If you're rolling a Warlock in Season 13, the first thing you'll notice is that the class doesn't feel like a simple "press one spender and sprint" leveller. It has teeth, but it also has a rhythm. Wrath keeps your main spells moving, while Dominance decides how often the bigger demon plays come online. That's why early gearing, gold costs, and small upgrades still matter, even if you're not chasing perfect items yet; a bit of planning around
D4 Gold can make the trip from the first zones into early Torment feel a lot less awkward. Based on the current Season of Reckoning sources, Dread Claws Warlock is the safest recommendation for most players, with Minion Warlock sitting close behind as the easier, steadier option.
Why Dread Claws is the main levelling pick
Dread Claws keeps showing up for a reason. Maxroll places Dreads Claw Warlock in A Tier for Season 13 levelling, and several Mobalytics planners from creators such as Raxxanterax, Mekuna, Tesdey, and NickTew lean into the same idea. The exact skill ranks change from build to build, but the shell is familiar: Dread Claws for the main work, Nether Step for movement, Command Fallen for resource
, and demon tools like Rampage, Terror Swarm, Summon Laalish, Sigil of Subversion, or Profane Sentinel depending on the setup. It's not the cleanest class in the first few levels, since Dominance can feel tight, but once the build gets moving it clears packs well and doesn't ask for rare endgame gear just to function.
Resources are the part players often underestimate
Warlock uses two main resources, and you really can't ignore either one. Wrath is the pink bar and pays for many of your regular spells, especially the core rotation. Dominance is the purple bar and is tied more heavily to Greater Demon skills. That second bar is where newer players get caught. Early on, Dominance comes back slowly, and there aren't many strong tools to smooth it out. Command Fallen helps here, since it's repeatedly used in Warlock builds and is described as a button you press roughly every 20 seconds for extra Wrath and Dominance. Rampage, on the other hand, spends Dominance to bring in heavier demon pressure, so spamming it without thinking can leave your rotation feeling dead for a few seconds.
Minions, Soulshards, and the slower route
Minion Warlock is also rated A Tier for levelling, and it's probably the better pick if you'd rather play a safer, more hands-off style. The Mobalytics Minions guide uses Sigil of Summons as the main skill, backed by Command Fallen, Bombardment, Rampage, and Fiend of Abaddon. It also favours Legion Shard, which fits the demon army theme nicely. Lesser Demons act as bodies on the field, and Spawn Fragment adds more of them over time. The trade-off is pace. The build is beginner friendly and controller friendly, but it isn't the fastest thing around, and mobility can be a real issue. That's why some setups use mobility tricks such as turning Evade into a blink-style movement tool.
Levelling habits that matter more than perfect theory
For most players, Hard World Tier is the better starting point. Expert sounds tempting, but slower kills can hurt the Season 13 Killstreak flow, and Warlock already needs a bit of time before its resource engine feels good. Push higher tiers when Helltides and seasonal content stop feeling dangerous, not before. Use mounts as soon as your account allows it, grab Whispers while doing Helltides, and don't waste early Paragon points trying to fill every board. Head toward Legendary bonuses and useful glyph paths instead. If you choose to stock up through
D4 Gold for sale, treat it as a convenience for smoother gearing and crafting rather than a substitute for learning the class rhythm.
