Författare Ämne: F2040-8 showing strange temperatures  (läst 1067 gånger)
Joseph Azadehdel
Joseph Azadehdel
« skrivet: 21 september 2021, 20:59:41 »
Hey sorry for English I am still learning.
My f2040-8 is showing the return temperate as higher than the condenser out temperature. Sometimes up to 10 degrees. Does anyone know if this is correct? And if not why it would be happening?
Thanks!
  • Antal inlägg: 4316
SV: F2040-8 showing strange temperatures
« Svar #1 skrivet: 21 september 2021, 22:25:59 »
During defrost condenser out temperature is supposed to be lower than return. Defrost duration is 2-7 minutes.
If the condenser out is lower than return temperature during heating, something is wrong.
Utloggad bjofossen
  • Nibe VVM320 F2040-8. Gulvvarme. 110 kvm, 5 soner med termostat(Uponor)
  • Stad/land: Norge
  • Antal inlägg: 31
  • F2040 VVM320 110 kvm
« Svar #2 skrivet: 05 februari 2022, 22:28:13 »
I had the same problem. The sensor for in / out temp inside the F2040 (BT12/BT3) were switched at the motherboard. The installer fixed this.
