Värmepumpar - Märkesspecifikt
Nibe
(Moderator:
NIBE F1255 - 8539R3
Ämne: NIBE F1255 - 8539R3 (läst 1691 gånger)
mthus
Lär mig om värmepumpar
Antal inlägg: 38
Värmepump eller värmepumpar?
mthus
NIBE F1255 - 8539R3
11 april 2018, 08:40:57 »
Version: 8539R3
Release date: 2018-04-10
Added
Now supports 4 units of the accessory ERS.
Country selection Australia and New Zeeland added
Stove guard function added for ERS
Now supports 4 units of the accessory HTS.
It is now possible to choose night cooling, separatly for each FLM in menu 5.3.1
Changes
EME20: Management of alarm update
Time zone Istanbul is now corrected and is always delayed with 3h compared to UTC*Uppdated circulation pump regulation
Improved compressor regulation
AXC40: Now possible to control shunt control addition with 0-10V signal
Improved control of ground water pump
EME10 is now regulated on power instead of current. New setting in menu 4.1.10 which indicates if EME10 is on single or three phase
EME20 now supports up to 12 PV-inverters
Min supply for the accessory HPAC can now be set down to -5, earlier +5 grader in menu 1.9.3.2
Load monitor: Solved a problem with the alarm 182 could indicate when a new internal electric step were going to step in
Improved control of the accessory HPAC at operation mode active cooling and run priority is hot water or pool
Solves a problem that could make the product to restart if the activated vacation period was longer than 127 days
Improved control of accessory ERS
Villa, 164kvm + 34kvm byggd 2014 i Skaraborg. Bergvärme NIBE 1255 + FTX
Nibe
(Moderator:
NIBE F1255 - 8539R3
gäster: 2164
användare: 7
25fOCUS
rocas
tyke
Zyberdude
lars
Björnliden
Börje__
