Värmepumpar - Luft/vatten
Övriga fabrikat
(Moderatorer:
Lmf
Effekt Sfinx 11KW
Sidor:
Prev
Alla
Ämne: Effekt Sfinx 11KW (läst 11627 gånger)
o o
Antal inlägg: 929
o o
SV: Effekt Sfinx 11KW
Svar #15 skrivet:
03 oktober 2013, 15:59:13 »
Hur f_n ska jag veta vad du missat om jag inte vet vad jag missat?
Nu hittade jag inte eländet som jag läst i, men jag hittade bifogad istället. Här står det faktiskt uttryckligare men jag har inte läst igenom hela. Än...
"6.4.2 Performance determination for multiple defrosts in the measurement
period
If two or more defrosting actions occur during the measurement period, then the measured values
found in the period between the beginning of the first defrosting cycle and the beginning of the last
defrosting cycle in the measurement period are used to calculate the output data (see Graph 3, Region
E).
The length of a working cycle is determined from the time between the next-to-last and the last defrost
cycle in the measurement period (graph 4, Region F “Working cycle with defrost”).
If a further defrost is expected at the end of the 3-hour measuring period, the measuring period can be
extended by up to 30 minutes in order to take this additional defrosting into account in the analysis."
purjo__
Guldmedlem
Stad/land: Gävleborg
Antal inlägg: 13444
Karma +23/-12
purjo__
Svar #16 skrivet:
03 oktober 2013, 16:15:55 »
4.4.4.5 Test procedure: When a defrost cycle ends the preconditioning period
If the quantity %∆T exceeds 2,5 % during the first 35 min of the data collection period, the heating capacity
test shall be designated a transient test (see 4.4.4.7). Likewise, if the heat pump initiates a defrost cycle
during the equilibrium period or during the first 35 min of the data collection period, the heating capacity test
shall be designated a transient test.
If the above conditions do not occur and the test tolerances specified in Table 4 are satisfied during both the
equilibrium period and the first 35 min of the data collection period, then the heat capacity test shall be
designated a steady-state test. Steady-state tests shall be terminated after 35 min of data collection.
Om jag fattar är grundprincipen att man kör 35 minuter kontinuerlig drift efter uppstartsfasen och eventuell avfrostning. Funkar inte det gör man ett 'transient test' i stället enligt kapitel 4.4.4.7. Då kör man tre timmar eller tills tre avfrostningar har gjorts. Jag vet dock inte om man räknar bort mätdatat för tiden den frostar av + 10 minuter för att få jämförbara värden eller hur man gör.
Nån som orkar läsa och förstå hela specen får gärna förtydliga...
o o
Antal inlägg: 929
o o
Svar #17 skrivet:
03 oktober 2013, 16:58:39 »
Grafen till texten jag klistrade in ovan.
Edit igen; Fick bilden omgjord från png till jpg när den laddades upp. Struntar i det, den ligger ju i filen jag bifogade.
Läste i den "riktiga" du la upp purjo, jag får det till samma sak fast krångligare uttryckt. Det innefattar avfrostning om temp avviker eller en avfrostning sker naturligt. Vid +2° och 84% RH och fullt skaft fryser det på snabbt.
Nån annan får gärna bekräfta eller dementera.
Senast ändrad: 03 oktober 2013, 17:22:09 av Bjebb
gossen
Har ingen aning, gissar bara.Jag har lärt mig en del av dom som är
Antal inlägg: 1055
gossen
Svar #18 skrivet:
03 oktober 2013, 18:18:38 »
Jag kan inte få det till annat heller, verkar vara en ok testmetod.
2013:Mål
<12000 Mer optimistiskt mål är <10000, men det nås nog inte 2013.
. Blev 11533kwh
2014:Mål 11000. Blev 11284kwh
purjo__
Guldmedlem
Antal inlägg: 13444
Karma +23/-12
purjo__
Svar #19 skrivet:
03 oktober 2013, 18:26:25 »
Det jag tycker är konstigt är att vid 35-minutersmätningen mäter man utan avfrostning, men om det inte går så mäter man 3 timmar eller 3 avfrostningar och inkluderar alla avfrostningar under tiden. Blir det inte ojämförbara resultat då?
o o
Antal inlägg: 929
o o
Svar #20 skrivet:
03 oktober 2013, 18:46:19 »
Jag gillar den där PDFen jag hittade idag från EHPA. När man läser i den blir det enklare att förstå varför de skriver så knöligt i den "riktiga".
"6.2.1 Measurement according to steady state or transient test conditions
Basically the performance measurements have to be proceeded under transient test conditions if
during the test a defrosting of the heat pump is possible.
According to experiences this applies to all of the tests regarding table 3 which are proceeded with an
air temperature less or equal +2 °C. All these tests have to be carried out under transient test
conditions regarding chapter 6.4. The measurement of the standard rated point A7/W35
(+7°DB 89%RH)
is always preceded under transient test conditions. If during this measurement no defrosting of the evaporator occurs, the measurements of A7/W55
(+7°DB 89%RH)
can be preceded under steady state conditions regarding chapter 6.3, otherwise the measurements have to be carried out regarding chapter 6.4.
The measurement under test conditions A20/W55
(+20°)
can always be carried out under steady state conditions (chapter 6.3)."
Givetvis.
sege
Expert på värmepump
Antal inlägg: 663
Karma +3/-1
sege
Svar #21 skrivet:
10 november 2013, 22:15:23 »
Här är för enfas 11kW med R410 från Sfinx gamla hemsida där den fanns med. Min ger dock aldrig i närheten av det här, jag ser typiskt 8-8,5 kW som absolut max vid 30 grader fram och 10 ute ungefär och COP på ~3,2 som absolut högst vid samma förhållanden.
Daikin Monoblock 7kW+acktank+60 vakuumrör från Sfinx. Heru 90 FTX-anläggning. Golvvärme i hela huset.
2019: ~22.000 kWh, Sfinx VP11 trasig våren, byts till Daikin Monoblock 7kW i slutet december
2018: 20893 kWh, värme+VV: ~7000 kWh, två elbilar, ~5000 kWh dit,
2017: 20354 kWh, värme+VV: 6991 kWh, två elbilar, ~5000 kWh dit
2016: 17241 kWh, värme+VV: 7537 kWh, dubbla elbilar införskaffas
2015: 13924 kWh, värme+VV: 6228 kWh
2014: 12429 kWh, värme+VV: 7042 kWh
2013: 13185 kWh
2012: 13993 kWh
2011: 12236 kWh, 115 kvm. LVVP+sol sen april.
2010: 16707 kWh, 115 kvm
2007-2009: ~12500 kWh, 73 kvm
HansMarten
Antal inlägg: 731
Kan lite om mycket=)
HansMarten
Svar #22 skrivet:
11 november 2013, 16:15:03 »
Jag tror inte det är något fel på den första tabellen inlagd i denna tråd på sfinxen. Pumpen har sämre effekt vid några plusgrader än vid torra kalla minusgrader.
Titta i den bifogade pdf för en Fujitsu luft/vatten och avläs siffrorna för 35C framledning, samma mönster. 6,39 kw vid +2C men 7,0kw vid -7C. Och tror att Fujitsu som är en någorlunda stor tillverkare inte har "tryckfelsnissat"
Senast ändrad: 11 november 2013, 16:17:36 av HansMarten
Fujitsu Waterstage 8KW LVVP dockad till NIBE EVC240
Mitsubishi FD25 VABH LLVP
Hydropro Eco Poolvärmepump
Renoverad 60tals kåk 142m2 1 planshus egenhändigt konverterat till vattenburet.
Uppvärmning: 3 600 kwh/år ( 25 kwh/m2/år !!)
Hushållsel + SpetsVarmvatten: 8 400 kwh/år
DUT -18C
Corroventa CTR300 med undertryck i krypgrund
Jag älskar Japanskt!
Sidor:
Prev
Alla
Övriga fabrikat
(Moderatorer:
Lmf
Effekt Sfinx 11KW
gäster: 3547
användare: 4
Pbenson
Mike
AÖd
Strip
