Värmepumpar - Märkesspecifikt
Nibe
(Moderator:
How to fix this?
Ämne: How to fix this? (läst 1371 gånger)
NK
Gäst
NK
How to fix this?
15 juni 2022, 20:25:22 »
I got alarm as below...
could you please guide me how to solve?
Tempeture was too high at immersion heater.
This may be due to :
-no water flow past immersion heater
944_Driver
Stad/land: Kumla
Antal inlägg: 1663
944_Driver
SV: How to fix this?
Svar #1 skrivet:
15 juni 2022, 22:08:53 »
Maybe you can provide a little information on the hardware?
Nibe of some kind I guess?
// Magnus
Nuvarande huset:
Förra huset:
Carl N
Manual-nörd
Guldmedlem
Antal inlägg: 31245
Karma +22/-8
Alien snowman.
Carl N
Svar #2 skrivet:
15 juni 2022, 23:12:24 »
Why is the immersion heater on in the summer?
tipo874
Guldmedlem
Stad/land: Uppsala
Antal inlägg: 4499
Karma +6/-0
tipo874
Svar #3 skrivet:
16 juni 2022, 07:39:34 »
Legionella burn off?
38x2m
2
solpaneler, 15,6kW, installerat 2020.
Carl N
Manual-nörd
Guldmedlem
Antal inlägg: 31245
Karma +22/-8
Alien snowman.
Carl N
Svar #4 skrivet:
16 juni 2022, 11:25:38 »
Citat från: tipo874 skrivet 16 juni 2022, 07:39:34
OK, make sense, the usual suspect is the 3-vay valve, but is can also be that the circulation pump that don't start.
Nibe
(Moderator:
How to fix this?
gäster: 3276
användare: 6
tyke
Kofoten
berkan
Mjolko
Ewald
dms_ax
