Författare Ämne: F750  (läst 2770 gånger)
Utloggad Soldis
  • Antal inlägg: 12
F750
« skrivet: 12 juli 2018, 13:31:31 »
Nu finns en ny uppdatering att hämta hem (8839R2)
Utloggad kWhalp
  • Försöker bli
  • Stad/land: Umeå
  • Antal inlägg: 2144
  • Energi- och VP-nörd
SV: F750
« Svar #1 skrivet: 12 juli 2018, 19:21:26 »
Added
• Extra climate system 2 - 8: It is now possible to block the shunt on AA5-X2:13-14. When there is a
connec- tion the shunt closes.
• The accessory AXC 20 (expanded exhaust air-functions) added
• EME20: It is now possible to choose “priority houshold electricity” in menu 4.1.11 (Solar electricity)
if exter- nal energy meter is connected
• Alarm for pressure switch climate system added. Activates through AUX-input. Alarm number 165
“Low pressure climate system”. The alarm is a redlight alarm without control action but lights the
red diode and can give a notification through Uplink or SMS.
Added a solution to problems scrolling in the menus. Prevents the display pointer from going back
and forth. This eliminates the need to replace the display unit due to this problem.
Changes
• Load monitor: Solved a problem with the alarm 182 indicating when a new internal electric step was
going to step in.
• HTS humidity control: Various updates.
• Night cooling: The function stopped working in v8228. Corrected
• Solves a problem that could cause the product to restart if the activated vacation period was longer
than 127 days
• EME20: Improved communication with the accessory.
• SAM: Improved control of control valve to reduce the risk of anti-freeze alarm
Jag har problem med scrollhjulet, kanske denna update löser problemet! :)
Utloggad d98josu
  • Antal inlägg: 475
SV: F750
« Svar #2 skrivet: 12 juli 2018, 23:18:02 »
Byt gärna rubrik till något mer förklarande typ ”F750 ny mjukvara tillgänglig”
2016 = 6490 kWh
2017 = 6509 kWh
2018 = 6338 kWh
2019 = 6547 kWh
Utloggad optimeraren
  • Antal inlägg: 69
  • Perfektion
SV: F750
« Svar #3 skrivet: 24 mars 2021, 20:49:10 »
Nu har NIBE släppt version 9086R9 till F750. (BF1 flow meter fixad)
Tyvärr är fläktsynkdrift fortfarande avslaget för svenska installationer. Om vi är tillräckligt många som hör av oss till dem kanske de ändrar sig...
