[NIBL 20180730 8310] Divisors 10 10 10 1 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 1 100 1 10 10 1 1 10 10 10 1 1 1 100 10 10 1 1 1 Date Time Outdoor temp [°C] Outdoor. Average [°C] Room temp [°C] Prio Calc. Supply S1 [°C] Supply temp S1 [°C] Return temp S1 [°C] Calc. Supply S2 [°C] Supply temp S2 [°C] Return temp S2 [°C] Calc.Heat dT [°C] Actually Heat dT [°C] Hot water top [°C] Hot water Load [°C] Condensor Out [°C] Hot Gas Temp [°C] Evaporator temp [°C] Suction temp [°C] Exhaust air temp [°C] Vented air temp [°C] BS1 Air flow Air flow reference Humidity average [%] Addition power[kW] Supply CP speed [%] Degree minutes [DGM] Comp Freq. ACT [Hz] Active defrosting time [s] Passive defrosting time [s] Current L1 [A] Current L2 [A] Current L3 [A] Alarm number Comp starts [ST] Comp time [h] Comp energy [kWh] Add.heating[kWh] Add.hot water[kWh] Auto heat medium pump speed, hw [%] Auto heat medium pump speed, heat [%] Supply CP speed [%] 40004 10 Outdoor temp [°C] BT1 Outdoor Temperature 40067 10 Outdoor. Average [°C] BT1 Average 40033 10 Room temp [°C] BT50 Room Temp S1 43086 1 Prio Prio 43009 10 Calc. Supply S1 [°C] Calc. Supply S1 40047 10 Supply temp S1 [°C] BT2 Supply temp S1 40012 10 Return temp S1 [°C] EB100-EP14-BT3 Return temp 43008 10 Calc. Supply S2 [°C] Calc. Supply S2 40007 10 Supply temp S2 [°C] EP21-BT2 Supply temp S2 40129 10 Return temp S2 [°C] EP21-BT3 Return temp S2 43064 10 Calc.Heat dT [°C] Heat Medium Flow dT Set Point 43065 10 Actually Heat dT [°C] Heat Medium Flow dT Actual 40013 10 Hot water top [°C] BT7 HW Top 40014 10 Hot water Load [°C] Hot water load temperature, BT6 40017 10 Condensor Out [°C] EB100-EP14-BT12 Condensor Out 40018 10 Hot Gas Temp [°C] EB100-EP14-BT14 Hot Gas Temp 40020 10 Evaporator temp [°C] EB100-BT16 Evaporator temp 40022 10 Suction temp [°C] EB100-EP14-BT17 Suction 40025 10 Exhaust air temp [°C] BT20 Exhaust air temp. 1 40026 10 Vented air temp [°C] BT21 Vented air temp. 1 41026 10 BS1 Air flow EB100-Adjusted BS1 Air flow 43124 10 Air flow reference Airflow ref. 41027 1 Humidity average [%] Humidity average 43084 100 Addition power[kW] Int. el.add. Power 43437 1 Supply CP speed [%] Supply Pump Speed EP14 43005 10 Degree minutes [DGM] Degree Minutes (16 bit) 43136 10 Comp Freq. ACT [Hz] Compressor Frequency, Actual 40934 1 Active defrosting time [s] Calculated time for active defrosting of the compressor. 40935 1 Passive defrosting time [s] Calculated time for passive defrosting of the compressor. 40083 10 Current L1 [A] EB100-BE1 Current 40081 10 Current L2 [A] EB100-BE2 Current 40079 10 Current L3 [A] EB100-BE3 Current 45001 1 Alarm number Alarm 43416 1 Comp starts [ST] Compressor starts EB100-EP14 43420 1 Comp time [h] Tot. op.time compr. EB100-EP14 43144 100 Comp energy [kWh] Compr. energy total 44300 10 Add.heating[kWh] Heat Meter - Heat Cpr and Add EP14 44298 10 Add.hot water[kWh] Heat Meter - HW Cpr and Add EP14 48452 1 Auto heat medium pump speed, hw [%] Auto heat medium pump speed hw 48453 1 Auto heat medium pump speed, heat [%] Auto heat medium pump speed heat 43437 1 Supply CP speed [%] Supply Pump Speed EP14
