Författare Ämne: IVT Greenline HT Plus "High Pressure Switch (HP)" / "Pressostat höj" error  (läst 14673 gånger)
  • Antal inlägg: 31230
Hi!
10 kg R407C cost 179 Euro, so the price is way to high.
http://www.eurorefrigerant.com/lang-en/
But it is a good idea to replace it, the refrigerant R407C is a mix of different gases and it's almost impossible to empty a refrigerating circuit and get out all gas in the right ratio.
When replacing it you know that the ratio between the gases is correct.
If they is responsable for filling to much they should do the correction free of charge.
« Senast ändrad: 07 april 2017, 07:44:44 av Carl N »
Kristian Lautrup
Kristian Lautrup
SV: IVT Greenline HT Plus "High Pressure Switch (HP)" / "Pressostat höj" error
« Svar #16 skrivet: 07 april 2017, 09:22:41 »
Thank you for the reply.
I will continue to investigate whether it is custom procedure to add new 1.5 kg coolant (refrigerant R-407C) instead of reusing the old (I suspect I'm paying for new all though company replacing the expansion valve has in fact reused the old coolant).
One more question.
It took the company 14 days to realize they had by accident put on 0.5 kg to much coolant, so a total of 2.0 kg where the Greenline HT Plus C9 should only have max 1.5kg.
So it has been running 14 days with too much coolant which has triggered the 'High Pressure Switch (HP)' error many times.
What is the risk that this has damaged the compressor?
Google'ing about this it seems that too much coolant thus too high a coolant pressure can cause the refrigerant to enter the compressor as liquid instead of gas causing damage.
The compressor is still running and as far as I can tell sounding normal.
But is there a risk that this has shortened its life due to excessive wear?
I think this kind of compressor (scroll) is less sensitive for liquid than for example a piston kompressor.
And the high pressure switch have also protected the heat pump.
  • Dot gäster: 2530
