Författare Ämne: How to remove the High Pressure sensor  (läst 1758 gånger)
Utloggad charliehl
  • Antal inlägg: 2
« skrivet: 26 februari 2020, 19:50:52 »
Appologies for writing English,  my Swedish is not good enough for this.
I have an Ecoel 1580 and ECOAIR 111v3.
I have been getting regular hot gas alarms.  Now i get a high pressure alarm and E1 on the 111.
The alarm happens almost immediatly when the Ecoair fn starts up.
I have checked for air in the water, the circulation pump works fine and i have no filters to clean.
I was going to swap out the high pressure sensor and the hot gas sensor.
How do i remove the hotgas sensor? Or is this somtjing that i would be better off asking a technician to do?
Thank you
Charlie
  • Antal inlägg: 5462
SV: How to remove the High Pressure sensor
« Svar #1 skrivet: 26 februari 2020, 20:52:50 »
The hot gas sensor is of electronics type plugged into a pipe that sits on the hot gas pipe and is only to be pulled out, the high pressure sensor is fixed to the hot gas pipe and cannot be replaced, you must have a refrigerator for it. But start with the sensor first. Hot gas failure can be a shortage of gas, and to check this, a cooling installer is needed
Utloggad charliehl
  • Antal inlägg: 2
« Svar #2 skrivet: 26 februari 2020, 21:04:10 »
Thank you
« Svar #3 skrivet: 26 februari 2020, 21:37:29 »
Sometimes the hot gas press  can get stuck in a broken position, try to knock it with a metal part so it can release where not worried it can handle it
