Författare Ämne: Fighter 360p HP-Larm + högt VV temperature  (läst 1527 gånger)
Utloggad cttime
  • Antal inlägg: 4
« skrivet: 09 november 2020, 19:53:06 »
Hi,
We recently moved into a house with a Fighter 360P and over the weekend we received a HP larm. From reading on this forum it sounds like the cause could be a number of things. So far we have checked the franlufts filter, the house is maintaining a comfortable 21 degrees, the compressor was functioning after resetting the alarm the first time and as of last night. The alarm is coming in combination with the VV-Givare showing 70+ degrees. The xvv is set to shutoff at 60 degrees and our curve is set at 8 (well insulated house built 2008 in Västra Götaland), -2 förskutning. Edit: I came home tonight and tested both safety valves (47 and 52) and released air from the system according to the "Påfyllning av vattenvärmare
och värmesystemet" instructions. I also reset the alarm and it has been on for 2 hrs without an alarm (after resetting it the first time last Friday it worked until Monday morning without tripping).
 I know the pump is 12 years old (original to the house) so it could be about that time... but I want to investigate all possibilities.
What could be causing the VV spike in temperature and could that be the cause of the HP Larm?
« Senast ändrad: 09 november 2020, 22:49:25 av cttime »
  • Antal inlägg: 31206
SV: Fighter 360p HP-Larm + högt VV temperature
« Svar #1 skrivet: 10 november 2020, 14:11:00 »
Hi!
Some possible causes to the HP larm:
Temperature sensor for compressor fails - compare 1.1 and 1.2 - they should not differ to mush.
Usually 1.1 show a littel lower value than 1.2.
Air, bleed with the safety valve (52).
Relay 11 fails and get stuck.
« Senast ändrad: 10 november 2020, 14:14:34 av Carl N »
Utloggad cttime
  • Antal inlägg: 4
« Svar #2 skrivet: 08 december 2020, 20:11:17 »
I wanted to follow up and let you know what I did and what has solved the problem (going on a month without another warning).
My temperatures seemed to match pretty closely so I followed safety valve checking procedure (page 9 in the manual) for both valves and then the procedure for filling/pressurizing the system. Since then no issues (knock on wood).
