SELECT [timestamp] ,[rad_return] ,[rad_forward] ,[heatcarrier_return] ,[heatcarrier_forward] ,[brine_in] ,[brine out] ,[outdoor] ,[indoor] ,[Hot_water_1_Top] ,[Hot_water_2_Mid] ,[Hot_gas_Compr] ,[Compressor_is] ,[Add_Heat_1] ,[Add_heat_2] ,[Pump_Cold_circuit] ,[Pump_Heat_circuit] ,[Pump_Radiator] ,[Switch_Valve] ,[Alarm] ,[Add_heat_status] ,[Heating_setpoint] ,[Warm_water_setpoint] ,[Room_temp_setpoint] ,[Room_sensor_influence] ,[Heat_set_1_CurveL] ,[Heat_set_3_Parallel] ,[deviceid] INTO [SAOutputtoSQL] FROM [SAInputTemplogger]
