Författare Ämne: Nibe Fighter 410p. Kompressor byte?  (läst 2985 gånger)
Puhma
Puhma
« skrivet: 27 september 2016, 15:09:12 »
I take this in English, but please go ahead and respond in Swedish.
The compressor in my 10 years old Fighter 410p has broken down and I'm wondering if it is worth replacing it? The replacement will cost me something between 16.000-20.000SEK. To replace the complete pump would cost around 65.000SEK.
The compressor is disconnected at the moment and the pump is used both for warm water and to heat the house (130m2).
I’m wondering if it is worth to run the pump without the compressor. Does anyone have experience how much more energy the pump will consume without the compressor?
Many thanks
Puhma
SV: Nibe Fighter 410p. Kompressor byte?
« Svar #1 skrivet: 27 september 2016, 19:28:29 »
The yearly saving of energy is near 8000 kWh with a working compressor (650 W). It's unfortunately so that the compressors in these models won't last more than approx. 10 years. In the beginning with R290 propane they very often only worked for 3-4 years, so it has improved.
/Josth
  • Antal inlägg: 19492
« Svar #2 skrivet: 27 september 2016, 19:32:12 »
Kompressorn finns att köpa för 4000 kr men är kanske mycket jobb att byta  Sc:,h
Puhma
Puhma
« Svar #3 skrivet: 27 september 2016, 20:45:51 »
8000kw/h is a lot, so I guess it's worth fixing it. I just hope that the compressor is less noisy.
Repairing it myself is a bit too advanced (I have never welded before)
Many thanks for your help!
