Författare Ämne: Strulvarning för nya sophämtningsregler !  (läst 10928 gånger)
Utloggad Sture
  • ฮัทเสห์
  • Stad/land: BORÅS
  • Antal inlägg: 534
SV: Strulvarning för nya sophämtningsregler !
« Svar #30 skrivet: 03 oktober 2007, 12:14:09 »
Där jag bor så gör man jord av matavfall och organiskt material, detta placeras i svarta påsar, resten förbränns till fjärrvärme och placeras i vita påsar.
Den automatiska sopsorteringsanläggningen har inga som helst problem att sortera vita och svarta påsar (egentligen letar den bara efter svarta så de vanliga butikskassarna går att använda).
Det funkar bra här i Borås, två påsar under diskbänken är OK. Men nu har man i Patong, Phuket, tagit åtskilliga steg framåt.  Kopierat från gårdagens Phuket Gazette:
Patong announces trash-sorting initiative
PATONG: Residents of Patong should get ready to start sorting their trash, as Patong Municipality plans to improve its waste management system by distributing plastic garbage bags in 10 colors, each designated for a particular category of waste.
The scheme, developed jointly with the Thai Industrialist Development Forum (TIDF), was announced at a press conference hosted by Patong Mayor Pian Keesin on Wednesday.
“Sorting all our trash into these 10 categories will make it a lot easier to dispose of. More useful types of trash then can be recycled.
“This initiative will not only reduce the volume of trash, but it will improve our environment and way of life by giving everyone a useful role to play in the community. It will also be a useful source of income for some people,” said Mayor Pian.
Finer details of the plan, such as what penalties will be imposed on those who fail to sort their garbage, were not discussed.
However, it was mentioned that the new system is intended to eliminate the need to truck refuse to the island’s overburdened trash incinerator at Saphan Hin.
The thick plastic bags will be distributed free and the new system is scheduled to go into operation in early December.
To dispose of the sorted waste, the TIDF will deploy a mobile grinding machine capable of rendering many categories of trash into re-usable litter.
The bag designations by color are:
Black: Food scraps and organic matter.
Blue: Cans, buckets, scrap iron.
Yellow: Plastics.
Gray: Cement and bricks.
Pink: Fabrics, such as cloth and silk.
Red: Glass.
Green: Paper.
Brown: Twigs and other plant matter.
Orange: Rubber, foam and leather.
Purple: Toxic items, such as batteries and aerosol canisters.
Man undrar ju hur det kommer att fungera, hoppas bara inte vi tar efter...
Sture
Tidigare Völund 777 luft/vattenpump installerad 1983 dockad till en CTC oljepanna från 1970. Byte i dec 2004 till IVT Optima 700 och Ep 290 A/W. Ytongvilla byggd 1970, 109 m2 med källare i Borås.
Förbr senaste månad (aug), medeltemp i Borås +16,2°: Värme och varmvatten 169 kWh, hushållsel 353 kWh. Senaste 12 mån 11.806 kWh resp 5.169 kWh. Rumsgivare i källaren inställd på 20°.
  • Antal inlägg: 36601
« Svar #31 skrivet: 03 oktober 2007, 13:29:41 »
Hmm, varför inte ett internationellt system med samma färgmarkeringar överallt och så en färgmarkering på alla produkter så blir det enkelt att sortera?  :-\
Utloggad messer
  • Antal inlägg: 1203
  • Karma +3/-4
  • Jag älskar så gott det går
« Svar #32 skrivet: 03 oktober 2007, 22:20:23 »
Fick just i dag ett brev från vårt sophanteringsföretag, vi skall nu för att komma in till sopstationen få ett kort att dra i en läsare för att öppna bommen så man kommer in.
Problemet blir var skall kortet förvaras hemma så man glömmer det när man åker till sopstationen eller i en av bilarna som antagligen inte är hemma när man skall till sopstationen.
Och varför skall man hindra någon från att kasta sopor på rätt ställe, dom kommer väl att hamna i naturen i stället.
Jag har 1,5 mil till min sopanläggning så det blir en resa på 3 mil varje gång.
Tänk om jag istället fick åka till den sopstation som ligger närmast, dit är det bara 5-6 km.
Men dom har redan en bom för att hindra folk från andra kommuner att kasta där.
Jag tycker det blir lite löjligt när dom talar om miljövänligt, när dom enbart tänker på ekonomin.
Det vill säga deras egen ekonomi inte samhällets.
MVH
Messer
Utloggad Art Deco
  • Antal inlägg: 2102
  • Karma +9/-4
« Svar #33 skrivet: 07 november 2007, 13:22:30 »
Tar upp denna tråd igen.
Kan vara värt att veta för er i radhusområden och vissa villaområden.
Kommunerna kommer att sträva efter att bara ha 1 centralt belägen sopstation i radhusområden och vissa villa-områden så att sopåkaren ska slippa att köra in på trånga gator, "då de mår psykiskt illa av detta" enligt Arbetsmiljöverket som nu ska genomföra ännu en lag. (ursäkten är alltså att man ev kan köra på ett barn nu eller vara trafikfarlig på trånga gator)
Effekten av detta blir att vissa personer då få gå ett par hundra meter för att slänga sina sopor, beroende på avstånd/läge till tänkta sopstation. Naturligtvis har detta startat ett jättebråk och det har redan gjorts nyhetsinslag om denna "nyordning". Först ut är vissa områden runt Sth typ Skärholmen m.fl som planlades på 60-70 talet då sopgubbarna inte mådde illa av att köra in på trånga gator, denna nya förordning kommer sen att gälla i hela Sverige. Kanske dags för en del här att kolla sin egen sop-situation.
Att sen kommunen/entreprenören tjänar grova belopp på att slippa tömma vid varje fastighet och istället ha en centralt belägen station talas det tyst om, "det är ju en försöksperiod".
Intressant att se hur man kan lyckas driva igenom en arbetsmiljölag, där syftet är högst tvivelaktigt samtidigt som det pågår en starkt lobbying i att just nu ordna med centrala upphämtningsplatser.
Hos oss blev effekten följande: Reglerna på 3 m från tomtgräns följs inte alls, hos vissa hårddrar man reglerna, hos vissa struntar man helt i nya förordningen och vissa slipper byta ut till moderna sopkärl helt och kör den gamla modellen. En del ger sopgubbarna någon hundring för att slippa tjafset och kör sen som inget hade hänt, så resultatet är muta och kör. När sen snön kommer blir det intressant och se hur snöröjningen kommer att funka då sophämtaren numera ställer alla tunnor på gatan (trots gällande förbud) och eftersom de boende kommer hem först på kvällen lär det då inte plogas på dessa gator alls eftersom detta alltid görs på eftermiddagen.
Utloggad Olle61
  • Antal inlägg: 1481
« Svar #34 skrivet: 08 november 2007, 12:07:57 »
Jag tycker inte det verkar så dumt. Om de i Thailand läser om det svenska systemet och att en gammal dam åtalas för att kastat en stekpanna i förpackningsinsamlingen, vill de hellre ha det systemet?
