Författare Ämne: Nibe outdoor sensor calibration?  (läst 1596 gånger)
Utloggad ja100
  • Antal inlägg: 22
« skrivet: 04 november 2023, 18:57:15 »
Hey sorry for English! My Nibe outdoor sensor BT1 always show a temp around 2-4 degrees above the actual temp. I thought this was because the pipes for my heatpump were installed around 10 cm below the temperature sensor so it was getting some heat from those and showing a higher degree but it also shows when the heatpump is off. The heatpump has not worked for around 10 hours today as it is quite warm in Stockholm but the temperature is show 2 degrees warmer than actual. Can it be calibrated or changed or anything ? Thanks!
  • Antal inlägg: 31238
SV: Nibe outdoor sensor calibration?
« Svar #1 skrivet: 07 november 2023, 23:00:51 »
I don't think it is possible on the newer models.
But it is easy to workaround, just tune the curve offset the same amount, 2-4 degrees.
