Divisors 1 10 10 10 10 10 10 10 10 10 10 1 1 1 10 1 1 10 10 10 10 10 10 10 10 10 10 10 10 1 1 100 1 Date Time Active defrosting time [s] AZ2-BT22 Supply air temp. SAM [°C] AZ2-BT23 Outdoor temp. SAM [°C] AZ2-BT68 Flow temp. SAM [°C] AZ2-BT69 Return temp. SAM [°C] BT1 Outdoor Temperature [°C] BT2 Supply temp S1 [°C] BT6 HW Load [°C] BT7 HW Top [°C] Calculated supply air temp. [°C] Calculated Supply S5 [°C] Chargepump speed [%] Compr. current max.freq. [Hz] Compr. current min.freq. [Hz] Compressor Frequency, Actual [Hz] Compressor Frequency, Request [Hz] Defrosting time [s] Degree Minutes (16 bit) EB100-Adjusted BS1 Air flow EB100-BS1 Air flow EB100-BT16 Evaporator temp [°C] EB100-BT61 Supply Radiator Temp [°C] EB100-BT62 Return Radiator Temp [°C] EB100-EP14-BT12 Condensor Out [°C] EB100-EP14-BT14 Hot Gas Temp [°C] EB100-EP14-BT3 Return temp [°C] EP21-BT2 Supply temp S2 [°C] EP21-BT3 Return temp S2 [°C] EP21-BT50 Room Temp S2 [°C] External SAM accessory GQ3 speed [%] Fan speed current [%] Int. el.add. Power [kW] Int. el.add. State 2019-01-03 20:07:32 0 151 -6 283 121 -6 308 485 491 160 200 1 112 20 291 29 0 -4812 2761 2293 -3 303 288 304 608 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:08:29 0 151 -5 283 121 -6 308 485 491 160 200 1 112 20 290 29 0 -4801 2760 2293 -3 303 288 304 608 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:09:29 0 152 -6 283 121 -6 307 485 491 160 200 1 112 20 290 29 0 -4790 2760 2302 -3 303 288 304 607 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:10:29 0 152 -6 283 121 -6 307 485 491 160 200 1 112 20 289 29 0 -4779 2760 2308 -3 303 288 304 607 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:11:29 0 152 -6 283 121 -7 307 485 491 160 200 1 112 20 289 29 0 -4768 2760 2299 -3 303 288 304 607 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:12:29 0 152 -6 283 121 -6 307 485 491 160 200 1 112 20 290 29 0 -4757 2761 2305 -3 303 288 304 607 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:13:29 0 152 -6 282 121 -7 307 484 491 160 200 1 112 20 290 29 0 -4746 2761 2298 -3 303 288 304 607 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:14:29 0 151 -6 283 121 -6 307 484 490 160 200 1 112 20 290 29 0 -4735 2761 2308 -3 303 288 304 607 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:15:29 0 151 -6 282 121 -7 307 484 490 160 200 1 112 20 290 29 0 -4725 2762 2301 -3 303 288 303 607 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:16:29 0 151 -6 283 121 -7 307 484 490 160 200 1 112 20 290 29 0 -4715 2761 2296 -3 303 288 303 606 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:17:29 0 152 -6 283 121 -6 307 484 491 160 200 1 112 20 291 29 0 -4705 2761 2314 -3 303 288 303 606 287 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:18:29 0 152 -6 282 122 -6 307 483 491 160 200 1 112 20 291 29 0 -4695 2762 2296 -2 303 288 303 606 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:19:29 0 152 -6 282 121 -7 307 481 491 160 200 1 112 20 290 29 0 -4685 2761 2289 -1 302 288 303 606 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:20:29 0 152 -6 282 121 -7 307 481 490 160 200 1 112 20 289 29 0 -4675 2760 2295 -1 302 288 303 606 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:21:29 0 152 -6 282 121 -7 307 480 490 160 200 1 112 20 289 29 0 -4665 2760 2306 -1 302 288 303 606 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:22:35 0 152 -6 282 121 -6 307 480 490 160 200 1 112 20 290 29 0 -4655 2762 2302 -1 303 288 303 606 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:23:32 0 151 -6 282 121 -6 307 479 490 160 200 1 112 20 290 29 0 -4645 2761 2291 -1 302 288 303 606 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:24:32 0 152 -6 282 121 -7 307 479 490 160 200 1 112 20 290 29 0 -4635 2761 2296 -1 302 287 303 606 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:25:32 0 152 -6 282 121 -6 307 479 490 160 200 1 112 20 290 29 0 -4625 2760 2297 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:26:32 0 151 -6 282 121 -7 307 479 490 160 200 1 112 20 291 29 0 -4615 2759 2289 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:27:32 0 151 -6 282 120 -7 307 479 490 160 200 1 112 20 290 29 0 -4605 2758 2306 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:28:32 0 152 -6 282 121 -7 307 479 490 160 200 1 112 20 290 29 0 -4595 2759 2302 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:29:32 0 152 -6 282 122 -7 307 479 490 160 200 1 112 20 291 29 0 -4585 2759 2293 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:30:32 0 152 -6 282 122 -7 307 479 490 160 200 1 112 20 290 29 0 -4575 2758 2290 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:31:32 0 152 -6 282 121 -6 307 478 490 160 200 1 112 20 290 29 0 -4565 2756 2285 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:32:31 0 152 -6 282 121 -6 307 478 490 160 200 1 112 20 290 29 0 -4555 2754 2280 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:33:31 0 151 -6 282 121 -7 306 478 490 160 200 1 112 20 291 29 0 -4545 2753 2285 -1 302 287 303 605 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:34:31 0 152 -6 282 121 -7 306 478 490 160 200 1 112 20 290 29 0 -4535 2752 2287 -1 302 287 303 603 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:35:31 0 152 -6 282 121 -7 306 478 490 160 200 1 112 20 289 29 0 -4525 2752 2293 -1 302 287 303 603 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:36:31 0 152 -6 282 121 -7 306 478 489 160 200 1 112 20 289 29 0 -4515 2750 2268 -1 302 287 303 603 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:37:32 0 151 -6 282 121 -6 306 478 489 160 200 1 112 20 290 29 0 -4505 2748 2292 -1 302 287 303 603 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:38:32 0 151 -6 282 121 -7 306 478 489 160 200 1 112 20 290 29 0 -4495 2749 2291 -1 302 287 303 603 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:39:31 0 151 -6 282 120 -7 306 477 489 160 200 1 112 20 289 29 0 -4485 2749 2290 0 302 287 303 603 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:40:31 0 151 -6 281 120 -6 306 477 489 160 200 1 112 20 289 29 0 -4476 2749 2291 0 302 287 302 603 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:41:31 0 151 -6 282 120 -7 306 477 489 160 200 1 112 20 290 29 0 -4467 2749 2283 0 302 287 302 603 286 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:42:31 0 150 -6 281 120 -6 306 477 489 160 200 1 112 20 290 29 0 -4458 2746 2269 1 302 287 302 603 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:43:31 0 151 -6 281 120 -7 306 477 489 160 200 1 112 20 289 29 0 -4449 2745 2286 1 302 287 302 603 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:44:31 0 151 -6 281 121 -7 306 477 489 160 200 1 112 20 291 29 0 -4440 2746 2292 1 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:45:31 0 151 -6 281 121 -7 306 476 489 160 200 1 112 20 290 29 0 -4431 2746 2287 1 301 286 302 603 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:46:31 0 150 -6 281 120 -7 306 476 489 160 200 1 112 20 290 29 0 -4422 2746 2296 1 302 287 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:47:31 0 151 -6 281 120 -7 306 476 489 160 200 1 112 20 290 29 0 -4413 2746 2266 1 302 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:48:31 0 150 -6 281 120 -7 306 476 489 160 200 1 112 20 290 29 0 -4404 2742 2268 1 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:49:31 0 150 -6 281 120 -7 306 476 489 160 200 1 112 20 289 29 0 -4395 2740 2267 1 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:50:31 0 151 -6 281 120 -8 306 475 489 160 200 1 112 20 290 29 0 -4386 2739 2287 1 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:51:31 0 151 -7 281 120 -7 306 475 489 160 200 1 112 20 289 29 0 -4377 2737 2266 1 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:52:30 0 151 -7 281 120 -8 306 475 489 160 200 1 112 20 290 29 0 -4368 2736 2283 1 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:53:30 0 151 -6 281 120 -7 306 475 489 160 200 1 112 20 289 29 0 -4359 2736 2276 1 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:54:30 0 150 -7 281 120 -8 305 472 489 160 200 1 112 20 290 29 0 -4350 2736 2281 1 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:55:30 0 150 -7 281 120 -8 305 469 489 160 200 1 112 20 290 29 0 -4341 2737 2280 2 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:56:30 0 150 -8 281 120 -7 305 467 489 160 200 1 112 20 290 29 0 -4332 2737 2272 2 301 286 302 602 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:57:30 0 150 -8 281 119 -8 305 466 489 160 200 1 112 20 289 29 0 -4323 2736 2278 2 301 286 302 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:58:30 0 150 -8 281 118 -8 305 466 489 160 200 1 112 20 290 29 0 -4314 2736 2272 2 301 286 302 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 20:59:30 0 151 -8 281 120 -8 305 466 489 160 200 1 112 20 290 29 0 -4305 2737 2303 2 301 286 302 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:00:30 0 151 -8 281 120 -8 305 466 489 160 200 1 112 20 289 29 0 -4296 2737 2288 2 301 286 302 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:01:30 0 151 -7 281 120 -7 305 465 489 160 200 1 112 20 290 29 0 -4287 2739 2293 2 301 286 302 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:02:30 0 151 -8 281 120 -8 305 465 489 160 200 1 112 20 290 29 0 -4278 2740 2298 2 301 286 302 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:03:30 0 151 -8 281 120 -8 305 465 489 160 200 1 112 20 290 29 0 -4269 2742 2271 1 301 286 302 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:04:30 0 150 -7 280 120 -8 305 465 489 160 200 1 112 20 289 29 0 -4261 2740 2288 2 301 286 302 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:05:30 0 150 -8 280 120 -7 305 464 489 160 200 1 112 20 290 29 0 -4253 2741 2298 1 301 286 301 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:06:30 0 150 -8 280 120 -8 305 464 489 160 200 1 112 20 290 29 0 -4245 2740 2284 1 300 286 301 601 285 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:07:36 0 151 -8 281 120 -8 305 464 489 160 200 1 112 20 290 29 0 -4237 2741 2285 1 300 286 301 601 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:08:33 0 151 -8 281 120 -8 305 464 488 160 200 1 112 20 289 29 0 -4229 2742 2288 1 300 286 301 601 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:09:33 0 151 -8 280 120 -7 305 464 488 160 200 1 112 20 291 29 0 -4221 2742 2293 1 301 286 301 601 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:10:32 0 151 -7 280 120 -8 305 463 488 160 200 1 112 20 290 29 0 -4213 2743 2277 1 300 286 301 601 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:11:32 0 151 -6 281 120 -7 305 463 488 160 200 1 112 20 289 29 0 -4205 2741 2280 1 300 285 301 601 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:12:32 0 151 -6 280 120 -8 305 463 488 160 200 1 112 20 290 29 0 -4197 2742 2286 1 300 286 301 601 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:13:32 0 150 -7 280 120 -8 305 463 488 160 200 1 112 20 290 29 0 -4189 2742 2290 1 300 285 301 601 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:14:32 0 150 -8 280 120 -8 305 462 488 160 200 1 112 20 290 29 0 -4181 2743 2284 1 300 285 301 601 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:15:32 0 150 -8 280 120 -8 305 462 488 160 200 1 112 20 290 29 0 -4173 2744 2302 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:16:32 0 151 -8 280 120 -8 305 462 488 160 200 1 112 20 290 29 0 -4165 2746 2293 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:17:32 0 150 -8 280 120 -8 305 462 488 160 200 1 112 20 290 29 0 -4157 2746 2295 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:18:32 0 150 -8 280 118 -8 304 461 488 160 200 1 112 20 290 29 0 -4149 2745 2275 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:19:32 0 150 -8 280 120 -8 304 461 488 160 200 1 112 20 290 29 0 -4141 2744 2279 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:20:32 0 151 -8 280 120 -8 304 461 488 160 200 1 112 20 291 29 0 -4133 2744 2284 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:21:32 0 150 -8 280 120 -8 304 461 488 160 200 1 112 20 289 29 0 -4125 2743 2284 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:22:38 0 150 -8 280 120 -8 304 460 488 160 200 1 112 20 290 29 0 -4117 2742 2285 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:23:35 0 150 -8 280 120 -9 304 460 488 160 200 1 112 20 290 29 0 -4109 2742 2283 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:24:35 0 150 -8 280 120 -8 304 460 488 160 200 1 112 20 289 29 0 -4101 2742 2286 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:25:35 0 150 -8 280 120 -9 304 460 488 160 200 1 112 20 290 29 0 -4093 2742 2280 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:26:35 0 150 -8 280 120 -9 304 459 488 160 200 1 112 20 291 29 0 -4085 2741 2293 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:27:35 0 150 -8 280 120 -9 304 459 488 160 200 1 112 20 291 29 0 -4077 2741 2283 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:28:35 0 150 -8 280 120 -8 304 459 488 160 200 1 112 20 290 29 0 -4070 2742 2298 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:29:35 0 150 -8 279 119 -8 304 459 488 160 200 1 112 20 291 29 0 -4063 2741 2275 1 300 285 301 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:30:35 0 150 -8 280 120 -9 304 458 487 160 200 1 112 20 289 29 0 -4056 2740 2282 1 300 285 300 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:31:35 0 150 -7 280 120 -8 304 458 487 160 200 1 112 20 290 29 0 -4049 2742 2308 1 300 285 300 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:32:35 0 151 -6 280 120 -8 304 458 486 160 200 1 112 20 290 29 0 -4042 2742 2274 1 300 285 300 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:33:35 0 151 -6 280 120 -9 304 458 486 160 200 1 112 20 290 29 0 -4035 2743 2285 1 300 285 301 600 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:34:35 0 150 -6 279 120 -9 304 457 486 160 200 1 112 20 290 29 0 -4028 2742 2273 1 299 284 300 600 284 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:35:35 0 150 -6 280 120 -8 304 457 486 160 200 1 112 20 290 29 0 -4021 2741 2282 1 300 285 300 600 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:36:35 0 150 -6 279 120 -9 304 457 486 160 200 1 112 20 290 29 0 -4014 2741 2285 1 299 284 300 600 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:37:31 0 150 -6 279 120 -9 304 457 486 160 200 1 112 20 290 29 0 -4007 2741 2293 1 299 284 300 600 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:38:31 0 150 -6 279 118 -8 304 456 486 160 200 1 112 20 290 29 0 -4001 2742 2293 1 299 284 300 600 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:39:31 0 150 -6 279 118 -9 304 456 486 160 200 1 112 20 300 30 0 -3995 2743 2286 0 299 284 301 600 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:40:31 0 150 -6 280 118 -9 304 456 486 160 200 1 112 20 299 30 0 -3988 2742 2282 -1 299 284 301 600 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:41:31 0 150 -7 280 120 -9 304 456 486 160 200 1 112 20 300 30 0 -3981 2741 2277 -3 300 284 300 601 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:42:31 0 150 -7 280 118 -9 304 456 486 160 200 1 112 20 300 30 0 -3974 2741 2296 -3 300 284 301 601 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:43:31 0 150 -6 280 118 -9 304 455 486 160 200 1 112 20 300 30 0 -3967 2743 2288 -3 300 284 301 601 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:44:31 0 150 -6 280 120 -9 304 455 486 160 200 1 112 20 300 30 0 -3961 2743 2290 -3 300 284 300 601 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:45:31 0 150 -6 279 118 -9 304 455 486 160 200 1 112 20 301 30 0 -3955 2742 2283 -3 300 284 300 601 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:46:31 0 150 -6 280 118 -9 304 455 486 160 200 1 112 20 299 30 0 -3949 2742 2285 -3 300 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:47:31 0 150 -6 279 118 -8 304 454 486 160 200 1 112 20 300 30 0 -3943 2742 2287 -3 299 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:48:31 0 150 -6 280 119 -9 304 454 486 160 200 1 112 20 300 30 0 -3937 2743 2288 -3 299 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:49:31 0 151 -6 280 120 -9 304 454 486 160 200 1 112 20 300 30 0 -3931 2744 2288 -3 300 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:50:31 0 150 -6 279 120 -9 304 454 486 160 200 1 112 20 300 30 0 -3925 2743 2276 -3 300 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:51:31 0 150 -6 280 118 -8 304 453 486 160 200 1 112 20 300 30 0 -3919 2743 2290 -3 299 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:52:33 0 150 -6 279 120 -9 304 453 485 160 200 1 112 20 300 30 0 -3913 2743 2282 -3 299 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:53:33 0 151 -6 279 120 -8 304 453 485 160 200 1 112 20 300 30 0 -3907 2743 2292 -3 299 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:54:33 0 150 -6 279 120 -9 304 453 485 160 200 1 112 20 301 30 0 -3901 2744 2291 -3 299 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:55:33 0 151 -6 280 120 -9 304 452 485 160 200 1 112 20 300 30 0 -3895 2743 2277 -3 299 284 300 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:56:33 0 151 -6 279 120 -8 304 452 485 160 200 1 112 20 309 31 0 -3889 2742 2290 -4 299 284 301 602 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:57:33 0 151 -6 279 120 -8 304 452 485 160 200 1 112 20 310 31 0 -3882 2744 2289 -5 299 284 300 603 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:58:33 0 151 -6 280 120 -8 304 452 485 160 200 1 112 20 310 31 0 -3876 2744 2283 -6 300 284 300 603 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 21:59:33 0 151 -6 280 120 -8 304 452 485 160 200 1 112 20 309 31 0 -3870 2744 2285 -6 300 284 300 603 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:00:33 0 151 -6 280 120 -8 304 451 485 160 200 1 112 20 310 31 0 -3864 2745 2302 -6 299 284 300 603 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:01:33 0 151 -6 280 120 -8 304 451 485 160 200 1 112 20 311 31 0 -3858 2745 2287 -6 300 284 300 603 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:02:33 0 151 -6 280 120 -8 304 451 485 160 200 1 112 20 311 31 0 -3852 2743 2264 -6 300 284 300 605 283 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:03:33 0 151 -6 280 120 -8 304 451 485 160 200 1 112 20 309 31 0 -3846 2741 2271 -6 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:04:33 0 151 -6 280 120 -8 304 450 485 160 200 1 112 20 310 31 0 -3840 2739 2275 -6 299 284 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:05:33 0 151 -6 280 120 -8 304 450 485 160 200 1 112 20 310 31 0 -3834 2739 2275 -6 299 284 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:06:33 0 151 -6 279 120 -8 304 450 485 160 200 1 112 20 310 31 0 -3828 2739 2291 -6 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:07:27 0 151 -5 279 120 -8 304 450 485 160 200 1 112 20 310 31 0 -3822 2739 2262 -7 299 284 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:08:24 0 150 -5 279 120 -8 304 450 485 160 200 1 112 20 309 31 0 -3816 2735 2263 -7 299 284 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:09:24 0 150 -5 279 120 -8 304 449 485 160 200 1 112 20 311 31 0 -3810 2734 2280 -7 299 284 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:10:24 0 151 -5 279 120 -8 304 449 485 160 200 1 112 20 310 31 0 -3804 2734 2284 -7 299 284 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:11:24 0 151 -5 279 121 -8 304 449 485 160 200 1 112 20 311 31 0 -3798 2733 2269 -8 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:12:24 0 151 -5 279 121 -8 304 449 485 160 200 1 112 20 310 31 0 -3792 2731 2262 -8 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:13:24 0 151 -5 279 120 -8 304 448 485 160 200 1 112 20 310 31 0 -3786 2730 2275 -7 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:14:24 0 151 -5 279 121 -8 304 448 485 160 200 1 112 20 310 31 0 -3780 2730 2267 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:15:24 0 151 -5 279 121 -8 304 448 484 160 200 1 112 20 309 31 0 -3774 2729 2270 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:16:24 0 151 -5 279 121 -7 304 448 485 160 200 1 112 20 309 31 0 -3768 2731 2282 -8 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:17:24 0 151 -5 279 121 -8 303 448 484 160 200 1 112 20 310 31 0 -3762 2731 2275 -8 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:18:24 0 151 -5 280 121 -8 303 447 484 160 200 1 112 20 309 31 0 -3756 2730 2282 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:19:24 0 151 -4 279 121 -7 303 447 484 160 200 1 112 20 309 31 0 -3750 2732 2281 -8 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:20:24 0 152 -3 279 121 -7 303 447 484 160 200 1 112 20 310 31 0 -3744 2730 2265 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:21:24 0 152 -3 279 122 -7 303 447 484 160 200 1 112 20 310 31 0 -3738 2730 2278 -7 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:22:27 0 152 -3 279 122 -7 303 447 484 160 200 1 112 20 310 31 0 -3732 2730 2275 -7 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:23:24 0 152 -3 279 122 -7 303 446 484 160 200 1 112 20 310 31 0 -3726 2731 2289 -7 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:24:24 0 152 -1 279 122 -6 303 446 484 160 200 1 112 20 310 31 0 -3720 2732 2282 -7 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:25:24 0 153 -1 279 122 -7 303 446 484 160 200 1 112 20 310 31 0 -3714 2734 2278 -8 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:26:24 0 153 -1 279 123 -6 303 446 484 160 200 1 112 20 310 31 0 -3708 2733 2275 -8 299 283 300 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:27:24 0 153 -1 279 123 -6 303 446 484 160 200 1 112 20 319 32 0 -3702 2733 2275 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:28:24 0 153 1 279 123 -6 304 445 484 160 200 1 112 20 321 32 0 -3696 2733 2287 -10 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:29:24 0 153 1 280 123 -6 303 445 484 160 200 1 112 20 310 31 0 -3689 2736 2299 -9 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:30:24 0 153 1 279 123 -6 303 445 484 160 200 1 112 20 311 31 0 -3682 2736 2285 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:31:24 0 154 1 280 123 -5 303 445 484 160 200 1 112 20 310 31 0 -3675 2737 2280 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:32:24 0 153 1 279 123 -5 303 445 484 160 200 1 112 20 310 31 0 -3668 2738 2288 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:33:24 0 155 1 280 123 -5 303 444 484 160 200 1 112 20 310 31 0 -3661 2738 2283 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:34:24 0 154 1 279 125 -5 303 444 484 160 200 1 112 20 309 31 0 -3654 2738 2286 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:35:24 0 154 2 279 125 -5 303 444 484 160 200 1 112 20 310 31 0 -3647 2738 2281 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:36:24 0 154 2 279 125 -5 303 444 484 160 200 1 112 20 309 31 0 -3640 2738 2282 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:37:26 0 154 2 279 125 -4 303 444 484 160 200 1 112 20 310 31 0 -3633 2738 2279 -7 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:38:26 0 155 2 279 125 -4 303 444 484 160 200 1 112 20 310 31 0 -3626 2738 2285 -8 299 283 300 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:39:26 0 155 2 279 125 -4 303 443 484 160 200 1 112 20 310 31 0 -3619 2738 2282 -8 299 283 299 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:40:26 0 155 2 279 125 -4 303 443 484 160 200 1 112 20 310 31 0 -3613 2736 2274 -8 299 283 299 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:41:26 0 155 3 279 125 -4 303 443 483 160 200 1 112 20 311 31 0 -3606 2736 2277 -8 299 283 299 606 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:42:26 0 155 4 279 125 -4 303 443 483 160 200 1 112 20 309 31 0 -3600 2735 2277 -8 299 283 299 605 282 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:43:26 0 155 4 280 125 -3 303 443 483 160 200 1 112 20 310 31 0 -3594 2737 2287 -8 299 283 300 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:44:26 0 155 4 279 125 -3 303 443 483 160 200 1 112 20 309 31 0 -3588 2737 2282 -8 299 283 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:45:26 0 155 4 279 125 -3 303 442 483 160 200 1 112 20 310 31 0 -3582 2738 2285 -8 299 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:46:26 0 155 4 279 125 -4 303 442 483 160 200 1 112 20 309 31 0 -3576 2739 2289 -8 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:47:26 0 155 4 279 126 -4 303 442 483 160 200 1 112 20 310 31 0 -3570 2738 2280 -8 298 283 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:48:26 0 155 4 279 126 -3 303 442 483 160 200 1 112 20 310 31 0 -3564 2739 2283 -8 299 283 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:49:26 0 156 4 279 126 -3 303 442 483 160 200 1 112 20 309 31 0 -3558 2738 2275 -8 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:50:26 0 155 4 279 126 -3 303 441 483 160 200 1 112 20 310 31 0 -3552 2738 2275 -8 298 283 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:51:26 0 156 4 279 126 -4 303 441 483 160 200 1 112 20 310 31 0 -3546 2736 2272 -8 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:52:28 0 156 4 279 126 -3 303 441 483 160 200 1 112 20 309 31 0 -3540 2737 2283 -8 299 283 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:53:28 0 156 6 279 126 -3 303 441 483 160 200 1 112 20 309 31 0 -3534 2738 2286 -8 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:54:28 0 156 5 279 126 -3 303 441 483 160 200 1 112 20 310 31 0 -3528 2738 2283 -8 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:55:28 0 156 5 279 126 -3 303 441 483 160 200 1 112 20 311 31 0 -3522 2738 2274 -8 298 283 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:56:28 0 156 6 279 126 -3 303 440 483 160 200 1 112 20 311 31 0 -3516 2738 2282 -7 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:57:28 0 156 6 279 126 -2 303 440 483 160 200 1 112 20 310 31 0 -3510 2737 2277 -6 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:58:28 0 156 6 279 126 -3 303 440 483 160 200 1 112 20 309 31 0 -3504 2736 2282 -6 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 22:59:28 0 156 6 279 126 -2 303 440 483 160 200 1 112 20 309 31 0 -3498 2736 2287 -6 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:00:28 0 156 6 279 126 -2 303 440 483 160 200 1 112 20 310 31 0 -3492 2738 2288 -6 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:01:28 0 156 6 279 126 -3 302 440 482 160 200 1 112 20 310 31 0 -3486 2738 2288 -6 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:02:28 0 156 6 279 126 -2 302 440 483 160 200 1 112 20 310 31 0 -3480 2741 2292 -6 298 282 299 605 281 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:03:28 0 172 6 282 155 -2 343 439 482 160 200 100 112 20 410 41 0 -3480 2741 2295 -7 293 278 410 627 397 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:04:28 0 192 6 275 188 -2 413 436 482 160 200 100 112 20 411 41 0 -3480 2743 2305 -14 287 282 438 653 422 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:05:28 0 191 6 271 186 -2 436 434 482 160 200 74 112 20 410 41 0 -3487 2747 2312 -12 284 282 449 675 429 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:06:28 0 185 4 268 177 -2 449 435 482 160 200 49 112 20 409 41 0 -3496 2748 2300 -8 282 284 460 696 431 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:07:33 0 178 4 267 166 -3 459 437 482 160 200 33 112 20 409 41 0 -3506 2749 2297 -6 282 283 474 716 433 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:08:30 0 175 4 267 164 -2 471 440 482 160 200 24 112 20 410 41 0 -3516 2748 2287 -5 281 282 490 732 435 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:09:30 0 175 4 266 164 -3 484 442 482 160 200 21 112 20 410 41 0 -3527 2749 2286 -5 281 281 500 748 438 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:10:30 0 174 4 265 163 -2 494 445 482 160 200 20 112 20 409 41 0 -3539 2748 2280 -5 280 280 507 763 442 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:11:30 0 173 2 264 163 -3 501 447 483 160 200 21 112 20 409 41 0 -3551 2748 2290 -5 279 280 511 776 445 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:12:30 0 172 2 264 161 -3 505 450 485 160 200 22 112 20 409 41 0 -3564 2749 2301 -5 279 279 514 787 449 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:13:30 0 172 2 263 161 -3 508 453 486 160 200 24 112 20 411 41 0 -3578 2748 2272 -5 278 279 515 797 453 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:14:30 0 172 2 263 161 -3 510 456 486 160 200 26 112 20 411 41 0 -3592 2747 2286 -4 278 279 516 807 457 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:15:30 0 172 2 263 160 -3 511 459 488 160 200 28 112 20 409 41 0 -3606 2747 2285 -4 278 279 516 816 461 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:16:30 0 172 2 262 160 -4 511 462 488 160 200 31 112 20 410 41 0 -3621 2746 2284 -3 277 278 516 823 465 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:17:30 0 171 2 262 160 -3 513 465 488 160 200 34 112 20 408 41 0 -3636 2745 2272 -3 277 278 517 831 469 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:18:30 0 171 2 262 160 -4 513 468 488 160 200 38 112 20 411 41 0 -3651 2743 2286 -3 277 278 518 837 473 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:19:30 0 171 2 261 160 -4 514 472 489 160 200 43 112 20 410 41 0 -3667 2743 2280 -3 276 277 517 843 477 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:20:30 0 169 2 261 159 -4 514 475 489 160 200 48 112 20 410 41 0 -3683 2742 2280 -3 276 277 518 849 481 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:21:30 0 169 2 261 159 -5 515 478 489 160 200 54 112 20 411 41 0 -3700 2740 2272 -2 276 277 518 855 485 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:22:36 0 169 2 261 159 -4 515 481 490 160 200 62 112 20 410 41 0 -3717 2741 2287 -1 276 277 518 861 490 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:23:33 0 168 2 260 158 -4 515 483 491 160 200 72 112 20 409 41 0 -3733 2740 2278 -1 275 277 519 866 493 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:24:32 0 169 2 260 159 -5 516 485 491 160 200 83 112 20 409 41 0 -3750 2740 2280 -1 275 276 519 870 497 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:25:32 0 169 1 260 159 -5 516 488 492 160 200 96 112 20 410 41 0 -3767 2739 2282 -1 275 276 519 875 500 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:26:32 0 168 1 259 158 -5 517 490 494 160 200 100 112 20 330 33 0 -3785 2737 2277 0 275 276 514 878 472 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:27:32 0 173 1 291 158 -5 361 492 495 160 200 100 112 20 310 31 0 -3785 2738 2273 -1 305 276 292 839 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:28:32 0 186 1 286 176 -4 308 493 495 160 200 90 112 20 311 31 0 -3785 2736 2274 0 297 277 291 811 277 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:29:32 0 177 1 278 159 -4 300 493 495 160 200 68 112 20 309 31 0 -3784 2737 2284 -1 294 277 293 790 277 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:30:32 0 168 1 276 146 -4 298 494 495 160 200 51 112 20 310 31 0 -3783 2735 2268 -5 293 277 293 771 276 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:31:32 0 161 1 274 138 -4 299 494 494 160 200 39 112 20 310 31 0 -3781 2735 2280 -3 293 278 295 754 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:32:32 0 157 1 274 133 -4 300 494 494 160 200 31 112 20 310 31 0 -3779 2735 2279 -4 294 279 296 738 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:33:32 0 155 1 275 129 -5 301 494 494 160 200 25 112 20 310 31 0 -3775 2734 2266 -6 294 279 296 723 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:34:32 0 155 1 276 128 -5 301 494 494 160 200 20 112 20 309 31 0 -3771 2733 2275 -6 295 279 296 711 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:35:32 0 155 1 276 127 -5 301 494 493 160 200 16 112 20 321 32 0 -3767 2732 2276 -6 295 279 297 699 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:36:32 0 155 1 276 127 -5 301 494 493 160 200 13 112 20 319 32 0 -3762 2733 2275 -8 295 278 296 689 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:37:34 0 155 1 277 127 -5 301 494 493 160 200 11 112 20 320 32 0 -3757 2733 2279 -9 296 278 297 680 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:38:34 0 156 1 277 127 -5 301 494 493 160 200 9 112 20 320 32 0 -3752 2733 2274 -10 296 279 297 672 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:39:34 0 155 1 277 127 -5 301 494 493 160 200 8 112 20 320 32 0 -3747 2732 2267 -10 296 279 297 665 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:40:34 0 155 1 277 126 -5 301 494 493 160 200 6 112 20 319 32 0 -3742 2732 2280 -10 296 279 297 659 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:41:34 0 155 1 277 126 -5 301 494 493 160 200 5 112 20 320 32 0 -3737 2733 2278 -10 296 279 297 653 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:42:34 0 155 1 277 126 -5 301 494 493 160 200 4 112 20 320 32 0 -3732 2735 2280 -10 296 279 297 648 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:43:34 0 155 1 277 126 -4 301 493 493 160 200 3 112 20 320 32 0 -3727 2734 2284 -10 296 279 297 643 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:44:34 0 155 1 277 126 -4 301 493 493 160 200 2 112 20 320 32 0 -3722 2735 2282 -10 296 279 297 640 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:45:34 0 155 2 277 126 -4 301 493 493 160 200 2 112 20 330 33 0 -3718 2736 2288 -11 296 279 297 636 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:46:34 0 155 2 277 126 -4 301 493 492 160 200 1 112 20 330 33 0 -3714 2736 2284 -12 296 279 297 633 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:47:34 0 155 2 277 126 -4 301 493 492 160 200 1 112 20 330 33 0 -3710 2736 2275 -13 296 279 297 631 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:48:34 0 155 1 277 126 -4 301 493 492 160 200 1 112 20 330 33 0 -3706 2735 2274 -13 296 279 297 628 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:49:34 0 155 2 277 126 -4 301 493 492 160 200 1 112 20 331 33 0 -3702 2732 2265 -13 296 279 297 626 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:50:34 0 155 1 277 126 -4 301 493 492 160 200 1 112 20 330 33 0 -3698 2731 2261 -13 296 279 297 624 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:51:34 0 155 1 277 126 -4 301 493 492 160 200 1 112 20 330 33 0 -3694 2730 2268 -13 296 279 297 622 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:52:37 0 153 1 277 126 -5 301 493 492 160 200 1 112 20 340 34 0 -3689 2730 2281 -14 296 279 298 621 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:53:37 0 153 1 277 125 -5 301 493 492 160 200 1 112 20 340 34 0 -3684 2730 2276 -15 297 279 297 619 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:54:36 0 155 1 277 126 -4 302 493 492 160 200 1 112 20 341 34 0 -3678 2730 2272 -17 297 279 297 619 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:55:36 0 154 1 277 126 -4 301 493 492 160 200 1 112 20 340 34 0 -3673 2731 2274 -17 297 279 298 618 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:56:36 0 153 1 277 126 -5 301 493 492 160 200 1 112 20 340 34 0 -3667 2731 2278 -17 297 279 298 617 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:57:36 0 154 1 278 126 -5 301 493 492 160 200 1 112 20 340 34 0 -3662 2731 2277 -17 297 279 297 617 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:58:36 0 154 1 278 125 -5 301 493 492 160 200 1 112 20 341 34 0 -3656 2730 2280 -17 297 279 297 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-03 23:59:36 0 155 1 278 126 -5 301 493 492 160 200 1 112 20 339 34 0 -3651 2732 2284 -17 297 279 297 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:00:36 0 155 1 278 126 -5 301 493 492 160 200 1 112 20 340 34 0 -3646 2732 2282 -17 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:01:36 0 155 1 278 126 -5 301 493 492 160 200 1 112 20 340 34 0 -3641 2732 2283 -17 297 279 297 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:02:36 0 155 1 278 126 -5 301 492 492 160 200 1 112 20 340 34 0 -3636 2734 2289 -17 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:03:36 0 155 1 278 126 -5 301 492 492 160 200 1 112 20 340 34 0 -3630 2735 2283 -17 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:04:36 0 156 1 278 126 -5 301 492 492 160 200 1 112 20 340 34 0 -3624 2737 2277 -17 297 279 297 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:05:36 0 155 1 278 126 -4 301 492 492 160 200 1 112 20 339 34 0 -3618 2736 2291 -17 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:06:36 0 155 1 278 126 -4 301 492 492 160 200 1 112 20 339 34 0 -3613 2737 2282 -17 297 279 297 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:07:42 0 155 1 278 126 -4 301 492 492 160 200 1 112 20 340 34 0 -3609 2736 2268 -17 297 279 297 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:08:39 0 155 1 278 126 -4 301 492 492 160 200 1 112 20 340 34 0 -3605 2735 2271 -17 297 279 297 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:09:39 0 156 2 278 126 -5 301 492 492 160 200 1 112 20 340 34 0 -3601 2735 2283 -17 297 279 297 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:10:39 0 155 2 277 127 -4 301 492 492 160 200 1 112 20 350 35 0 -3597 2734 2279 -17 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:11:39 0 156 2 278 127 -4 302 492 492 160 200 1 112 20 349 35 0 -3592 2735 2282 -18 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:12:39 0 156 2 278 127 -3 302 492 492 160 200 1 112 20 350 35 0 -3587 2733 2265 -19 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:13:39 0 156 2 278 127 -4 302 492 492 160 200 1 112 20 350 35 0 -3582 2733 2283 -19 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:14:39 0 156 2 278 127 -4 302 492 492 160 200 1 112 20 350 35 0 -3577 2732 2267 -19 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:15:39 0 156 2 278 127 -3 302 492 492 160 200 1 112 20 350 35 0 -3572 2732 2276 -20 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:16:39 0 156 2 278 127 -3 302 492 492 160 200 1 112 20 349 35 0 -3567 2732 2285 -19 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:17:39 0 156 1 278 127 -4 302 491 492 160 200 1 112 20 350 35 0 -3562 2732 2276 -20 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:18:39 0 156 2 278 127 -3 302 491 492 160 200 1 112 20 350 35 0 -3557 2733 2275 -20 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:19:39 0 156 2 278 127 -3 302 491 491 160 200 1 112 20 350 35 0 -3552 2733 2282 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:20:39 0 156 1 278 127 -3 302 491 491 160 200 1 112 20 350 35 0 -3547 2733 2266 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:21:39 0 156 1 278 127 -4 302 491 491 160 200 1 112 20 350 35 0 -3542 2731 2270 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:22:44 0 156 2 278 127 -3 302 491 491 160 200 1 112 20 350 35 0 -3537 2730 2276 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:23:41 0 156 2 278 127 -4 301 491 491 160 200 1 112 20 349 35 0 -3532 2730 2268 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:24:41 0 156 2 278 127 -3 302 491 491 160 200 1 112 20 349 35 0 -3527 2729 2277 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:25:41 0 156 2 278 127 -3 301 491 491 160 200 1 112 20 351 35 0 -3522 2729 2269 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:26:41 0 156 1 278 127 -3 301 491 491 160 200 1 112 20 350 35 0 -3517 2730 2301 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:27:41 0 156 1 278 126 -4 301 491 491 160 200 1 112 20 350 35 0 -3512 2731 2276 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:28:41 0 156 1 278 126 -3 302 491 491 160 200 1 112 20 350 35 0 -3507 2732 2280 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:29:41 0 156 1 278 126 -3 301 491 491 160 200 1 112 20 350 35 0 -3502 2733 2275 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:30:41 0 155 1 278 126 -3 301 491 491 160 200 1 112 20 350 35 0 -3497 2734 2284 -21 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:31:41 0 155 1 278 126 -3 301 490 491 160 200 1 112 20 350 35 0 -3492 2734 2273 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:32:41 0 155 1 278 126 -3 301 490 491 160 200 1 112 20 350 35 0 -3488 2735 2297 -21 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:33:41 0 155 1 278 126 -4 301 490 491 160 200 1 112 20 350 35 0 -3483 2736 2273 -21 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:34:41 0 155 1 278 126 -3 301 490 491 160 200 1 112 20 351 35 0 -3478 2734 2270 -21 297 279 298 613 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:35:41 0 155 1 278 126 -3 301 490 491 160 200 1 112 20 350 35 0 -3473 2733 2278 -21 297 279 297 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:36:41 0 155 1 278 126 -3 301 490 491 160 200 1 112 20 350 35 0 -3468 2733 2283 -21 297 279 297 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:37:43 0 155 2 278 126 -3 301 490 491 160 200 1 112 20 350 35 0 -3464 2734 2284 -21 297 279 297 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:38:43 0 156 2 278 127 -4 301 490 491 160 200 1 112 20 359 36 0 -3459 2734 2265 -21 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:39:43 0 156 2 278 127 -3 302 490 491 160 200 1 112 20 359 36 0 -3454 2732 2266 -23 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:40:43 0 156 2 278 127 -4 302 490 491 160 200 1 112 20 359 36 0 -3449 2732 2281 -23 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:41:43 0 156 2 278 127 -3 302 490 491 160 200 1 112 20 360 36 0 -3444 2731 2268 -23 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:42:43 0 156 2 278 127 -3 302 490 490 160 200 1 112 20 360 36 0 -3439 2729 2257 -24 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:43:43 0 156 2 278 127 -3 302 489 490 160 200 1 112 20 361 36 0 -3434 2727 2272 -24 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:44:43 0 156 2 278 127 -3 302 489 490 160 200 1 112 20 361 36 0 -3429 2727 2277 -24 297 279 298 614 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:45:43 0 156 2 278 127 -3 302 489 490 160 200 1 112 20 359 36 0 -3424 2728 2280 -24 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:46:43 0 156 2 278 127 -3 302 489 490 160 200 1 112 20 361 36 0 -3419 2729 2270 -23 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:47:43 0 156 2 278 127 -3 302 489 490 160 200 1 112 20 360 36 0 -3414 2728 2268 -24 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:48:43 0 156 2 278 127 -3 301 489 490 160 200 1 112 20 360 36 0 -3409 2728 2285 -24 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:49:43 0 156 2 278 127 -2 302 489 490 160 200 1 112 20 360 36 0 -3404 2728 2268 -24 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:50:43 0 156 2 278 127 -2 302 489 490 160 200 1 112 20 360 36 0 -3399 2729 2288 -24 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:51:43 0 156 2 278 127 -2 301 489 490 160 200 1 112 20 361 36 0 -3394 2731 2280 -24 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:51:46 0 156 2 278 127 -2 301 489 490 160 200 1 112 20 360 36 0 -3389 2731 2293 -24 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:52:46 0 156 2 278 127 -2 302 489 490 160 200 1 112 20 361 36 0 -3384 2734 2281 -23 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:53:46 0 156 4 278 127 -2 301 489 490 160 200 1 112 20 360 36 0 -3379 2733 2266 -24 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:54:46 0 156 4 278 127 -2 302 489 490 160 200 1 112 20 360 36 0 -3374 2732 2276 -23 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:55:46 0 156 3 278 127 -2 301 488 490 160 200 1 112 20 361 36 0 -3369 2732 2279 -23 297 279 298 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:56:46 0 156 3 278 127 -2 301 488 490 160 200 1 112 20 361 36 0 -3363 2732 2265 -24 297 279 298 616 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:57:46 0 156 2 278 127 -2 301 488 490 160 200 1 112 20 349 35 0 -3357 2731 2278 -23 297 279 297 616 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:58:45 0 156 2 278 127 -2 301 488 490 160 200 1 112 20 349 35 0 -3352 2731 2279 -23 297 279 297 616 278 -32768 -32768 -32768 90 3 0 0 2019-01-04 00:59:45 0 156 2 278 127 -2 301 488 490 160 200 1 112 20 350 35 0 -3347 2731 2263 -21 297 279 297 616 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:00:45 0 156 2 277 127 -2 301 488 490 160 200 1 112 20 349 35 0 -3342 2730 2275 -21 297 279 297 616 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:01:45 0 156 2 278 127 -2 301 488 490 160 200 1 112 20 350 35 0 -3337 2731 2283 -21 297 278 297 616 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:02:45 0 156 2 277 127 -2 301 488 490 160 200 1 112 20 349 35 0 -3332 2730 2269 -21 297 278 297 616 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:03:45 0 156 2 278 127 -2 301 488 490 160 200 1 112 20 350 35 0 -3327 2730 2281 -21 296 279 297 616 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:04:45 0 156 4 277 127 -1 301 488 490 160 200 1 112 20 350 35 0 -3322 2730 2274 -21 296 278 297 615 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:05:45 0 156 4 278 127 -2 301 488 489 160 200 1 112 20 350 35 0 -3317 2730 2280 -21 296 279 297 614 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:06:48 0 156 3 278 127 -2 301 488 489 160 200 1 112 20 349 35 0 -3312 2730 2275 -21 296 278 297 614 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:07:48 0 155 2 277 127 -2 301 486 489 160 200 1 112 20 350 35 0 -3307 2730 2278 -21 296 278 297 614 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:08:48 0 156 2 277 127 -2 301 486 489 160 200 1 112 20 349 35 0 -3302 2729 2266 -21 296 278 297 614 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:09:48 0 156 2 277 127 -2 301 486 489 160 200 1 112 20 350 35 0 -3297 2728 2278 -21 296 278 297 614 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:10:48 0 155 2 277 127 -3 301 486 489 160 200 1 112 20 350 35 0 -3292 2729 2275 -21 296 278 297 614 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:11:48 0 155 2 277 126 -3 301 486 489 160 200 1 112 20 351 35 0 -3287 2729 2280 -21 296 278 297 614 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:12:48 0 155 2 277 126 -3 300 486 489 160 200 1 112 20 351 35 0 -3282 2730 2263 -21 296 278 297 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:13:48 0 155 1 277 126 -3 300 486 489 160 200 1 112 20 351 35 0 -3277 2727 2269 -21 296 278 297 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:14:48 0 154 1 277 126 -3 300 486 489 160 200 1 112 20 348 35 0 -3272 2729 2285 -21 296 278 297 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:15:48 0 153 1 277 126 -3 300 486 489 160 200 1 112 20 350 35 0 -3267 2728 2268 -21 296 278 297 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:16:48 0 153 1 277 125 -3 300 486 489 160 200 1 112 20 349 35 0 -3262 2728 2275 -21 296 278 297 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:17:48 0 153 1 277 125 -3 300 486 489 160 200 1 112 20 350 35 0 -3258 2728 2272 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:18:48 0 153 1 277 125 -3 300 485 489 160 200 1 112 20 349 35 0 -3253 2729 2285 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:19:48 0 153 1 277 125 -4 300 485 489 160 200 1 112 20 350 35 0 -3249 2730 2284 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:20:48 0 153 1 277 125 -4 300 485 489 160 200 1 112 20 350 35 0 -3244 2731 2289 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:21:50 0 153 1 277 125 -3 300 485 489 160 200 1 112 20 349 35 0 -3240 2731 2273 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:22:50 0 154 1 277 125 -4 300 485 489 160 200 1 112 20 349 35 0 -3236 2730 2275 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:23:50 0 153 1 277 125 -3 300 485 489 160 200 1 112 20 349 35 0 -3232 2730 2279 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:24:50 0 153 1 277 125 -3 300 485 489 160 200 1 112 20 350 35 0 -3228 2730 2280 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:25:50 0 153 1 276 125 -3 300 485 489 160 200 1 112 20 350 35 0 -3224 2732 2286 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:26:50 0 153 -1 276 125 -3 300 485 489 160 200 1 112 20 351 35 0 -3220 2733 2293 -21 296 278 296 613 277 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:27:50 0 152 -1 276 125 -4 300 485 489 160 200 1 112 20 349 35 0 -3216 2734 2268 -21 295 278 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:28:50 0 152 -3 276 123 -4 300 485 489 160 200 1 112 20 350 35 0 -3212 2732 2264 -21 296 278 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:29:50 0 152 -1 276 124 -4 300 485 489 160 200 1 112 20 350 35 0 -3208 2732 2282 -21 295 278 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:30:50 0 152 -2 276 123 -4 300 484 489 160 200 1 112 20 350 35 0 -3204 2733 2278 -22 295 278 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:31:50 0 153 -1 276 124 -4 300 484 488 160 200 1 112 20 349 35 0 -3200 2731 2260 -21 295 278 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:32:50 0 152 -3 276 123 -5 300 484 488 160 200 1 112 20 350 35 0 -3196 2730 2273 -21 295 278 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:33:50 0 152 -3 276 123 -4 300 484 488 160 200 1 112 20 359 36 0 -3192 2730 2265 -22 295 277 297 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:34:50 0 152 -3 276 123 -4 300 484 488 160 200 1 112 20 360 36 0 -3188 2729 2276 -24 295 277 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:35:50 0 152 -3 276 123 -4 300 484 488 160 200 1 112 20 361 36 0 -3184 2729 2281 -25 296 278 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:36:52 0 152 -3 276 123 -5 300 484 488 160 200 1 112 20 360 36 0 -3180 2729 2278 -25 296 277 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:37:52 0 152 -3 277 123 -5 300 484 488 160 200 1 112 20 361 36 0 -3176 2730 2272 -25 296 277 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:38:52 0 152 -3 276 123 -5 300 484 488 160 200 1 112 20 360 36 0 -3173 2730 2276 -25 296 277 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:39:52 0 152 -3 276 123 -5 300 484 488 160 200 1 112 20 360 36 0 -3170 2731 2282 -25 296 277 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:40:52 0 153 -2 277 125 -4 300 484 488 160 200 1 112 20 359 36 0 -3167 2730 2282 -25 295 277 296 613 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:41:52 0 153 -1 277 125 -4 300 484 488 160 200 1 112 20 360 36 0 -3164 2731 2275 -25 296 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:42:52 0 153 -1 276 125 -4 300 483 488 160 200 1 112 20 361 36 0 -3161 2731 2267 -25 296 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:43:52 0 153 -1 277 125 -5 300 483 488 160 200 1 112 20 359 36 0 -3158 2731 2282 -25 295 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:44:52 0 153 -1 276 125 -5 300 483 488 160 200 1 112 20 359 36 0 -3155 2732 2281 -25 296 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:45:52 0 152 -1 276 125 -4 300 483 488 160 200 1 112 20 360 36 0 -3152 2731 2276 -25 296 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:46:52 0 152 -3 276 123 -5 300 483 488 160 200 1 112 20 360 36 0 -3149 2730 2272 -25 296 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:47:52 0 152 -3 276 123 -5 300 483 488 160 200 1 112 20 360 36 0 -3146 2732 2289 -25 295 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:48:52 0 152 -2 276 123 -5 300 483 488 160 200 1 112 20 360 36 0 -3143 2732 2281 -25 295 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:49:52 0 152 -2 276 123 -4 300 483 488 160 200 1 112 20 360 36 0 -3140 2731 2274 -25 295 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:50:52 0 152 -1 276 124 -5 300 483 488 160 200 1 112 20 359 36 0 -3137 2731 2272 -25 295 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:51:54 0 152 -1 276 124 -5 300 483 488 160 200 1 112 20 360 36 0 -3134 2730 2283 -25 295 277 296 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:52:54 0 152 -1 276 124 -5 300 483 488 160 200 1 112 20 369 37 0 -3131 2732 2284 -25 295 277 297 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:53:54 0 152 -3 276 123 -5 300 483 488 160 200 1 112 20 369 37 0 -3127 2733 2286 -26 296 277 297 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:54:54 0 153 -1 276 123 -5 300 482 486 160 200 1 112 20 370 37 0 -3123 2732 2272 -26 296 277 297 614 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:55:54 0 153 -1 276 125 -5 300 482 486 160 200 1 112 20 370 37 0 -3119 2734 2280 -26 296 277 296 616 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:56:54 0 153 -1 277 125 -5 300 482 486 160 200 1 112 20 369 37 0 -3116 2733 2265 -26 296 277 297 616 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:57:54 0 153 -1 277 125 -5 300 482 486 160 200 1 112 20 370 37 0 -3113 2732 2284 -26 296 277 297 616 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:58:54 0 153 1 276 125 -4 300 482 486 160 200 1 112 20 369 37 0 -3109 2733 2291 -26 296 277 297 616 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 01:59:54 0 154 1 277 126 -5 300 482 486 160 200 1 112 20 371 37 0 -3105 2734 2288 -26 296 277 297 616 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:00:54 0 155 2 277 126 -5 300 482 486 160 200 1 112 20 370 37 0 -3102 2734 2283 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:01:54 0 155 2 277 126 -4 300 482 486 160 200 1 112 20 370 37 0 -3098 2734 2277 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:02:54 0 155 2 277 126 -4 300 482 486 160 200 1 112 20 370 37 0 -3095 2734 2273 -27 296 277 297 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:03:54 0 155 2 277 126 -4 300 482 486 160 200 1 112 20 370 37 0 -3091 2734 2271 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:04:54 0 155 2 277 126 -4 300 482 486 160 200 1 112 20 370 37 0 -3088 2732 2281 -28 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:05:54 0 155 2 277 126 -5 300 482 486 160 200 1 112 20 370 37 0 -3085 2733 2285 -28 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:06:57 0 155 2 277 126 -4 300 481 486 160 200 1 112 20 371 37 0 -3082 2734 2283 -27 296 277 297 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:07:57 0 155 2 277 126 -4 300 481 486 160 200 1 112 20 370 37 0 -3079 2734 2265 -27 296 277 297 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:08:57 0 155 2 277 126 -4 300 481 486 160 200 1 112 20 370 37 0 -3076 2733 2284 -28 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:09:57 0 155 2 277 126 -4 300 481 486 160 200 1 112 20 371 37 0 -3073 2735 2291 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:10:57 0 155 2 277 126 -4 300 481 486 160 200 1 112 20 370 37 0 -3070 2735 2270 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:11:57 0 155 2 277 126 -4 300 481 486 160 200 1 112 20 369 37 0 -3067 2735 2278 -27 296 277 296 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:12:57 0 155 2 277 127 -4 300 481 486 160 200 1 112 20 370 37 0 -3064 2735 2276 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:13:57 0 155 2 277 126 -4 300 481 486 160 200 1 112 20 370 37 0 -3061 2734 2277 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:14:57 0 155 2 277 127 -4 300 481 486 160 200 1 112 20 370 37 0 -3058 2734 2271 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:15:57 0 156 2 277 127 -4 300 481 486 160 200 1 112 20 371 37 0 -3055 2732 2270 -28 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:16:57 0 156 4 277 127 -4 300 481 486 160 200 1 112 20 369 37 0 -3052 2733 2285 -28 295 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:17:57 0 156 4 277 127 -4 300 481 485 160 200 1 112 20 370 37 0 -3049 2733 2282 -27 296 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:18:57 0 156 4 277 128 -3 300 480 485 160 200 1 112 20 369 37 0 -3046 2733 2274 -28 296 277 296 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:19:57 0 156 4 277 127 -3 300 480 485 160 200 1 112 20 370 37 0 -3043 2732 2278 -28 296 277 296 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:21:00 0 156 4 277 127 -3 300 480 485 160 200 1 112 20 370 37 0 -3040 2732 2276 -28 295 277 296 617 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:21:59 0 156 4 277 128 -3 300 480 485 160 200 1 112 20 379 38 0 -3037 2734 2295 -28 296 277 297 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:22:59 0 156 4 277 127 -3 300 480 485 160 200 1 112 20 380 38 0 -3033 2735 2278 -29 296 277 297 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:23:59 0 156 4 277 127 -3 300 480 485 160 200 1 112 20 370 37 0 -3029 2736 2291 -29 296 277 296 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:24:59 0 156 4 277 127 -2 300 480 485 160 200 1 112 20 380 38 0 -3026 2736 2275 -29 296 277 297 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:25:59 0 156 3 277 127 -2 300 480 485 160 200 1 112 20 381 38 0 -3022 2735 2269 -30 296 277 297 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:26:59 0 156 4 277 127 -2 300 480 485 160 200 1 112 20 369 37 0 -3018 2734 2282 -30 296 277 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:27:59 0 156 4 277 127 -2 300 480 485 160 200 1 112 20 379 38 0 -3015 2735 2285 -30 296 277 297 618 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:28:59 0 156 4 277 127 -3 300 480 485 160 200 1 112 20 379 38 0 -3011 2735 2273 -30 296 277 297 619 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:29:59 0 156 4 277 127 -2 300 480 485 160 200 1 112 20 370 37 0 -3007 2735 2287 -30 296 277 296 619 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:30:59 0 156 4 277 127 -3 300 479 485 160 200 1 112 20 380 38 0 -3004 2735 2273 -30 296 277 297 619 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:31:59 0 156 4 277 127 -2 300 479 485 160 200 1 112 20 379 38 0 -3000 2735 2281 -30 296 277 297 619 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:32:59 0 156 4 277 128 -2 300 479 485 160 200 1 112 20 370 37 0 -2996 2736 2285 -30 296 277 296 619 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:33:59 0 156 4 277 127 -2 300 479 485 160 200 1 112 20 381 38 0 -2993 2737 2279 -30 296 277 296 619 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:34:59 0 156 4 277 127 -2 300 479 485 160 200 1 112 20 369 37 0 -2988 2738 2296 -29 296 277 296 619 276 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:36:05 0 156 4 277 127 -2 300 479 485 160 200 1 112 20 370 37 0 -2984 2737 2263 -28 295 277 296 619 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:37:02 0 156 4 277 127 -2 300 479 485 160 200 1 112 20 369 37 0 -2980 2736 2279 -28 295 277 296 619 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:38:02 0 156 4 277 127 -2 300 479 485 160 200 1 112 20 370 37 0 -2976 2735 2286 -28 295 277 296 619 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:39:02 0 156 6 277 128 -2 300 479 485 160 200 1 112 20 370 37 0 -2972 2736 2280 -28 295 277 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:40:02 0 156 4 276 128 -2 300 479 485 160 200 1 112 20 370 37 0 -2968 2735 2272 -28 295 277 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:41:02 0 156 4 277 128 -2 300 479 484 160 200 1 112 20 371 37 0 -2964 2736 2297 -28 295 277 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:42:02 0 156 4 276 127 -2 300 479 484 160 200 1 112 20 370 37 0 -2960 2738 2277 -28 295 277 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:43:02 0 156 6 276 128 -2 300 478 484 160 200 1 112 20 372 37 0 -2956 2736 2277 -28 295 277 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:44:02 0 156 6 276 128 -2 300 478 484 160 200 1 112 20 370 37 0 -2952 2736 2275 -28 295 277 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:45:02 0 156 4 276 128 -2 300 478 484 160 200 1 112 20 370 37 0 -2948 2735 2277 -28 295 276 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:46:02 0 156 4 276 127 -2 299 478 484 160 200 1 112 20 370 37 0 -2944 2734 2276 -28 295 276 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:47:01 0 155 2 276 126 -2 299 478 484 160 200 1 112 20 369 37 0 -2940 2735 2290 -28 295 276 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:48:01 0 155 2 276 126 -2 299 478 484 160 200 1 112 20 370 37 0 -2936 2736 2281 -28 295 276 296 618 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:49:01 0 155 2 276 126 -3 299 478 484 160 200 1 112 20 371 37 0 -2932 2735 2267 -28 295 276 296 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:50:01 0 153 1 276 125 -2 299 478 484 160 200 1 112 20 370 37 0 -2928 2734 2284 -28 295 276 296 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:51:07 0 153 1 276 125 -3 299 478 484 160 200 1 112 20 370 37 0 -2924 2735 2297 -28 295 276 296 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:52:04 0 154 1 276 126 -3 299 478 484 160 200 1 112 20 370 37 0 -2920 2736 2284 -28 295 276 296 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:53:04 0 153 1 276 126 -3 299 478 484 160 200 1 112 20 371 37 0 -2916 2736 2281 -28 295 276 295 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:54:04 0 155 2 276 126 -3 299 478 484 160 200 1 112 20 370 37 0 -2912 2736 2269 -28 295 276 295 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:55:04 0 155 2 276 126 -3 299 477 484 160 200 1 112 20 370 37 0 -2908 2735 2279 -28 295 276 296 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:56:04 0 155 2 276 126 -3 299 477 484 160 200 1 112 20 370 37 0 -2904 2735 2282 -28 295 276 296 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:57:04 0 155 2 276 126 -3 299 477 484 160 200 1 112 20 370 37 0 -2900 2735 2280 -28 295 276 296 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:58:04 0 154 2 276 126 -3 299 477 484 160 200 1 112 20 370 37 0 -2896 2736 2288 -28 295 276 295 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 02:59:04 0 153 1 276 125 -3 299 477 484 160 200 1 112 20 370 37 0 -2893 2736 2285 -28 295 276 295 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:00:04 0 152 -1 276 123 -4 299 477 484 160 200 1 112 20 370 37 0 -2890 2736 2276 -28 295 276 295 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:01:04 0 152 -3 275 123 -4 299 477 484 160 200 1 112 20 369 37 0 -2887 2736 2274 -28 295 276 295 617 275 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:02:04 0 151 -5 275 122 -4 299 477 484 160 200 1 112 20 370 37 0 -2884 2736 2279 -28 295 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:03:04 0 150 -6 275 121 -5 299 477 484 160 200 1 112 20 369 37 0 -2881 2736 2285 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:04:04 0 149 -8 275 120 -5 299 477 483 160 200 1 112 20 369 37 0 -2878 2737 2297 -28 295 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:05:04 0 149 -10 275 120 -6 299 477 483 160 200 1 112 20 369 37 0 -2875 2740 2294 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:06:09 0 149 -9 275 120 -6 299 477 483 160 200 1 112 20 370 37 0 -2872 2739 2277 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:07:06 0 150 -7 275 121 -6 299 477 483 160 200 1 112 20 369 37 0 -2869 2740 2286 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:08:06 0 151 -6 275 122 -6 299 477 483 160 200 1 112 20 369 37 0 -2866 2740 2287 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:09:06 0 151 -4 275 122 -6 299 476 483 160 200 1 112 20 370 37 0 -2864 2740 2286 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:10:06 0 152 -3 275 123 -5 299 476 483 160 200 1 112 20 369 37 0 -2862 2741 2285 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:11:06 0 152 -1 275 123 -5 299 476 483 160 200 1 112 20 370 37 0 -2860 2742 2290 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:12:06 0 153 -1 275 125 -5 299 476 483 160 200 1 112 20 369 37 0 -2858 2742 2287 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:13:06 0 153 1 275 125 -4 299 476 483 160 200 1 112 20 370 37 0 -2856 2744 2293 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:14:06 0 153 2 276 126 -4 299 476 483 160 200 1 112 20 371 37 0 -2854 2744 2301 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:15:06 0 155 4 276 127 -4 299 476 483 160 200 1 112 20 370 37 0 -2852 2745 2289 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:16:06 0 155 4 275 127 -3 299 476 483 160 200 1 112 20 370 37 0 -2850 2746 2299 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:17:06 0 156 6 276 128 -2 299 476 483 160 200 1 112 20 370 37 0 -2848 2746 2282 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:18:06 0 157 6 276 128 -2 299 476 483 160 200 1 112 20 370 37 0 -2846 2746 2297 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:19:06 0 157 8 276 129 -2 299 476 483 160 200 1 112 20 370 37 0 -2844 2747 2287 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:20:06 0 157 8 276 129 -1 299 476 483 160 200 1 112 20 371 37 0 -2842 2746 2300 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:21:09 0 157 8 276 129 -1 299 476 483 160 200 1 112 20 370 37 0 -2839 2748 2296 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:22:09 0 157 8 276 129 0 299 475 483 160 200 1 112 20 371 37 0 -2836 2749 2288 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:23:09 0 157 8 276 129 -1 299 475 483 160 200 1 112 20 370 37 0 -2833 2747 2277 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:24:09 0 157 8 276 129 0 299 475 482 160 200 1 112 20 370 37 0 -2830 2745 2287 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:25:09 0 157 9 276 129 0 299 475 482 160 200 1 112 20 369 37 0 -2827 2746 2294 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:26:08 0 158 9 276 130 0 299 475 482 160 200 1 112 20 370 37 0 -2824 2746 2274 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:27:08 0 158 9 276 131 0 299 475 482 160 200 1 112 20 369 37 0 -2821 2744 2272 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:28:08 0 158 11 276 131 0 299 475 482 160 200 1 112 20 370 37 0 -2818 2743 2278 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:29:08 0 158 10 276 131 0 299 475 482 160 200 1 112 20 370 37 0 -2815 2742 2281 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:30:08 0 158 11 276 131 1 299 475 482 160 200 1 112 20 370 37 0 -2812 2742 2285 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:31:08 0 159 11 276 131 1 299 475 482 160 200 1 112 20 370 37 0 -2809 2742 2284 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:32:08 0 159 11 276 132 1 299 475 482 160 200 1 112 20 369 37 0 -2806 2742 2299 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:33:08 0 160 13 277 132 2 299 475 482 160 200 1 112 20 370 37 0 -2803 2744 2285 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:34:08 0 159 13 276 132 2 299 475 482 160 200 1 112 20 369 37 0 -2800 2742 2277 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:35:08 0 159 13 276 132 2 299 474 482 160 200 1 112 20 370 37 0 -2797 2741 2278 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:36:14 0 159 13 276 132 3 299 474 482 160 200 1 112 20 370 37 0 -2794 2740 2290 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:37:11 0 159 14 276 133 2 299 474 482 160 200 1 112 20 370 37 0 -2791 2742 2294 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:38:11 0 160 14 276 133 3 299 474 482 160 200 1 112 20 370 37 0 -2788 2744 2298 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:39:11 0 160 14 276 133 3 299 474 482 160 200 1 112 20 370 37 0 -2785 2744 2291 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:40:11 0 160 14 276 133 3 299 474 482 160 200 1 112 20 370 37 0 -2782 2744 2282 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:41:11 0 160 14 276 133 3 299 474 482 160 200 1 112 20 370 37 0 -2779 2744 2291 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:42:11 0 160 14 276 133 4 299 474 482 160 200 1 112 20 370 37 0 -2776 2745 2294 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:43:11 0 160 14 276 133 4 299 474 482 160 200 1 112 20 370 37 0 -2773 2745 2281 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:44:11 0 161 15 276 133 4 299 474 482 160 200 1 112 20 370 37 0 -2770 2746 2299 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:45:11 0 160 14 276 133 4 299 474 482 160 200 1 112 20 370 37 0 -2767 2747 2297 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:46:11 0 160 14 276 133 4 299 474 482 160 200 1 112 20 369 37 0 -2763 2747 2289 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:47:11 0 160 14 276 133 5 298 474 482 160 200 1 112 20 369 37 0 -2759 2749 2301 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:48:11 0 160 14 276 133 5 299 474 482 160 200 1 112 20 370 37 0 -2755 2748 2292 -28 294 275 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:49:11 0 160 14 276 133 5 299 474 481 160 200 1 112 20 369 37 0 -2751 2749 2299 -28 294 276 295 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:50:11 0 160 15 276 133 5 298 473 482 160 200 1 112 20 360 36 0 -2747 2750 2295 -28 294 275 294 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:51:16 0 160 16 276 133 5 298 473 481 160 200 1 112 20 360 36 0 -2744 2749 2276 -26 294 275 294 617 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:52:13 0 160 16 276 133 5 298 473 481 160 200 1 112 20 360 36 0 -2741 2747 2278 -26 294 275 294 616 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:53:13 0 160 14 276 133 5 298 473 481 160 200 1 112 20 360 36 0 -2738 2745 2280 -26 294 275 294 616 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:54:13 0 160 14 276 133 5 298 473 481 160 200 1 112 20 360 36 0 -2735 2745 2295 -26 294 275 294 616 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:55:13 0 160 14 275 133 6 298 473 481 160 200 1 112 20 359 36 0 -2732 2745 2290 -26 294 275 294 616 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:56:13 0 160 14 276 133 5 298 473 481 160 200 1 112 20 359 36 0 -2729 2747 2299 -26 294 275 294 616 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:57:13 0 160 14 275 133 6 298 473 481 160 200 1 112 20 359 36 0 -2726 2749 2296 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:58:13 0 160 14 275 133 5 298 473 481 160 200 1 112 20 360 36 0 -2723 2750 2296 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 03:59:13 0 159 13 275 132 6 298 473 481 160 200 1 112 20 360 36 0 -2720 2751 2294 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:00:13 0 159 13 275 132 6 298 473 481 160 200 1 112 20 359 36 0 -2717 2751 2284 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:01:13 0 159 14 275 132 5 298 473 481 160 200 1 112 20 359 36 0 -2714 2750 2286 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:02:13 0 159 14 275 132 5 298 473 481 160 200 1 112 20 360 36 0 -2711 2748 2288 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:03:13 0 159 14 275 132 5 298 472 481 160 200 1 112 20 359 36 0 -2708 2747 2283 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:04:13 0 159 14 275 132 5 297 472 481 160 200 1 112 20 360 36 0 -2705 2745 2284 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:05:13 0 159 13 275 132 5 298 472 481 160 200 1 112 20 360 36 0 -2702 2743 2271 -26 294 275 294 614 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:06:19 0 159 13 275 132 5 297 472 481 160 200 1 112 20 360 36 0 -2699 2745 2302 -26 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:07:16 0 159 13 275 132 5 297 472 481 160 200 1 112 20 359 36 0 -2696 2747 2299 -26 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:08:16 0 159 13 275 132 5 297 472 481 160 200 1 112 20 359 36 0 -2693 2747 2299 -26 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:09:16 0 159 13 275 132 5 297 472 481 160 200 1 112 20 360 36 0 -2690 2749 2303 -26 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:10:16 0 159 13 275 132 5 297 472 481 160 200 1 112 20 361 36 0 -2687 2751 2297 -26 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:11:16 0 159 13 275 132 6 297 472 481 160 200 1 112 20 360 36 0 -2683 2750 2285 -26 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:12:15 0 159 14 275 132 6 297 472 480 160 200 1 112 20 360 36 0 -2679 2749 2271 -26 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:13:15 0 159 14 275 132 5 297 472 480 160 200 1 112 20 359 36 0 -2675 2747 2291 -26 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:14:15 0 160 14 275 133 6 297 472 480 160 200 1 112 20 349 35 0 -2671 2748 2298 -25 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:15:15 0 160 14 275 133 6 297 472 480 160 200 1 112 20 350 35 0 -2667 2749 2301 -25 294 275 294 613 274 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:16:15 0 159 14 275 133 6 297 472 480 160 200 1 112 20 350 35 0 -2663 2750 2301 -25 294 275 294 613 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:17:15 0 159 14 274 132 6 297 472 480 160 200 1 112 20 350 35 0 -2659 2750 2278 -24 294 275 294 613 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:18:15 0 159 14 274 132 6 297 471 480 160 200 1 112 20 350 35 0 -2655 2749 2300 -24 294 275 294 612 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:19:15 0 159 15 274 132 7 297 471 480 160 200 1 112 20 350 35 0 -2651 2750 2286 -23 293 275 294 612 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:20:15 0 159 14 274 132 6 297 471 480 160 200 1 112 20 350 35 0 -2647 2747 2272 -23 293 275 294 612 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:21:18 0 159 14 274 132 7 297 471 480 160 200 1 112 20 349 35 0 -2643 2745 2273 -23 293 274 294 612 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:22:18 0 159 16 274 132 7 297 471 480 160 200 1 112 20 351 35 0 -2639 2744 2275 -24 293 274 294 611 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:23:18 0 159 16 274 132 6 296 471 480 160 200 1 112 20 339 34 0 -2635 2744 2282 -23 293 274 293 611 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:24:18 0 159 16 274 133 6 296 471 480 160 200 1 112 20 339 34 0 -2632 2744 2284 -23 293 274 293 611 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:25:18 0 159 16 274 132 6 296 471 480 160 200 1 112 20 341 34 0 -2629 2743 2291 -22 293 274 293 611 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:26:18 0 159 16 274 132 6 296 471 480 160 200 1 112 20 341 34 0 -2625 2743 2296 -21 293 274 293 610 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:27:18 0 159 16 274 133 7 296 471 480 160 200 1 112 20 340 34 0 -2621 2743 2282 -21 293 274 293 610 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:28:18 0 159 16 274 132 7 296 471 480 160 200 1 112 20 340 34 0 -2618 2742 2269 -21 293 275 293 610 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:29:18 0 159 16 274 133 7 296 471 479 160 200 1 112 20 341 34 0 -2614 2740 2276 -21 293 274 293 609 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:30:18 0 159 16 274 132 6 296 471 479 160 200 1 112 20 340 34 0 -2610 2739 2279 -21 293 274 293 608 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:31:18 0 159 16 274 133 7 296 471 479 160 200 1 112 20 340 34 0 -2605 2739 2291 -21 293 274 293 608 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:32:18 0 159 16 273 132 7 296 471 479 160 200 1 112 20 330 33 0 -2600 2741 2288 -21 293 274 293 608 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:33:18 0 159 16 274 132 7 295 470 479 160 200 1 112 20 330 33 0 -2595 2742 2281 -20 292 274 293 607 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:34:18 0 159 16 273 132 7 295 470 479 160 200 1 112 20 330 33 0 -2590 2739 2272 -19 292 274 293 607 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:35:18 0 158 14 273 132 7 295 470 479 160 200 1 112 20 330 33 0 -2585 2740 2297 -18 292 274 293 607 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:36:20 0 159 16 273 132 7 295 470 479 160 200 1 112 20 331 33 0 -2580 2741 2278 -17 292 274 293 606 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:37:20 0 159 15 273 132 7 295 470 479 160 200 1 112 20 319 32 0 -2575 2739 2278 -17 292 274 292 606 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:38:20 0 159 16 273 132 6 295 470 479 160 200 1 112 20 319 32 0 -2571 2738 2276 -16 292 274 292 605 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:39:20 0 159 16 273 132 7 295 470 479 160 200 1 112 20 320 32 0 -2567 2738 2270 -15 291 274 292 605 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:40:20 0 157 14 272 131 6 295 470 478 160 200 1 112 20 320 32 0 -2563 2737 2276 -15 291 274 292 605 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:41:20 0 157 13 272 130 7 294 470 478 160 200 1 112 20 320 32 0 -2559 2736 2282 -15 291 274 292 603 273 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:42:20 0 156 11 272 129 6 294 470 478 160 200 1 112 20 320 32 0 -2555 2735 2283 -15 291 274 292 603 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:43:20 0 156 11 272 129 5 294 470 478 160 200 1 112 20 320 32 0 -2551 2736 2280 -15 291 274 292 603 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:44:20 0 157 13 272 129 5 294 470 478 160 200 1 112 20 310 31 0 -2547 2736 2292 -14 291 273 291 602 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:45:20 0 157 13 272 130 5 294 470 478 160 200 1 112 20 310 31 0 -2544 2738 2291 -13 291 274 291 601 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:46:20 0 157 13 272 129 6 294 469 478 160 200 1 112 20 309 31 0 -2541 2737 2270 -12 291 274 291 601 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:47:20 0 156 11 271 129 5 294 469 478 160 200 1 112 20 310 31 0 -2538 2736 2286 -12 290 274 291 600 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:48:20 0 156 11 271 128 4 294 469 478 160 200 1 112 20 309 31 0 -2535 2735 2269 -12 290 273 291 600 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:49:20 0 155 11 271 128 5 294 469 478 160 200 1 112 20 309 31 0 -2532 2732 2261 -12 290 273 291 600 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:50:20 0 155 11 271 128 4 294 469 478 160 200 1 112 20 310 31 0 -2529 2731 2273 -12 290 273 291 599 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:51:25 0 155 11 271 128 4 294 469 478 160 200 1 112 20 309 31 0 -2526 2731 2270 -12 290 273 291 599 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:52:22 0 155 11 271 128 4 294 469 478 160 200 1 112 20 310 31 0 -2523 2731 2276 -12 290 273 291 599 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:53:22 0 157 12 271 129 4 294 469 477 160 200 1 112 20 309 31 0 -2520 2730 2261 -12 290 273 291 597 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:54:22 0 156 13 271 129 4 294 469 477 160 200 1 112 20 310 31 0 -2517 2728 2269 -12 290 273 291 597 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:55:22 0 156 13 271 129 5 294 469 477 160 200 1 112 20 310 31 0 -2514 2728 2286 -12 290 273 291 597 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:56:22 0 157 13 271 129 5 294 469 477 160 200 1 112 20 310 31 0 -2512 2731 2286 -12 290 273 291 597 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:57:22 0 157 13 271 129 4 294 469 477 160 200 1 112 20 311 31 0 -2510 2730 2268 -12 290 273 291 596 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:58:22 0 157 13 271 129 5 294 469 477 160 200 1 112 20 300 30 0 -2508 2730 2281 -12 290 273 290 596 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 04:59:22 0 156 13 271 129 4 294 469 477 160 200 1 112 20 300 30 0 -2506 2729 2275 -10 290 273 290 596 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:00:22 0 156 13 271 129 5 294 468 477 160 200 1 112 20 300 30 0 -2504 2730 2272 -10 289 273 290 595 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:01:22 0 157 14 271 130 5 294 468 477 160 200 1 112 20 300 30 0 -2502 2729 2282 -8 289 273 290 595 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:02:22 0 157 14 270 130 5 294 468 477 160 200 1 112 20 300 30 0 -2500 2730 2273 -8 289 273 290 595 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:03:22 0 156 14 270 131 5 294 468 477 160 200 1 112 20 301 30 0 -2498 2729 2254 -8 289 273 290 594 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:04:22 0 157 14 270 131 5 294 468 477 160 200 1 112 20 300 30 0 -2496 2728 2272 -8 289 273 290 594 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:05:22 0 157 14 270 131 5 294 468 477 160 200 1 112 20 300 30 0 -2494 2727 2270 -8 289 273 290 594 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:06:28 0 157 14 270 131 5 293 468 477 160 200 1 112 20 299 30 0 -2492 2728 2272 -8 289 273 290 594 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:07:25 0 157 14 270 131 6 293 468 477 160 200 1 112 20 300 30 0 -2490 2725 2259 -8 289 273 290 593 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:08:24 0 157 14 270 131 6 293 468 477 160 200 1 112 20 300 30 0 -2488 2726 2280 -8 289 273 290 593 272 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:09:24 0 157 14 270 131 6 293 468 477 160 200 1 112 20 299 30 0 -2486 2727 2266 -8 289 273 290 593 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:10:24 0 157 14 270 131 6 293 468 477 160 200 1 112 20 300 30 0 -2484 2727 2279 -8 289 273 290 593 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:11:24 0 157 14 270 131 6 293 468 477 160 200 1 112 20 300 30 0 -2482 2726 2276 -8 289 273 290 593 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:12:24 0 157 14 270 131 5 293 468 476 160 200 1 112 20 300 30 0 -2480 2728 2279 -8 289 272 290 593 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:13:24 0 157 14 270 131 6 293 468 476 160 200 1 112 20 300 30 0 -2479 2729 2279 -8 289 272 290 593 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:14:24 0 158 16 270 131 6 293 468 476 160 200 1 112 20 300 30 0 -2478 2728 2272 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:15:24 0 157 16 270 131 6 293 468 476 160 200 1 112 20 299 30 0 -2477 2727 2257 -8 289 273 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:16:24 0 157 16 270 131 6 293 467 476 160 200 1 112 20 300 30 0 -2476 2726 2278 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:17:24 0 158 16 270 131 7 293 467 476 160 200 1 112 20 300 30 0 -2475 2726 2281 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:18:24 0 157 16 270 132 7 293 467 476 160 200 1 112 20 300 30 0 -2474 2727 2265 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:19:24 0 156 16 270 131 7 293 467 476 160 200 1 112 20 299 30 0 -2473 2727 2277 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:20:24 0 156 14 270 129 6 293 467 476 160 200 1 112 20 300 30 0 -2472 2728 2281 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:21:27 0 156 14 270 129 6 293 467 476 160 200 1 112 20 299 30 0 -2470 2729 2275 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:22:27 0 156 14 270 129 6 293 467 476 160 200 1 112 20 300 30 0 -2468 2729 2271 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:23:27 0 157 14 270 131 6 293 467 476 160 200 1 112 20 299 30 0 -2466 2728 2270 -8 289 272 289 592 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:24:27 0 156 14 270 129 5 293 467 476 160 200 1 112 20 300 30 0 -2464 2728 2277 -8 289 272 289 591 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:25:27 0 155 14 270 129 5 293 467 476 160 200 1 112 20 300 30 0 -2462 2727 2255 -8 289 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:26:27 0 155 13 270 128 6 293 467 476 160 200 1 112 20 301 30 0 -2460 2725 2273 -8 289 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:27:27 0 156 13 270 129 5 293 467 476 160 200 1 112 20 299 30 0 -2458 2726 2274 -8 289 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:28:27 0 156 13 270 129 4 293 467 476 160 200 1 112 20 299 30 0 -2456 2726 2267 -8 289 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:29:27 0 156 13 269 129 5 293 467 476 160 200 1 112 20 300 30 0 -2454 2726 2275 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:30:27 0 155 13 269 129 5 293 467 476 160 200 1 112 20 299 30 0 -2452 2726 2273 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:31:27 0 156 13 269 129 5 293 467 476 160 200 1 112 20 300 30 0 -2450 2726 2266 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:32:27 0 155 13 270 128 4 293 466 476 160 200 1 112 20 301 30 0 -2448 2725 2265 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:33:27 0 156 13 270 129 4 292 466 476 160 200 1 112 20 300 30 0 -2446 2725 2271 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:34:27 0 156 13 269 129 3 293 466 476 160 200 1 112 20 299 30 0 -2444 2723 2268 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:35:27 0 156 13 269 128 3 292 466 476 160 200 1 112 20 301 30 0 -2442 2724 2282 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:36:29 0 156 13 269 129 4 292 466 476 160 200 1 112 20 300 30 0 -2440 2726 2277 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:37:29 0 156 13 269 129 4 292 466 475 160 200 1 112 20 299 30 0 -2438 2725 2272 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:38:29 0 155 13 269 129 4 292 466 475 160 200 1 112 20 300 30 0 -2436 2726 2279 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:39:29 0 155 13 269 129 3 292 466 475 160 200 1 112 20 300 30 0 -2435 2726 2266 -8 288 272 289 590 271 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:40:29 0 156 13 269 129 4 292 466 475 160 200 1 112 20 300 30 0 -2434 2726 2271 -8 288 272 289 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:41:29 0 156 13 269 129 4 292 466 475 160 200 1 112 20 299 30 0 -2433 2727 2283 -8 288 272 289 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:42:29 0 155 13 269 129 4 292 466 475 160 200 1 112 20 300 30 0 -2432 2729 2272 -8 288 271 289 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:43:29 0 156 13 269 129 4 292 466 475 160 200 1 112 20 300 30 0 -2431 2729 2279 -8 288 271 289 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:44:29 0 156 13 269 129 4 292 466 475 160 200 1 112 20 300 30 0 -2430 2728 2266 -8 288 272 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:45:29 0 156 13 269 129 4 292 466 475 160 200 1 112 20 300 30 0 -2429 2727 2271 -8 288 272 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:46:29 0 156 13 269 129 4 292 466 475 160 200 1 112 20 301 30 0 -2428 2726 2272 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:47:29 0 156 13 269 129 5 292 465 475 160 200 1 112 20 299 30 0 -2428 2726 2266 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:48:29 0 156 13 269 129 5 292 465 475 160 200 1 112 20 300 30 0 -2427 2726 2268 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:49:29 0 156 13 269 129 5 292 465 475 160 200 1 112 20 301 30 0 -2427 2726 2282 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:50:29 0 156 13 269 129 5 292 465 475 160 200 1 112 20 300 30 0 -2426 2727 2275 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:51:33 0 156 13 269 129 4 292 465 475 160 200 1 112 20 300 30 0 -2425 2728 2281 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:52:31 0 156 12 269 128 4 292 465 475 160 200 1 112 20 299 30 0 -2424 2728 2273 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:53:31 0 155 13 269 129 4 292 465 475 160 200 1 112 20 300 30 0 -2423 2729 2274 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:54:31 0 156 13 269 129 5 292 465 475 160 200 1 112 20 302 30 0 -2422 2729 2279 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:55:31 0 156 13 269 129 5 292 465 475 160 200 1 112 20 300 30 0 -2421 2730 2278 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:56:31 0 156 13 269 129 5 292 465 475 160 200 1 112 20 300 30 0 -2420 2728 2249 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:57:31 0 155 12 269 128 4 292 465 475 160 200 1 112 20 300 30 0 -2419 2726 2267 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:58:31 0 156 13 269 129 4 292 465 475 160 200 1 112 20 299 30 0 -2419 2726 2272 -8 287 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 05:59:31 0 155 13 268 129 4 292 465 475 160 200 1 112 20 301 30 0 -2418 2726 2266 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:00:31 0 155 11 269 128 5 292 465 475 160 200 1 112 20 300 30 0 -2417 2726 2295 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:01:31 0 155 11 269 128 5 292 465 475 160 200 1 112 20 299 30 0 -2417 2727 2266 -8 287 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:02:31 0 155 11 269 128 5 292 465 475 160 200 1 112 20 300 30 0 -2417 2727 2269 -8 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:03:31 0 155 11 269 128 4 292 464 475 160 200 1 112 20 301 30 0 -2417 2728 2284 -8 287 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:04:31 0 153 11 268 128 4 292 464 475 160 200 1 112 20 310 31 0 -2417 2729 2283 -9 287 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:05:31 0 155 11 269 128 4 292 464 475 160 200 1 112 20 310 31 0 -2417 2729 2274 -10 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:06:37 0 153 10 269 127 4 292 464 474 160 200 1 112 20 310 31 0 -2417 2729 2277 -10 288 271 288 589 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:07:34 0 153 9 268 127 3 292 464 475 160 200 1 112 20 310 31 0 -2417 2728 2267 -11 288 271 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:08:33 0 152 8 269 126 3 292 464 475 160 200 1 112 20 310 31 0 -2417 2728 2287 -11 288 271 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:09:33 0 153 9 269 127 4 292 464 475 160 200 1 112 20 310 31 0 -2417 2729 2271 -11 288 271 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:10:33 0 153 9 269 127 4 292 464 475 160 200 1 112 20 310 31 0 -2417 2728 2251 -11 288 271 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:11:33 0 153 9 269 127 3 292 463 475 160 200 1 112 20 310 31 0 -2417 2726 2263 -11 288 271 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:12:33 0 153 9 269 127 3 292 463 474 160 200 1 112 20 309 31 0 -2417 2725 2259 -10 288 271 288 590 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:13:33 0 153 9 269 127 3 292 463 474 160 200 1 112 20 310 31 0 -2417 2723 2267 -10 288 271 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:14:33 0 153 9 269 127 3 292 463 474 160 200 1 112 20 310 31 0 -2417 2722 2267 -10 288 271 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:15:33 0 153 9 269 127 3 292 463 474 160 200 1 112 20 311 31 0 -2417 2722 2266 -10 288 271 288 590 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:16:33 0 153 9 269 127 3 292 463 474 160 200 1 112 20 310 31 0 -2417 2721 2252 -10 288 271 288 590 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:17:33 0 153 9 268 127 2 292 462 474 160 200 1 112 20 310 31 0 -2417 2719 2263 -10 288 271 288 590 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:18:33 0 153 9 268 127 2 292 463 474 160 200 1 112 20 309 31 0 -2417 2718 2261 -10 288 271 288 590 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:19:33 0 153 11 268 127 3 292 462 474 160 200 1 112 20 320 32 0 -2417 2717 2262 -11 287 271 289 592 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:20:33 0 153 11 269 127 2 292 462 474 160 200 1 112 20 320 32 0 -2416 2716 2249 -12 288 271 289 592 270 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:21:36 0 152 9 269 127 3 292 462 474 160 200 1 112 20 320 32 0 -2415 2715 2266 -12 288 271 289 592 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:22:36 0 153 9 269 127 3 292 462 474 160 200 1 112 20 321 32 0 -2414 2716 2272 -13 288 270 289 592 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:23:36 0 152 9 269 126 2 292 462 474 160 200 1 112 20 320 32 0 -2413 2718 2283 -13 288 271 288 593 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:24:36 0 153 9 269 126 2 292 462 474 160 200 1 112 20 320 32 0 -2413 2719 2272 -13 288 270 288 593 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:25:36 0 153 9 269 127 2 292 462 474 160 200 1 112 20 320 32 0 -2413 2719 2262 -13 288 271 288 593 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:26:36 0 153 9 269 127 2 292 462 474 160 200 1 112 20 320 32 0 -2413 2720 2269 -13 288 270 288 593 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:27:36 0 153 9 269 127 2 292 462 474 160 200 1 112 20 319 32 0 -2413 2721 2279 -13 288 270 288 593 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:28:36 0 153 9 269 127 1 292 462 474 160 200 1 112 20 320 32 0 -2413 2721 2269 -13 288 270 288 593 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:29:36 0 153 9 269 127 1 292 462 474 160 200 1 112 20 320 32 0 -2413 2721 2258 -13 288 270 288 593 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:30:36 0 152 9 269 126 1 292 462 474 160 200 1 112 20 320 32 0 -2413 2719 2258 -14 288 271 288 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:31:36 0 152 8 268 126 1 292 461 474 160 200 1 112 20 321 32 0 -2413 2719 2274 -14 288 270 288 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:32:36 0 152 8 268 126 1 292 461 474 160 200 1 112 20 320 32 0 -2413 2718 2245 -15 288 270 288 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:33:36 0 152 8 269 126 1 292 461 474 160 200 1 112 20 320 32 0 -2413 2717 2261 -14 288 270 288 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:34:36 0 153 8 268 126 0 292 461 474 160 200 1 112 20 319 32 0 -2413 2717 2263 -15 288 270 288 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:35:36 0 152 8 268 126 0 292 461 474 160 200 1 112 20 319 32 0 -2413 2716 2270 -14 288 270 288 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:36:38 0 152 8 268 126 1 292 461 473 160 200 1 112 20 320 32 0 -2413 2718 2269 -14 288 270 288 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:37:38 0 152 8 268 126 0 292 461 473 160 200 1 112 20 321 32 0 -2413 2717 2256 -15 288 270 288 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:38:38 0 153 8 269 126 0 292 461 473 160 200 1 112 20 330 33 0 -2413 2717 2255 -15 287 270 289 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:39:38 0 153 8 269 126 1 292 461 473 160 200 1 112 20 330 33 0 -2412 2716 2264 -16 288 270 289 594 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:40:38 0 153 8 269 126 0 292 461 473 160 200 1 112 20 330 33 0 -2411 2719 2283 -17 288 270 289 595 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:41:38 0 153 9 269 127 1 292 461 473 160 200 1 112 20 329 33 0 -2410 2721 2278 -17 288 270 289 595 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:42:38 0 153 9 269 126 1 292 461 473 160 200 1 112 20 331 33 0 -2409 2723 2278 -17 288 270 289 595 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:43:38 0 153 9 269 126 1 292 461 473 160 200 1 112 20 330 33 0 -2408 2723 2278 -17 288 270 289 595 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:44:38 0 153 9 269 127 1 292 461 473 160 200 1 112 20 330 33 0 -2407 2723 2258 -17 288 270 288 595 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:45:38 0 153 9 269 127 1 292 461 473 160 200 1 112 20 330 33 0 -2406 2723 2271 -17 288 270 289 595 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:46:38 0 153 9 269 127 1 292 461 473 160 200 1 112 20 330 33 0 -2405 2723 2267 -17 288 270 289 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:47:38 0 153 9 269 127 1 292 460 473 160 200 1 112 20 330 33 0 -2404 2721 2256 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:48:38 0 155 9 269 127 1 292 460 473 160 200 1 112 20 330 33 0 -2403 2721 2268 -17 288 270 289 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:49:38 0 154 9 269 127 1 292 460 473 160 200 1 112 20 330 33 0 -2402 2720 2262 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:50:38 0 153 9 269 127 2 292 460 473 160 200 1 112 20 330 33 0 -2401 2722 2272 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:50:40 0 153 8 268 127 2 292 460 473 160 200 1 112 20 330 33 0 -2400 2720 2256 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:51:40 0 152 8 269 126 1 292 460 473 160 200 1 112 20 329 33 0 -2400 2718 2256 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:52:40 0 153 8 269 126 1 292 460 473 160 200 1 112 20 330 33 0 -2400 2718 2263 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:53:40 0 152 8 269 126 1 292 460 473 160 200 1 112 20 329 33 0 -2400 2718 2272 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:54:40 0 152 8 268 126 1 292 460 473 160 200 1 112 20 330 33 0 -2401 2719 2261 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:55:40 0 153 8 269 126 1 292 460 473 160 200 1 112 20 330 33 0 -2402 2719 2274 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:56:40 0 153 8 269 126 0 292 460 472 160 200 1 112 20 330 33 0 -2404 2719 2260 -17 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:57:40 0 153 8 269 126 1 292 460 472 160 200 1 112 20 330 33 0 -2406 2719 2271 -18 288 270 288 596 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:58:40 0 153 8 269 126 2 292 460 472 160 200 1 112 20 340 34 0 -2408 2721 2269 -18 288 270 289 597 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 06:59:40 0 152 8 268 126 1 292 460 472 160 200 1 112 20 339 34 0 -2409 2720 2266 -19 288 270 289 597 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:00:40 0 153 8 269 126 1 292 460 472 160 200 1 112 20 340 34 0 -2410 2721 2264 -21 288 270 289 597 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:01:40 0 152 8 269 126 1 292 459 472 160 200 1 112 20 340 34 0 -2411 2721 2257 -21 288 270 289 597 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:02:40 0 151 8 269 125 1 292 459 472 160 200 1 112 20 340 34 0 -2412 2720 2277 -21 288 270 289 597 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:03:40 0 151 6 268 125 1 292 459 472 160 200 1 112 20 340 34 0 -2413 2719 2268 -21 288 270 289 598 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:04:40 0 151 6 269 125 1 292 459 472 160 200 1 112 20 341 34 0 -2415 2719 2265 -21 288 270 289 599 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:05:45 0 151 6 269 125 1 292 459 472 160 200 1 112 20 350 35 0 -2417 2720 2277 -21 288 270 289 599 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:06:42 0 152 6 269 125 1 293 459 472 160 200 1 112 20 350 35 0 -2418 2721 2268 -23 288 270 289 599 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:07:42 0 152 8 269 126 1 293 459 472 160 200 1 112 20 351 35 0 -2419 2721 2277 -23 288 270 289 599 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:08:42 0 152 8 269 126 1 293 459 472 160 200 1 112 20 349 35 0 -2420 2723 2273 -24 288 270 289 600 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:09:42 0 153 8 269 126 0 293 459 472 160 200 1 112 20 350 35 0 -2421 2722 2261 -25 288 270 289 600 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:10:42 0 153 8 269 126 1 293 459 472 160 200 1 112 20 350 35 0 -2422 2723 2276 -25 288 270 289 600 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:11:42 0 153 8 269 127 0 293 459 472 160 200 1 112 20 360 36 0 -2423 2721 2252 -25 288 270 290 601 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:12:42 0 153 8 269 127 1 293 459 472 160 200 1 112 20 360 36 0 -2424 2718 2245 -25 288 270 289 601 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:13:42 0 153 8 269 127 1 293 459 472 160 200 1 112 20 361 36 0 -2425 2716 2253 -26 289 270 289 601 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:14:42 0 153 8 269 127 1 293 459 472 160 200 1 112 20 360 36 0 -2425 2715 2261 -26 289 270 290 602 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:15:42 0 155 9 270 127 1 293 458 472 160 200 1 112 20 360 36 0 -2426 2716 2282 -26 289 270 289 602 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:16:42 0 155 9 270 128 1 293 458 472 160 200 1 112 20 360 36 0 -2426 2718 2262 -26 289 270 289 602 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:17:42 0 155 9 270 127 1 293 458 471 160 200 1 112 20 360 36 0 -2427 2717 2258 -26 289 270 290 603 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:18:42 0 153 9 269 127 1 293 458 471 160 200 1 112 20 360 36 0 -2428 2717 2273 -26 289 270 290 603 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:19:42 0 153 8 270 127 1 293 458 471 160 200 1 112 20 369 37 0 -2428 2719 2272 -26 289 270 290 603 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:20:44 0 153 8 270 126 1 294 458 471 160 200 1 112 20 369 37 0 -2428 2718 2260 -28 289 270 290 603 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:21:44 0 154 8 270 127 1 294 458 471 160 200 1 112 20 371 37 0 -2428 2718 2274 -28 289 270 290 605 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:22:44 0 155 8 270 127 0 294 458 471 160 200 1 112 20 370 37 0 -2428 2719 2272 -29 289 270 290 605 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:23:44 0 153 8 270 127 1 294 458 471 160 200 1 112 20 370 37 0 -2428 2720 2275 -29 289 270 290 606 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:24:44 0 154 8 270 127 1 294 458 471 160 200 1 112 20 371 37 0 -2428 2720 2271 -29 289 270 290 606 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:25:44 0 155 8 270 127 1 294 458 471 160 200 1 112 20 370 37 0 -2428 2721 2273 -29 289 270 290 606 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:26:44 0 155 9 270 128 1 294 458 471 160 200 1 112 20 370 37 0 -2428 2722 2280 -29 289 270 290 606 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:27:44 0 155 8 270 127 1 294 458 471 160 200 1 112 20 370 37 0 -2428 2722 2260 -30 289 270 290 607 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:28:44 0 153 8 270 127 1 294 458 471 160 200 1 112 20 371 37 0 -2428 2720 2262 -30 289 270 290 607 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:29:44 0 153 8 270 127 1 294 458 471 160 200 1 112 20 369 37 0 -2428 2721 2272 -30 289 270 290 607 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:30:44 0 153 8 270 127 1 294 457 471 160 200 1 112 20 369 37 0 -2428 2721 2279 -30 289 270 290 607 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:31:44 0 153 8 270 126 1 294 457 471 160 200 1 112 20 380 38 0 -2428 2720 2259 -30 289 270 290 608 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:32:44 0 153 6 270 126 0 294 457 471 160 200 1 112 20 380 38 0 -2428 2720 2271 -31 289 270 290 608 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:33:44 0 153 7 270 126 1 294 457 471 160 200 1 112 20 381 38 0 -2428 2721 2273 -32 289 270 290 608 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:34:44 0 153 6 270 126 1 294 457 471 160 200 1 112 20 380 38 0 -2428 2721 2271 -32 289 270 290 608 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:35:47 0 152 6 270 126 1 294 457 471 160 200 1 112 20 379 38 0 -2428 2722 2271 -32 289 270 290 610 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:36:47 0 152 4 270 125 0 294 457 471 160 200 1 112 20 379 38 0 -2428 2722 2275 -32 289 270 290 610 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:37:47 0 152 6 270 126 0 294 457 471 160 200 1 112 20 381 38 0 -2428 2722 2268 -32 290 270 290 610 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:38:47 0 153 6 270 126 0 294 457 470 160 200 1 112 20 380 38 0 -2428 2721 2267 -32 290 270 290 611 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:39:47 0 153 6 270 126 0 294 457 470 160 200 1 112 20 378 38 0 -2428 2721 2269 -32 290 270 290 611 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:40:47 0 153 8 270 127 0 294 457 470 160 200 1 112 20 380 38 0 -2428 2721 2259 -32 290 270 290 611 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:41:47 0 153 8 270 127 0 294 457 470 160 200 1 112 20 379 38 0 -2428 2721 2263 -32 290 270 290 611 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:42:47 0 152 6 270 126 0 294 457 470 160 200 1 112 20 380 38 0 -2428 2721 2256 -32 289 270 290 611 269 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:43:47 0 152 4 270 125 0 294 457 470 160 200 1 112 20 390 39 0 -2428 2720 2273 -32 290 269 291 612 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:44:46 0 152 6 270 126 -1 294 457 470 160 200 1 112 20 389 39 0 -2427 2720 2263 -34 290 269 291 612 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:45:46 0 152 6 270 126 -1 294 456 470 160 200 1 112 20 389 39 0 -2426 2720 2266 -34 290 270 291 612 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:46:46 0 152 6 270 126 -1 294 456 470 160 200 1 112 20 390 39 0 -2425 2720 2274 -34 290 269 291 612 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:47:46 0 152 4 271 125 -1 294 456 470 160 200 1 112 20 390 39 0 -2424 2721 2274 -34 290 269 291 612 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:48:46 0 152 4 270 125 -1 294 456 470 160 200 1 112 20 390 39 0 -2423 2721 2264 -34 290 270 291 613 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:49:46 0 152 4 270 125 -2 294 456 470 160 200 1 112 20 389 39 0 -2422 2721 2267 -35 290 269 291 613 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:50:49 0 152 4 271 125 -2 294 456 470 160 200 1 112 20 391 39 0 -2421 2721 2268 -34 290 269 291 613 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:51:49 0 152 4 271 125 -2 294 456 470 160 200 1 112 20 390 39 0 -2420 2721 2254 -35 290 269 291 613 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:52:49 0 151 2 270 125 -3 294 456 470 160 200 1 112 20 391 39 0 -2419 2720 2266 -35 290 270 291 613 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:53:49 0 150 1 270 123 -3 294 456 470 160 200 1 112 20 390 39 0 -2418 2720 2269 -35 290 269 291 613 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:54:49 0 150 1 270 122 -3 294 456 470 160 200 1 112 20 391 39 0 -2417 2720 2269 -35 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:55:49 0 150 -1 270 122 -4 294 456 470 160 200 1 112 20 389 39 0 -2416 2719 2257 -36 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:56:49 0 150 1 270 122 -4 294 456 470 160 200 1 112 20 390 39 0 -2416 2719 2269 -36 290 269 290 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:57:49 0 150 1 270 123 -4 294 456 470 160 200 1 112 20 390 39 0 -2416 2719 2256 -36 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:58:49 0 150 1 270 122 -5 294 456 469 160 200 1 112 20 390 39 0 -2416 2719 2261 -36 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 07:59:49 0 150 1 270 122 -4 294 456 469 160 200 1 112 20 391 39 0 -2416 2719 2267 -36 290 269 290 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:00:49 0 149 -1 270 122 -5 294 456 469 160 200 1 112 20 389 39 0 -2416 2720 2276 -36 290 269 290 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:01:49 0 149 -1 270 122 -5 294 455 469 160 200 1 112 20 390 39 0 -2417 2720 2273 -36 290 269 290 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:02:49 0 149 -3 269 121 -5 294 455 469 160 200 1 112 20 390 39 0 -2418 2720 2271 -36 290 269 290 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:03:49 0 147 -3 270 120 -6 294 455 469 160 200 1 112 20 390 39 0 -2419 2719 2255 -36 289 269 290 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:04:49 0 147 -3 269 120 -6 294 455 469 160 200 1 112 20 401 40 0 -2420 2719 2275 -36 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:05:51 0 147 -4 270 120 -6 294 455 469 160 200 1 112 20 400 40 0 -2420 2719 2258 -37 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:06:51 0 147 -5 270 120 -6 294 455 469 160 200 1 112 20 401 40 0 -2420 2719 2254 -38 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:07:51 0 147 -5 270 120 -6 294 455 469 160 200 1 112 20 400 40 0 -2420 2719 2273 -38 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:08:51 0 146 -6 269 118 -7 294 455 469 160 200 1 112 20 400 40 0 -2420 2719 2266 -38 290 269 291 614 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:09:51 0 146 -6 270 118 -7 294 455 469 160 200 1 112 20 399 40 0 -2420 2719 2257 -38 290 269 290 616 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:10:51 0 147 -5 269 120 -7 294 455 469 160 200 1 112 20 400 40 0 -2421 2718 2263 -38 290 269 290 616 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:11:51 0 146 -6 269 118 -7 294 455 469 160 200 1 112 20 401 40 0 -2422 2719 2265 -38 290 269 290 616 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:12:51 0 147 -5 270 120 -7 294 455 469 160 200 1 112 20 399 40 0 -2422 2718 2268 -38 290 269 291 616 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:13:51 0 149 -3 270 121 -7 294 455 469 160 200 1 112 20 400 40 0 -2422 2718 2264 -38 290 269 290 616 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:14:51 0 149 -3 270 121 -6 294 455 469 160 200 1 112 20 410 41 0 -2423 2718 2263 -39 290 269 291 617 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:15:51 0 149 -2 270 122 -7 294 455 469 160 200 1 112 20 410 41 0 -2423 2719 2267 -40 290 269 291 617 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:16:51 0 149 -3 270 121 -7 294 454 469 160 200 1 112 20 410 41 0 -2423 2718 2264 -40 290 269 291 617 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:17:51 0 150 -3 271 122 -6 294 454 469 160 200 1 112 20 410 41 0 -2423 2717 2268 -40 290 269 291 617 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:18:51 0 150 -1 271 122 -6 294 454 469 160 200 1 112 20 409 41 0 -2423 2719 2273 -40 290 269 291 618 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:19:51 0 149 -3 270 121 -6 294 454 469 160 200 1 112 20 411 41 0 -2423 2719 2269 -40 290 269 291 618 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:20:48 0 150 -1 270 122 -6 294 454 469 160 200 1 112 20 410 41 0 -2423 2720 2275 -40 290 269 291 618 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:21:48 0 149 -1 270 122 -6 294 454 469 160 200 1 112 20 411 41 0 -2423 2721 2273 -41 290 269 291 619 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:22:48 0 149 -3 271 121 -6 294 454 469 160 200 1 112 20 411 41 0 -2423 2721 2267 -42 290 269 291 619 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:23:48 0 150 -1 271 122 -5 294 454 469 160 200 1 112 20 410 41 0 -2423 2720 2263 -42 290 269 291 619 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:24:48 0 150 -1 270 122 -5 294 454 469 160 200 1 112 20 410 41 0 -2424 2721 2276 -41 290 269 291 619 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:25:48 0 149 -1 270 122 -6 294 454 468 160 200 1 112 20 420 42 0 -2425 2723 2289 -42 290 269 292 619 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:26:48 0 149 -3 270 121 -6 294 454 468 160 200 1 112 20 420 42 0 -2425 2723 2263 -42 290 269 291 621 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:27:48 0 149 -3 270 121 -6 294 454 468 160 200 1 112 20 420 42 0 -2426 2723 2264 -43 290 269 291 621 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:28:48 0 149 -3 270 121 -6 294 454 468 160 200 1 112 20 419 42 0 -2427 2724 2277 -44 291 269 291 621 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:29:48 0 149 -3 270 121 -6 294 454 468 160 200 1 112 20 420 42 0 -2428 2723 2262 -44 290 269 291 622 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:30:48 0 149 -3 271 121 -6 294 453 468 160 200 1 112 20 420 42 0 -2429 2724 2276 -44 290 269 291 622 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:31:48 0 149 -3 270 121 -6 294 453 468 160 200 1 112 20 420 42 0 -2430 2725 2276 -44 291 269 291 623 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:32:48 0 149 -3 270 121 -7 294 453 468 160 200 1 112 20 430 43 0 -2431 2724 2254 -44 291 269 292 623 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:33:48 0 149 -3 270 121 -6 294 453 468 160 200 1 112 20 429 43 0 -2431 2724 2275 -46 291 269 292 623 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:34:47 0 149 -3 271 121 -6 294 453 468 160 200 1 112 20 430 43 0 -2431 2724 2276 -46 291 269 292 624 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:35:48 0 149 -4 271 121 -6 294 453 468 160 200 1 112 20 430 43 0 -2431 2724 2266 -46 291 269 292 624 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:36:48 0 147 -5 271 120 -7 294 453 468 160 200 1 112 20 430 43 0 -2431 2724 2272 -46 291 269 292 626 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:37:48 0 147 -5 271 120 -7 294 453 468 160 200 1 112 20 430 43 0 -2431 2723 2261 -46 291 269 292 626 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:38:48 0 149 -3 271 121 -7 294 453 468 160 200 1 112 20 430 43 0 -2431 2722 2261 -46 291 269 292 626 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:39:48 0 148 -5 271 121 -7 294 453 468 160 200 1 112 20 430 43 0 -2431 2720 2271 -46 291 269 292 627 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:40:48 0 149 -5 271 121 -7 294 453 468 160 200 1 112 20 430 43 0 -2431 2721 2281 -46 291 269 292 627 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:41:48 0 149 -3 271 121 -7 294 453 468 160 200 1 112 20 430 43 0 -2431 2723 2269 -46 291 269 292 627 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:42:48 0 150 -1 271 122 -6 294 453 468 160 200 1 112 20 430 43 0 -2431 2723 2265 -47 291 269 292 627 268 -32768 -32768 -32768 90 3 0 0 2019-01-04 08:43:48 0 163 -1 274 129 -7 294 453 468 160 200 1 112 20 439 44 0 -2431 2674 1604 -51 291 269 291 628 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:44:48 0 173 1 274 139 -7 294 453 468 160 200 1 112 20 438 44 0 -2432 2577 1598 -66 291 270 291 629 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:45:48 0 175 -1 274 143 -6 294 452 468 160 200 1 112 20 440 44 0 -2433 2494 1594 -70 290 270 292 633 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:46:48 0 176 -1 274 143 -6 294 452 467 160 200 1 112 20 439 44 0 -2434 2422 1597 -75 290 270 291 634 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:47:48 0 175 -3 274 142 -6 294 452 467 160 200 1 112 20 441 44 0 -2437 2358 1599 -79 290 270 291 638 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:48:48 0 174 -3 274 142 -6 294 452 467 160 200 1 112 20 440 44 0 -2439 2303 1595 -78 290 270 291 640 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:49:48 0 174 -5 273 140 -7 294 452 467 160 200 1 112 20 449 45 0 -2441 2256 1601 -83 290 270 291 642 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:50:50 0 174 -5 274 140 -6 294 452 467 160 200 1 112 20 449 45 0 -2443 2213 1584 -82 290 270 291 645 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:51:50 0 173 -5 273 140 -7 294 452 467 160 200 1 112 20 451 45 0 -2445 2173 1584 -86 290 270 290 646 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:52:50 0 173 -5 273 140 -6 294 452 467 160 200 1 112 20 450 45 0 -2447 2139 1576 -85 290 270 291 649 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:53:50 0 173 -5 273 140 -7 294 452 467 160 200 1 112 20 460 46 0 -2449 2109 1591 -86 290 270 291 650 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:54:50 0 174 -5 273 140 -7 294 452 467 160 200 1 112 20 460 46 0 -2451 2082 1578 -89 290 270 291 651 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:55:50 0 174 -5 273 140 -7 294 452 467 160 200 1 112 20 460 46 0 -2453 2058 1577 -88 290 270 291 654 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:56:50 0 173 -5 273 140 -7 294 452 467 160 200 1 112 20 460 46 0 -2455 2038 1580 -91 290 270 291 655 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:57:50 0 174 -5 274 140 -7 294 452 467 160 200 1 112 20 460 46 0 -2457 2020 1582 -89 290 270 291 656 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:58:50 0 174 -5 274 140 -7 294 452 467 160 200 1 112 20 471 47 0 -2459 2005 1576 -90 290 270 291 658 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 08:59:50 0 174 -5 274 141 -7 294 452 467 160 200 1 112 20 470 47 0 -2461 1990 1571 -91 290 270 292 660 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:00:50 0 174 -6 274 140 -7 294 452 467 160 200 1 112 20 469 47 0 -2462 1978 1587 -91 290 270 292 660 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:01:50 0 174 -6 274 140 -8 294 452 467 160 200 1 112 20 470 47 0 -2463 1968 1579 -93 290 270 291 662 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:02:50 0 174 -6 274 140 -8 294 451 467 160 200 1 112 20 470 47 0 -2464 1959 1580 -90 290 270 292 663 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:03:50 0 174 -6 273 140 -8 294 451 467 160 200 1 112 20 470 47 0 -2464 1950 1577 -93 290 270 291 663 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:04:50 0 173 -6 274 140 -8 294 451 467 160 200 1 112 20 480 48 0 -2465 1942 1567 -92 290 270 292 664 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:05:52 0 174 -6 274 140 -7 294 451 467 160 200 1 112 20 478 48 0 -2465 1934 1570 -93 291 269 292 666 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:06:52 0 174 -6 274 140 -8 294 451 467 160 200 1 112 20 480 48 0 -2466 1929 1565 -96 291 270 292 667 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:07:52 0 174 -6 274 140 -8 294 451 467 160 200 1 112 20 481 48 0 -2466 1922 1575 -92 291 270 292 667 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:08:52 0 174 -5 274 141 -8 294 451 467 160 200 1 112 20 480 48 0 -2466 1918 1580 -98 291 270 291 668 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:09:52 0 175 -6 274 140 -8 294 451 466 160 200 1 112 20 480 48 0 -2466 1915 1571 -93 291 270 292 670 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:10:52 0 174 -6 274 140 -8 294 451 467 160 200 1 112 20 480 48 0 -2466 1911 1575 -96 291 270 291 669 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:11:52 0 174 -6 274 140 -9 294 451 466 160 200 1 112 20 480 48 0 -2467 1909 1585 -94 291 270 292 671 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:12:52 0 174 -6 274 140 -9 294 451 466 160 200 1 112 20 480 48 0 -2467 1906 1562 -94 291 270 291 671 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:13:52 0 174 -6 274 140 -9 294 451 466 160 200 1 112 20 480 48 0 -2468 1902 1565 -98 291 269 292 671 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:14:52 0 173 -7 274 140 -8 294 451 466 160 200 1 112 20 490 49 0 -2468 1900 1575 -93 291 269 292 673 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:15:52 0 173 -8 274 139 -9 294 451 466 160 200 1 112 20 489 49 0 -2470 1898 1570 -101 291 270 291 674 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:16:52 0 173 -8 274 139 -9 294 451 466 160 200 1 112 20 490 49 0 -2471 1896 1569 -94 291 270 293 675 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:17:52 0 173 -8 274 139 -9 294 451 466 160 200 1 112 20 489 49 0 -2472 1893 1552 -103 291 270 291 675 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:18:52 0 173 -8 274 139 -9 294 451 466 160 200 1 112 20 489 49 0 -2474 1888 1543 -96 290 269 293 678 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:19:52 0 173 -8 274 139 -9 294 451 466 160 200 1 112 20 491 49 0 -2474 1885 1553 -103 291 269 290 678 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:20:55 0 173 -8 274 139 -9 294 450 466 160 200 1 112 20 501 50 0 -2477 1882 1549 -101 290 269 293 681 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:21:55 0 173 -8 273 139 -9 295 450 466 160 200 1 112 20 500 50 0 -2477 1878 1537 -99 291 270 291 681 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:22:55 0 173 -8 274 139 -10 294 450 466 160 200 1 112 20 499 50 0 -2480 1875 1547 -107 291 269 292 684 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:23:55 0 174 -8 274 139 -9 295 450 466 160 200 1 112 20 500 50 0 -2480 1872 1547 -95 291 270 293 685 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:24:55 0 174 -6 274 140 -10 294 450 466 160 200 1 112 20 500 50 0 -2482 1871 1552 -109 291 270 291 685 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:25:55 0 174 -6 274 140 -9 295 450 466 160 200 1 112 20 500 50 0 -2483 1870 1550 -96 291 269 294 688 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:26:55 0 174 -6 274 140 -9 294 450 466 160 200 1 112 20 510 51 0 -2483 1868 1547 -107 291 270 291 687 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:27:55 0 174 -6 274 140 -9 294 450 466 160 200 1 112 20 510 51 0 -2485 1868 1548 -103 291 269 294 689 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:28:55 0 174 -8 274 140 -10 295 450 466 160 200 1 112 20 510 51 0 -2484 1866 1545 -104 292 269 291 689 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:29:55 0 174 -8 274 140 -10 294 450 466 160 200 1 112 20 510 51 0 -2487 1864 1543 -109 291 269 293 691 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:30:55 0 174 -8 274 140 -9 295 450 466 160 200 1 112 20 510 51 0 -2487 1862 1547 -98 291 269 293 691 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:31:55 0 174 -8 275 139 -10 294 450 465 160 200 1 112 20 509 51 0 -2489 1860 1534 -111 291 270 291 692 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:32:55 0 174 -8 274 139 -10 295 450 465 160 200 1 112 20 519 52 0 -2489 1858 1538 -98 291 269 294 694 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:33:55 0 174 -8 274 139 -10 294 450 465 160 200 1 112 20 520 52 0 -2489 1856 1522 -114 292 269 291 694 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:34:54 0 174 -8 274 139 -10 295 450 465 160 200 1 112 20 521 52 0 -2490 1852 1529 -103 291 270 294 696 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:35:56 0 174 -10 275 139 -10 295 449 465 160 200 1 112 20 519 52 0 -2489 1851 1539 -112 292 269 291 695 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:36:56 0 173 -10 275 139 -10 294 449 465 160 200 1 112 20 520 52 0 -2491 1850 1530 -107 291 270 294 698 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:37:56 0 173 -10 274 139 -10 296 449 465 160 200 1 112 20 520 52 0 -2490 1848 1533 -107 292 269 291 696 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:38:56 0 173 -10 275 139 -10 294 449 465 160 200 1 112 20 520 52 0 -2492 1848 1531 -112 291 269 293 699 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:39:56 0 173 -10 274 139 -10 296 449 465 160 200 1 112 20 520 52 0 -2491 1846 1537 -103 292 270 293 698 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:40:56 0 174 -10 275 139 -10 294 449 465 160 200 1 112 20 530 53 0 -2493 1845 1534 -115 292 269 292 699 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:41:56 0 174 -9 274 140 -10 296 449 465 160 200 1 112 20 530 53 0 -2493 1845 1535 -102 292 270 294 701 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:42:56 0 175 -8 275 140 -10 294 449 465 160 200 1 112 20 530 53 0 -2493 1843 1523 -118 292 269 292 701 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:43:56 0 175 -8 275 140 -10 295 449 465 160 200 1 112 20 529 53 0 -2493 1841 1520 -104 292 269 294 702 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:44:56 0 175 -8 275 140 -10 295 449 465 160 200 1 112 20 530 53 0 -2492 1839 1520 -118 292 269 291 702 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:45:56 0 176 -6 275 142 -10 295 449 465 160 200 1 112 20 530 53 0 -2493 1838 1528 -108 292 270 294 704 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:46:56 0 177 -5 275 143 -9 296 449 465 160 200 1 112 20 530 53 0 -2492 1837 1514 -114 292 270 291 702 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:47:56 0 176 -5 276 143 -8 295 449 465 160 200 1 112 20 530 53 0 -2495 1835 1525 -112 292 270 294 705 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:48:56 0 176 -5 275 143 -8 296 449 465 160 200 1 112 20 539 54 0 -2495 1834 1517 -110 292 270 292 704 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:49:56 0 177 -3 276 143 -8 295 449 465 160 200 1 112 20 539 54 0 -2498 1832 1513 -117 292 270 294 707 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:50:51 0 177 -3 275 143 -8 297 448 465 160 200 1 112 20 541 54 0 -2498 1829 1506 -110 292 270 293 705 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:51:51 0 177 -3 276 143 -7 295 448 465 160 200 1 112 20 539 54 0 -2500 1826 1509 -120 292 270 293 708 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:52:51 0 176 -5 275 143 -8 297 448 464 160 200 1 112 20 541 54 0 -2500 1825 1510 -108 292 270 294 708 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:53:51 0 175 -5 276 142 -8 295 448 464 160 200 1 112 20 549 55 0 -2502 1823 1499 -123 292 270 293 708 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:54:51 0 175 -6 276 142 -8 296 448 464 160 200 70 112 20 508 47 4 -2502 1819 1493 -109 292 270 294 710 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:55:51 0 186 -5 279 163 -8 288 448 464 160 200 0 112 20 0 0 64 -2503 1817 1506 -93 287 269 269 683 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:56:51 0 194 -5 268 177 -8 284 448 464 160 200 0 112 20 0 0 124 -2513 1815 1503 -40 278 271 269 646 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:57:51 0 191 -5 262 173 -8 283 448 464 160 200 0 112 20 0 0 184 -2531 1815 1522 -18 274 271 269 619 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:58:51 0 182 -5 257 159 -8 283 448 464 160 200 0 112 20 0 0 244 -2552 1817 1528 -7 272 274 270 605 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 09:59:51 0 169 -5 256 140 -8 284 448 464 160 200 0 112 20 0 0 304 -2574 1821 1546 -4 272 273 270 593 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:00:51 0 165 -5 256 133 -9 284 448 464 160 200 0 112 20 0 0 364 -2596 1824 1534 -2 271 271 270 580 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:01:51 0 163 -5 255 132 -8 285 448 463 160 200 0 112 20 0 0 424 -2619 1826 1535 -1 270 270 271 567 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:02:51 0 163 -5 254 132 -9 285 448 463 160 200 0 112 20 0 0 484 -2643 1829 1547 8 269 269 271 556 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:03:51 0 161 -5 253 131 -8 286 448 463 160 200 0 112 20 0 0 544 -2668 1832 1546 50 268 269 272 544 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:04:51 0 159 -6 252 128 -8 281 447 463 160 200 70 112 20 400 40 0 -2694 1835 1551 59 269 268 288 624 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:05:53 0 158 -6 255 125 -9 288 447 463 160 200 70 112 20 400 40 0 -2702 1842 1596 -2 277 268 284 640 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:06:53 0 159 -5 261 125 -9 287 447 463 160 200 59 112 20 400 40 0 -2712 1852 1598 -48 280 267 283 641 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:07:53 0 160 -5 263 125 -9 287 447 463 160 200 48 112 20 551 55 0 -2723 1860 1604 -54 281 267 289 643 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:08:53 0 160 -3 265 125 -8 293 447 463 160 200 43 112 20 550 55 0 -2726 1869 1609 -74 285 267 289 648 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:09:53 0 161 -1 268 123 -8 292 447 463 160 200 37 112 20 560 56 0 -2732 1877 1612 -93 287 267 290 656 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:10:53 0 161 1 269 123 -7 294 447 463 160 200 33 112 20 560 56 0 -2735 1884 1606 -98 288 267 290 662 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:11:53 0 161 1 270 122 -7 293 447 463 160 200 29 112 20 560 56 0 -2740 1889 1612 -110 288 267 290 669 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:12:53 0 161 0 271 121 -8 294 447 463 160 200 27 112 20 570 57 0 -2743 1894 1600 -103 289 268 292 674 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:13:53 0 161 1 271 121 -7 294 447 463 160 200 23 112 20 569 57 0 -2746 1896 1600 -117 290 268 291 679 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:14:53 0 160 1 272 121 -6 294 447 463 160 200 22 112 20 569 57 0 -2748 1900 1601 -106 290 268 294 684 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:15:53 0 159 -1 272 119 -7 295 447 463 160 200 19 112 20 579 58 0 -2749 1902 1598 -118 291 268 292 687 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:16:53 0 158 -3 272 117 -7 295 447 463 160 200 18 112 20 579 58 0 -2750 1903 1598 -111 291 269 294 692 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:17:53 0 158 -5 273 117 -7 296 447 463 160 200 16 112 20 580 58 0 -2750 1906 1599 -118 292 269 292 694 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:18:53 0 158 -5 273 116 -8 296 447 463 160 200 15 112 20 580 58 0 -2751 1908 1598 -115 292 269 294 699 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:19:53 0 158 -5 273 116 -7 297 447 463 160 200 14 112 20 579 58 0 -2751 1909 1589 -114 293 269 294 699 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:20:54 0 157 -5 274 116 -7 296 447 463 160 200 12 112 20 590 59 0 -2752 1909 1588 -118 293 269 294 702 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:21:54 0 157 -6 274 115 -8 297 446 463 160 200 11 112 20 590 59 0 -2752 1909 1610 -115 293 269 294 704 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:22:54 0 157 -6 274 115 -9 297 446 463 160 200 11 112 20 589 59 0 -2752 1911 1595 -121 294 269 294 705 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:23:54 0 156 -6 274 114 -9 297 446 463 160 200 10 112 20 589 59 0 -2752 1910 1583 -117 294 269 295 707 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:24:54 0 156 -6 275 115 -9 297 446 463 160 200 9 112 20 590 59 0 -2752 1909 1587 -122 294 269 294 708 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:25:54 0 157 -6 275 115 -9 297 446 463 160 200 8 112 20 590 59 0 -2752 1908 1589 -119 294 269 295 710 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:26:54 0 157 -6 275 115 -9 298 446 463 160 200 8 112 20 601 60 0 -2751 1908 1584 -121 294 269 295 710 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:27:54 0 156 -6 275 113 -9 298 446 463 160 200 7 112 20 600 60 0 -2750 1906 1586 -123 294 270 295 711 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:28:54 0 156 -8 275 113 -10 298 446 463 160 200 6 112 20 600 60 0 -2749 1904 1576 -122 294 270 295 713 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:29:54 0 156 -8 276 113 -10 298 446 463 160 200 6 112 20 600 60 0 -2748 1904 1588 -124 294 270 295 713 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:30:54 0 156 -8 275 113 -10 298 446 463 160 200 5 112 20 600 60 0 -2747 1903 1579 -123 294 270 295 714 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:31:54 0 156 -8 275 113 -10 298 446 463 160 200 5 112 20 600 60 0 -2746 1902 1579 -124 294 270 295 716 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:32:54 0 156 -8 276 113 -10 298 445 463 160 200 4 112 20 599 60 0 -2745 1901 1577 -124 294 270 295 716 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:33:54 0 156 -8 276 113 -11 299 444 463 160 200 4 112 20 600 60 0 -2744 1901 1587 -124 294 270 295 716 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:34:54 0 156 -8 276 113 -10 298 443 462 160 200 3 112 20 600 60 0 -2743 1900 1579 -124 294 270 295 717 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:35:57 0 156 -8 276 113 -10 299 442 462 160 200 3 112 20 600 60 0 -2742 1900 1583 -124 294 270 295 717 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:36:57 0 156 -9 276 113 -11 299 442 462 160 200 3 112 20 610 61 0 -2741 1900 1582 -125 294 270 296 719 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:37:57 0 156 -8 276 112 -11 299 442 462 160 200 2 112 20 610 61 0 -2739 1899 1578 -125 294 270 296 719 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:38:57 0 157 -6 276 113 -10 299 442 462 160 200 2 112 20 609 61 0 -2737 1899 1590 -126 294 270 296 720 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:39:57 0 157 -6 276 115 -11 299 442 462 160 200 2 112 20 609 61 0 -2735 1899 1579 -126 295 270 296 720 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:40:57 0 156 -7 276 113 -10 299 442 462 160 200 2 112 20 609 61 0 -2733 1899 1572 -126 295 270 296 722 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:41:57 0 157 -6 277 113 -11 299 442 462 160 200 1 112 20 611 61 0 -2731 1898 1582 -127 295 270 296 722 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:42:57 0 157 -6 277 115 -10 299 442 462 160 200 1 112 20 609 61 0 -2729 1896 1569 -126 295 270 296 722 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:43:57 0 157 -6 277 115 -11 299 442 462 160 200 1 112 20 610 61 0 -2727 1895 1566 -127 295 270 296 722 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:44:57 0 157 -6 277 114 -10 299 442 462 160 200 1 112 20 610 61 0 -2725 1893 1573 -128 295 270 296 723 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:45:57 0 157 -6 277 115 -10 299 441 462 160 200 1 112 20 610 61 0 -2723 1893 1570 -126 295 270 296 723 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:46:57 0 157 -8 277 113 -11 299 441 462 160 200 1 112 20 610 61 0 -2721 1891 1568 -128 295 270 296 723 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:47:57 0 157 -6 277 114 -10 299 440 462 160 200 1 112 20 610 61 0 -2719 1890 1566 -127 295 270 296 723 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:48:57 0 161 -6 278 121 -10 336 437 462 160 200 100 112 20 709 71 0 -2719 1888 1562 -127 289 269 404 745 386 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:50:02 0 175 -6 270 149 -11 409 431 462 160 200 100 112 20 711 71 0 -2719 1888 1574 -139 280 271 434 777 413 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:50:59 0 178 -5 263 153 -11 433 428 462 160 200 81 112 20 710 71 0 -2735 1888 1566 -123 274 272 446 805 420 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:51:59 0 176 -5 259 151 -11 447 428 462 160 200 60 112 20 710 71 0 -2755 1885 1564 -119 272 272 458 826 424 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:52:59 0 174 -6 257 149 -11 458 429 461 160 200 45 112 20 711 71 0 -2777 1884 1559 -120 271 272 472 847 427 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:53:59 0 173 -5 257 149 -11 471 432 462 160 200 34 112 20 710 71 0 -2800 1882 1561 -118 271 271 488 866 431 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:54:59 0 172 -5 256 147 -11 483 435 463 160 200 31 112 20 710 71 0 -2824 1881 1558 -118 270 270 500 882 434 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:55:59 0 171 -5 255 146 -11 495 438 464 160 200 30 112 20 710 71 0 -2849 1880 1547 -116 269 269 506 898 439 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:56:59 0 171 -6 254 146 -11 501 441 466 160 200 31 112 20 711 71 0 -2874 1878 1561 -115 268 268 512 911 444 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:57:59 0 169 -6 253 145 -11 507 444 467 160 200 33 112 20 709 71 0 -2900 1878 1566 -114 267 268 515 925 449 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:58:59 0 169 -6 252 145 -11 509 448 468 160 200 35 112 20 710 71 0 -2927 1877 1549 -113 267 267 517 936 454 -32768 -32768 -32768 66 0 0 0 2019-01-04 10:59:59 0 169 -6 252 145 -11 513 452 469 160 200 38 112 20 710 71 0 -2955 1874 1539 -111 266 267 518 946 458 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:00:59 0 168 -6 251 144 -11 514 455 471 160 200 42 112 20 710 71 0 -2983 1871 1550 -110 265 266 518 954 463 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:01:59 0 167 -6 251 144 -11 514 459 472 160 200 46 112 20 711 71 0 -3011 1870 1550 -110 265 266 519 963 467 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:02:59 0 167 -6 250 143 -12 515 463 472 160 200 51 112 20 710 71 0 -3040 1868 1546 -109 265 266 519 971 472 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:03:59 0 167 -6 250 144 -11 515 466 473 160 200 56 112 20 711 71 0 -3069 1865 1539 -109 264 265 519 979 477 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:05:02 0 167 -6 249 143 -11 516 469 474 160 200 63 112 20 710 71 0 -3099 1864 1549 -108 264 265 518 985 478 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:05:59 0 166 -8 249 143 -12 513 471 477 160 200 64 112 20 710 71 0 -3129 1862 1537 -108 264 265 513 988 475 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:06:59 0 166 -8 249 143 -12 510 473 478 160 200 69 112 20 709 71 0 -3160 1860 1538 -106 263 264 516 991 479 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:07:59 0 166 -6 249 143 -12 513 475 479 160 200 75 112 20 709 71 0 -3191 1858 1524 -106 263 264 518 997 484 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:08:59 0 165 -6 249 142 -11 515 477 481 160 200 83 112 20 709 71 0 -3222 1855 1538 -107 263 264 519 1000 490 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:09:59 0 165 -8 248 142 -11 515 479 483 160 200 89 112 20 710 71 0 -3253 1854 1531 -106 263 264 515 1006 486 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:10:59 0 165 -8 248 142 -12 514 481 484 160 200 95 112 20 709 71 0 -3284 1851 1526 -105 263 263 517 1009 491 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:11:59 0 164 -8 248 140 -12 516 482 486 160 200 100 112 20 710 71 0 -3317 1847 1514 -105 262 263 519 1013 494 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:12:59 0 165 -8 248 140 -12 516 484 489 160 200 100 112 20 710 71 0 -3350 1845 1524 -105 262 263 518 1016 493 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:13:59 0 165 -8 247 142 -12 517 486 490 160 200 100 112 20 710 71 0 -3383 1842 1512 -105 262 263 522 1019 498 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:14:59 0 164 -8 247 140 -12 521 488 491 160 200 100 112 20 711 71 0 -3416 1839 1516 -105 262 263 525 1022 501 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:15:59 0 164 -8 247 140 -11 524 490 493 160 200 100 112 20 631 63 0 -3449 1835 1508 -104 262 263 529 1025 497 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:16:59 0 165 -8 272 139 -12 365 492 494 160 200 100 112 20 610 61 0 -3449 1833 1516 -117 297 262 286 982 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:17:59 0 181 -6 280 152 -11 304 493 496 160 200 96 112 20 610 61 0 -3449 1831 1509 -111 291 263 284 943 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:18:59 0 185 -6 273 159 -12 293 494 496 160 200 82 112 20 610 61 0 -3460 1829 1515 -120 286 265 285 912 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:20:04 0 167 -6 266 132 -11 293 494 496 160 200 72 112 20 609 61 0 -3468 1827 1510 -125 286 266 287 886 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:21:01 0 151 -5 265 111 -11 294 495 496 160 200 62 112 20 620 62 0 -3475 1825 1499 -128 287 269 291 864 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:22:01 0 140 -5 265 98 -11 296 495 496 160 200 55 112 20 620 62 0 -3478 1823 1519 -129 289 269 293 846 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:23:01 0 134 -6 265 90 -11 297 495 495 160 200 49 112 20 630 63 0 -3480 1821 1508 -131 290 269 294 831 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:24:01 0 150 -6 274 106 -11 294 495 495 160 200 44 112 20 630 63 0 -3483 1819 1501 -132 291 264 289 817 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:25:01 0 166 -6 274 132 -11 294 495 495 160 200 39 112 20 640 64 0 -3489 1817 1499 -133 290 265 291 805 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:26:01 0 172 -5 273 139 -11 295 494 494 160 200 36 112 20 650 65 0 -3493 1814 1490 -137 290 266 292 796 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:27:01 0 173 -5 273 139 -12 296 494 494 160 200 33 112 20 649 65 0 -3495 1810 1483 -138 291 267 293 788 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:28:01 0 172 -6 274 138 -11 296 494 494 160 200 30 112 20 660 66 0 -3497 1807 1498 -140 291 267 293 782 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:29:01 0 172 -5 275 137 -12 297 494 494 160 200 28 112 20 659 66 0 -3499 1805 1478 -142 292 267 294 778 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:30:01 0 172 -6 275 137 -12 297 494 494 160 200 26 112 20 660 66 0 -3500 1801 1477 -144 292 267 294 773 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:31:01 0 172 -6 275 137 -12 297 494 494 160 200 24 112 20 671 67 0 -3501 1796 1472 -144 292 267 294 769 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:32:00 0 172 -6 275 137 -12 297 494 494 160 200 22 112 20 670 67 0 -3502 1792 1456 -146 293 267 294 768 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:33:00 0 172 -6 276 136 -11 297 494 494 160 200 20 112 20 680 68 0 -3503 1788 1465 -148 293 268 294 766 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:34:00 0 177 -6 280 145 -11 296 494 494 160 200 70 112 20 0 0 29 -3504 1782 1447 -148 293 263 277 761 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:35:06 0 204 -6 273 199 -11 282 494 493 160 200 0 112 20 0 0 89 -3507 1777 1463 -98 281 268 264 722 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:36:03 0 205 -6 264 196 -12 279 494 493 160 200 0 112 20 0 0 149 -3524 1779 1516 -52 274 269 265 689 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:37:03 0 202 -6 260 191 -11 279 494 493 160 200 0 112 20 0 0 209 -3547 1785 1524 -25 270 269 265 669 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:38:03 0 193 -5 257 176 -11 280 494 493 160 200 0 112 20 0 0 269 -3572 1792 1536 -11 269 269 266 651 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:39:03 0 188 -3 257 173 -11 280 494 493 160 200 0 112 20 0 0 329 -3598 1798 1537 -5 268 268 267 636 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:40:03 0 186 -3 256 172 -11 281 494 493 160 200 0 112 20 0 0 389 -3625 1805 1543 -3 267 268 268 622 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:41:03 0 182 -4 254 163 -11 282 494 492 160 200 0 112 20 0 0 449 -3653 1810 1537 17 266 267 269 607 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:42:03 0 180 -3 253 160 -10 283 494 492 160 200 70 112 20 0 0 0 -3682 1815 1526 53 265 266 270 594 262 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:43:03 0 176 -3 252 157 -10 280 494 492 160 200 70 112 20 400 40 0 -3712 1818 1553 53 266 265 285 675 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:44:03 0 176 -3 257 155 -10 285 494 492 160 200 70 112 20 399 40 0 -3724 1826 1588 -8 274 264 282 684 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:45:03 0 177 -3 263 156 -10 285 494 492 160 200 59 112 20 400 40 0 -3738 1838 1598 -51 278 264 280 680 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:46:03 0 178 -3 264 155 -9 285 494 492 160 200 48 112 20 573 58 0 -3753 1845 1586 -62 279 264 286 680 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:47:03 0 178 -3 265 153 -9 294 493 492 160 200 45 112 20 690 69 0 -3758 1853 1595 -83 283 263 291 682 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:48:03 0 180 -3 270 153 -9 294 493 492 160 200 41 112 20 699 70 0 -3764 1862 1606 -115 286 264 291 693 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:49:03 0 181 -1 272 153 -9 294 493 492 160 200 38 112 20 700 70 0 -3767 1870 1612 -128 288 264 289 699 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:50:07 0 182 -3 273 153 -8 294 493 492 160 200 35 112 20 709 71 0 -3773 1878 1618 -138 288 264 292 710 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:51:04 0 182 -3 274 153 -8 295 493 492 160 200 32 112 20 720 72 0 -3776 1884 1601 -137 290 265 292 717 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:52:04 0 182 -3 275 153 -8 295 493 492 160 200 30 112 20 720 72 0 -3779 1889 1608 -144 290 265 293 724 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:53:04 0 182 -1 275 153 -8 296 493 492 160 200 28 112 20 730 73 0 -3781 1894 1609 -142 291 265 294 729 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:54:04 0 182 -1 276 153 -8 296 493 492 160 200 26 112 20 730 73 0 -3782 1898 1607 -146 292 266 294 735 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:55:04 0 183 -3 277 153 -7 297 493 492 160 200 25 112 20 740 74 0 -3783 1901 1583 -147 292 266 294 740 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:56:04 0 183 -3 277 153 -7 297 493 492 160 200 23 112 20 740 74 0 -3784 1902 1593 -148 293 266 294 745 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:57:04 0 184 -3 278 153 -7 298 493 492 160 200 22 112 20 750 75 0 -3785 1902 1592 -150 293 266 295 750 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:58:04 0 184 -1 278 153 -6 298 493 492 160 200 21 112 20 750 75 0 -3785 1902 1578 -151 294 266 295 755 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 11:59:04 0 184 -1 279 153 -7 299 493 492 160 200 19 112 20 761 76 0 -3785 1901 1586 -153 294 267 295 758 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:00:04 0 184 -1 279 153 -7 299 493 492 160 200 18 112 20 759 76 0 -3785 1902 1582 -154 294 267 295 761 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:01:04 0 184 -1 279 153 -7 299 493 492 160 200 17 112 20 770 77 0 -3784 1901 1583 -156 294 267 296 766 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:02:04 0 184 -1 280 153 -6 300 492 492 160 200 17 112 20 770 77 0 -3783 1900 1584 -156 294 267 296 769 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:03:04 0 184 -1 280 153 -6 300 492 492 160 200 16 112 20 770 77 0 -3782 1900 1578 -158 294 267 296 773 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:04:04 0 184 -1 280 153 -6 300 492 492 160 200 15 112 20 780 78 0 -3781 1899 1576 -159 295 267 297 775 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:05:09 0 179 -1 279 144 -6 301 492 492 160 200 14 112 20 778 78 0 -3778 1897 1576 -159 295 269 299 778 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:06:06 0 172 -1 278 133 -6 302 492 492 160 200 14 112 20 780 78 0 -3773 1897 1579 -159 296 269 298 781 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:07:06 0 168 -1 279 129 -5 302 492 492 160 200 13 112 20 779 78 0 -3769 1896 1558 -159 297 269 298 783 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:08:06 0 168 -1 280 128 -6 302 492 492 160 200 12 112 20 780 78 0 -3765 1891 1552 -160 297 269 298 786 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:09:06 0 168 -1 280 128 -6 302 492 492 160 200 12 112 20 790 79 0 -3761 1888 1557 -162 297 269 299 788 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:10:06 0 167 -1 280 128 -5 302 492 492 160 200 11 112 20 790 79 0 -3756 1887 1573 -162 297 269 299 790 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:11:06 0 168 -1 280 128 -5 302 492 492 160 200 11 112 20 789 79 0 -3751 1884 1550 -162 297 269 299 792 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:12:06 0 168 1 280 128 -5 302 492 492 160 200 10 112 20 791 79 0 -3746 1882 1554 -163 297 269 299 794 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:13:06 0 168 1 280 128 -5 303 491 492 160 200 10 112 20 790 79 0 -3741 1880 1552 -163 297 269 299 796 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:14:06 0 168 1 281 128 -5 303 490 492 160 200 9 112 20 790 79 0 -3736 1877 1542 -162 298 269 300 796 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:15:06 0 168 -1 281 128 -4 303 490 491 160 200 9 112 20 790 79 0 -3731 1873 1535 -163 298 269 299 797 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:16:06 0 168 -1 281 128 -4 303 490 491 160 200 9 112 20 789 79 0 -3726 1869 1537 -165 298 269 300 797 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:17:06 0 168 -1 281 128 -4 303 490 491 160 200 8 112 20 789 79 0 -3720 1866 1542 -165 298 269 300 799 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:18:06 0 168 -1 281 127 -4 303 489 491 160 200 8 112 20 790 79 0 -3714 1864 1541 -165 298 270 300 799 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:19:06 0 168 -1 281 128 -3 303 489 491 160 200 8 112 20 790 79 0 -3708 1861 1527 -165 298 270 300 801 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:20:09 0 168 0 281 128 -3 303 489 491 160 200 7 112 20 790 79 0 -3702 1859 1529 -166 298 270 300 801 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:21:09 0 168 -1 281 128 -3 303 489 491 160 200 7 112 20 791 79 0 -3696 1855 1527 -166 298 270 300 801 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:22:09 0 168 0 281 128 -3 303 489 491 160 200 7 112 20 791 79 0 -3690 1851 1517 -166 298 270 300 802 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:23:09 0 168 1 281 128 -2 303 489 491 160 200 6 112 20 790 79 0 -3684 1848 1521 -166 298 270 300 803 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:24:09 0 168 1 281 128 -3 304 489 491 160 200 6 112 20 791 79 0 -3678 1844 1514 -166 298 270 300 803 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:25:09 0 168 1 281 128 -3 304 488 491 160 200 6 112 20 790 79 0 -3672 1840 1496 -166 298 270 300 803 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:26:09 0 168 -1 281 127 -3 303 488 491 160 200 5 112 20 789 79 0 -3666 1835 1506 -168 298 270 300 803 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:27:09 0 167 -1 281 127 -3 304 488 491 160 200 5 112 20 789 79 0 -3660 1831 1490 -169 298 270 300 805 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:28:09 0 167 -1 281 127 -2 304 488 491 160 200 5 112 20 790 79 0 -3653 1826 1495 -169 298 270 300 805 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:29:09 0 167 -1 281 127 -2 303 488 491 160 200 5 112 20 790 79 0 -3646 1821 1480 -169 298 270 300 805 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:30:09 0 168 -1 281 127 -2 303 488 491 160 200 4 112 20 790 79 0 -3639 1815 1476 -169 298 270 300 806 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:31:09 0 168 -1 281 127 -2 303 488 491 160 200 4 112 20 790 79 0 -3632 1809 1464 -169 298 270 300 807 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:32:09 0 167 -1 281 127 -2 303 488 491 160 200 4 112 20 790 79 0 -3625 1801 1453 -170 298 270 300 807 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:33:09 0 167 -1 281 127 -2 303 486 491 160 200 4 76 20 760 76 0 -3618 1793 1448 -171 298 270 299 807 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:34:09 0 168 -1 281 127 -2 302 486 491 160 200 3 74 20 740 74 0 -3612 1787 1446 -169 298 270 298 805 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:35:14 0 168 -1 281 128 -2 302 486 491 160 200 70 74 20 495 46 14 -3607 1779 1423 -166 297 270 296 803 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:36:11 0 179 0 283 146 -1 289 486 491 160 200 0 74 20 0 0 74 -3602 1770 1436 -128 290 270 270 767 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:37:11 0 186 1 270 160 -1 285 486 490 160 200 0 74 20 0 0 134 -3609 1769 1499 -70 279 271 271 726 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:38:11 0 183 0 263 158 -1 284 486 490 160 200 0 74 20 0 0 194 -3624 1775 1514 -33 275 272 271 700 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:39:11 0 180 1 260 155 -1 284 485 490 160 200 0 74 20 0 0 254 -3643 1781 1523 -11 272 272 272 680 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:40:11 0 177 2 258 153 -1 285 485 490 160 200 0 74 20 0 0 314 -3664 1787 1524 -5 271 272 272 661 270 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:41:11 0 176 2 257 152 -1 286 485 490 160 200 0 74 20 0 0 374 -3686 1791 1514 6 270 270 273 645 270 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:42:11 0 174 1 256 151 -1 286 485 490 160 200 0 74 20 0 0 434 -3709 1795 1531 38 269 269 274 628 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:43:11 0 174 2 255 150 -1 287 485 489 160 200 0 74 20 0 0 494 -3733 1799 1526 67 268 268 274 613 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:44:11 0 173 2 254 150 0 288 484 489 160 200 0 74 20 0 0 554 -3758 1804 1532 84 267 267 275 600 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:45:11 0 173 3 253 150 0 289 484 489 160 200 0 74 20 0 0 614 -3784 1808 1531 95 266 267 276 588 262 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:46:11 0 172 4 252 150 0 290 484 489 160 200 0 74 20 0 0 674 -3811 1813 1539 102 265 266 277 580 261 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:47:11 0 172 4 252 149 0 291 484 489 160 200 0 74 20 0 0 734 -3838 1818 1547 109 265 266 278 572 260 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:48:11 0 172 4 251 149 0 292 484 489 160 200 0 74 20 0 0 794 -3865 1822 1549 117 264 265 278 565 259 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:49:11 0 171 4 251 149 0 289 483 489 160 200 70 74 20 400 40 0 -3893 1828 1553 120 265 265 268 560 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:50:16 0 169 4 252 145 0 287 483 489 160 200 70 74 20 400 40 0 -3903 1832 1574 47 271 264 283 685 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:51:13 0 171 4 259 144 0 286 483 489 160 200 66 74 20 401 40 0 -3913 1842 1611 -20 277 264 280 682 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:52:13 0 173 4 263 145 0 284 483 489 160 200 52 74 20 439 44 0 -3926 1853 1600 -55 278 264 280 681 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:53:13 0 173 4 263 144 0 289 483 489 160 200 47 74 20 680 68 0 -3935 1860 1596 -60 280 264 292 681 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:54:12 0 173 4 266 143 0 294 482 489 160 200 44 75 20 740 74 0 -3935 1868 1610 -107 285 264 291 691 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:55:12 0 173 4 270 143 0 295 482 489 160 200 41 76 20 750 75 0 -3936 1876 1614 -123 288 264 292 701 263 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:56:12 0 175 4 273 143 0 294 482 489 160 200 37 76 20 750 75 0 -3938 1884 1626 -144 289 264 292 713 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:57:12 0 176 4 273 143 1 295 481 489 160 200 35 77 20 759 76 0 -3938 1891 1608 -139 290 265 294 723 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:58:12 0 176 4 274 143 0 295 481 489 160 200 33 77 20 759 76 0 -3938 1896 1610 -149 291 265 293 731 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 12:59:12 0 177 4 275 143 1 296 481 489 160 200 31 77 20 760 76 0 -3937 1902 1615 -146 292 266 294 739 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:00:12 0 176 4 276 143 1 297 481 489 160 200 29 78 20 770 77 0 -3936 1906 1613 -150 293 266 294 745 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:01:12 0 177 4 277 143 1 298 481 489 160 200 27 78 20 770 77 0 -3935 1909 1610 -150 293 266 295 751 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:02:12 0 176 4 277 143 1 298 481 489 160 200 26 78 20 769 77 0 -3933 1911 1609 -152 294 267 295 755 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:03:12 0 176 4 278 142 1 299 480 489 160 200 24 79 20 780 78 0 -3930 1914 1602 -153 294 267 296 759 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:04:12 0 176 2 278 142 0 299 480 489 160 200 23 79 20 780 78 0 -3926 1913 1581 -153 294 267 296 764 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:05:17 0 177 4 279 142 1 300 480 489 160 200 22 79 20 780 78 0 -3922 1913 1607 -155 294 267 296 768 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:06:14 0 176 4 279 142 1 300 480 489 160 200 21 79 20 779 78 0 -3918 1913 1590 -156 295 267 297 771 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:07:14 0 177 4 279 142 1 300 480 489 160 200 19 79 20 780 78 0 -3913 1912 1586 -156 295 268 297 775 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:08:14 0 177 4 280 143 1 300 480 489 160 200 18 79 20 781 78 0 -3908 1911 1580 -156 295 268 297 776 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:09:14 0 177 4 280 142 1 301 479 489 160 200 18 80 20 790 79 0 -3903 1909 1584 -158 296 268 298 780 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:10:14 0 177 3 280 142 1 301 479 489 160 200 17 80 20 790 79 0 -3897 1908 1576 -159 296 268 298 781 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:11:14 0 177 3 280 142 1 301 479 489 160 200 16 80 20 790 79 0 -3891 1905 1572 -159 296 268 298 785 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:12:14 0 177 2 280 142 1 301 479 489 160 200 15 80 20 789 79 0 -3885 1904 1580 -159 296 268 298 787 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:13:14 0 177 2 281 142 1 302 479 489 160 200 15 80 20 789 79 0 -3879 1900 1557 -159 296 268 298 788 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:14:14 0 177 2 281 142 1 302 479 489 160 200 14 80 20 790 79 0 -3873 1897 1576 -161 296 268 298 790 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:15:14 0 177 2 281 140 1 302 478 489 160 200 13 80 20 790 79 0 -3867 1895 1547 -161 297 268 299 790 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:16:14 0 177 2 281 140 2 302 478 489 160 200 13 80 20 790 79 0 -3860 1891 1564 -162 297 268 299 792 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:17:14 0 177 2 281 142 1 302 478 489 160 200 12 80 20 789 79 0 -3853 1889 1554 -162 297 269 299 794 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:18:14 0 177 2 281 142 2 302 478 489 160 200 12 80 20 789 79 0 -3846 1885 1537 -162 297 269 299 794 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:19:14 0 178 2 282 142 1 302 478 489 160 200 11 80 20 790 79 0 -3839 1881 1547 -162 297 269 299 796 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:20:16 0 178 4 281 142 2 303 477 489 160 200 11 80 20 790 79 0 -3832 1878 1551 -162 297 269 299 796 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:21:16 0 177 4 281 142 2 303 477 489 160 200 10 80 20 790 79 0 -3825 1876 1545 -162 297 269 299 797 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:22:16 0 177 3 282 142 1 303 477 489 160 200 10 80 20 789 79 0 -3818 1872 1541 -162 298 269 299 797 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:23:16 0 177 2 282 142 1 303 477 489 160 200 9 80 20 790 79 0 -3811 1870 1541 -162 298 269 299 797 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:24:16 0 177 2 282 142 1 303 477 489 160 200 9 80 20 790 79 0 -3804 1866 1532 -162 298 269 299 799 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:25:16 0 177 2 282 141 1 303 477 489 160 200 9 80 20 790 79 0 -3797 1863 1524 -164 297 269 299 799 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:26:16 0 177 2 282 140 1 303 476 489 160 200 8 80 20 790 79 0 -3790 1860 1531 -164 298 269 300 799 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:27:16 0 176 2 282 140 2 303 476 489 160 200 8 80 20 789 79 0 -3783 1857 1530 -166 298 269 299 799 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:28:16 0 177 2 282 140 2 303 476 488 160 200 7 80 20 789 79 0 -3775 1853 1525 -166 298 269 300 801 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:29:16 0 176 2 282 140 1 303 476 488 160 200 7 80 20 790 79 0 -3767 1850 1515 -166 298 269 299 801 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:30:16 0 176 1 282 140 1 303 476 488 160 200 7 80 20 780 78 0 -3758 1846 1509 -166 298 269 299 801 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:31:16 0 176 2 282 140 1 303 476 488 160 200 6 80 20 781 78 0 -3750 1842 1509 -165 298 269 299 801 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:32:16 0 176 2 282 140 1 303 476 488 160 200 6 80 20 780 78 0 -3742 1836 1494 -166 298 269 299 801 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:33:16 0 176 1 282 140 1 303 475 488 160 200 6 80 20 780 78 0 -3734 1831 1499 -166 298 269 299 801 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:34:16 0 176 2 282 140 2 303 475 488 160 200 6 80 20 781 78 0 -3726 1827 1490 -166 298 270 299 801 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:35:21 0 177 2 282 140 2 303 475 488 160 200 5 80 20 780 78 0 -3718 1821 1481 -166 297 269 299 801 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:36:18 0 177 2 282 140 1 303 475 488 160 200 5 80 20 779 78 0 -3710 1815 1473 -167 297 270 299 801 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:37:18 0 177 2 282 141 2 303 475 488 160 200 5 80 20 779 78 0 -3702 1809 1472 -168 297 270 299 801 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:38:18 0 177 2 282 140 1 302 475 488 160 200 4 80 20 780 78 0 -3694 1803 1458 -169 297 270 299 801 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:39:18 0 182 2 285 149 2 301 474 488 160 200 70 80 20 231 20 29 -3686 1795 1449 -167 298 265 283 799 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:40:18 0 210 2 279 205 1 285 474 488 160 200 0 80 20 0 0 89 -3680 1789 1475 -114 286 270 266 756 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:41:18 0 211 3 268 203 2 281 474 488 160 200 0 80 20 0 0 149 -3689 1790 1515 -57 277 271 267 717 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:42:18 0 207 4 263 196 2 281 474 488 160 200 0 80 20 0 0 209 -3705 1795 1536 -22 273 271 267 694 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:43:18 0 196 4 260 181 2 281 474 487 160 200 0 80 20 0 0 269 -3724 1801 1535 -7 271 271 268 674 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:44:18 0 193 4 259 177 2 281 474 486 160 200 0 80 20 0 0 329 -3744 1803 1513 -1 270 270 268 655 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:45:18 0 191 4 258 175 2 282 473 486 160 200 0 80 20 0 0 389 -3765 1806 1529 29 269 269 269 638 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:46:18 0 185 4 256 167 2 283 473 486 160 200 0 80 20 0 0 449 -3787 1808 1517 60 268 268 270 622 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:47:18 0 182 4 255 163 2 278 473 486 160 200 70 80 20 400 40 0 -3810 1811 1540 77 268 267 282 668 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:48:18 0 180 4 258 159 2 287 473 486 160 200 70 80 20 401 40 0 -3815 1819 1579 6 274 266 284 716 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:49:18 0 182 4 264 159 1 287 473 485 160 200 63 80 20 400 40 0 -3822 1828 1577 -35 279 266 282 709 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:50:23 0 182 4 266 159 2 286 473 485 160 200 50 80 20 500 50 0 -3832 1836 1574 -60 280 265 284 704 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:51:20 0 182 4 267 158 2 293 473 485 160 200 46 80 20 740 74 0 -3836 1843 1586 -65 283 265 295 703 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:52:20 0 182 4 271 157 2 296 472 485 160 200 44 80 20 780 78 0 -3832 1853 1606 -113 288 265 294 710 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:53:20 0 184 4 275 157 1 297 472 485 160 200 41 80 20 790 79 0 -3829 1862 1608 -130 291 265 294 719 264 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:54:20 0 183 4 275 155 2 296 472 485 160 200 38 80 20 790 79 0 -3827 1870 1599 -148 292 267 295 731 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:55:20 0 176 4 275 142 1 299 472 485 160 200 35 80 20 789 79 0 -3823 1877 1620 -149 293 267 295 740 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:56:20 0 172 4 276 134 1 298 472 485 160 200 33 80 20 789 79 0 -3819 1884 1597 -154 294 267 295 748 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:57:20 0 170 2 277 133 1 299 472 485 160 200 31 80 20 790 79 0 -3815 1887 1601 -153 294 267 296 755 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:58:20 0 169 2 277 132 1 299 472 485 160 200 30 81 20 800 80 0 -3810 1892 1595 -155 294 267 296 761 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 13:59:20 0 169 2 278 132 1 300 471 485 160 200 28 81 20 800 80 0 -3805 1893 1584 -156 295 268 297 766 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:00:20 0 169 2 278 131 1 300 471 485 160 200 26 81 20 800 80 0 -3799 1894 1586 -158 295 268 297 771 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:01:20 0 169 2 279 131 1 300 471 485 160 200 25 81 20 800 80 0 -3793 1894 1576 -159 295 268 297 776 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:02:20 0 168 2 279 131 1 301 471 485 160 200 24 81 20 799 80 0 -3787 1894 1586 -159 296 268 298 780 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:03:20 0 168 2 279 131 1 301 471 485 160 200 23 81 20 800 80 0 -3780 1894 1577 -161 296 268 298 781 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:04:20 0 168 2 280 129 2 301 471 485 160 200 22 81 20 800 80 0 -3773 1895 1583 -161 296 269 298 785 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:05:19 0 169 2 280 129 1 302 471 485 160 200 21 81 20 801 80 0 -3766 1896 1586 -162 297 269 298 788 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:06:16 0 168 2 280 129 1 302 470 485 160 200 20 81 20 800 80 0 -3759 1895 1572 -162 297 269 298 790 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:07:16 0 168 2 280 129 1 302 470 485 160 200 19 81 20 800 80 0 -3751 1894 1570 -162 297 269 299 792 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:08:16 0 168 2 280 129 2 302 470 485 160 200 18 81 20 790 79 0 -3743 1892 1562 -162 297 269 299 792 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:09:16 0 169 2 281 129 1 302 470 485 160 200 17 81 20 790 79 0 -3735 1889 1555 -162 297 269 299 794 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:10:16 0 168 2 281 129 1 302 470 485 160 200 16 81 20 789 79 0 -3727 1886 1560 -162 297 269 299 794 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:11:16 0 168 2 280 129 2 302 470 485 160 200 15 81 20 791 79 0 -3719 1885 1563 -162 298 269 299 796 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:12:16 0 168 1 280 129 1 303 469 485 160 200 15 81 20 790 79 0 -3711 1884 1561 -162 298 269 299 796 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:13:16 0 168 1 281 128 1 303 469 485 160 200 14 81 20 790 79 0 -3703 1883 1563 -162 298 269 299 796 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:14:16 0 168 2 281 129 1 303 469 485 160 200 13 81 20 790 79 0 -3695 1881 1557 -162 298 269 299 797 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:15:16 0 168 1 281 128 2 303 469 485 160 200 13 81 20 790 79 0 -3686 1879 1554 -162 298 270 300 797 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:16:16 0 168 1 281 128 1 303 469 485 160 200 12 81 20 791 79 0 -3678 1876 1548 -162 298 269 300 797 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:17:16 0 168 1 281 128 2 303 469 485 160 200 12 81 20 781 78 0 -3669 1874 1544 -162 298 269 299 797 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:18:16 0 167 1 281 128 2 303 469 485 160 200 11 81 20 779 78 0 -3661 1871 1544 -162 298 270 300 797 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:19:16 0 167 1 281 127 2 303 468 485 160 200 11 81 20 780 78 0 -3652 1869 1549 -162 298 270 300 797 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:20:16 0 167 1 281 128 2 303 468 485 160 200 10 81 20 780 78 0 -3643 1866 1544 -162 298 270 300 797 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:21:16 0 168 1 281 128 1 303 468 485 160 200 10 81 20 780 78 0 -3634 1863 1529 -162 298 270 300 797 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:22:16 0 168 1 281 128 1 303 468 485 160 200 9 81 20 770 77 0 -3625 1860 1531 -162 298 270 299 797 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:23:16 0 167 1 281 127 2 303 468 485 160 200 9 81 20 770 77 0 -3617 1858 1539 -162 298 270 299 796 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:24:16 0 167 1 281 127 2 303 468 485 160 200 8 81 20 770 77 0 -3609 1855 1524 -162 298 270 299 796 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:25:16 0 167 1 281 127 1 303 468 485 160 200 8 81 20 771 77 0 -3600 1852 1530 -162 298 270 300 796 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:26:16 0 167 1 281 127 1 303 468 485 160 200 8 81 20 770 77 0 -3591 1849 1519 -162 298 270 300 796 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:27:16 0 167 1 281 127 1 303 467 485 160 200 7 81 20 771 77 0 -3582 1846 1524 -162 298 270 299 796 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:28:16 0 167 0 281 127 1 303 467 485 160 200 7 81 20 760 76 0 -3573 1843 1520 -162 298 270 299 795 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:29:16 0 167 1 281 127 1 303 467 484 160 200 7 81 20 759 76 0 -3565 1840 1505 -162 298 270 299 794 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:30:16 0 167 -1 281 127 1 303 467 484 160 200 6 81 20 760 76 0 -3557 1835 1496 -162 298 270 299 794 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:31:16 0 166 -1 281 126 1 303 467 484 160 200 6 81 20 760 76 0 -3549 1830 1505 -162 298 270 299 794 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:32:16 0 167 -1 281 126 1 303 467 484 160 200 6 81 20 760 76 0 -3541 1827 1502 -162 298 270 299 792 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:33:16 0 166 0 281 126 1 303 467 484 160 200 5 81 20 760 76 0 -3533 1823 1481 -162 298 270 299 792 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:34:16 0 167 0 280 126 1 303 467 484 160 200 5 81 20 759 76 0 -3525 1818 1491 -162 298 270 299 792 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:35:21 0 167 -1 281 127 0 302 466 484 160 200 5 81 20 750 75 0 -3517 1814 1479 -162 298 270 299 792 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:36:18 0 167 -1 281 127 1 302 466 484 160 200 4 81 20 751 75 0 -3509 1808 1467 -162 297 270 299 792 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:37:18 0 167 -1 280 127 0 302 466 484 160 200 4 81 20 750 75 0 -3501 1801 1469 -162 297 270 299 790 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:38:18 0 166 -1 280 126 1 302 466 484 160 200 4 81 20 750 75 0 -3493 1795 1450 -165 297 270 299 790 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:39:18 0 166 -1 280 126 1 302 466 484 160 200 4 81 20 750 75 0 -3486 1788 1452 -166 297 270 299 790 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:40:18 0 167 -1 281 127 1 302 466 484 160 200 70 81 20 357 33 21 -3478 1781 1429 -165 297 269 291 788 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:41:18 0 182 -1 282 152 1 287 466 484 160 200 0 81 20 0 0 81 -3472 1773 1451 -122 288 269 269 750 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:42:18 0 187 -1 268 165 1 283 465 484 160 200 0 81 20 0 0 141 -3479 1773 1502 -60 278 271 270 710 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:43:18 0 184 -1 262 161 1 283 463 484 160 200 0 81 20 0 0 201 -3493 1779 1514 -27 274 272 270 687 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:44:18 0 171 -1 257 141 1 283 461 484 160 200 0 81 20 0 0 261 -3511 1784 1524 -9 273 274 271 667 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:45:18 0 159 -1 256 123 0 284 460 483 160 200 0 81 20 0 0 321 -3529 1790 1531 -4 272 273 271 649 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:46:18 0 153 -1 255 117 0 284 460 483 160 200 0 81 20 0 0 381 -3548 1795 1516 3 271 271 272 633 269 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:47:18 0 151 -1 254 115 -1 285 460 483 160 200 0 81 20 0 0 441 -3568 1799 1518 34 270 270 273 617 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:48:18 0 150 -1 253 113 -1 282 460 483 160 200 70 81 20 399 40 0 -3590 1801 1510 65 269 269 269 603 268 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:49:18 0 146 -1 252 111 -1 287 459 483 160 200 70 81 20 399 40 0 -3596 1805 1558 20 274 268 286 707 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:50:23 0 145 0 257 108 -1 289 459 483 160 200 67 81 20 401 40 0 -3601 1815 1578 -24 280 268 284 704 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:51:20 0 145 -1 261 107 -1 288 459 482 160 200 52 81 20 440 44 0 -3609 1824 1565 -58 282 267 284 699 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:52:20 0 145 -1 262 105 -1 292 459 482 160 200 47 81 20 680 68 0 -3614 1832 1580 -61 283 267 295 698 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:53:20 0 145 -1 264 104 -1 297 459 482 160 200 44 81 20 750 75 0 -3608 1841 1598 -101 289 266 294 702 265 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:54:20 0 145 -1 269 103 -2 298 459 482 160 200 41 81 20 760 76 0 -3605 1851 1601 -120 291 267 296 713 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:55:20 0 146 -1 271 103 -1 297 459 482 160 200 38 81 20 761 76 0 -3601 1859 1588 -140 293 267 294 722 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:56:20 0 146 -1 273 103 -2 298 458 482 160 200 35 81 20 760 76 0 -3598 1864 1585 -143 294 267 295 731 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:57:20 0 146 -1 273 102 -1 298 457 483 160 200 33 81 20 761 76 0 -3594 1870 1598 -148 294 267 295 737 266 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:58:20 0 146 -1 274 102 -2 299 457 482 160 200 31 81 20 760 76 0 -3590 1876 1594 -149 294 268 296 745 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 14:59:20 0 146 -1 274 102 -2 299 457 482 160 200 29 81 20 761 76 0 -3585 1879 1578 -149 294 268 296 750 267 -32768 -32768 -32768 66 0 0 0 2019-01-04 15:00:20 0 145 -1 274 100 -2 300 457 482 160 200 27 81 20 759 76 0 -3580 1881 1583 -152 295 269 297 755 268 -32768 -32768 -32768 66 0 0 0
