[NIBL;20170201;6859] Divisors 1 1 10 10 10 10 10 10 10 10 10 10 10 10 10 10 1 1 10 10 10 1 10 10 10 10 10 Date Time Version(43001) R-Version(44331) BT1 Outdoor temp [°C] BT2 Supply temp S1 [°C] BT3 Return temp [°C] BT6 Hot Water load [°C] BT7 Hot Water top [°C] BT10 Brine in temp [°C] BT11 Brine out temp [°C] BT12 Cond. out [°C] BT14 Hot gas temp [°C] BT17 Suction [°C] BT50 Room Temp S1 [°C] Calculated Supply Temperature S1 [°C] Degree Minutes Compressor Frequency, Actual [Hz] GP1 [%] GP2 [%] Ström Ph1 Ström Ph2 Ström Ph3 Prio EP21-BT2 Supply temp S2 [°C] EP21-BT3 Return temp S2 [°C] Calculated Supply Temperature S2 [°C] EP21-BT50 Room Temp S2 [°C] Room sensor factor S2 43001 44331 40004 40008 40012 40014 40013 40015 40016 40017 40018 40022 40033 43009 43005 43136 43437 43439 40083 40081 40079 43086 40007 40129 43008 40032 47401
