Författare Ämne: chipa /jumpra upp en ras 10 till ras 16  (läst 4156 gånger)
Utloggad nikitalord
  • Antal inlägg: 233
« skrivet: 02 februari 2011, 21:17:51 »
Vet inte om det varit uppe tidigare men hittade detta på nätet:
Toshiba RAS 10/13 SAVP/SKVP-ND model differences
Another question for you high tech guys.
I deliver Toshib AC/heat pumps. I talked with a service tecnician at the importer today regarding a problem with a RAS 13 SAVP/SKVP-ND.
He said that the compressor and outdor unit PCB board was identical on the RAS 10 and RAS 13. The heat exhanger and pipes look like they are identical. 4-way valve is identical. Indor fan motor is identical. Indor housing is identical. I think indor heat exhanger is identical. But the indor PCB is NOT identical acording to the service tecnician
Is it possible that the only difference betveen RAS 10 and RAS 13 is the software in the indor PCB forcing the RAS 10 outdor compressor and the indor fan motor to run at a lower RPM to produce lower capacity?
If so, a RAS 13 indor unit and a RAS 10 outdor unit would have the same capacity as the originat RAS 13 kit. But at a lower price tag.
Yes, but you need to change jumper wires in outdoor unit to match indoor unit. And you also could match indoor RAS16 and outdoor RAS10.
What jumper? Do you have a picture?
What willl the capacity be of that RAS10/RAS16 combination? Is the RAS10 and RAS16 outdor unit identicall also?
What is prize for that information?
Amazing!!
I had a feeling that 10 and 13 was the same when i talked with that service technician today, but if he knew, he didnt admit it. They charge 15% more for the 13 compared to the 10, and that is hardt to explain when they are identical. And another 15% more for the 16. The jumper position, is that to tell the outdor PCB if it is, errr should act as, a 10, 13 or 16 unit?
Yes, i got a mail from you. It had a picture of page 41 of the RAV 1400SP servicemanual. I have that manual. Maybe you have any information regarding the configuration of the RAS 10-16 SAVP/SKVP-ND heatpump
Its only page 41 from the RAV 1400SP manual. Doesnt say a word about RAS 10-13 heat pumps there
My bad, you got new mail!
Everything is on that page!
« Senast ändrad: 02 februari 2011, 21:31:02 av nikitalord »
Utloggad nikitalord
  • Antal inlägg: 233
SV: chipa /jumpra upp en ras 10 till ras 16
« Svar #1 skrivet: 02 februari 2011, 21:44:49 »
googlat vidare på 10-16 och det lär nog krävas att man går upp en dimension i rör men 10 till 13 verkar ok.
Utloggad td
  • Antal inlägg: 59
« Svar #2 skrivet: 02 februari 2011, 22:17:17 »
På de nya PAVP (Polar2) så har jag för mig att förångaren är mindre på RAS 7 och 10 jämfört med RAS 13-16-18  Sc:,h
Kan inte svära på det men tror att jag läst det någonstans.
Om du tittar i denna http://www.toshiba-klima.at/pdf/en/serviceanleitung/SM%20RAS-10%2013%2016%20PKVP-E%20PAVP-E%20(A08-10).pdf
så ser man att det ska vara mer gas i 13-16-18 jämfört med RAS 7 och 10. Beror väl på den större VVX
Utloggad nikitalord
  • Antal inlägg: 233
« Svar #3 skrivet: 02 februari 2011, 22:29:18 »
Googlat vidare och snabbläst repmanualen samt reservdelslistan och vad jag fick fram är det samma grejer i maskinerna även samma moderkort men kortet har 4 jumprar som vid byte måste ses till är rätt klippta eller slutna för att maskinen ska bete sig som dess typbeteckningen   10'ans fläkt ska kunna varavas upp något extra samt att kompressorvarvet ska tillåtas 16rps mer  förstår jag tekniken rätt så gör det med följande 3 jumprar se bifogad bild.
Eftersom korten har en bios borde den ju vara specifik ock behövas flachas men inget nämns om detta.
Utloggad nikitalord
  • Antal inlägg: 233
« Svar #4 skrivet: 02 februari 2011, 22:53:30 »
Den infon jag hittade gällde polar 1'an eftersom jag har en sån hängande i köket,
2'an har jag inte letat uppgifter på men det lilla jag sett så verkar den vara mer nerstrypt även möjligheten att få den att ge mer än normalt bara med en knapp tryckning verkar saknas.
Utloggad nikitalord
  • Antal inlägg: 233
« Svar #5 skrivet: 03 februari 2011, 13:55:37 »
Bläddrade igenom lite äldre trådar och tydligen har ämnet redan varit upp, så kan det gå när man är ny på forumet. *roflmao*
