Författare Ämne: Netatmo thermostat and CTC  (läst 1985 gånger)
Utloggad sascha_blekinge
  • Antal inlägg: 1
« skrivet: 04 oktober 2018, 08:55:34 »
Dear all,
first of all sorry that I am writing in English. We have a vacation house in the south of Sweden and I was thinking about installing the netatmo thermostat in the house to monitor the heating when we are not in Sweden.
We have a CTC ECOEL 1550/1800 pump with a thermostat.
Unfortunately, Netatmo does not list the pump, so I wanted to ask you, if someone here might know, if it will also work with this pump or not.
This is the link to the Netatmo product: https://www.netatmo.com/product/energy/thermostat
Thank you very much for your kind help and support
Sascha
Utloggad Trycklöst
  • Antal inlägg: 38
SV: Netatmo thermostat and CTC
« Svar #1 skrivet: 04 oktober 2018, 21:53:54 »
Hi.
The EcoEl 1550/1800 doesn't seem to have much in the way of remote control, but if you just want to monitor the house temperature then I can't see why that shouldn't work.
If you want to control it then it might not be so easy.
If I read the manual correctly it has the posibility of triggering the function to create extra warm water, or to disable the pump/heater, or to trigger "reduced temperature at night". But thats about all it can do.
Newer models have the possibility to be controlled and monitored over the internet (CTC Connect), but it doesn't look like it works with your model.
good luck :)
(also located in Blekinge ; )
  • Dot gäster: 1929
