Författare Ämne: winter mode not workin  (läst 1127 gånger)
Utloggad jamiemackenzie
« skrivet: 03 november 2017, 18:57:56 »
i have a 360p installed with a gas boiler connection so i dont use the electric immersion heater. now that the temp has dropped in scotland i have put it into winter mode but the boiler will not kick in. when i select extra hot water then the boiler will come on but not in winter mode. does anybody have any suggestions about the settings.  thank you#
since writing this post i have found  that the compressor wont start either. i have looked at the relay card and found one of them has a small amount of burning inside it so it is possible it has got a short and burned out. does anybody have a wiring diagram for the relay card
« Senast ändrad: 03 november 2017, 22:03:23 av jamiemackenzie »
  • Antal inlägg: 31239
SV: winter mode not workin
« Svar #1 skrivet: 04 november 2017, 15:48:22 »
http://www.nibeonline.com/pdf/411482-1.pdf
Hi.
Check the temp in menu 1.2 and 1.3 and compare with 1.0?
Also check 8.31, should be no.
« Senast ändrad: 04 november 2017, 15:50:31 av Carl N »
