Författare Ämne: Panasonic ce9pke varmer dåligt. Defekt spole?  (läst 2186 gånger)
Utloggad maraxion
  • Antal inlägg: 10
« skrivet: 03 juli 2023, 20:37:37 »
Hello, writing from another nordic country, so feel free to write in swedish. I just cannot :)
So iv got this 6 year old panasonic with bad heating. It might start out good, then after a few minutes it just heats less and less. It might help to shut it of for a while, or switch to cooling and then back to heat.
I got a tip it might be the 4-valve electric coil that has a internal break, because then the voltage wil drop and is a common problem.
Hoping someone have some tips about what can be the problem, or explain where this coil might be so I can get it out to ohm. But any tips except the coil is great too. Refilled gas and removed a leak before, so dont think thats the issue.
Coil / spole, one of many potential problems.
« Senast ändrad: 03 juli 2023, 20:42:17 av maraxion »
  • Antal inlägg: 4317
SV: Panasonic ce9pke varmer dåligt. Defekt spole?
« Svar #1 skrivet: 03 juli 2023, 23:24:11 »
Det går ganska snabbt att lokalisera komponenter i en värmepump, skruva upp ordentligt så du ser och kommer åt, så är det inga problem att hitta den. Se 4-vägsventilen, enda med 4 rör till en komponent i hela värmepumpen.
