Författare Ämne: Flytta luftvärmepump själv?  (läst 12419 gånger)
Utloggad Flinta
  • Antal inlägg: 628
« skrivet: 20 augusti 2013, 14:33:51 »
Har en Panasonic CU-E12DKE (utedel) / CS-E12DKEW (innerdel) luft-luft värmepump som jag skulle behöva flytta från en plats till en annan. Måste alltså flytta både innerdelen och utedelen och därför koppla loss rören osv.
Hittade en servicemanual på nätet som beskriver detta på engelska, där det också står "Using New Refrigerant Piping". Vad exakt menas med det?
Finns denna servicemanual på svenska någonstans? Hittar inte det själv.
På engelska:
11.4.2. Transferring (Using New Refrigerant Piping)
1. Removing the unit
a. Collecting the refrigerant into the outdoor unit by pumping down
The refrigerant can be collected into the outdoor unit (pumping down) by pressing the TEST RUN button, even when the
temperature of the room is low.
• Check to make sure that the valve stems of the 2-way valve and 3-way valve have been opened by turning them counterclockwise.
(Remove the valve stem caps and check to see that the valve stems are fully opened position. Always use
a hex wrench (with 4-mm opposing sides) to operate the valve stems.)
• Press the TEST RUN button on the indoor unit, and allow preliminary operation for 5-6 minutes. (TEST RUN mode)
• After stopping the operation, let the unit sit for about 3 minutes, then close the 2-way valve by turning the valve stem in
the clockwise direction.
• Press the TEST RUN button on the indoor unit again, and after 2-3 minutes of operation, turn the valve stem of the 3-
way valve quickly in the clockwise direction to close it, then stop the operation.
• Tighten the caps of the 2-way valve and 3-way valve to the stipulated torque.
• Remove the connection pipes (liquid side and gas side).
b. Removing the indoor and outdoor units.
• Disconnect the pipes and connecting electric cables from between the indoor and outdoor units.
• Put capped flare nuts onto all of the pipe connections of the indoor and outdoor units, to make sure no dust or other
foreign matter enters.
• Remove the indoor and outdoor units.
2. Installing the unit
Install the unit using new refrigerant piping. Follow the instructions in section 4.1 to evacuate the pipes connecting the indoor
and outdoor units, and the pipes of the indoor unit, and check for gas leaks.
Är det något annat jag bör tänka på speciellt? Vill ju inte sabba värmepumpen :) ...den måste förbli användbar med full verkningsgrad.
Utloggad Bingoberra
  • Stad/land: Linköping
  • Antal inlägg: 334
  • Daikin Evolution surrar fint i pannrummet...
SV: Flytta luftvärmepump själv?
« Svar #1 skrivet: 20 augusti 2013, 15:46:43 »
Det man ska tänka på att det väl är olagligt att koppla viss kylutrustning själv, om jag inte fattat fel förstås.
120 kvm enplansradhus från 1960
Daikin Evolution 163 m borrhål ca 153 m aktivt december 2013. Tilläggsisolerat vind december 2012. FTX Temovex 250S december 2012.
2007     2008     2009     2010     2011     2012  2013
16784   16141   17598   19954   17728  18151  16432
Senaste 12 månaderna: 10851 (inkl hh-el)
« Svar #2 skrivet: 20 augusti 2013, 16:05:29 »
Du skall alltså dra nya rör, vakuumsuga och läckagetesta.
Utloggad Flinta
  • Antal inlägg: 628
« Svar #3 skrivet: 20 augusti 2013, 16:56:12 »
Så det går ej att flytta den utan att dra nya rör? Då måste man ju skaffa nya rör. Sedan vakuumsuga och kolla efter gasläckor.
Av ren nyfikenhet, varför skall man ha nya rör? Är det något fel på befintliga som fungerar i existerande installation?
Kanske är lika bra att låta fackman göra arbetet.
Hade man bara kunnat flytta enheten utan att skaffa nya delar till eller nya verktyg, så hade det ju varit smidigt. Har inget jag kan vakuumsuga med heller.
Att allt skall vara så omständigt  :'(
« Senast ändrad: 20 augusti 2013, 16:58:10 av Flinta »
« Svar #4 skrivet: 20 augusti 2013, 17:47:32 »
I princip borde man kunna använda de gamla rören så länge det inte har blivit nåt haveri på VP'n som har skapat föroreningar. Dock måste dom skyddas mot fukt och kapas i ändarna och konas om. Är det skarpa böjar på dom så kan det bli veck/brott när man böjer om dom för att passa på det nya stället.
Utloggad Flinta
  • Antal inlägg: 628
« Svar #5 skrivet: 20 augusti 2013, 21:14:26 »
Ok, jag får tänka igenom saken då. Att allt skall vara så krångligt :)
  • Dot gäster: 2201
