using System; using System.Collections.Generic; using System.Data; using System.Linq; using System.Web; using System.Web.UI; using System.Web.UI.DataVisualization.Charting; using System.Web.UI.WebControls; public partial class _Default : Page { protected void Page_Load(object sender, EventArgs e) { Chart1.ChartAreas[0].AxisY.Interval = 10; Chart1.ChartAreas[0].AxisY.LabelStyle.Format = "{0}°C"; Chart1.ChartAreas[0].AxisX.LabelStyle.Format = "yyyy-MM-dd HH:mm"; Chart1.ChartAreas[0].AxisX.LabelStyle.Angle = 30; if (DropDownList1.SelectedValue.ToString() == "-24") { Chart1.ChartAreas[0].AxisX.IntervalType = DateTimeIntervalType.Hours; Chart1.ChartAreas[0].AxisX.Interval = 1; } var dataview = (DataView)SqlDataSource2.Select(DataSourceSelectArguments.Empty); foreach (DataRowView dataviewrow in dataview) { lblpumpstarts.Text = "Pump Starts: " + dataviewrow["stopstarts"].ToString(); } var dataview1 = (DataView)SqlDataSource3.Select(DataSourceSelectArguments.Empty); foreach (DataRowView dataviewrow1 in dataview1) { lblvalveopens.Text = "Valve Opens: " + dataviewrow1["valveopen"].ToString(); } DateTime stoptime = DateTime.Now; DateTime starttime = DateTime.Now; int totalminutes = 0; string state = null; var dataview3 = (DataView)SqlDataSource4.Select(DataSourceSelectArguments.Empty); foreach (DataRowView dataviewrow3 in dataview3) { { if (dataviewrow3["Compressor_is"].ToString() != "0") { starttime = Convert.ToDateTime(dataviewrow3["timestamp"]); state = "started"; lbllastupdate.Text = "Last update:" + dataviewrow3["timestamp"].ToString(); } else { if (state != null) { stoptime = Convert.ToDateTime(dataviewrow3["timestamp"]); TimeSpan runtime = stoptime.Subtract(starttime); state = null; totalminutes = totalminutes + Convert.ToInt32(runtime.TotalMinutes) ; lbllastupdate.Text = "Last update: " + dataviewrow3["timestamp"].ToString(); } } } } // Response.Write(totalminutes / 60); // Response.Write(SqlDataSource4.SelectCommand.ToString()); lblcomptime.Text = "Compressor time: " + totalminutes / 60 + " hours"; } }
