast ändrad: 02 januari 2024, 21:49:26 av kWhalp »
  • Antal inlägg: 8
« Svar #2 skrivet: 02 januari 2024, 21:57:29 »
dear kWhalp,
Thank you for your quick response. I had the SPA activated until a while ago. However, even now that I do not have it, I can see this peas at night (the screenshots are already when the SPA was off). I am away for work so I can only access the nibe app, is there a specific data you are after? Here is a general status info.
Thank you so much!
Matteo
Utloggad kWhalp
  • Försöker bli
  • Stad/land: Umeå
« Svar #3 skrivet: 02 januari 2024, 22:35:43 »
Well, sad to say, but your exhaust air and extract air temperatures are (almost) equal, that means that only your electric heater is providing heat, and not your heat pump (compressor).
The ratio of COP (coefficient of performance) is about 1:3, so it coincides with an defective heat pump, where you one day have 20 kWh with a working compressor, and the other day 60 kWh, with only the electric heater.
(Please provide all data you can, when you are back home, so we can diagnose your equipment.)
« Senast ändrad: 02 januari 2024, 22:47:53 av kWhalp »
  • Antal inlägg: 8
« Svar #4 skrivet: 02 januari 2024, 22:58:54 »
Are you saying that, no matter what settings I might have modified, this is not the result of a bad setup from my side?
At this point, I can only hope, the pump is still under warranty, if that is really the problem!
Here are some more stats
Thanks!
Matteo
Utloggad kWhalp
  • Försöker bli
  • Stad/land: Umeå
« Svar #5 skrivet: 02 januari 2024, 23:03:51 »
I see the problem, the BS1-value is corrupt, or your fan motor is broken. BS1 is the air flow thorugh the F730, i.e that flows into the evaporator.
Restart the system when at home, and check the BS1-value again, if that does not fix the problem, you need to contact Nibe Service, and mention that BS1 is sadly only 7.6 m³/h...
Edit: 9->7.6 m³/h.
« Senast ändrad: 02 januari 2024, 23:11:19 av kWhalp »
  • Antal inlägg: 8
« Svar #6 skrivet: 02 januari 2024, 23:10:25 »
The BS1 in the screenshot says 7.6, where did you get the 9 from?
Thank you so much, it has been like this for months now, I feel so stupid thinking it was just me having done something wrong...
I will let you know!
Matteo
Utloggad kWhalp
  • Försöker bli
  • Stad/land: Umeå
« Svar #7 skrivet: 02 januari 2024, 23:13:40 »
Your BS1 should be at least 133 m² × 0.35 l/s/m² => × 3.6 = 168 m³/h.
Is the display unit glowing red, or green when you are about to open the heat pump side door?
Is the front switch on I, O, or /!\ ?
« Senast ändrad: 02 januari 2024, 23:20:04 av kWhalp »
  • Antal inlägg: 8
« Svar #8 skrivet: 02 januari 2024, 23:23:38 »
Until now, the light has always been green, never seen anything but that.
I will be back home tomorrow, and will double check, but the front switch should be on I
Utloggad kWhalp
  • Försöker bli
  • Stad/land: Umeå
« Svar #9 skrivet: 02 januari 2024, 23:34:24 »
Also, there is a very small possibility that your ventilation system is blocked, by say a stuck fire safety valve, birds nest, or so.
However I will bet my money on the supposedly broken fan motor, or the eventually faulty BS1-sensor, secondarily.
Do you hear the fan noise going up/down when you change from 62% to 80%, and back to 62% fan speed?
Does the BS1-value move at all, during that procedure?
« Senast ändrad: 02 januari 2024, 23:44:08 av kWhalp »
  • Antal inlägg: 8
« Svar #10 skrivet: 03 januari 2024, 13:17:30 »
Thanks to my neighbour,
We performed a factory settings reset, and the first thing that the system gave back was a defrosting of the conpressor. After that, these are the stats. What do you say?
Matteo
Utloggad kWhalp
  • Försöker bli
  • Stad/land: Umeå
« Svar #11 skrivet: 03 januari 2024, 13:38:26 »
It looks just fine!  tummenupp
But I find it really wierd that it did not alarm you in any way...
It approximately drained you guys some 1500-2000 kronor...
Keep an eye on the BS1-value; it should variate around your 133 m² × 0.35 * 3.6 =  168 m³/h, ideally.
More after defrost, less late in the cooling cycle.
It shoule never drop below ~100 for you, it would indicate a clogged air filter, permafrost, or broken fan/BS1-sensor.
« Senast ändrad: 03 januari 2024, 13:46:37 av kWhalp »
  • Antal inlägg: 8
« Svar #12 skrivet: 03 januari 2024, 14:07:44 »
Thank you so much! We will inform our Nibe contact anyway,
So that they can decide whether they should come in and check something. It is worrying indeed we did not receive any alarm from the pump, it has been going on like this for a couple of months at least. I feel so silly taking actions just now :(
Fingers crossed! & thank you so much for all your knowledge and tips!
Utloggad kWhalp
  • Försöker bli
  • Stad/land: Umeå
« Svar #13 skrivet: 03 januari 2024, 14:50:13 »
Nice to see that things worked out! :)
One last thing, did you at anytime in 2023  touch the "fläktsynkdrift" "fansyncdrive"?
It could potentially fool the system during the winter...
Also, please check the air filter from time to time, and vacuum it at least every 3 months!
  • Antal inlägg: 8
« Svar #14 skrivet: 03 januari 2024, 15:40:43 »
I didn’t fiddle with any of the settings,
I only update the firmware when it was released.
I regularly clean the filter once a month :)
