Författare Ämne: Nibe Fighter 310P electricity costs  (läst 1261 gånger)
Utloggad mark1977
« skrivet: 04 oktober 2022, 18:16:56 »
Hi everyone. Apologies for the English but would take me a year to write in Swedish. I have a Nibe fighter 310P and need some advice. Any tips on how I can reduce the electricity intake it uses. As of now we are using the fireplace as much as we can to heat the house so would like if possible to reduce the amount of electricity the Nibe uses. Not to turn the heat off completely but do something to hopefully help reduce electricity bill costs. Someone has told me you can do something that alters when the pumps main electricity kicks in to help heat the house if its too cold outside but I don't where to start. Thanks in advance guys.
  • Antal inlägg: 4321
SV: Nibe Fighter 310P electricity costs
« Svar #1 skrivet: 04 oktober 2022, 21:01:25 »
Se till att det inte är onödigt varmt inne. Du sänker förbrukningen med cirka 5% per grad du minskar innetemperaturen.
Bästa spartipset kan vara att installera luft/luft-värmepump. Efterfrågan är dock hög och installatörerna har mycket att göra.
Men den ger billigare värme än 310P.
Det är viktigt att se om kompressorn fungerar i 310P.
Kolla kanal 04 och kanal 05.
Du väljer kanal efter du tar bort översta frontdelen.
  • Antal inlägg: 31291
« Svar #2 skrivet: 04 oktober 2022, 21:50:10 »
I have 2 tips.
The first is to set all thermostats on maximum and then adjust the kurve and tuning (red and gray wheel) so it controls the heat inside from the heat pump.
It is better for the pump if no thermostat is open/closed over time, that can trigger immersion heater unnecessarily.
You ca have a few thermostats active in the rooms that you want to have a little cooler but the most should be always open.
Then buy a room temperature control to the pump (RG10).
It will detect when you put on a fire and will reduce the supply temperature from the heat pump.
