Författare Ämne: Solstyrningarnas Rolls Royce?  (läst 5085 gånger)
Utloggad humlan57
  • Antal inlägg: 2701
  • Karma +0/-4
« skrivet: 06 maj 2007, 14:50:03 »
Den här gillar jag skarpt!
Specifications:
1) Dimensions: 210mm x 145mm x 48mm
2) Self power consumption: 3W
3) Measuring accuracy of temperature: ±2°C
4) Temperature range of measurement: 0 - 150°C
5) Maximum power of controlled circulation pump: possible to control 4 pumps,
    every power: ≤600W
6) Power of auxiliary electrical booster: ≤2,000W (standard collocation),
    ≤3,000W (not standard, selection available)
7) Inputs:
    a) 6 inputs, Pt-1000 for collector: sensor temperature: ≤500°C (silicon
        cable: ≤280°C)
    b) NTC10K, B=3950 for tank, sensor temperature ≤13°C (PVC cable:
        ≤105°C)
8) Outputs: 5 outputs: one for electrical booster, 4 for circulation pump or 3-way
    electromagnetic value
9) Ambient temperature range: -10 ~ 50°C
10) Water protection grade: IP40
Ska se om den går att få tag i till "rätt" pris...
mvh humlan.
Utloggad nsiak
  • Antal inlägg: 548
  • Karma +2/-1
    • Logg och sol
SV: Solstyrningarnas Rolls Royce?
« Svar #1 skrivet: 06 maj 2007, 16:14:03 »
Om den e rolls va är då denna?
Custom programmable controller with all functions for solar and heating systems. Any desired control tasks can be implemented using (multiple) calls to function modules.
16 sensor inputs: optionally analogue for KTY(2 k ) and Pt 1000 sensor types, radiation sensors or digital, two inputs are suitable for pulse recording from flow sensors, one input for 0-10 volts and 0-20 mA.
11 outputs: 4 x semiconductor outputs RPM-controllable, 7 x relay outputs - one of which is voltage-free, with UVR1611K option to fit an extra relay module with two additional outputs; also features a 0-10 volt analogue out-put.
Integrated potentiostat for electronic sacrificial anode.
CAN bus (50 kbps) for communication with the bootloader, CAN monitor and additional UVR1611 controllers.
ca 85 kvm uppvärmt. Panasonic CS-PE12CKE i huset samt en Pamexa i tvättstugan. Varmvatten med 60 sfinxrör och eltillskott vid behov. Belagt nåra mil norr om GBG
Utloggad humlan57
  • Karma +0/-4
« Svar #2 skrivet: 06 maj 2007, 16:27:33 »
Förstod att den skulle dyka upp  ;D Helt ärligt tycker jag det är en produkt som inte tjänar nåt syfte, om Du inte ska använda den som centralenhet för flera anläggningar, dessutom till ett pris som en bättre solfångar-anläggning. Mer än svindyr med andra ord...
mvh humlan.
Utloggad Lelle
  • Mer en påläst amatör än
  • Antal inlägg: 1008
  • Karma +2/-0
  • Inga frågor är fördummande!
« Svar #3 skrivet: 06 maj 2007, 16:34:35 »
Vad ska man ha om två solpaneler placeras i varsitt väderstreck då?  ::)
En panel i SO och en i SV på två olika väggar...
Energibehov ca 30-35 MWh/år.
Utloggad nsiak
  • Antal inlägg: 548
  • Karma +2/-1
    • Logg och sol
« Svar #4 skrivet: 06 maj 2007, 16:35:49 »
Håller med, men ja tycker inte heller att det var nån rolls du kom med.
Men å andra sidan vem behöver en rolls royce?  ^-^
Utloggad humlan57
  • Karma +0/-4
« Svar #5 skrivet: 06 maj 2007, 16:52:27 »
Det klara ju nästan "alla" sol-styrar av, å den jag la upp klarar mycket mer än så, för fler än 4 cirk-pumpar å 6 sensorer behövs knappast till en öst-väst anläggning. Steca Suntana 2 som jag har liggande klarar åxå en öst-väst anläggning.. Men tyvärr är alla Steca svindyra, så det roliga skulle vara om det gick att få den där till ett lägre pris.
mvh humlan.
Utloggad Lelle
  • Karma +2/-0
« Svar #6 skrivet: 06 maj 2007, 16:56:18 »
Aha, ok och tack! Jag är inte så påläst på sol som du märker. Är två kretsar att rekommendera för ett sånt fall som jag beskrev?
Utloggad Sfinx
  • Antal inlägg: 971
  • Karma +2/-1
« Svar #7 skrivet: 06 maj 2007, 16:58:35 »
Två solfångare i olika väderstreck löses enkelt med en tempdiffstyrning till, som går mot samma cirkpump.  Billigaste tempdiffstyrmningen i byggsats kostar 189 kr på conrad.
Artikelnummer: 194360 på www.conrad.se
Dvs en vanlig för styrning och display av en av solfångarna acctank + en slav för att starta den andra av solfångarna. I samma krets.
Utloggad Lelle
  • Karma +2/-0
« Svar #8 skrivet: 06 maj 2007, 17:30:33 »
Det var ju enkelheten självt. Nu är den här Rollstråden kapad med "low tech"  ;D
Men varför inte bara ha en sån styrning på varje panel och närapå strunta i styrcentralen?
Lite mer logik än så här lär det väl gå åt, men inte så mycket mer.
Men helt klart är den där styrningen du visat Humlan57 intressant till rätt pris.
Mvh L
« Senast ändrad: 06 maj 2007, 17:40:56 av Lelle »
Utloggad humlan57
  • Karma +0/-4
« Svar #9 skrivet: 06 maj 2007, 17:39:28 »
Men guuuud va töööntigt, ger minuspoäng som skrytfaktor  ::) ;D  ;) Här är en bättre bild på fronten av den jag lagt upp.
mvh humlan.
Utloggad Lelle
  • Karma +2/-0
« Svar #10 skrivet: 06 maj 2007, 18:01:43 »
Skrytfaktor... :D  Många gånger är det enkla även det bästa. Avancerade saker tenderar ofta att bli mer obegripliga. ;D  Men så ibland så är det någon som tänkt till och gjort det mest avancerade enklare än det enklaste...   ^-^
Utloggad humlan57
  • Karma +0/-4
« Svar #11 skrivet: 06 maj 2007, 19:04:24 »
Skrytfaktorn är viktig  ;) Fast visst har Du rätt, å mitt värmesystem är nog bland det enklaste som går att få. Men en styrbox som den jag lagt upp här, kan knappast kallas avancerad, den innehåller ju samma saker som en enklare variant, bara lite mer av samma sak  :) För övrigt så följde jag en slags debatt om just "skrytfaktorn" eller om Vi ska kalla det utseende på saker. Å numera sas det, är design (skrytfaktorn) det som säljer bäst, funktion kommer mycket längre ner, som det som drar köpare. Bästa exemplet är mobiltelefoner, där nästan ingen längre bryr sig i hur bra den är, som just telefon, utan design å finesser är det som säljer. Därför är mönsterskydd idag, många gånger viktigre, än ett "vanligt" patent.
mvh humlan.
Utloggad Tigershark
  • Stad/land: Oskarshamn
  • Antal inlägg: 36
« Svar #12 skrivet: 21 juni 2007, 00:24:24 »
Vad tror ni om PC baserad styrning, industri PC utan hårddisk. PLCer och anpassade hårdvarukort är iofs stabilare, men inte lika häftigt.
Hittade en länk till ett Scada system. Tycks vara ett med obegränsade I/O. Krävs självklart någon form av kommunikationskort på PCn.
Tänk vilka häftiga bilder/animeringar mm som kan skapas.
Vet inte om detta HMI är motsvarande InTouch? Kanske finns det någon som jobbat i Proview som kan delge oss info.
Ska själv inte ha detta..driftsäkerhet och PC är inte förenligt i min värld.
http://linux.softpedia.com/progDownload/Proview-Download-9896.html
Konverterat från oisolerad golvvärme till isolerad golvvärme + 2-rörs radiatorsystem.
Luftvärmepump Panasonic HE9DKE
Elpanna Egor 1983
100mm stenull på vinden
110m2 boyta 30 biyta 30000kvh
