Författare Ämne: Mitsubishi Ecodan EHPT20X-YM9C - F9 flow sensor error  (läst 2027 gånger)
KasperMoe
KasperMoe
« skrivet: 16 november 2018, 16:39:28 »
We have a Mitsubishi Ecodan air to water system. After we have started it up after the summer we have got errors with the system coming with a F9 flow sensor error.
We have check all radiators, removed air, dirt etc, but it still coming back. Event if we disable the house heating so it only created hot water it still gets the same error.
In DK we dont have so much esperiance with this model, so there is no really experts on it. The company there have looked at it belives that the only thing left we can try is exchanging the flow sensor which is quite expensive, when we are not sure thats the problem :S
Have any of you experianced anything like this problem?
Utloggad Kloge
  • Antal inlägg: 401
  • Värmepump Ja tack
SV: Mitsubishi Ecodan EHPT20X-YM9C - F9 flow sensor error
« Svar #1 skrivet: 20 november 2018, 22:23:42 »
http://www.mitsubishitech.co.uk/Data/Ecodan/Air/Monoblock/Outdoor/PUHZ-W/2015/PUHZ-W112VHA_SM_OCH562.pdf
På sidan 13 står det
"2 connector open
Abnormal if both 63H and 63L connector
circuits are open for 3 minutes continuously
from being switched on.
63H: High-pressure switch
63L: Low-pressure switch"
Case:
1 Disconnection or contact failure
of connector (63H,63L) on
outdoor controller circuit board.
2 Disconnection or contact failure
of 63H, 63L
3 63H and 63L are working due
to defective parts.
4 Defective outdoor controller
board.
Judgment and action:
1 Check connection of connector (63H,63L) on
Refer to "8-6. TEST POINT DIAGRAM".
2 Check the 63H and 63L side of connecting
wire.
3 Check continuity of 63H and 63L.
Replace the pressure switch if it is defective.
4 Replace outdoor controller circuit board.
Hus på 120 m2 i 1,5 plan med källare byggt 1937. Sedan vintern 2014 även uppvärmning av uterum ca 25m2 med både vattenburet och elelement
Handöl 33T täljstenskamin
Mitsubishi Ecodan 14 kw
Innedel EHST 20C-YM9A.UK
Utedel  PUHZ RP100 YKA.
Installerad 29/5-2012
2025 Vp 8369 kwh
2024 Vp 7804 kwh
2023 Vp 7794 kwh
2022 Vp 7816 kwh
2021 Vp 9610 kwh
2020 Vp 8400 kwh
2019 Vp 8532 kwh
2018 Vp 8868 kwh
2017 Vp 9171 kwh
2016 Vp 9225 kwh
2015 Vp 7929 kwh
2014 Vp 7142 kwh
2013 Vp 8241 kwh
2012 Vp 3458 kwh  (7 mån)
