Författare Ämne: Building sauna over vertical ground collection pipes  (läst 2029 gånger)
Utloggad Rikhard
« skrivet: 10 november 2018, 20:45:45 »
Hei!
First I want to apologize my spelling errors. Hope you can forgive me.  :)
Jag ska inte skriva svenska när jag har glömt så mycket. Så jag hoppas att vi kan skriva på engelska.
Eller Finska  ;)
Ok. Here is my problem. I want to build a 6m * 3m Sauna building to my back yard. Unfortunatly my back yard is full of heat collector pipes.
Is here any knowledge about building over pipes? I know it's no, no but I'am going to build it anyway. I don't have any other place to build.
I was wondering if I should put frost insulation all the way or should I only insulate Foundation? I would like to loose so few meters of heat effective collector pipes as possible. Below is a link to a picture. it shows what I am thinking of.
Ps. my info.
House 172m2 in two floors + 60m2 carage +15c . build in 2008. House has insulation in walls 200mm and in ceiling 400mm.
I have 2*250m pipes in ground. ground is clay.
Thanks for your answers in advance.
Rikhard
https://photos.app.goo.gl/aTnLZLJpfwzXx88PA
