Författare Ämne: Toshiba RAS-B13SKVP-E/RAS-13SAVP-E; broken indoor motor  (läst 2406 gånger)
Utloggad martin64
  • Antal inlägg: 3
Hi,
sorry that I do write in english. I hope that I find some help here (Toshiba RAS-B13SKVP-E/RAS-13SAVP-E).
Instead of the indoor unit of a Toshiba Super Daiseikai I use an other heat exchanger (designet for R410a) to transfer the energy of the gas to the water of the heating system of my house. First  off all I use the comple indoor PC board and the indoor motor fan (Panasonc ARW40C8P45TF) because otherwise the system do not work.
And then  I do a horrible mistake. I try to modify the working system by replaying the indoor motor in order to save power. While testing I do a mistake (short circuit) and the indoor motor and the PC board was brocken. I bought a new pc board first. But the system does not operate with the broken fan motor. The outoor unit starts the operation and stop after 20 sec.
Is there any posibility to operate the the system without the indoor motor fan? If yes it would be grat if someone could explain me the way. If no, I need an address to buy a new motor. In germany the motor is very expensive.
Please help me.
Martin
PS.: sorry for my bad english
