Författare Ämne: En engelsk lista på ord för de ljud som en vp kan frambringa  (läst 4501 gånger)
Utloggad ElVikingo
  • Stad/land: Landsbygd
  • Antal inlägg: 227
  • Hellre en värmepump i handen än två på foten
TROUBLESHOOTING GUIDE
Glossary of Noises
1. BOOM: Low, resonant sound, like a drum roll or distant thunder.
2. BUZZ: Low-pitched sound, something like a bee; usually associated with
vibrations.
3. CHATTER: Rapidly repeating metallic sound, like teeth chattering.
4. CHUCKLE: High-pitched, melodious sound that repeats rapidly, like a
bird.
5. CLANG: Heavy sound of metal-to-metal, like a gong.
6. CLICK: Light sound, like a ballpoint pen being clicked.
7. GRIND: Abrasive sound, like a grinding wheel or sandpaper rubbing
against wood.
8. GROAN: Continuous, low-pitched sound, like a person groaning.
9. GROWL: Low, gutteral sound like an angry dog.
10. HISS: Continuous sound, like air escaping from a balloon.
11. HUM: Continuous sound at varying pitches, like a wire humming in the
wind.
12. KNOCK: Heavy, loud, repeating sound, like a knock at a door.
13. PING: Similar to knock, but at a higher pitch.
14. RATTLE: A sound suggesting looseness, such as marbles rolling around
in a can.
15. ROAR: Deep, prolonged sound, like a lion’s roar.
16. RUMBLE: Low, heavy, continuous sound, like thunder or wagons.
17. SQUEAK: High-pitched sound, like rubbing a clean window.
18. SQUEAL: High-pitched sound, like a tire on pavement.
19. TAP: Light, hammering sound, like tapping a pencil on a table.
20. WHIR: High-pitched, buzzing sound, like an electric drill or motor.
21. WHISTLE: Sharp, shrill sound, like a tin whistle.
Tänk att det kan vara så svårt, att vara efterklok i förväg....
Många fiskar små...får plats i en stor å
Utloggad Keld
  • Stad/land: Borås
  • Antal inlägg: 332
  • Say WHAT??
    • keld.eu
SV: En engelsk lista på ord för de ljud som en vp kan frambringa
« Svar #1 skrivet: 07 januari 2008, 18:28:53 »
Så vill vi bara ha den på svenska oxå >:D
Utloggad AndersA
  • Antal inlägg: 1376
« Svar #2 skrivet: 07 januari 2008, 19:47:43 »
Den svenska tack, annars blir det nr 9.
///AndersA
Utloggad ElVikingo
  • Antal inlägg: 227
På det kommer inget 3 utan jag höjer och synar med 16-15-16
Vad säger ni nu då
19 19 19 19 19 19 19 19 19
10?
Tänkte väl det.....
 ;D
Jag tror den får vara på engelska, liksom servicemanualerna.
Ideomatiska uttryck är svåra att översätta.
Jag kan framförallt inte hitta ord för alla ljuden, även om jag vet att bin surrar, tänder skallrar osv....
