Författare Ämne: Någon som köpt MODBUS 40  (läst 77716 gånger)
Utloggad thwp
  • Antal inlägg: 3
SV: Någon som köpt MODBUS 40
« Svar #45 skrivet: 01 april 2012, 12:02:07 »
Hello Wallac,
thank you for the log file!
In 3.txt I see the following information:
5C 00 20 6B 00 4B 06
5C 00 20 69 00 49 C0 69 00 A9 06
5C 00 20 68 50
01 A8 24 01       43009    Calculated Supply Temperature S1 [°C]
00 A8 64 00       43008    Calculated Supply Temperature S2 [°C]
FD A7 BE FE       43005    Degree Minutes [DM]
44 9C 0E 00       40004    EB100-BT1 Outdoor temp S1 [ºC]
4F 9C A7 00       40015    EB100-BT10 Brine in temp [ºC]
50 9C 7B 00       40016    EB100-BT11 Brine out temp [ºC]
51 9C EE 00       40017    EB100-BT12 Cond. out [ºC]
52 9C 11 01       40018    EB100-BT14 Hot gas temp [ºC]
87 9C F1 00       40071    EB100-BT25 external supply temp [°C]
4E 9C F0 01       40014    EB100-BT6 Hot Water load [ºC]
47 9C F8 00       40007    EB21-BT2 Supply temp S2 [ºC]
15 B9 B0 FF       47381    Low brine out temp. [°C]
3A B9 4B 00       47418    Speed brine pump [%]
C9 AF 00 00       45001    Alarm number
48 9C EC 00       40008    EB100-BT2 Supply temp S1 [ºC]
4C 9C ED 00       40012    EB100-BT3 Return temp S1 [ºC]
4B 9C 00 00       40011    EB21-BT3 Return temp S2 [ºC]
FF FF 00 00
FF FF 00 00
FF FF 00 00 DF 06
You dont use the 20 fixed parameters, but nevertheless the Nibe heatpump sends the 20 parameters to the MODBUS module.
Can you try the manual mode by using the "Read holding register" command to read a single value?
Can you also try the "Write holding register" command?
Thank you for your support!
Utloggad Wallac
  • Antal inlägg: 40
« Svar #46 skrivet: 01 april 2012, 14:29:15 »
Hi
I think this is when I read a single register not included in the 20 fixed
Register 47206 / B866 DM start heat (answer -70)
5C 00 20 69 00 49 C0 69 02 66 B8 75 06
5C 00 20 6A 06 66 B8 BA FF 00 00 D7 06
5C 00 20 68 50
01 A8 1C 01
00 A8 64 00
FD A7 A8 02
44 9C 22 00
4F 9C 3D 00
50 9C 36 00
51 9C D9 01
52 9C 8C 02
87 9C 21 01
4E 9C F9 01
47 9C 01 01
15 B9 B0 FF
3A B9 4B 00
C9 AF 00 00
48 9C B8 01
4C 9C F4 00
4B 9C 00 00
FF FF 00 00
FF FF 00 00
FF FF 00 00 32 06
Full log below.
No luck with write holding register. Probably because of some wrong setting in the program I use.
"14:06:55: 'Nibe F1145': Dm start heating: Illegal function "
1 Plans villa 120 m2 och 80 m2 källare samt 50 m2 fristående garage med loft. Direktverkande el, braskamin Keddy.
Byggt 1956 tillbyggd 2007- ort Stockholm.
Pågående konvertering till vattenburen golvvärme 180 av 300 m2 klart.
Värmepump Nibe 1145-15
Utloggad thwp
  • Antal inlägg: 3
« Svar #47 skrivet: 02 april 2012, 15:45:24 »
Hi Wallac,
great!
Regarding write holding register... are you sure you tried to write a writable register?
You should contact the Nibe support to solve this problem. The MODBUS module is too expensive to refuse this feature.
Which program do you use for communication?
By the way, nice whiskey!  tummenupp
Best regards
Thorsten
Utloggad Wallac
  • Antal inlägg: 40
« Svar #48 skrivet: 04 april 2012, 20:06:57 »
Hi
Yes I tried 47206 (DM start heating)
One time I was able to change the value, but I tried so many settings so I didn't find my way back.
I tried modscan32 and through mango m2m.
Today i got some more time to test and i found the problem.
In mango the setting "Use multiple write commands only" must be activated and I can't read any of the 20 fixed registers at the same time.
I think it has someting to do with the way mango handles the communication.
In the log I first changed 47206 to -100 and then back to -50
woops the second boss is caling , no more basement time today.  dontknaow
Utloggad JohanElmis
  • Tekniknörd
  • Stad/land: Lomma
  • Antal inlägg: 4
    • VillaElmerfjord
« Svar #49 skrivet: 10 april 2012, 14:51:55 »
Köpte Modbus 40 för ett halvår sedan men fick sedan aldrig tid att installera den.
Den kom på plats nu i påsken - men fungerade inte med det nya firmware som medleverarades (v1270).
Fanns helt enkelt ingen Modbus att bocka för i System-installningsmenyn.
Skulle ringa Nibe idag - men hittade till min förvåning att de lagt upp sina firmware på webben.
http://www.nibe.se/Support/programvara/
Jippi - som jag har väntat på - och frågat efter detta.
Har en liten liux-dator som jag tänkte använda för läsning och styrning.
Återkommer med hur det går senare.
Nybyggt (2010) stenhus av IsoLeca på 192m2 i 1,5 plan + 28m2 förråd, norr om Malmö.
Golvvärme uppe och nere i huset, Optimaltanken 750-15-90, 3*30rör Sfinx Heatpipe, Nibe 1145-6kW med 340m markkollektor.
FTX ventilation: Enervent LTR-6 190 eco EDE i huset och Fresh Renovent M180 i förrådet.
6 extra elmätare + 3 Actaris CF ECHO II för VV, Sol och Golvärme mätning.
KNX styrning/loggning av allt.
Utloggad mexitegel
  • Antal inlägg: 398
  • Karma +2/-0
« Svar #50 skrivet: 11 april 2012, 20:15:03 »
Oj, här händer det saker. Kul att se  - själv har jag inte kommit så långt på grund av FVJ (Familj, Villa och Jobb)...
Utloggad JohanElmis
  • Tekniknörd
  • Stad/land: Lomma
  • Antal inlägg: 4
    • VillaElmerfjord
« Svar #51 skrivet: 24 april 2012, 11:50:09 »
Strulade en hel del med kommunikationen.
ModScan64 (64-bitarsversionen av ModScan32) visade sig vara underbar.
Testversionen fungerar ju så länge man inte får vettig data tillbaka, och har först därefter begränsningar.
Det går också enkelt att se om man får någonting tillbaka eller ej, vilket också är till väldigt stor hjälp.
Det visade sig att jag fått data+/- felvänt - även om jag kollat det hundratals gånger tidigare.
Normalt är väl A (-) och B (+) ?
Terminerings-motstånd mellan signal-ledarna - men ingen pull-upp/down.
Har nu en lista på alla Nibes parametrar - och ett litet c-program som kan läsa ut parametrarna.
Jag kör det på en liten Arm-baserad Linux. Arbetar fortfarande på hur jag ska få data därifrån till resten av systemet.
Funderar starkt på SNMP - eller någan annan typ av daemon som cachar alla värden mellan mina läsningar.
Att läsa 39 värden tar ca 40s. (då bara 20 kan vara fördefinierade).
Nu har jag ett Enervent LTR-6 FTX-aggregat med EDA-styrning som kan ska koppla upp mig mot också.
Och så de 3 M-Bus energimätarna som kan skymtas på bilden. Vi får väl se om jag får tid till att sätta ihop ett interface i helgen. :-)
Nibe Modbus 40 - med RS-485 till USB converter (USB-COMi-TB) samt Energimätare.
Bild på Modbus-signalerna (kurvorna är justerade i Y-led). http://www.villaelmerfjord.se/drupal6/node/90
Klicka här för en kopia på Nibes parameterlista: http://www.villaelmerfjord.se/drupal6/sites/villaelmerfjord.se/files/nibeparams_list.txt
« Svar #52 skrivet: 24 april 2012, 13:06:58 »
Varför inte en webserver på Linuxburken?
Utloggad mexitegel
  • Antal inlägg: 398
  • Karma +2/-0
« Svar #53 skrivet: 25 april 2012, 00:05:32 »
Hellre en webservice, då blir det lättare för andra att fortsätta utveckla tillämpningar också.
Utloggad ducken
  • Antal inlägg: 76
« Svar #54 skrivet: 09 oktober 2013, 08:43:42 »
Var står alla i detta?
Är det inköp av MODBUS40 som gäller eller går det att läsa data ur pumparna på annat sätt?
Utloggad mexitegel
  • Antal inlägg: 398
  • Karma +2/-0
« Svar #55 skrivet: 17 oktober 2013, 20:03:57 »
Mitt projekt har hamnat på is på grund av andra prioriteringar. Blir det aktuellt att kika på det igen så köper jag antagligen en uppgraderingskit för nibe uplink.
Raniman
Raniman
« Svar #56 skrivet: 18 oktober 2013, 23:54:11 »
Satte in en länk till en sida med en lösning hur man får ut all logdata direkt ur pumpen utan modbus40, tidigare idag. Men den har tagits bort. Har jag brutit mot någon regel?  Det var ju bara ett litet program och en kabel till serieporten som behövdes.  Sc:,h
  • Antal inlägg: 19496
« Svar #57 skrivet: 19 oktober 2013, 07:52:46 »
Är intresserad av den lösningen kan du skicka länken till mig eller lägga in den igen borde vara ok bryter du mot nått borde du fått höra det.
Raniman
Raniman
« Svar #58 skrivet: 19 oktober 2013, 08:46:56 »
Jag provar igen utan länk. Det är en del av ett hemautomationsprogram. Openhab heter det och har org i slutet. Modulen för nibe går under namnet nibegw.
  • Antal inlägg: 4502
« Svar #59 skrivet: 19 oktober 2013, 19:03:50 »
Om inte ens denna typ av information får avhandlas på forumet tycker jag det har gått för långt med censuren.
Jag har köpt Logger 2020, och är väldigt nöjd med det, jag betalar ett abonnemang till E-logger, och denna typ av information är ingen konkurrent i mitt tycke.
