Författare Ämne: NIBE EAHP energy consumption data  (läst 1377 gånger)
Utloggad a62vw
  • Stad/land: East Grinstead, UK
  • Antal inlägg: 2
  • Hello, I am from England!
« skrivet: 29 oktober 2021, 15:29:37 »
Hi from the UK!
Apologies for my post in English, sadly I do not speak Swedish, and can only enjoy this site thanks to Google Translate!
Are there any forum members who keep historical data on, or have weblinks to live, energy consumption of the NIBE EAHP in their property, please? I'm specifically interested in F730 primarily but also F470. I would be very interested to get access to it, please, if you are willing to share it.
Many thanks
King regards,
Vaughn.
SV: NIBE EAHP energy consumption data
« Svar #1 skrivet: 29 oktober 2021, 15:52:49 »
Hi! EAHP fits with new houses built very well insulated with small transmission energy losses compared to ventilation energy losses. Typically new houses built in Scandinavia and in accordance with national requirements. If the insulation level is so-so air/water heatpumps or ground source heat pumps are more adequate. For what kind of house are you looking for a heat pump?
« Senast ändrad: 29 oktober 2021, 16:21:53 av Josth »
Utloggad a62vw
  • Antal inlägg: 2
« Svar #2 skrivet: 29 oktober 2021, 16:16:13 »
Hi Josth,
Thanks for your reply. Firstly, I should clarify; I work for NIBE here in the UK, in a technical/sales role, since joining the company last year. Naturally, I am very familiar with the products and specify them for many new build and renovations projects here in the UK as part of my role. However, I am keen to find more sources of 'real world' data to demonstrate them in action for potential projects.
I hope that helps?
King regards,
Vaughn.
« Svar #3 skrivet: 29 oktober 2021, 16:34:37 »
Ok, misinterpreted the question a bit. Then you know the products well. Hopefully forum members here using NIBE Uplink och other logging software will answer to your request. They are rather many but nowadays they are not at this site so often as ealier. Guess it will be more activity here when the winter starts för real here in Scandinavia(?)
/Regards Josth
