Författare Ämne: Help with Hot Water (English!)  (läst 1345 gånger)
Utloggad deskjet
  • Antal inlägg: 3
« skrivet: 29 november 2021, 20:52:34 »
Hi all (You can write answers in Swedish as well).
I have a IVT Greenline heater in my house. I was having problems with it and heating the house and did a "Factory Reset" on the system. That solved the heating problems in the radiators.
But another problem arose - now I have almost no hot water in the taps. I have a separate hot water tank next to the IVT machine. Is it possible that I reset a setting that is stopping water from properly entering that tank? I've tried "Adding Hot Water" in the setting but that doesn't seem to do anything.
Any help is appreciated.
Utloggad 944_Driver
  • Stad/land: Kumla
  • Antal inlägg: 1663
SV: Help with Hot Water (English!)
« Svar #1 skrivet: 29 november 2021, 22:19:33 »
Check the valve that directs the flow to either the radiators or the hot water tank. They can get stuck. Växelventil in swedish if you search.
Are the temperatures in the display correct? If the hot water is said to be 60C despite being cold it will never try to heat up the water.
// Magnus
Nuvarande huset:
Förra huset:
Utloggad deskjet
  • Antal inlägg: 3
« Svar #2 skrivet: 30 november 2021, 09:05:03 »
I think I solved it. When I reset the Pump it seems that I needed to confirm the sensor (GT3?) for the hot water tank. Doing that in the Installation settings seems to have made it flow normally. thanks.
  • Dot gäster: 8939
