Författare Ämne: Fail to save data  (läst 2706 gånger)
Utloggad TP
  • Antal inlägg: 3
Fail to save data
« skrivet: 11 februari 2007, 15:48:33 »
Hi forum
I´ve recieved and istalled the temp logger, however I have a problem with it. After logging appr. 22-23 hours this alarm will appear: Failed to save data. If I go to check the temp sensors these are gone and I have to start all over again. Do you have any idea whats wrong and what to do about it
regards
Thomas  (Roskilde Denmark)
  • Antal inlägg: 36601
SV: Fail to save data
« Svar #1 skrivet: 11 februari 2007, 18:33:33 »
How are your power saving settings, you cant let the harddrive go into sleep mode.
Utloggad TP
  • Antal inlägg: 3
« Svar #2 skrivet: 11 februari 2007, 22:47:22 »
Hi Rickard
Thanks for your answer. The power sawing feature is not activated. I can effect the time before the logger fail to save data by changing the temperature reading time. The longer reading time the longer it takes before saving failure will appear. When it was 5 min it took 8-10 hours before the failure came. Then I changed it to 15 min. and 22 hours later the failure occured. Now I have set it to 30 min. then I will see what happens. I hope this will help.
« Svar #3 skrivet: 12 februari 2007, 06:42:38 »
I think your problem has to do with your computer and some of the softwares you use, this is not a bug report that is common, i have from time to time problems with save failure, but it always happend when i have a lot of demanding softwares running and the computer itselves is working porly.
A reboot of the computer fixes the problem i experiance.
This installation on an old computer has been logging for more then 3 weeks no without problems. http://www.varmepumpsforum.com/hif.htm
Utloggad TP
  • Antal inlägg: 3
« Svar #4 skrivet: 12 februari 2007, 18:13:48 »
After I changed the Temp reading interval to 30 min. I haven´t had any failure for 24 hours. So hopefully this has solved my probem.  :-* Thank you for your help so far.
