Författare Ämne: Här är rören som tål 350-400 graders värme!!!!!!  (läst 8956 gånger)
Utloggad humlan57
  • Antal inlägg: 2701
  • Karma +0/-4
Pust, det tog tid att ringa runt till alla tillverkare i Kina, men nu är det iaf gjort  ::) :)
Description:
All glass evacuated tubes are the key component of solar collectors. The evacuated tube is similar to a conventional Dewar flask and consists of two borosilicate glass tubes, a glass with high chemical and thermal shock resistance. The outer side of the inner tube is coated with a sputtered solar selective surface. This coated inner tube is closed at one end and sealed at the other end to the outer tube. The annular space between the outer tube and inner tube is evacuated to virtually eliminate heat loss by conduction and convection.
Sunna developed the rotary three-layering magnetron sputtering technology and used it to produce Double M-ALN cermets coatings tube which has the advantages of highest thermal efficiency(0.96) , lowest emittance rate(<=0.05/20°) and working effectively in the high temperature(350-400°) in contrast to the normal selective coating evacuated tube. The corresponding film structure is ALN / M-ALN (LMVF) / M-ALN (HMVF) / Cu.
LMVF: Low Metal Volume Fraction.
HMVF: High Metal Volume Fraction
1. Absorption layer
2. Ceramic anti-reflection
3. Metal infrared reflector
Advantages over normal vacuum glass tube:
1) Higher heat efficiency: 12% higher heat absorbent ratio than normal vacuum tube.
2) Resisting ageing and attenuation: Normal vacuum tube could have problems such as film ageing and attenuation under high temperature exposure(250 degree Celsius) for a long time while the three- target vacuum tube can endure high temperature of 400 degree Celsius, therefore the service life can be significantly prolonged.
Features:
High solar-thermal conversion and low heat loss
Stable advanced coating up to 380°
Long time warranty to 15 years
High level vacuum ensure operation under cold weather
Synd att jag ännu inte hittat en riktig hemsida, men jag ska söka vidare.
mvh humlan.
PS. Du Professor Kapsyl, Du får nog skaffa lite värre isolering, om Du ska testa hur hett det går att få med dom här rören  :) ;) DS
« Senast ändrad: 05 april 2007, 15:52:31 av humlan57 »
Utloggad Gäst407
  • Antal inlägg: 3104
  • Karma +3/-6
SV: Här är rören som tål 350-400 graders värme!!!!!!
« Svar #1 skrivet: 05 april 2007, 16:52:41 »
hej
Dr Hum-Lan
 du som är kung i solriket,vet du vad som skilljer i effektivitet mellan 58 mm å 70mm rör,dvs vad gör det i effekt ??
Utloggad humlan57
  • Karma +0/-4
« Svar #2 skrivet: 05 april 2007, 17:00:28 »
hej
Dr Hum-Lan
70mm..., är inte det bara U-pipe som har den dimensionen? Iaf så har jag ingen aning om hur mycket det skiljer, men ju mer absorbtionsyta ju högre effekt. Å om det finns som heatpipe, så tvivlar jag passar i din kollektor.. Kolla med Sfinxen, han vet säkert det där...
mvh humlan.
Utloggad humlan57
  • Karma +0/-4
« Svar #3 skrivet: 05 april 2007, 19:49:09 »
Här är en bild på ett rör, å vad dom heter/betecknas. Om det bara finns den där varianten vet jag inte, har dom den där beteckningen, så tål dom uppåt +400C.
mvh humlan.
Utloggad humlan57
  • Karma +0/-4
« Svar #4 skrivet: 06 april 2007, 12:08:48 »
Lite mer å begriplig info om rören: http://www.solarpanel.ca/SCGV_specs.html
Det står 60W effekt där, men jag har sett en annan uppgift som sa 110W, så det måste vara mätt under olika förhållanden, eller nåt.
mvh humlan.
« Senast ändrad: 06 april 2007, 12:18:44 av humlan57 »
Utloggad humlan57
  • Karma +0/-4
« Svar #5 skrivet: 06 april 2007, 12:32:27 »
Hittade en svensk sida med dom där rören!!!! Å där står effekten som 120W. Vill Ni kolla så finns uppgifterna hos "Svensk Solvärme". Återstår bara å se om dom kommer i 58mm utförande, annars är det knappast lönt, mer än av nyfikenhet  :), byta ut de rör som man redan har.
mvh humlan.
Utloggad solvärme
« Svar #6 skrivet: 10 april 2007, 22:37:52 »
hej
Dr Hum-Lan
Det skiljer ca 30w vid full effekt mellan 58 och 70 tuberna alla fall dom som svensk solvärme levererar.
Utloggad humlan57
  • Karma +0/-4
« Svar #7 skrivet: 10 april 2007, 22:53:43 »
hej
Dr Hum-Lan
Det tror jag säkert, då det inte är samma typ av rör. Men iaf så har Sfinxen tydligen skaffat fram 58mm rör av den nya typen, å dom lämnar visst åxå ca 120W. Får det inte riktigt att gå ihop, men det är ju SP som mätt fram det, så jag får väl så lov att acceptera fakta.
Värmerör för vakuumrör 58/1800
Anslutning diam 14, L= 75 mm
Material Syrefritt koppar
Start temperatur <= 25 C
Max Effekt >=120W
Värmeledare Aluminium
Max temperatur >=200 C
Vikt 350 gr
mvh humlan.
Utloggad Stig53
  • Stad/land: Mariehamn Åland
  • Antal inlägg: 195
« Svar #8 skrivet: 11 april 2007, 19:43:22 »
Jag började undra efter att studerat bilden i inlägg Svara #3 skrivet: 05 April 2007, 19:49:09 », är solfångar i dessa rör av plan typ, och hur är dom känsliga för riktning.
Solfångare Intelli-heat 24/58 4 st, i söderläge 30 ° lutning från lodrät, 1 st optimaltank tekniktank 750 l +2 st optimaltank 750 slav. Steca 603 solautomatik. Etna k 30 vedpanna med laddomat.
Utloggad humlan57
  • Karma +0/-4
« Svar #9 skrivet: 11 april 2007, 21:44:36 »
Dom är av heatpipe typ, men 70mm i diameter, är 1900mm långa å har betydligt tjockare glas http://www.svensksolvarme.se/images/Tekniska%20data%20tuber.pdf . Men vad jag förstått, så finns även glasrören/vakumrören till 58 mm. Sfinx t.ex, har dom rören, åtminstone är beteckningen samma på dom, enligt Sfinx:en. Å det "bevisas" även av de värden som hans nya rör uppvisar vid test.... Med viss sannolikhet är jag inne på att testa 70x1900mm rören som Svensk Solvärme har http://www.svensksolvarme.se/ på mitt nya projekt, med dubbla oberoende system. Har varit i kontakt med dom, så nu ska jag "prata" lite mer med firman, så får Vi se vad det leder till...
mvh humlan.
Utloggad humlan57
  • Karma +0/-4
« Svar #10 skrivet: 11 april 2007, 22:56:33 »
Jag har blivit upplyst om att absorbatorn är platt i rören med 70mm diameter, nåt som jag helt missat. Tog för givet den var rund, när det var den nya typen av beläggning. Givetvis är det sämre med platt absorbator, då den av praktiska skäl inte kan ge full effekt under alla timmar som den blir belyst. Beroende på att Solen bestrålar från olika vinklar under dagen, nåt som inte nämnvärt inte påverkar ett rör med rund absorbator. Ber om ursäkt, ifall jag vilselett någon...
mvh humlan.
Utloggad Stig53
  • Antal inlägg: 195
« Svar #11 skrivet: 12 april 2007, 05:33:26 »
Nu börjar dett bli intresant, hur ser dessa rörs effektkurva ut om man monterar dom i 60°, finns dett någon testning på hur lång tid som dessa rör leverera hög effekt unde dagens timmar. Sc:,h
Utloggad Sfinx
  • Antal inlägg: 971
  • Karma +2/-1
« Svar #12 skrivet: 12 april 2007, 07:31:27 »
www.spf.ch har massvis med pdf filer med olika testresultat.
en snarlk med plan absorbator här är ex http://www.spf.ch/factsheets/scf689en.pdf
Glasets brytning ger en liten förbättring men inte alls som om absorbatorn är rund
Att jämföra med den typ som har rund absorbator. Ex bifogas.
Upp till ca 75 graders infallsvinkel är "förstärkningen" jämfört med plan yta över 1.53.
Dvs under 6 tim före och efter solen står i Zenit får man ut upp till 50% mer än en plan yta på grund av solfångarens form.
« Senast ändrad: 12 april 2007, 07:45:50 av Sfinx »
Utloggad Stig53
  • Antal inlägg: 195
« Svar #13 skrivet: 12 april 2007, 16:53:25 »
Finns det någon som kan säga hur mycket högre utbyte som dessa rör ger en solig dag, om solfångarena är indentisk monterade. Jag har studerat länkarna i Sfinx inlägg och jag tror att utbytet över en dag inte är vesäntligt mycket bättre än solfångare med rund absorbatoryta.
Utloggad humlan57
  • Karma +0/-4
« Svar #14 skrivet: 12 april 2007, 17:14:34 »
Sett över en hel dag är det bättre med rund absorbator, det var det missförståndet av mig, som jag rättade till lite längre upp, i det här topicet. Jag antog helt felaktigt, att det vara rund absorbator i 70mm rören jag lade in en bild på, en löjlig miss från min sida alltså. Inte så konstigt, att jag inte kunde få ihop att effekten på 58mm, å 70mm var identisk  ;D Men nu verkar det som så att Sfinx nya rör, har beläggningen som gör att de klarar den högre tempen. Men jag är ändå lite kluven över om jag ändå ska testa 70mm rören p.g.a att placeringen är i syd-öst, å rören kommer att belysas inom ett relativt snävt gradtal i sidled, under stora delar av året. Avgörandet beror på vad jag kan förhandla fram för pris på rör+kollektor/vvx hos resp firma  :)
mvh humlan.
  • Dot gäster: 2732
