Författare Ämne: Modbus Register list for EcoZenith i255  (läst 6812 gånger)
MartinDK
MartinDK
« skrivet: 12 oktober 2021, 09:50:38 »
Hello everyone
I am looking like crazy for a modbus register list for the built-in MODBUS/TCP slave(server) on my EcoZenith i255 and perhaps some interface information.
No response from info @enertech.se on the subject and I can only find the normal user manuals online with extremely limited info on interfaces and some old register lists for the old CTC Internet accessory.
For some reason I can connect to the modbus port (502), but the slave doesn't reply anything on my modbus requests. I am considering trying the RTU interface, but would prefer TCP.
Can anybody help?
Med venlig hilsen fra Danmark
Martin
  • Antal inlägg: 31274
SV: Modbus Register list for EcoZenith i255
« Svar #1 skrivet: 13 oktober 2021, 22:58:12 »
Here.
MartinDK
MartinDK
« Svar #2 skrivet: 15 oktober 2021, 07:55:46 »
Mange tak :)
Unfortunately it is not the CTC Internet/BMS module (https://shop.ctc.se/produkt/ctc-bms-internet/) with MODBUS/RTU, that i have.
CTC started issuing retrofit displays/controllers with built in internet and BMS for the i250 instead: https://shop.ctc.se/produkt/displayenhet-ez-i255-i250/ but haven't issued any modbus register list or interface description. And unfortunately no response from info@enertech.se.
If anyone have a direct support email address or similar, i would be very happy.
På forhånd tak,
Martin
« Svar #3 skrivet: 16 oktober 2021, 23:32:54 »
I don't think that display is ment to be used for any external modbus communication?
CTC don't have any parameter list for that, and they will probably not support the use for any external communication.
If the parameter list for the BMS interface don't work then:  dontknow
MartinDK
MartinDK
« Svar #4 skrivet: 18 oktober 2021, 09:29:32 »
The new retrofit display is now provided instead of the old CTC BMS or CTC Internet box; see screenshots from manuals below.
I've tried the MODBUS-TCP interface via port 2 but get no data from it, but will try port 1 with MODBUS-RTU one of the coming days.
https://www.ctc.no/file-download/37b972f942d391ac18a3c3ec7008bf63.pdf :
https://ctc.se/file-download/a7b626e9a9dbfe59020bdc830f5642fc.pdf
« Svar #5 skrivet: 18 oktober 2021, 21:05:08 »
OK, Modbus via TCP internet sounds little like putting a Porche engine in a Lada. (Internet = Porsche, Modbus = Lada).
Usually the internet interface have much better kommunication than modbus, I don't understand the benefit to use modbus over internet.
I would use CTC myUplink instead.
But i found this when I searched, it seems to be different from the other one.
https://www.rskdatabasen.se/infodocs/MAN/MAN_31_6246513.pdf
MartinDK
MartinDK
« Svar #6 skrivet: 19 oktober 2021, 09:10:17 »
Thanks - i'll try and see if I can get some response from the controller with that :)
If i'm succesful i'll post results here...
/Martin
Utloggad jewe
  • Antal inlägg: 24
« Svar #7 skrivet: 28 mars 2023, 18:34:06 »
Bumpar tråden, har precis fått en i255 installerad och provade att ansluta via Modbus TCP men får den inte att kommunicera, kan pinga den.
Hittar inte var man sätter Device id, finns inställningar under RTU där man kan ställa in den men funkar inte..
Yggdrazil
Yggdrazil
« Svar #8 skrivet: 23 maj 2023, 10:29:15 »
Har du ställt om i menyn till Modbus? Man kan inte köra på både TCP och Modbus.
Under: Inställningar - Definiera - Fjärrstyrning så satte jag Ethernet = "Modbus TCP".
Jag gjorde den inställningen och sen funkar allt kanon, läser av från Home Assistant och kan även skicka kommandon till pumpen.
Har iofs en i360 men tror dom borde vara snarlika.
Utloggad jewe
  • Antal inlägg: 24
« Svar #9 skrivet: 28 maj 2023, 21:56:37 »
Ja, hade missat det, nu funkar det fint, har inga problem att lösa och skriva värden men har inte skapat något larm än, tycker det är svårt att tolka dokumentet på hur larm ska läsas men ska titta vidare på det inom kort.
