Författare Ämne: Greenline HT Plus E14 restarts again and again  (läst 10854 gånger)
  • Antal inlägg: 2277
  • Karma +5/-4
SV: Greenline HT Plus E14 restarts again and again
« Svar #30 skrivet: 16 oktober 2023, 07:47:47 »
Don't bother the alarm, It should reset by itself
Utloggad blumi
  • Antal inlägg: 19
« Svar #31 skrivet: 16 oktober 2023, 17:13:00 »
I've tried to reduce the speed of the heat carrier pump (8m to 7m), the GT8/GT9 delta increased to cca. 10 degrees, and the hot water producing stopped when the GT9 was only 47 degrees. :(
  • Karma +5/-4
« Svar #32 skrivet: 16 oktober 2023, 18:26:00 »
I'm little lost now, but maybe
Check/clean the heatexchanger and then
logg all the sensor every minute until it stops and present.
Here my curve as an example
« Senast ändrad: 16 oktober 2023, 21:39:33 av Börje__ »
Utloggad Larsa H
  • Antal inlägg: 16
  • IVT Greenline HT+ E11 + Home Assitant med Husdata
« Svar #33 skrivet: 06 november 2023, 13:37:54 »
It can of course be a faulty PCB, or it might be enough to replace the capacitors, but usually a bad capacitor is "swollen" on top.
We've experienced numerous issues with intermittent restarts on our HT Plus E11 which were caused by faulty electrolytic capacitors (ELCO) on the Rego. None of the original ELCOs were swollen on the top but had likely lost their capacity due to aging. Give it a try; replacing the ELCOs is a pretty straightforward process and only takes 10-15 minutes in total.
Check this thread: https://www-varmepumpsforum-com.translate.goog/vpforum/index.php?topic=80742.0&_x_tr_sl=sv&_x_tr_tl=en&_x_tr_hl=en-US&_x_tr_pto=wapp
« Senast ändrad: 06 november 2023, 13:47:52 av LarsHammar »
Utloggad blumi
  • Antal inlägg: 19
« Svar #34 skrivet: 08 december 2023, 22:01:39 »
Thanks, I'll check this thread.
« Senast ändrad: 09 december 2023, 07:12:40 av Rickard »
