Divisors		10	10	10	10	10	10	10	10	10	10	10	10	10	10	100	1	10	10	10	10	1	1	10	10	10	1	1	1	100	100	10	10
Date	Time	Outdoor temp	Calc. Supply	Supply temp	Return temp	Hot water load	Hot water top	Condensor Out	Hot Gas Temp	Evaporator temp	Suction temp	Exhaust air temp	Vented air temp	BS1 Air flow	Air flow reference	Addition power[kW]	Supply CP speed	Degree minutes	Comp Freq. [Hz]	Outdoor average	Room temp	PCA Base relays	Prio	Current L1 [A]	Current L2 [A]	Current L3 [A]	Alarm number	Comp starts	Comp time [h]	Comp energy [kWh]	Comp en. HW [kWh]	Add.heating[kWh]	Add.hot water[kWh]
2022-11-23	11:28:02	21	341	236	222	440	452	227	459	91	112	200	89	-32768	-32768	0	0	0	0	-32768	203	6	10	0	0	0	998	23683	36421	3845565	797395	479842	72620
2022-11-23	11:28:59	21	341	236	222	440	452	229	444	100	127	200	98	-32768	-32768	0	0	-119	0	21	203	6	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:29:59	22	341	233	224	440	452	225	434	115	147	200	99	-32768	-32768	0	100	-238	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:30:59	22	341	231	224	440	452	226	423	135	161	200	103	-32768	-32768	0	100	-356	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:31:59	22	341	230	224	440	451	225	414	152	172	200	107	-32768	-32768	0	100	-473	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:32:59	22	341	230	224	440	451	226	404	161	178	200	109	-32768	-32768	0	100	-590	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:33:59	22	341	229	224	439	451	225	397	166	184	200	112	-32768	-32768	0	100	-707	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:34:59	22	341	229	224	438	451	225	390	168	187	200	116	-32768	-32768	0	100	-824	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:35:59	23	341	229	224	437	451	225	386	170	191	201	122	-32768	-32768	0	100	-941	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:36:59	24	341	229	224	436	450	225	381	172	194	200	126	-32768	-32768	0	100	-1058	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:37:59	24	341	229	224	435	450	225	377	173	196	200	129	-32768	-32768	0	100	-1175	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:38:59	24	341	229	224	435	450	225	373	173	197	200	132	-32768	-32768	0	100	-1292	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:39:59	24	341	229	223	433	450	225	370	174	198	200	136	-32768	-32768	0	100	-1409	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:40:59	24	341	229	223	432	450	225	367	175	198	200	138	-32768	-32768	0	100	-1527	0	21	203	3	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:41:59	24	341	224	221	431	450	226	364	175	199	200	142	-32768	-32768	0	0	-1645	0	21	203	6	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:43:05	25	341	225	222	431	450	228	361	175	199	200	146	-32768	-32768	0	0	-1765	0	21	203	6	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:44:02	26	341	226	222	430	450	229	358	175	199	200	150	-32768	-32768	0	0	-1885	0	21	203	6	10	0	0	0	0	23683	36421	3845565	797395	479842	72620
2022-11-23	11:45:02	26	341	226	222	430	450	224	356	175	199	200	151	-32768	-32768	0	70	-2006	223	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:46:02	26	341	232	220	429	450	240	447	70	61	199	107	-32768	-32768	0	70	-2006	400	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:47:02	26	341	235	220	429	450	238	455	-20	-13	199	65	-32768	-32768	0	68	-2108	401	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:48:02	26	341	235	220	429	450	237	465	-60	69	199	44	-32768	-32768	0	53	-2212	381	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:49:02	26	341	234	220	429	450	232	473	-56	108	199	44	-32768	-32768	0	39	-2319	230	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:50:02	26	341	232	220	429	450	234	480	-36	131	199	51	-32768	1979	0	29	-2427	259	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:51:02	26	341	233	220	429	450	237	486	-28	80	199	52	-32768	1979	0	22	-2532	291	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:52:02	27	341	234	220	429	450	237	493	-39	68	199	47	-32768	1979	0	18	-2636	319	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:53:02	27	341	235	220	428	450	239	502	-47	113	199	41	-32768	1979	0	15	-2739	350	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:54:02	26	341	237	221	428	450	241	510	-51	22	199	38	-32768	1979	0	12	-2840	382	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:55:02	27	341	238	221	427	450	242	519	-63	91	199	31	-32768	1979	0	11	-2941	410	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:56:02	27	341	240	221	427	450	244	529	-65	17	199	29	-32768	1979	0	9	-3039	439	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:57:02	27	340	241	221	426	450	244	538	-77	73	199	24	-32768	1979	0	8	-3137	470	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:58:07	27	340	243	221	426	449	247	550	-79	4	199	21	-32768	1979	0	7	-3231	500	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	11:59:04	26	340	244	222	425	449	248	565	-89	64	199	18	-32768	1979	0	7	-3325	529	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:00:04	27	340	245	222	424	449	249	578	-94	14	199	15	-32768	1979	0	6	-3416	561	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:01:04	26	340	246	222	424	449	251	592	-101	12	199	11	-32768	1979	0	6	-3507	591	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:02:04	27	340	247	222	423	449	251	604	-110	39	199	8	-32768	1979	0	5	-3597	620	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:03:04	26	340	248	223	422	449	252	617	-116	-7	199	2	-32768	1979	0	5	-3685	650	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:04:04	26	340	249	223	422	449	254	633	-123	1	199	-1	-32768	1979	0	5	-3773	681	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:05:04	26	340	250	223	421	449	254	648	-131	18	199	-6	-32768	1979	0	4	-3860	710	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:06:04	26	340	251	224	420	449	255	662	-136	-15	199	-10	-32768	1979	0	4	-3945	740	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:07:04	26	340	252	224	420	449	257	679	-141	-12	199	-12	-32768	1979	0	4	-4030	771	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:08:04	26	340	253	224	420	448	257	695	-148	2	198	-17	-32768	1979	0	4	-4113	801	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:09:04	26	340	254	224	419	448	259	711	-153	-24	199	-23	-32768	1979	0	3	-4195	830	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:10:04	26	340	255	225	418	448	260	728	-158	-39	199	-26	-32768	1979	0	3	-4276	859	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:11:04	26	340	256	225	418	448	261	744	-164	-17	198	-26	-32768	1979	0	3	-4356	890	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:12:04	26	340	257	225	417	448	262	761	-169	-10	198	-27	-32768	1979	0	3	-4435	920	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:13:11	26	340	258	225	416	448	262	778	-171	-12	198	-31	-32768	1979	0	3	-4513	900	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:14:08	24	340	259	226	415	448	262	787	-170	-17	198	-32	-32768	1979	0	3	-4591	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:15:08	24	340	259	226	415	448	262	794	-167	-20	198	-34	-32768	1979	0	3	-4669	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:16:08	24	340	259	226	414	448	263	799	-166	-19	198	-34	-32768	1979	0	3	-4746	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:17:08	24	340	259	227	413	447	263	803	-166	-15	198	-36	-32768	1979	0	3	-4823	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:18:08	24	340	260	227	413	447	263	807	-166	-19	198	-35	-32768	1979	0	3	-4900	871	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:19:08	24	340	260	227	412	447	263	810	-166	-18	198	-36	-32768	1979	0	3	-4977	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:20:08	24	340	260	228	411	447	264	812	-166	-15	198	-35	-32768	1979	0	3	-5053	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:21:08	24	340	261	228	410	447	264	814	-166	-19	198	-36	-32768	1979	0	3	-5129	871	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:22:08	24	340	261	228	409	447	265	816	-166	-19	198	-36	-32768	1979	0	3	-5205	869	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:23:08	24	340	261	228	408	447	265	818	-166	-19	198	-36	-32768	1979	0	3	-5280	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:24:08	24	340	261	228	408	447	265	820	-166	-16	198	-37	-32768	1979	0	3	-5355	871	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:25:08	22	340	262	229	407	446	265	822	-166	-17	198	-36	-32768	1979	0	3	-5430	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:26:08	22	340	262	229	406	446	265	822	-166	-17	198	-36	-32768	1979	0	3	-5505	869	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:27:08	22	340	262	229	405	446	265	823	-166	-17	198	-36	-32768	1979	0	3	-5579	871	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:28:11	22	340	262	229	404	446	266	823	-166	-19	198	-36	-32768	1979	0	3	-5653	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:29:08	21	340	262	229	404	446	266	823	-166	-17	198	-37	-32768	1979	0	3	-5727	870	22	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:30:08	21	340	263	229	403	446	266	825	-166	-15	198	-38	-32768	1979	0	2	-5801	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:31:08	21	340	263	230	402	445	267	825	-166	-17	198	-38	-32768	1979	0	2	-5875	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:32:08	21	340	263	230	401	445	266	825	-166	-15	198	-38	-32768	1979	0	2	-5949	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:33:08	20	340	263	230	399	445	267	825	-166	-15	198	-40	-32768	1979	0	2	-6022	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:34:08	19	340	263	230	396	445	267	825	-165	-17	198	-40	-32768	1979	0	2	-6095	870	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:35:08	19	340	263	230	395	445	267	825	-166	-17	198	-42	-32768	1979	0	2	-6168	870	21	204	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:36:08	19	340	264	230	394	445	267	825	-165	-15	198	-44	-32768	1979	0	2	-6241	870	21	204	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:37:08	19	340	264	230	392	445	267	825	-166	-15	199	-44	-32768	1979	0	2	-6314	871	21	203	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:38:08	18	340	264	230	391	444	267	825	-165	-15	198	-44	-32768	1979	0	2	-6387	870	21	204	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:39:08	18	340	264	231	390	444	268	825	-166	-15	199	-46	-32768	1979	0	2	-6460	870	21	204	3	30	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:40:08	18	340	264	305	389	444	315	830	-165	-19	198	-47	-32768	1979	0	70	-6532	871	21	204	15	20	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:41:08	18	340	327	374	387	444	409	864	-155	-10	199	-48	-32768	1979	0	70	-6532	870	21	204	15	20	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:42:08	18	341	380	393	386	443	433	896	-150	27	199	-33	-32768	1979	0	63	-6630	869	21	204	15	20	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:43:15	17	341	410	400	386	443	451	920	-141	-1	200	-34	-32768	1979	0	50	-6734	870	21	204	15	20	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:44:12	16	341	428	404	388	443	463	939	-140	2	200	-40	-32768	1979	0	47	-6841	878	21	204	15	20	0	0	0	0	23684	36421	3845565	797395	479842	72620
2022-11-23	12:45:12	16	341	441	410	391	443	470	959	-141	-1	200	-42	-32768	1979	0	47	-6949	899	21	204	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:46:12	16	341	450	416	396	444	476	977	-143	-2	200	-46	-32768	1979	0	49	-7058	919	21	204	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:47:12	16	341	456	422	401	446	478	994	-146	-6	200	-50	-32768	1979	0	53	-7168	939	21	204	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:48:12	16	341	461	428	406	448	482	1013	-148	-7	200	-54	-32768	1979	0	59	-7278	960	21	204	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:49:12	14	341	464	435	411	449	483	1031	-150	-5	200	-54	-32768	1979	0	67	-7389	970	21	204	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:50:12	14	341	466	441	417	450	484	1045	-150	-5	200	-54	-32768	1979	0	76	-7501	970	21	205	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:51:12	14	341	468	448	421	450	485	1059	-149	-3	200	-55	-32768	1979	0	87	-7613	971	21	205	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:52:12	14	341	469	453	426	450	486	1070	-148	-1	199	-56	-32768	1979	0	100	-7726	970	21	205	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:53:12	14	341	471	458	431	450	491	1082	-147	0	199	-56	-32768	1979	0	100	-7840	970	21	205	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:54:12	14	341	475	463	435	449	495	1089	-145	-2	200	-57	-32768	1979	0	100	-7955	969	21	205	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:55:12	14	341	479	466	439	449	499	1097	-145	-1	199	-58	-32768	1979	0	100	-8070	970	21	205	15	20	0	0	0	0	23684	36422	3845673	797395	479842	72620
2022-11-23	12:56:12	14	341	482	469	442	451	500	1105	-141	13	200	-56	-32768	1979	0	100	-8186	806	21	205	15	20	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	12:57:12	13	342	477	466	445	454	471	1057	-96	50	200	-24	-32768	1979	0	0	-8303	0	21	205	6	20	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	12:58:18	13	342	468	463	448	455	471	955	-28	83	200	2	-32768	1979	0	0	-8420	0	21	205	6	20	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	12:59:15	13	343	464	461	451	456	474	818	-10	117	200	14	-32768	1979	0	0	-8420	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:00:15	13	343	461	459	452	456	479	723	13	143	200	7	-32768	1979	0	0	-8420	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:01:15	13	343	460	452	453	455	485	684	63	163	201	19	-32768	1979	0	0	-8539	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:02:15	13	342	459	436	453	455	489	679	86	162	202	44	-32768	1979	0	0	-8659	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:03:15	13	342	458	426	453	455	491	678	98	160	202	59	-32768	1979	0	0	-8778	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:04:15	13	342	457	419	453	455	491	677	106	159	202	66	-32768	1979	0	0	-8897	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:05:15	13	342	456	411	453	454	491	675	112	159	202	72	-32768	1979	0	0	-9016	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:06:15	13	342	456	406	453	454	490	674	118	159	202	75	-32768	1979	0	0	-9136	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:07:15	14	342	455	401	453	454	489	673	122	160	202	78	-32768	1979	0	0	-9256	0	21	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:08:15	14	342	455	397	453	454	488	671	126	160	202	80	-32768	1979	0	0	-9376	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:09:15	14	342	455	393	453	454	486	669	130	161	202	83	-32768	1979	0	0	-9496	0	21	205	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:10:15	14	343	455	390	453	454	485	667	135	163	202	86	-32768	1979	0	0	-9616	0	21	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:11:15	14	343	453	387	453	454	484	664	140	166	202	88	-32768	1979	0	0	-9738	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:12:15	14	343	453	386	453	454	483	662	144	169	202	92	-32768	1979	0	0	-9860	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:13:18	14	343	452	384	453	454	482	659	149	172	202	96	-32768	1979	0	0	-9982	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:14:18	16	343	451	382	453	454	481	655	151	175	202	100	-32768	1979	0	0	-10104	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:15:18	16	343	450	380	453	454	481	653	154	177	202	103	-32768	1979	0	0	-10226	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:16:18	16	343	450	378	453	454	479	649	158	180	202	105	-32768	1979	0	0	-10349	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:17:18	16	343	450	376	453	454	478	646	160	182	202	107	-32768	1979	0	0	-10471	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:18:18	17	343	450	374	453	454	477	643	162	185	202	109	-32768	1979	0	0	-10594	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:19:18	18	343	449	371	453	454	476	640	163	188	202	112	-32768	1979	0	0	-10717	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:20:18	18	343	448	369	453	454	475	636	164	191	202	113	-32768	1979	0	0	-10840	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:21:18	18	343	448	366	453	454	474	633	165	193	202	116	-32768	1979	0	0	-10963	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:22:18	18	343	446	363	453	454	473	629	165	194	202	117	-32768	1979	0	0	-11086	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:23:18	18	343	445	361	453	453	472	626	166	195	202	118	-32768	1979	0	0	-11209	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:24:18	19	343	445	358	452	454	471	623	166	195	202	120	-32768	1979	0	0	-11332	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:25:18	19	343	445	356	452	454	469	619	166	195	202	121	-32768	1979	0	0	-11455	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:26:18	19	343	444	354	452	454	468	617	167	196	202	122	-32768	1979	0	0	-11578	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:27:18	19	343	444	352	452	453	467	613	168	196	202	123	-32768	1979	0	0	-11701	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:28:25	21	343	443	349	452	453	466	610	168	197	202	125	-32768	1979	0	0	-11824	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:29:22	21	343	442	347	452	453	464	606	169	197	202	126	-32768	1979	0	0	-11948	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:30:22	21	343	442	345	452	453	463	603	169	197	202	127	-32768	1979	0	0	-11990	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:31:22	21	343	441	343	452	453	461	600	171	197	202	127	-32768	1979	0	0	-11990	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:32:22	21	343	441	341	452	453	460	596	171	197	202	128	-32768	1979	0	0	-11990	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:33:22	22	343	441	340	452	453	458	594	172	197	202	129	-32768	1979	0	0	-11990	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:34:22	22	343	440	338	452	453	457	590	172	197	202	129	-32768	1979	0	0	-11990	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:35:22	22	342	440	336	452	453	455	587	172	197	202	131	-32768	1979	0	0	-11990	0	20	207	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:36:22	22	342	439	335	452	453	454	585	172	197	202	131	-32768	1979	0	0	-11990	0	20	207	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:37:22	22	342	439	333	452	453	452	581	173	198	202	132	-32768	1979	0	0	-11990	0	20	206	6	30	0	0	0	183	23684	36422	3845673	797395	479842	72620
2022-11-23	13:38:22	24	342	436	262	452	453	310	582	173	198	202	132	-32768	-32768	0	70	-11990	0	20	206	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:39:22	24	342	315	220	452	453	247	711	86	111	203	95	-32768	-32768	0	70	-11990	579	20	206	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:40:22	24	342	273	219	451	453	255	661	-26	-48	202	42	-32768	-32768	0	70	-11990	820	20	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:41:22	24	342	261	219	451	453	251	641	-119	-125	202	10	-32768	-32768	0	67	-11990	931	20	206	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:42:22	24	342	253	220	451	453	250	669	-119	-18	202	1	-32768	-32768	0	63	-11990	941	20	206	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:43:26	24	342	251	220	450	453	251	699	-125	-23	202	-9	-32768	-32768	0	59	-11990	951	20	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:44:23	24	342	251	221	450	453	252	727	-163	-33	202	-6	-32768	1998	0	56	-11990	960	20	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:45:23	24	343	252	221	450	453	253	751	-175	-30	202	-14	-32768	1998	0	54	-11990	937	20	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:46:23	24	343	252	222	450	453	253	768	-173	-26	202	-17	-32768	1998	0	51	-11990	900	20	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:47:23	24	343	252	223	449	453	254	778	-168	-21	203	-14	-32768	1998	0	48	-11990	880	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:48:23	24	343	253	223	449	453	255	787	-164	-25	203	-15	-32768	1998	0	46	-11990	880	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:49:23	24	343	254	224	449	452	256	794	-160	-23	203	-17	-32768	1998	0	44	-11990	880	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:50:23	24	343	255	224	448	453	257	801	-156	-23	203	-19	-32768	1998	0	42	-11990	879	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:51:23	24	343	255	225	447	453	257	807	-154	-22	203	-21	-32768	1998	0	40	-11990	879	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:52:23	24	343	256	225	447	453	258	810	-150	-23	203	-22	-32768	1998	0	38	-11990	880	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:53:23	24	343	256	225	446	452	259	814	-140	-23	204	-23	-32768	1998	0	37	-11990	880	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:54:23	24	343	257	226	446	452	259	818	-128	-25	204	-25	-32768	1998	0	36	-11990	890	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:55:23	23	343	257	226	445	452	260	822	-125	-25	204	-26	-32768	1998	0	34	-11990	900	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:56:23	22	342	258	226	444	452	261	827	-126	-24	204	-28	-32768	1998	0	33	-11990	910	21	207	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:57:23	22	342	259	226	443	453	261	831	-126	-26	204	-30	-32768	1998	0	33	-11990	919	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:57:28	22	342	259	227	442	452	262	835	-126	-26	204	-30	-32768	1998	0	32	-11990	930	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:58:25	22	341	260	227	441	452	263	841	-126	-28	204	-32	-32768	1998	0	31	-11990	940	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	13:59:25	22	341	260	227	441	452	263	845	-126	-28	204	-33	-32768	1998	0	31	-11990	949	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:00:25	22	341	261	227	440	452	264	851	-127	-30	204	-34	-32768	1998	0	30	-11990	960	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:01:25	21	341	261	228	439	452	264	855	-129	-32	204	-36	-32768	1998	0	29	-11990	969	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:02:24	21	341	262	228	438	452	265	862	-130	-34	204	-38	-32768	1998	0	29	-11990	979	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:03:24	21	341	262	228	438	452	266	866	-137	-34	204	-41	-32768	1998	0	28	-11990	990	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:04:24	21	341	263	228	437	452	266	870	-146	-34	204	-44	-32768	1998	0	29	-11990	1001	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:05:24	20	341	264	228	436	452	267	876	-162	-33	204	-46	-32768	1998	0	29	-11990	1010	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:06:24	19	341	264	229	435	452	266	879	-176	-32	204	-49	-32768	1998	0	28	-11990	990	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:07:24	19	341	264	229	435	452	266	879	-179	-25	204	-50	-32768	1998	0	28	-11990	950	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:08:24	19	342	263	229	434	452	265	877	-176	-18	204	-48	-32768	1998	0	27	-11990	910	21	208	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:09:24	19	342	263	229	433	452	265	870	-172	-12	204	-46	-32768	1998	0	26	-11990	870	21	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:10:24	18	343	262	230	432	452	265	862	-167	-6	204	-44	-32768	1998	0	26	-11990	860	21	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:11:24	18	343	263	230	431	452	265	855	-163	-10	204	-43	-32768	1998	0	25	-11990	861	21	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:12:25	18	343	263	230	431	451	265	849	-162	-12	204	-44	-32768	1998	0	24	-11990	860	21	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:13:25	18	343	263	230	430	451	265	845	-163	-10	204	-46	-32768	1998	0	23	-11990	860	21	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:14:25	17	343	263	230	429	451	265	841	-164	-10	204	-47	-32768	1998	0	23	-11990	860	21	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:15:25	16	343	263	231	428	451	266	839	-163	-11	204	-50	-32768	1998	0	22	-11990	860	21	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:16:25	16	343	263	230	427	451	266	835	-164	-13	203	-50	-32768	1998	0	22	-11990	861	21	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:17:25	16	343	263	231	426	451	266	833	-165	-10	203	-52	-32768	1998	0	21	-11990	861	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:18:25	16	343	263	231	425	451	266	831	-166	-9	203	-52	-32768	1998	0	20	-11990	860	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:19:25	15	343	264	231	425	451	266	829	-166	-8	203	-53	-32768	1998	0	20	-11990	860	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:20:25	14	343	264	231	424	451	266	827	-166	-10	203	-53	-32768	1998	0	19	-11990	859	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:21:25	14	343	264	231	423	451	267	827	-166	-10	203	-53	-32768	1998	0	18	-11990	861	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:22:25	14	342	264	231	422	451	267	825	-166	-10	203	-54	-32768	1998	0	18	-11990	859	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:23:25	14	342	264	231	421	451	267	825	-166	-12	203	-54	-32768	1998	0	17	-11990	859	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:24:25	13	342	264	231	420	450	267	823	-166	-12	203	-53	-32768	1998	0	17	-11990	860	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:25:25	13	342	264	231	420	450	267	823	-167	-9	203	-55	-32768	1998	0	16	-11990	861	20	209	3	30	0	0	0	0	23685	36422	3845673	797395	479842	72620
2022-11-23	14:26:25	13	342	264	231	419	450	267	823	-167	-12	203	-57	-32768	1998	0	16	-11990	860	20	209	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:27:28	13	342	264	231	418	450	267	822	-168	-12	203	-58	-32768	1998	0	15	-11990	860	20	209	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:28:25	13	342	264	231	418	450	267	822	-169	-12	203	-59	-32768	1998	0	15	-11990	860	20	209	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:29:25	13	342	264	232	416	450	267	822	-169	-13	203	-59	-32768	1998	0	14	-11990	860	20	209	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:30:25	11	343	264	232	416	450	267	822	-169	-17	203	-60	-32768	1998	0	14	-11990	860	20	209	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:31:25	11	343	264	231	415	450	267	822	-169	-10	202	-60	-32768	1998	0	14	-11990	860	20	209	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:32:25	11	343	264	232	414	450	268	822	-169	-15	202	-60	-32768	1998	0	13	-11990	860	20	209	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:33:25	11	343	265	232	413	450	267	822	-169	-15	203	-60	-32768	1998	0	13	-11990	860	20	209	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:34:25	11	343	265	232	412	450	267	822	-170	-17	203	-59	-32768	1998	0	12	-11990	860	20	210	3	30	0	0	0	0	23685	36423	3845817	797395	479842	72620
2022-11-23	14:35:25	11	343	259	232	411	449	237	801	-145	1	203	-44	-32768	1998	0	0	-11990	0	20	209	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:36:25	9	343	249	233	410	449	240	728	-56	37	203	-5	-32768	1998	0	0	-11990	0	20	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:37:25	9	343	246	234	410	449	244	677	-17	67	203	4	-32768	1998	0	0	-11990	0	20	209	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:38:25	9	343	245	234	409	449	250	642	-8	88	203	12	-32768	1998	0	0	-11990	0	20	209	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:39:25	9	343	245	235	409	448	257	618	-1	104	203	17	-32768	1998	0	0	-11990	0	20	209	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:40:25	9	343	245	235	409	448	263	606	30	118	203	37	-32768	1998	0	0	-11990	0	20	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:41:25	9	343	245	235	409	448	268	588	67	129	203	50	-32768	1998	0	0	-11990	0	20	209	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:42:31	9	343	246	236	409	448	272	564	89	139	203	61	-32768	1998	0	0	-11990	0	20	209	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:43:28	9	343	246	236	408	448	274	549	102	147	203	68	-32768	1998	0	0	-11990	0	20	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:44:28	9	344	246	237	408	448	275	540	111	150	203	72	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:45:28	10	344	245	239	408	448	276	534	118	151	203	76	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:46:28	11	344	245	240	408	447	276	527	124	152	203	79	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:47:28	11	344	245	243	408	447	276	521	129	153	203	82	-32768	1998	0	0	-11990	0	19	209	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:48:28	11	344	245	246	408	447	276	516	135	156	203	84	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:49:28	11	344	245	248	408	447	276	510	140	157	203	87	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:50:28	11	344	245	251	407	447	276	506	145	159	203	90	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:51:28	11	344	245	253	407	447	276	502	150	161	203	92	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:52:28	11	344	245	256	407	447	275	498	155	164	204	94	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:53:28	12	344	244	258	407	447	275	495	158	167	204	96	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:54:28	13	344	244	260	407	447	275	492	160	169	204	99	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:55:28	13	344	244	262	407	447	274	489	163	173	204	102	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:56:28	13	344	244	265	407	447	274	486	164	175	204	104	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:57:32	13	344	244	267	406	447	274	483	166	177	204	107	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:58:32	13	344	244	269	406	447	274	481	167	181	204	109	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	14:59:32	14	344	244	270	406	447	274	478	168	184	204	111	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:00:32	14	344	244	272	406	446	274	476	169	187	204	112	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:01:32	14	344	244	274	406	446	273	474	171	190	204	113	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:02:38	16	344	244	275	406	446	273	471	171	192	204	115	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:03:38	16	344	244	277	406	446	273	469	171	193	204	116	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:04:38	16	344	243	278	406	446	272	467	172	194	204	117	-32768	1998	0	0	-11990	0	19	209	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:05:38	16	344	244	279	405	446	272	465	172	195	205	118	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:06:38	18	344	244	280	403	446	272	463	173	196	204	120	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:07:38	18	344	244	281	403	446	272	461	174	197	205	120	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:08:38	18	344	244	282	403	446	272	459	174	197	204	121	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:09:38	18	344	244	283	402	446	271	457	174	198	204	121	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:10:38	18	344	244	284	402	446	271	455	174	198	204	122	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:11:38	19	344	244	284	402	445	271	453	174	198	204	122	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:12:42	19	344	244	285	402	445	271	451	175	198	204	123	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:13:42	19	344	244	285	402	445	271	449	175	198	204	123	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:14:42	19	344	244	285	402	445	270	447	175	198	204	123	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:15:42	20	344	244	286	402	445	270	445	175	198	204	123	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:16:42	21	344	244	286	401	445	270	443	175	198	204	124	-32768	1998	0	0	-11990	0	19	210	6	30	0	0	0	183	23685	36423	3845817	797395	479842	72620
2022-11-23	15:17:42	21	344	239	222	401	445	247	535	160	139	204	118	-32768	-32768	0	70	-11990	459	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:18:42	21	344	244	221	400	445	253	572	17	-8	203	55	-32768	-32768	0	70	-11990	701	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:19:42	21	344	248	221	400	445	253	549	-83	-97	202	11	-32768	-32768	0	67	-11990	860	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:20:41	21	344	247	221	399	445	249	576	-123	-7	202	-1	-32768	-32768	0	61	-11990	870	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:21:41	22	344	247	221	399	444	250	612	-142	-39	202	-6	-32768	-32768	0	58	-11990	880	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:22:41	22	344	248	221	399	444	252	645	-161	-13	202	-11	-32768	2037	0	54	-11990	890	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:23:41	23	344	249	222	399	445	253	674	-168	-19	202	-23	-32768	2037	0	51	-11990	899	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:24:41	24	343	250	222	398	444	254	700	-171	-21	202	-25	-32768	2037	0	49	-11990	890	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:25:41	24	343	251	223	398	444	254	719	-171	-13	202	-26	-32768	2037	0	46	-11990	860	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:26:41	24	343	251	223	398	444	255	733	-166	-11	202	-26	-32768	2037	0	44	-11990	851	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:27:44	24	343	252	224	397	444	256	745	-165	-19	202	-28	-32768	2037	0	42	-11990	850	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:28:44	24	343	253	224	397	444	256	755	-164	-15	202	-30	-32768	2037	0	40	-11990	850	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:29:44	24	343	253	225	396	444	257	763	-163	-12	201	-32	-32768	2037	0	38	-11990	849	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:30:44	24	343	254	225	395	444	258	771	-164	-12	201	-34	-32768	2037	0	36	-11990	850	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:31:44	24	343	255	226	395	444	258	778	-163	-15	201	-36	-32768	2037	0	35	-11990	850	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:32:44	22	343	256	226	394	444	259	783	-162	-13	201	-38	-32768	2037	0	33	-11990	851	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:33:44	22	343	256	226	394	443	260	788	-163	-14	201	-38	-32768	2037	0	32	-11990	850	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:34:44	22	343	257	227	393	444	260	792	-162	-15	202	-39	-32768	2037	0	31	-11990	850	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:35:44	22	343	257	227	392	443	261	796	-162	-19	200	-39	-32768	2037	0	30	-11990	849	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:36:44	22	343	257	227	392	443	261	799	-162	-17	200	-39	-32768	2037	0	29	-11990	850	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:37:44	21	343	258	228	391	443	262	801	-162	-13	200	-38	-32768	2037	0	28	-11990	850	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:38:44	21	343	258	228	390	443	262	803	-162	-15	200	-40	-32768	2037	0	27	-11990	850	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:39:44	21	343	258	228	390	443	262	805	-162	-14	200	-39	-32768	2037	0	26	-11990	850	19	210	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:40:44	21	343	284	356	389	443	378	828	-160	-77	200	-40	-32768	2037	0	100	-11990	851	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:41:44	21	343	353	392	387	443	418	863	-131	19	200	-38	-32768	2037	0	100	-11990	850	19	210	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:42:51	21	343	393	404	386	442	435	893	-121	-8	200	-33	-32768	2037	0	82	-11990	871	19	210	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:43:48	21	342	415	409	388	442	449	921	-104	-8	200	-30	-32768	2037	0	64	-11990	890	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:44:48	21	342	430	414	392	442	461	945	-100	-14	200	-30	-32768	2037	0	58	-11990	911	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:45:48	21	342	441	418	397	442	467	968	-105	-13	200	-27	-32768	2037	0	56	-11990	929	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:46:48	19	342	449	422	402	443	473	991	-107	-21	200	-25	-32768	2037	0	57	-11990	951	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:47:48	19	342	455	429	407	445	478	1013	-108	-12	200	-25	-32768	2037	0	61	-11990	950	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:48:48	19	342	460	435	412	446	480	1030	-117	-6	200	-25	-32768	2037	0	68	-11990	950	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:49:48	19	342	463	442	418	448	483	1045	-134	-6	200	-26	-32768	2037	0	76	-11990	951	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:50:48	19	342	466	448	422	448	485	1059	-137	-3	200	-28	-32768	2037	0	87	-11990	949	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:51:48	18	342	469	454	427	448	486	1070	-140	-3	200	-32	-32768	2037	0	100	-11990	950	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:52:48	18	342	471	459	432	449	491	1082	-141	-2	200	-37	-32768	2037	0	100	-11990	948	19	210	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:53:48	18	342	474	463	436	449	495	1089	-139	2	200	-40	-32768	2037	0	100	-11990	950	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:54:48	18	342	478	467	440	451	499	1097	-138	2	200	-43	-32768	2037	0	100	-11990	950	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:55:48	18	342	483	470	443	453	501	1101	-134	16	200	-44	-32768	2037	0	100	-11990	900	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:56:48	18	342	485	473	447	456	503	1101	-126	24	200	-41	-32768	2037	0	100	-11990	849	19	209	15	20	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:57:52	18	342	487	476	450	458	504	1097	-118	30	200	-38	-32768	2037	0	100	-11990	799	19	209	11	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:58:52	17	342	397	229	453	460	258	1055	-116	58	200	-38	-32768	2037	0	100	-11990	800	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	15:59:52	16	343	301	227	455	462	254	1004	-132	-3	200	-42	-32768	2037	0	98	-11990	800	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:00:52	16	343	270	227	457	461	253	967	-146	-16	200	-48	-32768	2037	0	90	-11990	800	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:01:52	16	343	260	227	458	460	254	940	-151	5	200	-52	-32768	2037	0	83	-11990	800	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:02:52	16	343	257	226	458	460	254	916	-153	-3	199	-52	-32768	2037	0	76	-11990	810	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:03:52	16	343	256	226	458	459	255	895	-155	-4	199	-53	-32768	2037	0	70	-11990	820	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:04:52	16	343	256	226	457	459	256	879	-157	-3	199	-54	-32768	2037	0	65	-11990	830	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:05:52	15	343	256	227	457	459	257	868	-159	-6	199	-57	-32768	2037	0	61	-11990	840	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:06:52	14	343	257	227	457	459	258	858	-161	-6	199	-59	-32768	2037	0	57	-11990	851	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:07:52	14	343	258	227	456	459	259	849	-164	-8	199	-61	-32768	2037	0	54	-11990	860	19	209	3	30	0	0	0	0	23686	36423	3845817	797395	479842	72620
2022-11-23	16:08:52	14	343	258	228	456	460	260	843	-166	-6	199	-63	-32768	2037	0	50	-11990	869	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:09:52	14	343	259	228	456	460	261	839	-168	-8	199	-65	-32768	2037	0	48	-11990	879	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:10:52	14	343	260	228	456	460	262	837	-170	-12	199	-67	-32768	2037	0	46	-11990	889	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:11:52	14	343	260	229	455	460	262	835	-171	-10	199	-68	-32768	2037	0	43	-11990	860	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:12:51	14	343	260	229	455	460	262	831	-169	-1	199	-66	-32768	2037	0	41	-11990	840	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:13:51	13	343	260	229	455	459	262	827	-166	-6	199	-65	-32768	2037	0	39	-11990	840	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:14:51	13	343	260	229	454	460	262	823	-166	-6	199	-65	-32768	2037	0	37	-11990	840	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:15:51	13	343	261	229	454	459	263	820	-166	-6	199	-65	-32768	2037	0	35	-11990	840	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:16:51	13	343	261	229	454	459	263	818	-166	-8	199	-65	-32768	2037	0	33	-11990	840	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:17:51	13	343	261	229	453	459	263	816	-166	-6	199	-65	-32768	2037	0	32	-11990	840	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:18:51	13	343	261	230	453	459	264	814	-166	-8	199	-65	-32768	2037	0	31	-11990	840	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:19:51	13	343	262	230	452	459	264	812	-167	-8	199	-65	-32768	2037	0	29	-11990	839	19	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	16:20:51	11	343	261	230	452	460	255	808	-166	-6	199	-65	-32768	2037	0	70	-11990	413	19	209	3	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:21:51	11	343	250	231	452	459	236	754	-96	30	199	-24	-32768	2037	0	0	-11990	0	19	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:22:51	11	343	246	232	451	459	240	694	-31	64	199	-3	-32768	2037	0	0	-11990	0	19	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:23:51	11	343	245	232	451	459	244	653	-11	86	199	10	-32768	2037	0	0	-11990	0	19	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:24:51	11	343	244	233	451	458	250	617	-6	104	199	8	-32768	2037	0	0	-11990	0	19	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:25:51	11	344	244	233	451	458	256	580	10	133	199	15	-32768	2037	0	0	-11990	0	19	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:26:51	11	344	245	234	451	458	262	555	43	146	199	36	-32768	2037	0	0	-11990	0	19	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:27:56	11	344	245	234	451	458	266	542	70	149	199	50	-32768	2037	0	0	-11990	0	19	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:28:56	11	344	245	235	451	458	270	535	89	150	199	59	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:29:56	11	344	245	236	450	458	272	531	104	151	200	65	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:30:56	11	344	245	238	450	458	274	525	115	152	200	70	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:31:56	11	344	245	240	450	457	275	520	121	155	200	74	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:32:56	11	344	245	242	450	457	275	515	127	156	200	78	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:33:56	13	344	245	244	450	457	276	510	133	158	200	80	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:34:56	13	344	245	247	450	457	276	506	138	159	200	83	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:35:56	13	344	245	249	450	458	276	502	143	163	200	86	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:36:55	13	344	245	250	449	458	276	499	149	166	200	90	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:37:55	13	344	245	252	448	458	276	496	153	169	200	92	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:38:55	13	344	245	255	447	457	276	493	156	173	200	95	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:39:55	14	344	244	257	447	457	276	490	158	176	200	99	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:40:55	14	344	244	259	446	457	276	488	159	180	200	100	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:42:01	14	344	244	261	446	457	277	484	161	182	200	103	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:42:58	14	344	244	263	446	457	276	482	163	184	200	104	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:43:58	14	344	244	265	446	457	277	480	164	186	202	107	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:44:58	14	344	244	266	445	457	276	477	165	187	202	109	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:45:58	16	344	244	268	445	457	276	475	167	189	202	109	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:46:58	16	344	244	270	445	456	276	473	167	190	202	111	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:47:58	16	344	244	271	445	456	277	471	168	191	202	113	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:48:58	16	344	244	273	445	456	276	468	169	192	202	115	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:49:58	17	344	244	274	445	456	276	466	170	193	202	116	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:50:58	18	344	244	276	444	456	276	464	171	194	202	117	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:51:58	18	344	244	277	444	456	276	462	172	195	202	118	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:52:58	18	344	244	278	443	456	276	460	172	196	203	119	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:53:58	19	344	244	279	441	456	276	458	173	196	203	121	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:54:58	19	344	244	279	440	456	276	456	173	197	203	121	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:55:58	19	344	244	280	439	456	276	453	174	197	203	122	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:57:05	19	344	244	281	439	456	276	451	174	197	203	122	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:58:02	19	344	244	282	438	456	276	450	174	198	203	123	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	16:59:02	21	344	244	283	438	455	275	448	175	198	203	123	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	17:00:02	21	344	244	284	438	455	275	446	175	198	203	124	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	17:01:02	21	344	244	284	437	455	276	444	175	198	203	125	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	17:02:02	21	344	244	286	437	455	275	442	175	198	203	125	-32768	2037	0	0	-11990	0	18	209	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	17:03:02	21	344	244	286	437	455	275	440	175	198	202	125	-32768	2037	0	0	-11990	0	18	208	6	30	0	0	0	183	23686	36424	3845956	797395	479842	72620
2022-11-23	17:04:02	22	344	244	286	436	456	273	438	176	198	202	125	-32768	-32768	0	70	-11990	0	18	209	3	30	0	0	0	0	23686	36424	3845956	797395	479842	72620
2022-11-23	17:05:02	22	344	241	221	436	455	245	559	112	108	202	100	-32768	-32768	0	70	-11990	527	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:06:02	22	343	245	220	436	455	252	555	-19	-40	200	42	-32768	-32768	0	70	-11990	780	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:07:02	23	343	248	220	436	455	249	553	-109	-93	200	8	-32768	-32768	0	66	-11990	851	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:08:02	24	343	246	220	435	455	249	586	-114	13	200	1	-32768	-32768	0	61	-11990	860	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:09:02	24	343	247	220	435	455	249	620	-149	-12	200	-6	-32768	-32768	0	57	-11990	869	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:10:02	24	343	247	221	434	455	251	652	-160	-13	200	-5	-32768	2041	0	54	-11990	880	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:11:02	24	343	248	221	434	455	252	679	-166	-12	200	-6	-32768	2041	0	51	-11990	890	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:12:09	24	343	250	222	434	455	253	703	-169	-17	200	-8	-32768	2041	0	48	-11990	900	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:13:06	24	343	251	222	433	455	254	724	-171	-21	200	-17	-32768	2041	0	46	-11990	889	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:14:06	24	343	251	223	432	455	254	739	-170	-8	200	-25	-32768	2041	0	44	-11990	860	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:15:06	24	343	252	223	431	454	255	750	-166	-12	200	-28	-32768	2041	0	42	-11990	859	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:16:06	24	343	253	224	431	454	256	760	-165	-13	200	-30	-32768	2041	0	40	-11990	860	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:17:06	24	343	253	224	430	454	257	768	-164	-10	200	-31	-32768	2041	0	38	-11990	860	18	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:18:06	24	343	254	225	429	454	258	776	-163	-15	200	-32	-32768	2041	0	37	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:19:06	24	343	255	225	428	454	258	781	-163	-11	200	-34	-32768	2041	0	35	-11990	861	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:20:06	24	343	256	225	427	454	259	787	-163	-12	200	-34	-32768	2041	0	34	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:21:06	23	343	256	226	426	454	260	792	-163	-13	200	-36	-32768	2041	0	33	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:22:06	22	342	257	226	425	454	260	796	-163	-10	199	-36	-32768	2041	0	32	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:23:06	22	342	257	227	424	454	261	798	-163	-12	200	-36	-32768	2041	0	31	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:24:06	22	342	258	227	424	454	261	801	-162	-12	200	-36	-32768	2041	0	30	-11990	859	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:25:06	22	342	258	227	422	453	261	803	-163	-12	200	-36	-32768	2041	0	29	-11990	861	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:26:06	22	342	258	227	421	453	262	806	-162	-12	200	-37	-32768	2041	0	28	-11990	859	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:27:13	22	342	259	227	421	453	262	808	-162	-13	200	-37	-32768	2041	0	27	-11990	859	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:28:10	21	342	259	228	420	453	262	808	-162	-13	199	-38	-32768	2041	0	26	-11990	859	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:29:10	21	342	259	228	420	453	263	810	-162	-10	199	-38	-32768	2041	0	25	-11990	859	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:30:10	21	342	259	228	419	453	263	812	-162	-12	199	-38	-32768	2041	0	25	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:31:10	21	342	260	228	418	453	263	812	-162	-13	200	-38	-32768	2041	0	24	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:32:10	21	342	260	228	417	453	263	814	-162	-11	199	-38	-32768	2041	0	23	-11990	861	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:33:10	20	342	260	229	416	453	264	816	-162	-13	199	-39	-32768	2041	0	22	-11990	861	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:34:10	19	342	261	229	414	453	264	816	-162	-10	200	-40	-32768	2041	0	22	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:35:10	19	342	261	229	414	453	264	816	-162	-10	200	-40	-32768	2041	0	21	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:36:10	19	342	261	229	413	453	264	818	-162	-12	200	-40	-32768	2041	0	20	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:37:10	19	342	261	229	412	452	264	818	-162	-12	200	-39	-32768	2041	0	20	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:38:10	18	342	262	229	411	452	264	818	-162	-11	200	-39	-32768	2041	0	19	-11990	860	19	209	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:39:10	18	342	262	230	409	452	265	818	-162	-10	200	-40	-32768	2041	0	19	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:40:09	18	342	262	230	407	452	265	818	-162	-10	200	-40	-32768	2041	0	18	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:41:09	18	342	262	230	406	452	265	820	-162	-12	200	-40	-32768	2041	0	18	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:42:17	17	342	262	230	405	452	265	820	-162	-10	200	-40	-32768	2041	0	17	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:43:14	16	342	263	230	403	452	265	820	-162	-13	200	-40	-32768	2041	0	17	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:44:14	16	342	262	230	402	452	266	820	-162	-13	200	-41	-32768	2041	0	16	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:45:14	16	342	263	230	400	452	266	820	-162	-12	200	-42	-32768	2041	0	16	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:46:14	16	342	263	230	398	452	266	820	-162	-13	200	-43	-32768	2041	0	16	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:47:14	16	342	263	230	397	451	266	820	-162	-11	200	-44	-32768	2041	0	15	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:48:14	14	342	263	231	396	451	266	820	-162	-8	200	-44	-32768	2041	0	15	-11990	859	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:49:13	14	342	263	231	395	451	267	820	-163	-10	200	-45	-32768	2041	0	14	-11990	859	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:50:13	14	342	263	231	394	451	267	820	-163	-11	201	-46	-32768	2041	0	14	-11990	861	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:51:13	14	343	264	231	393	451	267	820	-164	-10	200	-48	-32768	2041	0	13	-11990	860	19	210	3	30	0	0	0	0	23687	36424	3845956	797395	479842	72620
2022-11-23	17:52:13	14	343	264	231	393	451	267	820	-165	-15	201	-49	-32768	2041	0	13	-11990	860	18	210	3	30	0	0	0	0	23687	36425	3846081	797395	479842	72620
2022-11-23	17:53:13	13	343	264	231	392	451	267	820	-166	-13	200	-51	-32768	2041	0	13	-11990	859	18	210	3	30	0	0	0	0	23687	36425	3846081	797395	479842	72620
2022-11-23	17:54:13	13	343	264	231	391	450	267	820	-165	-11	200	-52	-32768	2041	0	12	-11990	860	18	210	3	30	0	0	0	0	23687	36425	3846081	797395	479842	72620
2022-11-23	17:55:13	13	343	264	231	390	450	267	820	-166	-13	200	-52	-32768	2041	0	12	-11990	860	18	210	3	30	0	0	0	0	23687	36425	3846081	797395	479842	72620
2022-11-23	17:56:13	13	343	272	336	389	450	361	835	-164	-80	200	-54	-32768	2041	0	100	-11990	859	18	210	15	20	0	0	0	0	23687	36425	3846081	797395	479842	72620
2022-11-23	17:57:18	13	343	345	386	387	450	411	867	-146	-2	200	-54	-32768	2041	0	100	-11990	860	18	210	15	20	0	0	0	0	23687	36425	3846081	797395	479842	72620
2022-11-23	17:58:18	12	343	386	398	386	450	426	897	-143	21	201	-50	-32768	2041	0	90	-11990	571	18	210	15	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	17:59:18	11	343	398	398	388	450	403	850	-83	50	202	-12	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:00:18	11	343	398	396	391	450	402	775	-25	80	202	-3	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:01:18	11	343	397	395	393	449	405	714	-9	103	202	2	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:02:18	11	343	396	393	394	449	410	642	13	143	202	6	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:03:18	11	343	395	390	394	449	414	606	56	159	202	29	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:04:18	11	343	395	386	394	449	418	592	80	158	202	50	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:05:18	11	343	394	381	394	449	419	582	97	158	202	63	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:06:18	11	343	393	374	394	449	419	578	107	157	203	69	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:07:18	11	343	393	369	394	449	418	573	113	157	203	72	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:08:18	11	343	393	365	394	449	417	570	119	157	203	75	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:09:18	11	344	393	361	394	448	416	567	123	157	203	78	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:10:18	11	344	393	358	394	449	415	564	126	159	203	79	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:11:18	11	344	392	355	393	449	414	562	131	161	203	82	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:12:20	12	344	392	353	393	448	413	558	135	164	203	84	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:13:17	13	344	392	350	392	448	412	556	141	168	203	87	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:14:17	13	344	391	348	392	448	411	554	145	172	203	90	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:15:17	13	344	391	345	392	448	410	550	149	175	203	94	-32768	2041	0	0	-11990	0	18	210	6	20	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:16:17	13	344	391	342	392	448	409	548	152	180	203	99	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:17:17	14	344	390	339	392	448	408	545	155	183	203	103	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:18:17	14	344	390	337	392	448	407	543	156	186	203	107	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:19:17	14	344	390	334	392	448	406	540	158	187	203	108	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:20:17	14	344	389	331	392	448	405	538	160	190	203	111	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:21:17	15	344	389	330	392	448	404	536	161	191	203	113	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:22:17	16	344	389	327	392	448	403	534	163	193	203	115	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:23:17	16	344	388	325	392	448	402	532	164	193	203	116	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:24:17	16	344	388	323	392	448	401	530	166	194	202	116	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:25:17	16	344	388	321	392	447	400	526	166	195	202	117	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:26:17	16	344	387	319	391	447	399	524	167	196	202	120	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:27:24	16	344	387	317	392	447	398	522	167	196	202	121	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:28:21	18	344	386	315	391	447	397	520	168	196	202	122	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:29:21	18	344	386	313	391	447	396	518	168	197	202	122	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:30:21	18	344	386	312	391	447	394	515	169	197	202	123	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:31:21	18	344	385	310	391	447	393	513	169	197	202	125	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:32:21	18	344	385	309	389	447	392	510	169	197	202	126	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:33:21	19	344	384	308	387	447	391	508	171	197	202	126	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:34:21	19	344	384	306	386	447	389	506	171	197	202	127	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:35:21	19	344	384	305	386	447	388	503	172	197	202	127	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:36:21	19	344	383	304	385	447	387	501	172	197	202	128	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:37:21	19	344	383	303	385	447	386	499	172	197	202	129	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:38:21	20	344	382	302	384	446	385	497	172	197	201	129	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:39:21	21	344	382	301	384	446	383	495	173	197	201	129	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:40:21	21	344	381	301	384	446	382	492	173	197	202	131	-32768	2041	0	0	-11990	0	18	210	6	30	0	0	0	183	23687	36425	3846081	797395	479842	72620
2022-11-23	18:41:21	21	344	352	224	384	446	242	537	170	173	202	129	-32768	-32768	0	70	-11990	399	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:42:28	21	344	278	221	384	446	245	612	48	56	200	88	-32768	-32768	0	70	-11990	500	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:43:25	21	343	257	221	383	446	246	585	-30	-38	200	52	-32768	-32768	0	66	-11990	619	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:44:25	21	343	249	221	383	446	246	583	-102	-7	199	29	-32768	-32768	0	59	-11990	739	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:45:25	21	343	248	221	383	446	249	605	-127	-56	200	19	-32768	-32768	0	54	-11990	861	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:46:25	21	343	249	221	383	446	250	640	-105	-50	199	10	-32768	2000	0	50	-11990	871	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:47:25	21	343	249	222	383	445	252	670	-102	-28	199	1	-32768	2000	0	47	-11990	880	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:48:25	21	343	250	222	383	445	253	697	-124	-13	199	-5	-32768	2000	0	45	-11990	890	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:49:25	21	343	252	223	382	445	254	721	-155	-22	199	-5	-32768	2000	0	43	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:50:25	22	343	253	223	382	445	256	741	-166	-26	199	-5	-32768	2000	0	41	-11990	911	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:51:25	21	343	253	223	382	445	256	759	-169	-30	199	-8	-32768	2000	0	39	-11990	919	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:52:25	22	343	254	224	382	445	257	775	-171	-32	199	-19	-32768	2000	0	37	-11990	909	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:53:25	21	343	255	224	381	445	258	787	-170	-22	199	-26	-32768	2000	0	36	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:54:25	21	343	255	225	381	445	258	796	-169	-26	199	-28	-32768	2000	0	34	-11990	899	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:55:25	21	343	256	225	381	445	259	803	-169	-27	199	-28	-32768	2000	0	33	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:56:25	21	343	256	225	380	445	259	810	-168	-26	199	-30	-32768	2000	0	32	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:56:27	21	343	257	226	380	445	260	816	-167	-29	199	-32	-32768	2000	0	31	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:57:27	21	343	257	226	380	444	261	820	-163	-29	199	-33	-32768	2000	0	30	-11990	899	18	209	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:58:27	21	343	258	226	380	444	261	823	-159	-30	199	-34	-32768	2000	0	29	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	18:59:27	21	343	258	227	380	444	261	827	-157	-26	199	-35	-32768	2000	0	28	-11990	900	18	209	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:00:27	19	343	258	227	379	444	262	831	-153	-24	199	-36	-32768	2000	0	27	-11990	901	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:01:27	19	343	259	227	379	444	262	833	-153	-25	199	-36	-32768	2000	0	26	-11990	899	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:02:27	19	343	259	227	379	444	262	835	-156	-26	199	-36	-32768	2000	0	25	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:03:27	19	343	259	227	378	444	263	837	-155	-28	200	-36	-32768	2000	0	25	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:04:27	19	343	260	228	378	444	263	838	-150	-28	199	-37	-32768	2000	0	24	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:05:27	19	343	260	228	378	444	263	839	-144	-27	200	-38	-32768	2000	0	23	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:06:27	18	343	260	228	378	443	263	841	-143	-26	200	-38	-32768	2000	0	22	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:07:27	18	343	260	228	378	443	264	841	-148	-26	199	-40	-32768	2000	0	22	-11990	900	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:08:27	18	343	261	228	377	443	264	843	-146	-23	199	-40	-32768	2000	0	21	-11990	899	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:09:27	18	343	261	229	377	443	264	843	-151	-23	200	-41	-32768	2000	0	21	-11990	900	18	209	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:10:27	17	343	261	251	377	443	269	843	-157	-25	200	-42	-32768	2000	0	90	-11990	901	18	209	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:11:30	16	343	315	364	376	443	392	876	-147	-20	200	-40	-32768	2000	0	90	-11990	899	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:12:29	16	343	368	385	375	442	417	908	-143	19	200	-36	-32768	2000	0	84	-11990	911	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:13:29	16	343	396	392	376	442	434	933	-147	-11	200	-36	-32768	2000	0	65	-11990	931	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:14:29	16	343	415	397	379	442	450	954	-150	-10	200	-38	-32768	2000	0	52	-11990	951	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:15:29	15	343	430	402	384	442	462	975	-152	-15	200	-42	-32768	2000	0	48	-11990	971	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:16:29	14	343	442	408	388	442	469	996	-155	-15	200	-44	-32768	2000	0	49	-11990	991	18	209	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:17:29	14	343	451	415	393	443	475	1017	-157	-12	200	-46	-32768	2000	0	51	-11990	1000	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:18:29	14	343	457	421	399	445	480	1035	-156	-12	200	-48	-32768	2000	0	55	-11990	1001	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:19:29	14	343	461	428	405	447	481	1052	-156	-8	199	-49	-32768	2000	0	61	-11990	1001	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:20:29	13	343	464	435	411	448	483	1066	-154	-8	200	-49	-32768	2000	0	69	-11990	998	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:21:29	13	343	467	442	417	449	485	1078	-153	-5	199	-50	-32768	2000	0	78	-11990	999	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:22:29	13	343	469	448	422	449	486	1089	-152	1	199	-50	-32768	2000	0	90	-11990	1000	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:23:29	13	343	471	455	427	448	489	1097	-150	-1	199	-50	-32768	2000	0	100	-11990	1000	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:24:29	13	343	473	459	432	448	492	1101	-148	4	200	-48	-32768	2000	0	100	-11990	950	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:25:29	11	343	475	462	437	448	494	1105	-141	21	199	-46	-32768	2000	0	100	-11990	900	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:26:36	11	343	478	466	441	450	496	1101	-132	22	199	-43	-32768	2000	0	100	-11990	851	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:27:33	11	343	480	469	444	453	499	1093	-125	22	199	-40	-32768	2000	0	100	-11990	851	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:28:33	11	343	484	472	447	455	502	1089	-122	29	199	-39	-32768	2000	0	100	-11990	850	18	210	15	20	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:29:33	11	343	487	475	450	458	506	1089	-121	27	199	-39	-32768	2000	0	100	-11990	851	18	209	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:30:33	11	344	381	228	453	460	259	1044	-130	29	199	-42	-32768	2000	0	100	-11990	850	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:31:33	11	344	296	227	455	461	255	996	-146	-3	200	-48	-32768	2000	0	98	-11990	850	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:32:33	9	344	270	226	457	461	254	963	-159	-12	199	-54	-32768	2000	0	91	-11990	851	18	210	3	30	0	0	0	0	23688	36425	3846081	797395	479842	72620
2022-11-23	19:33:33	9	344	261	227	458	460	256	938	-164	-1	199	-57	-32768	2000	0	83	-11990	850	18	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:34:33	9	344	258	226	458	459	256	916	-166	-8	199	-57	-32768	2000	0	77	-11990	861	18	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:35:33	9	344	257	226	458	459	257	898	-168	-6	199	-59	-32768	2000	0	71	-11990	869	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:36:33	9	344	257	227	457	459	258	883	-170	-12	199	-61	-32768	2000	0	66	-11990	879	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:37:33	9	344	258	227	457	459	258	872	-171	-8	199	-62	-32768	2000	0	61	-11990	840	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:38:33	9	344	258	227	457	459	258	862	-169	-1	199	-61	-32768	2000	0	56	-11990	819	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:39:33	9	344	258	228	456	459	259	851	-165	-3	199	-59	-32768	2000	0	52	-11990	819	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:40:33	9	344	258	228	456	459	260	841	-165	-5	199	-60	-32768	2000	0	48	-11990	820	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:41:40	8	344	259	229	456	460	261	833	-165	-3	199	-60	-32768	2000	0	45	-11990	820	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:42:37	8	344	260	229	456	459	261	827	-166	-6	199	-60	-32768	2000	0	42	-11990	819	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:43:37	8	344	260	229	455	459	261	822	-166	-6	199	-61	-32768	2000	0	40	-11990	820	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:44:37	8	344	260	229	455	460	262	818	-166	-8	199	-61	-32768	2000	0	37	-11990	820	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:45:37	8	344	260	229	454	459	262	814	-166	-6	199	-61	-32768	2000	0	35	-11990	820	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:46:37	8	344	261	229	454	459	262	810	-166	-8	199	-61	-32768	2000	0	33	-11990	819	17	209	3	30	0	0	0	0	23688	36426	3846227	797395	479842	72620
2022-11-23	19:47:37	7	344	260	229	453	459	251	806	-164	-3	199	-60	-32768	2000	0	70	-11990	318	17	210	3	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:48:36	6	344	250	230	453	459	236	747	-91	36	199	-23	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:49:36	6	344	245	232	452	459	240	689	-31	68	199	-4	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:50:36	6	344	244	232	452	459	244	649	-11	88	199	0	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:51:36	6	344	244	233	452	458	251	622	-6	101	200	7	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:52:36	6	344	244	234	452	458	257	607	1	113	200	23	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:53:36	6	344	244	234	452	458	263	593	32	125	200	38	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:54:36	6	344	244	235	452	458	267	578	64	132	200	52	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:55:36	6	344	245	235	452	458	271	565	86	137	200	60	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:56:37	6	344	245	237	452	458	273	553	103	142	200	66	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:57:37	6	344	245	238	451	458	275	543	113	145	200	69	-32768	2000	0	0	-11990	0	17	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:58:37	6	345	244	240	451	458	276	534	120	147	200	72	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	19:59:37	8	345	244	242	451	458	276	526	127	149	202	75	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:00:37	8	345	244	244	451	458	277	520	133	151	202	78	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:01:37	8	345	244	247	451	458	277	514	138	152	202	79	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:02:37	8	345	244	249	451	458	277	509	143	155	203	82	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:03:37	8	345	244	251	451	458	277	505	149	157	203	84	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:04:37	8	345	244	253	451	457	278	501	154	159	204	88	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:05:37	8	345	244	255	451	457	277	498	157	161	204	91	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:06:37	9	345	244	257	450	457	277	495	160	164	205	96	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:07:37	9	345	243	259	450	457	278	492	162	166	205	100	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:08:37	9	345	243	261	450	457	277	489	164	169	205	103	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:09:37	9	345	243	263	450	457	277	486	165	173	205	106	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:10:37	9	345	243	265	450	457	278	484	167	176	206	108	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:11:40	11	345	243	267	450	457	278	481	168	180	206	109	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:12:40	11	345	243	269	450	457	278	479	169	182	206	112	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:13:40	11	345	243	270	450	457	277	477	170	184	206	113	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:14:40	12	345	244	272	450	457	277	474	172	186	206	116	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:15:40	13	345	243	274	450	457	277	472	172	188	206	117	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:16:40	13	345	243	275	450	457	277	470	173	191	205	118	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:17:40	13	345	243	277	450	457	277	468	173	193	205	120	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:18:40	13	345	243	278	449	456	277	466	173	194	204	121	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:19:40	14	345	243	280	449	457	277	464	174	196	204	122	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:20:40	14	345	243	281	449	457	277	462	174	196	204	123	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:21:40	14	345	243	282	449	456	277	460	174	197	203	123	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:22:40	16	345	244	283	449	456	277	458	174	197	203	125	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:23:40	16	345	243	284	449	456	277	456	174	197	203	125	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:24:40	16	345	243	285	449	456	277	454	174	197	203	126	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:25:40	16	345	243	286	449	456	277	452	175	197	203	127	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:26:45	18	345	243	287	449	456	277	450	175	197	202	127	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:27:45	18	345	243	287	449	456	277	448	175	197	203	128	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:28:45	18	345	243	288	448	456	277	446	175	197	202	128	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:29:45	18	345	244	289	449	456	277	444	175	197	202	128	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:30:45	18	344	244	289	448	456	276	442	175	197	202	129	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:31:45	19	344	244	290	448	456	276	440	175	197	202	130	-32768	2000	0	0	-11990	0	16	209	6	30	0	0	0	183	23688	36426	3846227	797395	479842	72620
2022-11-23	20:32:45	19	344	239	222	448	456	248	539	151	127	202	122	-32768	-32768	0	70	-11990	481	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:33:45	19	344	244	220	448	456	252	566	7	-17	200	65	-32768	-32768	0	70	-11990	720	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:34:45	19	344	248	220	448	456	251	546	-89	-102	200	20	-32768	-32768	0	67	-11990	829	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:35:44	19	344	246	220	448	456	247	572	-121	0	200	7	-32768	-32768	0	61	-11990	841	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:36:44	19	344	246	221	448	455	249	605	-141	-39	200	-2	-32768	-32768	0	56	-11990	849	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:37:44	19	344	247	221	448	456	250	638	-158	-1	200	-6	-32768	2008	0	52	-11990	860	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:38:44	19	344	248	221	448	456	252	666	-165	-7	200	-6	-32768	2008	0	49	-11990	870	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:39:44	19	344	249	222	447	455	253	690	-167	-30	200	-17	-32768	2008	0	46	-11990	880	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:40:44	20	344	250	222	447	455	255	713	-168	-15	199	-26	-32768	2008	0	44	-11990	890	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:41:47	20	344	252	223	447	455	256	732	-171	-10	200	-31	-32768	2008	0	42	-11990	890	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:42:44	20	344	253	223	446	455	255	747	-170	-11	199	-34	-32768	2008	0	40	-11990	869	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:43:44	19	344	253	224	446	455	257	759	-168	-12	199	-34	-32768	2008	0	38	-11990	869	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:44:44	19	344	254	224	445	455	257	769	-167	-10	199	-34	-32768	2008	0	36	-11990	871	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:45:44	19	344	255	225	445	455	258	777	-168	-12	199	-35	-32768	2008	0	35	-11990	871	16	209	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:46:44	19	344	255	225	444	455	259	785	-167	-15	199	-36	-32768	2008	0	33	-11990	871	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:47:44	19	344	256	226	444	455	260	790	-167	-17	199	-37	-32768	2008	0	32	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:48:44	19	344	257	226	443	455	261	796	-166	-16	199	-38	-32768	2008	0	31	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:49:44	19	344	257	226	443	455	261	801	-167	-10	199	-39	-32768	2008	0	30	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:50:44	19	344	258	227	442	455	261	805	-167	-10	199	-39	-32768	2008	0	29	-11990	869	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:51:44	19	344	258	227	442	454	262	807	-167	-17	199	-40	-32768	2008	0	28	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:52:44	18	344	259	228	441	455	262	810	-166	-13	199	-40	-32768	2008	0	27	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:53:44	18	344	259	228	441	454	262	812	-167	-12	199	-40	-32768	2008	0	26	-11990	869	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:54:44	18	344	259	228	440	454	263	814	-166	-17	199	-40	-32768	2008	0	25	-11990	871	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:55:44	18	344	260	228	439	454	263	816	-166	-15	199	-40	-32768	2008	0	24	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:56:45	18	344	260	228	439	454	264	818	-166	-10	199	-42	-32768	2008	0	24	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:57:45	18	344	260	229	438	454	264	820	-166	-12	199	-41	-32768	2008	0	23	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:58:45	17	344	261	229	437	454	264	822	-166	-15	199	-41	-32768	2008	0	22	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	20:59:45	16	344	261	229	437	454	264	822	-166	-15	199	-42	-32768	2008	0	22	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:00:45	16	344	261	229	436	454	265	823	-166	-13	199	-42	-32768	2008	0	21	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:01:44	16	344	262	229	436	454	265	823	-166	-10	199	-43	-32768	2008	0	21	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:02:44	16	344	262	230	435	454	265	825	-166	-11	199	-44	-32768	2008	0	20	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:03:44	14	344	262	230	435	453	265	825	-166	-17	199	-45	-32768	2008	0	19	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:04:44	14	344	262	230	434	453	266	825	-166	-16	199	-46	-32768	2008	0	19	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:05:44	14	344	263	230	433	453	266	827	-166	-6	199	-46	-32768	2008	0	18	-11990	871	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:06:44	14	344	263	230	433	453	266	827	-166	-10	199	-47	-32768	2008	0	18	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:07:44	13	344	263	230	432	453	266	827	-166	-15	199	-48	-32768	2008	0	17	-11990	871	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:08:44	13	344	263	231	431	453	266	827	-166	-15	198	-48	-32768	2008	0	17	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:09:44	13	344	263	231	431	453	267	827	-166	-13	198	-48	-32768	2008	0	16	-11990	869	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:10:44	13	344	263	231	430	453	267	827	-166	-10	198	-48	-32768	2008	0	16	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:11:49	13	344	264	231	429	453	267	827	-166	-13	198	-48	-32768	2008	0	15	-11990	869	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:12:49	13	344	264	231	429	453	267	829	-166	-10	198	-48	-32768	2008	0	15	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:13:49	12	344	264	231	428	453	267	828	-166	-8	198	-47	-32768	2008	0	14	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:14:49	11	344	264	232	427	453	267	827	-166	-13	198	-48	-32768	2008	0	14	-11990	869	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:15:49	11	344	264	232	426	452	268	828	-166	-9	198	-50	-32768	2008	0	14	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:16:49	11	344	265	232	426	452	268	828	-167	-10	198	-50	-32768	2008	0	13	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:17:49	11	344	265	232	425	452	268	828	-167	-15	198	-52	-32768	2008	0	13	-11990	870	16	208	3	30	0	0	0	0	23689	36426	3846227	797395	479842	72620
2022-11-23	21:18:49	11	344	265	232	425	452	268	829	-168	-9	198	-52	-32768	2008	0	13	-11990	870	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:19:49	11	344	265	232	424	452	268	829	-169	-8	198	-54	-32768	2008	0	12	-11990	871	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:20:49	9	344	265	232	423	452	268	829	-169	-19	198	-55	-32768	2008	0	12	-11990	870	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:21:49	9	344	265	232	422	452	268	829	-169	-8	199	-57	-32768	2008	0	11	-11990	870	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:22:49	9	344	265	232	422	452	268	829	-169	-10	198	-57	-32768	2008	0	11	-11990	871	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:23:49	9	344	265	232	421	452	269	829	-169	-15	198	-59	-32768	2008	0	11	-11990	870	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:24:49	9	344	266	233	420	451	269	829	-169	-17	198	-61	-32768	2008	0	11	-11990	870	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:25:49	9	344	265	233	420	451	269	829	-169	-15	198	-61	-32768	2008	0	10	-11990	870	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:26:53	8	344	266	233	420	451	269	829	-171	-12	198	-63	-32768	2008	0	10	-11990	870	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:27:53	8	344	265	232	419	451	269	829	-170	-9	198	-63	-32768	2008	0	10	-11990	860	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:28:53	8	344	265	233	419	451	269	829	-170	-21	198	-63	-32768	2008	0	9	-11990	860	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:29:53	8	344	265	233	418	451	269	829	-170	-20	198	-65	-32768	2008	0	9	-11990	859	16	208	3	30	0	0	0	0	23689	36427	3846352	797395	479842	72620
2022-11-23	21:30:53	8	344	265	233	417	451	268	829	-170	-10	198	-65	-32768	2008	0	70	-11990	727	16	208	3	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:31:53	8	344	256	233	416	451	238	790	-119	9	198	-35	-32768	2008	0	0	-11990	0	16	208	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:32:53	8	344	249	234	416	451	242	721	-42	43	198	-5	-32768	2008	0	0	-11990	0	16	208	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:33:53	8	344	247	234	416	450	247	674	-14	71	198	4	-32768	2008	0	0	-11990	0	16	208	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:34:53	7	344	246	235	415	450	254	642	-7	90	198	13	-32768	2008	0	0	-11990	0	15	208	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:35:53	7	344	246	235	415	449	261	617	0	104	198	15	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:36:53	6	344	246	237	415	449	267	593	31	124	198	36	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:37:53	7	345	246	239	415	449	271	570	66	142	198	56	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:38:53	7	345	246	241	415	449	273	551	89	151	198	65	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:39:53	8	345	246	244	415	449	274	541	103	152	198	71	-32768	2008	0	0	-11990	0	15	208	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:40:53	8	345	246	248	414	449	274	535	111	151	198	75	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:41:57	8	345	246	251	414	449	274	530	117	151	198	73	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:42:57	8	345	246	254	414	449	274	525	122	152	198	75	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:43:57	8	345	246	257	414	449	274	520	126	152	198	78	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:44:57	8	345	246	259	414	448	273	516	131	154	199	79	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:45:57	8	345	245	261	414	448	273	511	136	156	198	82	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:46:57	9	345	245	263	413	449	273	508	140	159	199	86	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:47:57	9	345	245	265	413	448	272	505	145	163	199	90	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:48:57	9	345	245	268	412	448	272	502	150	166	199	93	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:49:57	9	345	245	269	412	448	272	499	154	169	199	98	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:50:57	9	345	245	271	412	448	272	496	156	173	199	102	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:51:57	11	345	245	273	412	448	271	494	158	176	199	103	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:52:57	11	345	245	274	412	448	271	491	160	180	200	106	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:53:57	11	345	244	276	411	448	271	489	162	183	200	108	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:54:57	11	345	244	277	411	448	271	486	163	185	200	111	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:56:04	12	345	244	278	411	448	270	483	164	186	200	113	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:57:01	13	345	244	280	411	447	270	481	165	188	200	115	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:58:01	13	345	244	281	411	447	270	479	166	189	199	116	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	21:59:01	13	345	244	281	411	447	270	477	167	190	199	118	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:00:01	13	345	244	282	411	447	269	475	168	191	199	120	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:01:01	14	345	244	283	411	447	269	473	168	192	199	121	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:02:01	14	345	244	283	411	447	269	471	168	193	199	122	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:03:01	14	345	244	283	410	447	269	468	169	194	199	123	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:04:01	16	345	244	284	410	447	269	466	169	194	200	124	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:05:01	16	345	244	284	410	447	268	464	170	195	200	125	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:06:01	16	345	244	284	409	447	268	462	171	195	200	126	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:07:01	16	345	244	284	409	447	268	460	171	195	200	127	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:08:01	18	345	244	284	409	447	268	458	172	195	200	127	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:09:01	18	345	244	284	408	447	268	456	172	195	200	128	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:10:01	18	345	244	284	408	446	268	454	172	196	200	128	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:11:08	18	345	244	284	408	446	268	452	172	196	199	129	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:12:05	19	344	244	284	408	446	268	450	173	196	199	130	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:13:05	19	344	244	283	408	446	268	448	173	195	199	131	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:14:05	19	344	244	283	408	446	268	446	173	196	199	132	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:15:05	19	344	244	283	408	446	269	444	173	195	199	131	-32768	2008	0	0	-11990	0	15	207	6	30	0	0	0	183	23689	36427	3846352	797395	479842	72620
2022-11-23	22:16:05	20	344	239	223	408	446	251	552	143	116	199	119	-32768	-32768	0	70	-11990	586	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:17:05	21	344	249	222	408	446	260	576	-12	-57	198	45	-32768	-32768	0	70	-11990	849	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:18:05	21	344	251	222	408	446	251	556	-113	-107	198	9	-32768	-32768	0	67	-11990	861	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:19:05	21	344	248	221	407	445	250	587	-122	1	198	0	-32768	-32768	0	61	-11990	870	15	207	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:20:05	21	344	248	222	407	445	251	621	-156	-16	198	-6	-32768	-32768	0	56	-11990	880	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:21:05	21	344	248	222	407	445	252	653	-167	-26	198	-15	-32768	2006	0	53	-11990	890	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:22:05	21	344	250	223	407	445	254	681	-171	-26	197	-24	-32768	2006	0	50	-11990	890	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:23:05	21	344	250	223	406	445	254	703	-171	-13	197	-28	-32768	2006	0	47	-11990	860	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:24:05	21	344	251	224	406	445	255	720	-167	-12	197	-28	-32768	2006	0	44	-11990	850	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:25:05	21	344	252	224	406	445	256	734	-165	-13	197	-29	-32768	2006	0	42	-11990	849	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:26:11	21	344	253	225	405	445	257	745	-165	-15	197	-31	-32768	2006	0	39	-11990	850	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:27:08	21	344	254	225	405	445	258	755	-164	-15	197	-32	-32768	2006	0	37	-11990	850	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:28:08	21	344	254	226	404	445	258	764	-165	-14	197	-34	-32768	2006	0	35	-11990	851	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:29:08	21	344	255	226	404	444	259	771	-163	-13	197	-34	-32768	2006	0	34	-11990	851	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:30:08	21	344	256	227	403	444	260	778	-163	-13	197	-36	-32768	2006	0	32	-11990	850	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:31:08	21	344	256	227	403	444	260	783	-163	-12	197	-36	-32768	2006	0	31	-11990	849	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:32:08	21	344	257	227	402	444	261	788	-164	-13	197	-36	-32768	2006	0	30	-11990	849	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:33:08	20	344	257	227	402	444	261	792	-163	-15	197	-32	-32768	2006	0	29	-11990	849	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:34:08	19	344	258	228	401	444	262	796	-163	-17	196	-36	-32768	2006	0	28	-11990	850	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:35:08	19	344	258	228	400	444	262	799	-163	-17	196	-38	-32768	2006	0	27	-11990	851	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:36:08	19	344	259	228	400	444	263	801	-164	-15	197	-40	-32768	2006	0	26	-11990	851	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:37:08	19	344	259	229	399	444	263	804	-163	-15	197	-40	-32768	2006	0	25	-11990	850	15	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:38:08	19	344	259	229	399	443	263	807	-162	-15	197	-42	-32768	2006	0	24	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:39:08	19	344	260	229	398	443	263	807	-163	-15	197	-41	-32768	2006	0	23	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:40:08	18	344	260	229	397	443	264	808	-162	-15	197	-42	-32768	2006	0	22	-11990	849	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:41:15	18	344	260	230	396	443	264	810	-162	-16	197	-43	-32768	2006	0	21	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:42:12	18	344	261	230	396	443	264	812	-162	-17	196	-44	-32768	2006	0	21	-11990	851	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:43:12	18	344	261	230	395	443	265	812	-162	-14	196	-44	-32768	2006	0	20	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:44:12	18	344	261	230	394	443	265	814	-162	-13	196	-44	-32768	2006	0	20	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:45:12	16	344	261	230	394	443	265	814	-162	-12	196	-46	-32768	2006	0	19	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:46:12	16	344	262	230	393	443	265	814	-162	-12	196	-46	-32768	2006	0	18	-11990	851	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:47:12	16	344	262	231	392	442	266	816	-162	-13	196	-46	-32768	2006	0	18	-11990	851	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:48:12	16	344	262	231	392	442	266	816	-162	-13	196	-46	-32768	2006	0	17	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:49:12	16	344	262	231	391	442	266	816	-162	-13	196	-46	-32768	2006	0	17	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:50:12	14	344	263	231	391	442	266	816	-162	-13	196	-46	-32768	2006	0	16	-11990	851	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:51:12	14	344	263	231	390	442	266	816	-162	-13	196	-46	-32768	2006	0	16	-11990	850	16	206	3	30	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:52:12	14	344	287	357	389	441	380	837	-160	-71	196	-46	-32768	2006	0	100	-11990	850	16	206	15	20	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:53:12	14	344	355	394	387	441	420	870	-130	14	196	-44	-32768	2006	0	100	-11990	861	16	206	15	20	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:54:12	13	344	396	406	386	441	439	901	-132	-3	196	-41	-32768	2006	0	82	-11990	880	16	206	15	20	0	0	0	0	23690	36427	3846352	797395	479842	72620
2022-11-23	22:55:12	13	344	418	411	388	441	452	926	-122	-3	196	-42	-32768	2006	0	65	-11990	901	16	206	15	20	0	0	0	0	23690	36427	3846352	797575	479842	72620
2022-11-23	22:56:16	13	344	432	416	392	441	463	951	-132	-12	196	-41	-32768	2006	0	60	-11990	920	16	206	15	20	0	0	0	0	23690	36427	3846352	797575	479842	72620
2022-11-23	22:57:16	13	344	444	421	397	441	470	974	-141	-13	196	-42	-32768	2006	0	59	-11990	941	15	205	15	20	0	0	0	0	23690	36427	3846352	797575	479842	72620
2022-11-23	22:58:16	13	344	451	427	402	443	476	995	-146	-9	196	-42	-32768	2006	0	62	-11990	951	15	205	15	20	0	0	0	0	23690	36427	3846352	797575	479842	72620
2022-11-23	22:59:16	12	344	457	433	408	444	478	1015	-147	-9	196	-44	-32768	2006	0	67	-11990	950	15	205	15	20	0	0	0	0	23690	36427	3846352	797575	479842	72620
2022-11-23	23:00:16	11	344	461	439	413	446	481	1032	-147	-6	196	-48	-32768	2006	0	74	-11990	949	15	205	15	20	0	0	0	0	23690	36427	3846352	797575	479842	72620
2022-11-23	23:01:16	11	344	464	445	419	447	483	1045	-147	-5	196	-50	-32768	2006	0	83	-11990	949	15	205	15	20	0	0	0	0	23690	36427	3846352	797575	479842	72620
2022-11-23	23:02:16	11	344	467	451	423	448	485	1057	-145	-2	196	-52	-32768	2006	0	95	-11990	950	15	205	15	20	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:03:16	11	344	469	456	428	447	488	1068	-144	-1	196	-53	-32768	2006	0	100	-11990	949	15	205	15	20	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:04:16	11	344	472	460	433	448	493	1078	-143	6	196	-54	-32768	2006	0	100	-11990	949	15	205	15	20	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:05:16	11	344	476	464	437	447	496	1085	-141	0	196	-54	-32768	2006	0	100	-11990	949	15	205	15	20	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:06:16	11	344	480	468	440	449	500	1093	-141	2	196	-54	-32768	2006	0	100	-11990	950	15	205	15	20	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:07:16	9	344	484	471	444	452	503	1101	-141	9	196	-54	-32768	2006	0	100	-11990	900	15	205	15	20	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:08:16	9	344	487	474	447	455	505	1101	-135	13	196	-52	-32768	2006	0	100	-11990	850	15	205	15	20	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:09:16	9	344	488	476	450	458	506	1097	-129	27	196	-49	-32768	2006	0	100	-11990	851	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:10:16	9	344	382	230	453	461	261	1055	-132	23	196	-50	-32768	2006	0	100	-11990	850	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:11:23	9	344	297	229	456	462	257	1004	-147	-8	196	-55	-32768	2006	0	98	-11990	850	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:12:20	9	344	270	228	458	461	255	970	-160	-14	196	-63	-32768	2006	0	90	-11990	850	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:13:20	9	344	262	229	458	460	257	944	-165	-6	195	-65	-32768	2006	0	82	-11990	850	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:14:20	9	344	259	228	458	460	257	921	-167	-10	196	-67	-32768	2006	0	76	-11990	861	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:15:20	8	344	258	228	458	459	258	904	-169	-17	196	-71	-32768	2006	0	69	-11990	870	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:16:20	8	344	258	228	458	459	258	890	-171	-12	196	-72	-32768	2006	0	64	-11990	840	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:17:20	8	344	258	228	457	459	258	876	-170	-5	196	-72	-32768	2006	0	59	-11990	820	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:18:20	8	344	258	229	457	459	260	864	-167	-6	196	-70	-32768	2006	0	54	-11990	820	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:19:20	8	344	259	229	457	459	260	853	-166	-9	196	-72	-32768	2006	0	50	-11990	820	15	205	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-23	23:20:19	8	344	258	229	457	459	246	839	-161	-2	196	-67	-32768	2006	0	70	-11990	0	15	205	7	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:21:19	6	344	249	231	456	459	237	773	-80	40	196	-17	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:22:19	6	344	246	232	456	459	241	717	-26	71	196	-3	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:23:19	6	344	245	232	456	459	249	678	-10	89	196	18	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:24:19	6	344	245	233	456	459	257	634	-6	112	196	26	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:25:19	6	344	245	234	456	459	263	596	0	136	196	35	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:25:26	6	345	245	235	456	458	268	571	33	145	196	41	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:26:23	6	345	245	237	455	458	270	557	65	147	197	56	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:27:23	7	345	244	241	456	458	272	549	85	147	196	64	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:28:23	7	345	244	244	455	458	272	544	98	149	196	72	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:29:23	8	345	244	249	455	458	272	538	109	149	196	76	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:30:23	8	345	244	252	456	458	273	534	118	149	196	78	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:31:23	8	345	244	255	455	458	272	530	123	150	196	80	-32768	2006	0	0	-11990	0	15	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:32:23	8	345	244	257	455	458	272	525	128	150	196	83	-32768	2006	0	0	-11990	0	14	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:33:23	8	345	244	259	455	458	272	522	133	151	196	88	-32768	2006	0	0	-11990	0	14	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:34:23	8	345	244	261	455	458	271	519	137	152	196	94	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:35:23	8	345	244	263	455	458	271	516	142	154	196	99	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:36:23	8	345	243	265	455	458	271	513	145	157	196	102	-32768	2006	0	0	-11990	0	14	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:37:23	9	345	243	267	455	458	271	509	149	159	196	104	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:38:23	9	345	243	269	455	458	271	507	152	161	197	107	-32768	2006	0	0	-11990	0	14	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:39:23	9	345	243	271	455	458	270	504	154	165	196	109	-32768	2006	0	0	-11990	0	14	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:40:30	9	345	243	273	455	458	270	502	156	168	196	112	-32768	2006	0	0	-11990	0	14	205	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:41:27	9	345	243	274	455	458	270	499	158	173	196	115	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:42:27	11	345	243	276	455	458	270	497	159	176	196	116	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:43:27	11	345	243	277	455	458	270	494	160	180	196	117	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:44:27	11	345	244	278	455	458	270	492	161	182	196	120	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:45:27	12	345	243	280	455	458	270	490	163	183	196	121	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:46:27	13	345	244	280	455	458	269	488	164	185	196	122	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:47:27	13	345	244	281	455	458	269	485	165	186	196	123	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:48:27	13	345	243	282	454	457	269	484	165	187	196	125	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:49:27	13	345	244	283	454	458	269	482	165	187	196	125	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:50:27	14	345	244	284	455	457	269	480	166	188	196	126	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:51:27	14	345	244	284	454	457	269	478	166	190	196	127	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:52:27	14	345	244	285	454	457	269	475	166	190	196	128	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:53:27	16	345	244	285	454	457	268	473	167	191	196	128	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:54:27	16	345	244	286	454	457	268	471	167	191	196	129	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:55:30	16	345	244	286	454	457	268	469	167	192	196	131	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:56:30	16	345	244	286	454	457	268	467	167	192	196	131	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:57:30	18	345	244	286	454	457	268	465	168	193	196	132	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:58:30	18	345	244	286	454	457	268	462	168	192	196	133	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-23	23:59:30	18	345	244	287	454	457	268	460	168	193	196	133	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-24	00:00:30	19	345	244	287	454	457	268	458	168	193	196	134	-32768	2006	0	0	-11990	0	14	204	6	30	0	0	0	183	23690	36428	3846486	797575	479842	72620
2022-11-24	00:01:30	19	344	244	286	454	457	268	456	168	193	196	134	-32768	-32768	0	70	-11990	0	14	204	3	30	0	0	0	0	23690	36428	3846486	797575	479842	72620
2022-11-24	00:02:30	19	344	241	221	454	457	246	581	109	101	196	112	-32768	-32768	0	70	-11990	520	14	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:03:30	19	344	245	221	454	457	253	578	-21	-40	195	54	-32768	-32768	0	70	-11990	761	14	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:04:30	20	344	248	220	453	457	249	568	-110	-82	195	16	-32768	-32768	0	65	-11990	830	14	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:05:30	21	344	246	220	453	457	249	597	-138	16	195	4	-32768	-32768	0	59	-11990	839	14	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:06:30	21	344	247	221	453	457	249	627	-156	-19	195	-6	-32768	-32768	0	55	-11990	850	14	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:07:30	21	344	247	221	453	457	251	657	-163	-4	195	-6	-32768	2013	0	51	-11990	859	14	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:08:30	21	344	249	222	453	457	252	681	-168	-12	195	-10	-32768	2013	0	48	-11990	870	14	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:09:30	21	344	250	222	453	457	254	704	-169	-23	195	-21	-32768	2013	0	46	-11990	880	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:10:34	21	344	251	223	452	456	254	723	-170	-15	195	-28	-32768	2013	0	43	-11990	861	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:11:34	20	344	252	223	452	457	255	738	-170	-3	195	-30	-32768	2013	0	41	-11990	860	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:12:34	21	344	253	224	452	457	256	750	-169	-15	195	-32	-32768	2013	0	39	-11990	860	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:13:34	19	344	253	224	451	456	257	760	-168	-6	194	-35	-32768	2013	0	37	-11990	861	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:14:34	19	344	254	225	451	456	257	769	-169	-8	195	-36	-32768	2013	0	35	-11990	860	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:15:34	19	344	255	225	450	456	258	776	-168	-14	195	-38	-32768	2013	0	34	-11990	860	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:16:34	19	344	256	225	450	456	259	783	-168	-6	195	-40	-32768	2013	0	32	-11990	861	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:17:34	19	344	256	226	449	456	260	788	-168	-13	195	-40	-32768	2013	0	31	-11990	861	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:18:34	19	344	257	226	449	456	260	794	-167	-8	194	-42	-32768	2013	0	30	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:19:34	19	344	257	226	448	456	260	797	-168	-13	194	-43	-32768	2013	0	29	-11990	859	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:20:34	19	344	258	227	448	456	261	801	-167	-16	194	-44	-32768	2013	0	28	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:21:34	18	344	258	227	447	456	262	803	-168	-6	195	-45	-32768	2013	0	27	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:22:34	18	344	258	227	447	456	262	807	-167	-13	194	-46	-32768	2013	0	26	-11990	859	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:23:34	18	344	259	228	447	456	263	808	-167	-8	194	-47	-32768	2013	0	25	-11990	859	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:24:34	18	344	259	228	446	456	263	810	-168	-8	194	-48	-32768	2013	0	24	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:25:39	18	344	260	228	445	455	263	812	-167	-15	194	-48	-32768	2013	0	24	-11990	859	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:26:36	17	344	260	228	445	456	263	814	-168	-9	194	-48	-32768	2013	0	23	-11990	859	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:27:36	16	344	260	228	444	455	263	816	-168	-8	194	-49	-32768	2013	0	22	-11990	859	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:28:36	16	344	261	229	444	455	264	816	-168	-13	194	-50	-32768	2013	0	22	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:29:36	16	344	261	229	444	455	264	818	-167	-10	194	-50	-32768	2013	0	21	-11990	859	15	204	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:30:36	16	344	261	229	443	455	264	818	-168	-9	194	-50	-32768	2013	0	20	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:31:36	15	344	261	229	443	455	264	820	-167	-13	194	-51	-32768	2013	0	20	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:32:36	14	344	261	230	442	455	265	820	-167	-6	194	-52	-32768	2013	0	19	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:33:36	14	344	262	230	442	455	265	820	-167	-14	194	-52	-32768	2013	0	18	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:34:36	14	344	262	230	441	455	265	822	-167	-12	194	-52	-32768	2013	0	18	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:35:36	14	344	262	230	441	455	265	822	-168	-6	194	-53	-32768	2013	0	17	-11990	861	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:36:36	13	344	262	230	440	454	266	822	-167	-15	194	-52	-32768	2013	0	17	-11990	861	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:37:36	13	344	263	230	440	455	266	822	-167	-6	194	-54	-32768	2013	0	16	-11990	861	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:38:36	13	344	262	230	439	454	265	822	-168	-8	194	-54	-32768	2013	0	16	-11990	861	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:39:36	13	344	263	230	439	454	266	823	-167	-15	194	-54	-32768	2013	0	15	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:40:44	11	344	263	230	438	454	266	823	-168	-5	194	-53	-32768	2013	0	15	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:41:40	11	344	263	231	437	454	266	823	-168	-13	194	-52	-32768	2013	0	14	-11990	859	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:42:40	11	344	263	231	437	454	266	823	-168	-13	194	-52	-32768	2013	0	14	-11990	860	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:43:40	11	344	263	230	436	454	266	823	-168	-5	194	-50	-32768	2013	0	13	-11990	861	15	203	3	30	0	0	0	0	23691	36428	3846486	797575	479842	72620
2022-11-24	00:44:40	11	344	264	231	436	454	267	823	-168	-19	194	-50	-32768	2013	0	13	-11990	860	15	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:45:40	10	344	264	231	435	454	267	825	-168	-8	194	-49	-32768	2013	0	13	-11990	861	15	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:46:40	9	344	264	231	435	454	267	825	-169	-8	194	-48	-32768	2013	0	12	-11990	860	15	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:47:40	9	344	264	231	434	453	267	825	-169	-19	194	-50	-32768	2013	0	12	-11990	861	15	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:48:40	9	344	264	231	433	453	267	825	-169	-10	194	-50	-32768	2013	0	11	-11990	860	15	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:49:40	9	344	264	231	433	453	267	825	-169	-6	194	-51	-32768	2013	0	11	-11990	860	15	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:50:40	9	344	264	231	432	453	267	825	-169	-17	194	-51	-32768	2013	0	11	-11990	860	15	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:51:40	8	344	264	231	432	453	267	825	-169	-15	194	-51	-32768	2013	0	10	-11990	860	15	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:52:40	8	344	264	232	431	453	267	825	-170	-6	194	-52	-32768	2013	0	10	-11990	861	14	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:53:40	8	344	264	232	431	453	267	825	-170	-15	194	-54	-32768	2013	0	10	-11990	861	14	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:54:40	8	344	264	231	430	453	267	827	-170	-19	194	-54	-32768	2013	0	9	-11990	861	14	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:55:45	8	344	264	232	429	453	267	827	-170	-12	194	-54	-32768	2013	0	9	-11990	841	14	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:56:45	7	344	264	232	429	453	267	825	-169	-12	194	-54	-32768	2013	0	9	-11990	841	14	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:57:45	6	344	264	232	428	453	267	825	-169	-15	194	-54	-32768	2013	0	8	-11990	841	14	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:58:45	6	344	264	232	428	453	267	823	-169	-21	194	-54	-32768	2013	0	8	-11990	840	14	203	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	00:59:44	6	344	263	232	427	452	252	820	-165	-6	194	-51	-32768	2013	0	70	-11990	260	14	203	3	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:00:44	6	344	251	233	426	452	238	759	-82	26	194	-11	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:01:44	6	344	246	233	426	452	241	700	-27	57	194	1	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:02:44	6	345	245	234	426	452	244	660	-10	79	194	14	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:03:44	6	345	245	234	426	451	248	631	-1	95	194	13	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:04:44	5	345	245	235	425	451	252	614	20	109	194	17	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:05:44	6	345	245	236	425	451	256	604	52	122	195	40	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:06:44	6	345	245	236	425	451	259	592	77	129	195	53	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:07:44	6	345	246	236	425	450	263	579	93	133	195	60	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:08:44	6	345	246	237	425	451	266	566	104	136	195	63	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:09:44	6	345	246	236	425	451	269	554	112	138	195	66	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:10:48	6	345	247	236	425	451	272	543	117	140	195	68	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:11:48	6	345	247	236	424	450	275	534	122	143	195	69	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:12:48	6	345	247	235	424	450	278	525	127	145	195	72	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:13:48	6	345	248	234	424	450	280	519	131	149	195	74	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:14:48	6	345	248	234	424	450	282	514	136	152	195	78	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:15:48	8	345	248	234	424	450	284	508	140	156	195	80	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:16:48	8	345	248	233	424	450	286	504	144	159	195	84	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:17:48	8	345	248	233	424	450	287	501	147	163	195	89	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:18:48	8	345	249	234	424	450	289	498	150	165	195	92	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:19:48	9	345	249	234	424	450	290	495	151	169	195	96	-32768	2013	0	0	-11990	0	14	203	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:20:48	9	345	249	235	424	450	291	492	152	173	195	99	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:21:48	9	345	249	236	424	450	292	489	155	176	195	100	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:22:48	9	345	249	236	423	450	293	486	156	178	195	103	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:23:48	11	345	249	237	423	450	294	483	158	181	195	106	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:24:48	11	346	249	238	423	449	294	481	159	183	195	107	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:25:52	11	346	249	239	423	449	294	479	159	184	195	109	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:26:52	11	345	249	240	423	449	295	477	160	185	195	111	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:27:52	13	345	249	241	423	449	296	474	160	186	195	112	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:28:52	13	345	249	242	423	449	296	472	161	187	195	115	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:29:52	13	345	249	243	423	449	296	470	161	188	195	116	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:30:52	13	345	249	244	423	449	297	468	163	188	195	117	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:31:52	14	345	249	246	423	449	297	466	163	189	195	118	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:32:52	14	345	249	247	423	449	298	464	164	190	195	120	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:33:52	15	345	249	248	422	449	298	462	164	190	195	121	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:34:52	16	345	249	249	422	449	299	459	165	190	195	121	-32768	2013	0	0	-11990	0	13	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:35:52	16	345	249	249	422	449	299	457	165	190	195	122	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:36:52	16	345	249	250	422	448	299	455	165	190	195	123	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:37:52	18	345	249	251	422	448	300	453	165	190	195	123	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:38:52	18	345	249	252	422	448	300	451	165	190	195	125	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:39:52	18	345	249	252	422	448	300	449	166	191	195	126	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:40:56	18	345	249	253	422	448	300	447	166	191	195	126	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:41:56	19	345	249	254	422	448	300	445	166	191	195	127	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:42:56	19	345	249	255	422	448	301	443	167	191	195	127	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:43:56	19	345	249	256	421	448	301	441	167	191	195	126	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:44:56	19	345	249	256	422	448	301	439	167	191	195	127	-32768	2013	0	0	-11990	0	14	202	6	30	0	0	0	183	23691	36429	3846618	797575	479842	72620
2022-11-24	01:45:56	21	345	249	258	421	448	299	437	167	191	194	127	-32768	-32768	0	70	-11990	0	14	202	3	30	0	0	0	0	23691	36429	3846618	797575	479842	72620
2022-11-24	01:46:56	21	345	242	221	421	448	246	561	103	100	195	104	-32768	-32768	0	70	-11990	541	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:47:56	21	345	245	221	421	448	253	557	-22	-48	194	49	-32768	-32768	0	70	-11990	779	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:48:56	21	344	248	220	421	448	249	556	-119	-89	194	13	-32768	-32768	0	66	-11990	851	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:49:56	21	344	246	220	421	448	249	590	-144	8	194	0	-32768	-32768	0	60	-11990	861	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:50:56	21	344	246	220	421	448	250	623	-162	-15	194	-6	-32768	-32768	0	56	-11990	871	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:51:56	21	344	247	221	421	447	251	654	-169	-23	194	-13	-32768	1998	0	52	-11990	879	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:52:56	21	344	248	221	421	448	252	681	-171	-21	193	-25	-32768	1998	0	49	-11990	860	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:53:56	21	344	249	222	420	447	252	699	-170	-7	194	-26	-32768	1998	0	46	-11990	830	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:55:02	21	344	249	222	420	447	253	714	-167	-12	193	-27	-32768	1998	0	43	-11990	830	14	202	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:55:59	21	344	250	223	420	447	254	727	-166	-10	193	-29	-32768	1998	0	40	-11990	830	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:56:59	21	344	251	224	420	447	255	739	-166	-12	193	-32	-32768	1998	0	38	-11990	830	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:57:59	21	344	252	224	420	447	256	748	-165	-10	193	-34	-32768	1998	0	36	-11990	830	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:58:59	20	344	253	224	420	447	257	756	-165	-10	193	-35	-32768	1998	0	34	-11990	831	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	01:59:59	19	344	253	225	419	447	257	763	-165	-12	193	-36	-32768	1998	0	33	-11990	830	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:00:59	19	344	254	225	419	447	258	769	-164	-10	193	-38	-32768	1998	0	31	-11990	830	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:01:59	19	344	255	226	418	447	258	775	-164	-12	193	-40	-32768	1998	0	30	-11990	830	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:02:59	19	344	255	226	418	447	259	778	-164	-14	193	-40	-32768	1998	0	29	-11990	829	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:03:59	19	344	256	226	418	447	259	781	-163	-11	193	-42	-32768	1998	0	27	-11990	830	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:04:59	19	344	256	227	417	446	260	785	-163	-10	193	-42	-32768	1998	0	26	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:05:59	19	344	257	227	417	446	260	788	-163	-12	193	-44	-32768	1998	0	25	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:06:59	19	344	257	227	416	446	261	790	-163	-15	193	-45	-32768	1998	0	24	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:07:59	19	344	257	227	416	446	261	792	-163	-10	193	-40	-32768	1998	0	23	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:08:59	18	344	258	227	415	446	261	794	-163	-8	193	-42	-32768	1998	0	22	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:10:06	18	344	258	228	414	446	261	796	-162	-13	193	-44	-32768	1998	0	22	-11990	830	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:11:03	18	344	258	228	414	446	262	797	-162	-10	193	-46	-32768	1998	0	21	-11990	829	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:12:03	18	344	258	228	413	445	262	799	-162	-8	193	-48	-32768	1998	0	20	-11990	831	14	201	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:13:03	17	344	259	228	413	445	262	799	-162	-12	193	-48	-32768	1998	0	19	-11990	829	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:14:03	16	344	259	228	412	445	263	801	-162	-10	193	-50	-32768	1998	0	19	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:15:03	16	344	259	228	412	445	263	801	-162	-12	193	-50	-32768	1998	0	18	-11990	831	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:16:03	16	344	260	229	411	445	263	803	-162	-10	193	-50	-32768	1998	0	18	-11990	831	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:17:03	16	344	260	229	410	445	263	803	-162	-8	193	-50	-32768	1998	0	17	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:18:03	14	344	260	229	410	445	263	803	-162	-11	193	-50	-32768	1998	0	16	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:19:03	14	344	260	229	409	445	264	805	-162	-10	193	-50	-32768	1998	0	16	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:20:03	14	344	260	229	408	445	264	805	-162	-8	193	-52	-32768	1998	0	15	-11990	831	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:21:03	14	344	261	230	407	444	264	805	-162	-10	193	-52	-32768	1998	0	15	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:22:03	13	344	261	230	407	444	264	805	-162	-12	193	-52	-32768	1998	0	14	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:23:03	13	344	261	229	406	444	264	805	-162	-10	193	-52	-32768	1998	0	14	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:24:03	13	344	261	230	405	444	265	805	-162	-12	193	-52	-32768	1998	0	13	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:25:11	13	344	261	230	405	444	265	807	-162	-10	193	-52	-32768	1998	0	13	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:26:08	13	344	261	230	404	444	265	807	-162	-10	193	-51	-32768	1998	0	12	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:27:08	11	344	261	230	404	443	265	807	-162	-10	193	-51	-32768	1998	0	12	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:28:08	11	344	262	230	403	443	265	807	-162	-8	193	-51	-32768	1998	0	11	-11990	831	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:29:08	11	344	261	230	402	443	265	807	-162	-13	193	-51	-32768	1998	0	11	-11990	829	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:30:08	11	344	262	230	402	443	265	807	-162	-9	193	-52	-32768	1998	0	11	-11990	830	14	200	3	30	0	0	0	0	23692	36429	3846618	797575	479842	72620
2022-11-24	02:31:08	11	344	262	230	401	443	265	807	-163	-12	193	-52	-32768	1998	0	11	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:32:08	11	344	262	231	400	443	266	807	-163	-12	193	-52	-32768	1998	0	10	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:33:08	10	344	262	230	400	443	266	807	-163	-12	193	-52	-32768	1998	0	10	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:34:08	9	344	262	231	400	442	266	807	-164	-12	193	-52	-32768	1998	0	9	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:35:08	9	344	262	231	398	442	266	807	-165	-12	193	-52	-32768	1998	0	9	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:36:08	9	344	262	231	398	442	266	807	-165	-13	193	-52	-32768	1998	0	9	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:37:08	9	344	262	231	397	442	266	807	-165	-10	193	-54	-32768	1998	0	8	-11990	831	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:38:07	9	344	262	231	397	442	266	808	-166	-12	193	-56	-32768	1998	0	8	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:39:07	8	344	263	231	396	442	266	808	-166	-14	193	-57	-32768	1998	0	8	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:40:12	8	344	263	231	395	442	266	808	-166	-14	193	-59	-32768	1998	0	7	-11990	829	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:41:12	8	344	262	231	395	442	266	808	-166	-12	193	-61	-32768	1998	0	7	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:42:12	8	344	263	231	394	441	266	808	-166	-15	193	-63	-32768	1998	0	7	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:43:12	8	344	263	231	393	441	266	808	-166	-19	193	-63	-32768	1998	0	7	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:44:12	8	344	262	231	393	441	267	810	-168	-17	193	-65	-32768	1998	0	6	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:45:12	8	344	263	232	392	441	266	810	-168	-13	193	-67	-32768	1998	0	6	-11990	829	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:46:12	7	344	262	232	391	441	266	810	-169	-14	193	-67	-32768	1998	0	6	-11990	830	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:47:12	6	344	263	232	391	441	266	810	-169	-16	193	-67	-32768	1998	0	6	-11990	829	14	200	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:48:12	6	344	262	231	390	441	266	812	-169	-21	193	-70	-32768	1998	0	5	-11990	830	14	199	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	02:49:12	6	344	257	232	389	440	237	793	-146	0	193	-54	-32768	1998	0	100	-11990	0	14	200	7	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:50:12	6	344	247	232	389	440	239	722	-57	34	193	-8	-32768	1998	0	0	-11990	0	14	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:51:12	6	345	244	233	389	440	244	670	-18	63	193	1	-32768	1998	0	0	-11990	0	14	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:52:12	6	345	243	233	388	440	252	634	-8	83	193	19	-32768	1998	0	0	-11990	0	14	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:53:12	6	345	242	233	388	439	259	610	-1	97	193	21	-32768	1998	0	0	-11990	0	14	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:54:12	6	345	242	233	388	439	263	594	23	111	193	27	-32768	1998	0	0	-11990	0	14	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:55:16	6	345	242	234	388	439	264	574	53	125	193	44	-32768	1998	0	0	-11990	0	14	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:56:16	6	345	242	235	388	438	265	554	76	136	193	56	-32768	1998	0	0	-11990	0	14	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:57:16	6	345	242	238	388	438	264	538	91	143	193	63	-32768	1998	0	0	-11990	0	14	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:58:16	6	345	242	241	388	438	263	529	102	144	193	66	-32768	1998	0	0	-11990	0	14	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	02:59:16	6	345	241	244	387	438	262	522	110	145	194	68	-32768	1998	0	0	-11990	0	14	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:00:16	6	345	241	248	387	438	262	517	116	146	193	72	-32768	1998	0	0	-11990	0	14	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:01:16	8	345	241	252	387	438	261	511	122	147	193	73	-32768	1998	0	0	-11990	0	13	200	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:02:16	8	345	241	255	387	438	260	507	127	150	193	77	-32768	1998	0	0	-11990	0	13	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:03:16	8	345	241	257	387	438	259	503	132	155	193	81	-32768	1998	0	0	-11990	0	13	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:04:16	8	345	241	260	387	438	259	499	137	158	194	84	-32768	1998	0	0	-11990	0	13	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:05:16	8	345	241	262	387	438	258	496	141	161	194	88	-32768	1998	0	0	-11990	0	13	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:06:16	9	345	241	264	387	437	257	492	144	165	194	92	-32768	1998	0	0	-11990	0	13	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:07:16	9	345	239	265	387	437	257	490	148	168	193	96	-32768	1998	0	0	-11990	0	13	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:08:16	9	345	240	266	387	437	256	486	151	172	194	99	-32768	1998	0	0	-11990	0	13	199	6	20	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:09:16	9	345	240	267	387	437	256	484	152	175	194	101	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:09:23	10	345	241	267	387	437	256	481	154	178	194	103	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:10:20	11	345	240	268	387	437	256	479	156	181	194	106	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:11:20	11	345	240	268	387	437	255	476	157	182	194	108	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:12:20	11	345	240	268	386	437	255	474	158	184	195	109	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:13:20	11	345	239	268	387	437	255	472	159	185	195	112	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:14:20	13	345	239	269	387	436	255	470	160	186	195	113	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:15:19	13	345	239	268	386	436	255	467	161	187	195	115	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:16:19	13	345	239	269	387	436	255	465	162	188	195	117	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:17:19	13	345	239	269	386	436	255	463	163	188	195	118	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:18:19	14	345	239	268	386	436	255	461	163	188	194	118	-32768	1998	0	0	-11990	0	13	200	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:19:19	14	345	239	268	386	436	255	459	164	189	194	120	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:20:19	14	345	239	268	386	436	256	457	164	190	194	121	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:21:19	16	345	239	267	386	436	256	455	164	190	194	122	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:22:19	16	345	239	267	386	436	257	453	164	190	194	122	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:23:19	16	345	239	266	386	436	258	451	165	190	194	123	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:24:25	17	345	239	266	386	435	259	449	165	190	194	123	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:25:22	18	345	239	266	386	435	260	447	165	190	194	125	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:26:22	18	345	239	266	386	435	261	445	165	190	194	126	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:27:22	18	345	239	265	386	435	262	443	166	190	194	126	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:28:22	19	345	239	265	386	435	263	441	166	190	194	127	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:29:22	19	345	238	265	386	435	264	439	166	190	194	127	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:30:22	19	345	238	265	386	435	265	437	166	190	194	127	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:31:22	19	345	238	264	386	435	266	435	166	190	194	127	-32768	1998	0	0	-11990	0	13	199	6	30	0	0	0	183	23692	36430	3846739	797575	479842	72620
2022-11-24	03:32:22	19	344	238	246	386	435	252	434	166	190	194	128	-32768	-32768	0	70	-11990	0	14	199	3	30	0	0	0	0	23692	36430	3846739	797575	479842	72620
2022-11-24	03:33:22	21	344	237	221	386	434	242	559	84	101	193	96	-32768	-32768	0	70	-11990	519	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:34:21	21	344	241	220	386	435	247	553	-25	-32	193	46	-32768	-32768	0	70	-11990	640	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:35:21	21	344	242	220	386	434	245	549	-100	-21	192	14	-32768	-32768	0	61	-11990	761	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:36:21	21	344	243	220	386	434	249	575	-135	-38	193	2	-32768	-32768	0	56	-11990	830	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:37:21	21	344	245	220	386	434	249	608	-154	-5	193	-6	-32768	-32768	0	52	-11990	840	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:38:21	21	344	246	220	386	434	250	638	-162	-22	192	-6	-32768	2030	0	49	-11990	851	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:39:26	21	344	247	221	386	434	252	665	-167	-17	192	-17	-32768	2030	0	46	-11990	860	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:40:26	21	344	248	221	386	434	253	689	-170	-17	192	-27	-32768	2030	0	43	-11990	870	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:41:26	21	344	249	222	385	434	253	708	-171	-17	192	-32	-32768	2030	0	41	-11990	830	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:42:26	21	344	249	222	385	434	253	722	-168	1	192	-32	-32768	2030	0	38	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:43:26	21	344	250	223	385	433	254	733	-164	-15	192	-32	-32768	2030	0	36	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:44:26	21	344	251	223	384	434	255	743	-165	-5	192	-33	-32768	2030	0	34	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:45:26	21	344	252	224	384	433	255	751	-165	-10	192	-30	-32768	2030	0	32	-11990	819	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:46:26	21	344	252	224	384	433	256	758	-164	-8	192	-32	-32768	2030	0	31	-11990	821	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:47:26	20	344	253	225	383	433	257	764	-164	-6	192	-36	-32768	2030	0	29	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:48:26	20	344	253	225	383	433	258	769	-163	-10	192	-37	-32768	2030	0	28	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:49:26	19	344	254	225	382	433	258	774	-163	-6	192	-38	-32768	2030	0	27	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:50:26	19	344	254	226	382	433	258	778	-162	-13	192	-40	-32768	2030	0	26	-11990	819	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:51:26	19	344	255	226	381	433	259	781	-162	-8	192	-40	-32768	2030	0	25	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:52:26	19	344	255	226	381	433	259	783	-162	-8	192	-42	-32768	2030	0	24	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:53:26	18	344	256	226	381	432	260	787	-162	-12	192	-42	-32768	2030	0	23	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:54:29	18	344	256	227	380	432	260	788	-163	-6	192	-43	-32768	2030	0	22	-11990	819	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:55:29	18	344	256	227	379	432	260	790	-162	-11	192	-44	-32768	2030	0	21	-11990	820	14	198	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:56:29	18	344	257	227	379	432	261	792	-162	-4	192	-44	-32768	2030	0	20	-11990	819	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:57:29	17	344	257	227	378	432	261	794	-163	-11	192	-45	-32768	2030	0	20	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:58:29	16	344	257	227	378	432	261	794	-162	-8	192	-46	-32768	2030	0	19	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	03:59:29	16	344	258	228	377	431	261	796	-162	-8	192	-46	-32768	2030	0	18	-11990	821	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:00:29	16	344	258	227	377	431	262	796	-162	-13	192	-46	-32768	2030	0	18	-11990	821	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:01:29	16	344	258	228	376	431	262	797	-162	-6	192	-46	-32768	2030	0	17	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:02:29	14	344	258	228	376	431	262	797	-162	-7	192	-47	-32768	2030	0	16	-11990	820	14	199	3	30	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:03:29	14	344	286	352	375	431	374	819	-161	-66	192	-47	-32768	2030	0	100	-11990	819	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:04:29	14	344	351	386	373	430	410	850	-137	20	192	-44	-32768	2030	0	100	-11990	830	14	199	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:05:29	14	344	386	396	373	430	428	879	-137	-5	192	-40	-32768	2030	0	78	-11990	849	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:06:29	13	344	408	400	376	430	441	904	-121	-3	192	-40	-32768	2030	0	60	-11990	868	14	199	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:07:29	13	344	422	404	380	430	454	927	-111	-8	192	-42	-32768	2030	0	50	-11990	888	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:08:29	13	344	435	408	385	431	464	950	-109	-12	192	-42	-32768	2030	0	48	-11990	910	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:09:32	13	344	444	413	389	432	470	972	-117	-13	192	-45	-32768	2030	0	48	-11990	919	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:10:32	11	344	451	418	394	434	474	991	-116	-10	192	-45	-32768	2030	0	50	-11990	920	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:11:32	11	344	456	422	399	436	476	1009	-119	-12	192	-46	-32768	2030	0	53	-11990	918	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:12:32	11	344	459	427	404	437	478	1022	-120	-10	192	-45	-32768	2030	0	57	-11990	921	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:13:32	11	344	461	433	410	437	480	1035	-113	-3	192	-44	-32768	2030	0	63	-11990	919	14	198	15	20	0	0	0	0	23693	36430	3846739	797575	479842	72620
2022-11-24	04:14:32	11	344	463	438	415	437	481	1048	-112	-5	192	-43	-32768	2030	0	70	-11990	920	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:15:32	9	344	464	443	419	437	482	1056	-123	-2	192	-42	-32768	2030	0	79	-11990	919	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:16:32	9	344	466	448	423	437	483	1067	-136	-3	192	-44	-32768	2030	0	89	-11990	920	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:17:32	9	344	467	453	427	438	484	1074	-139	-1	192	-44	-32768	2030	0	100	-11990	920	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:18:32	9	344	469	457	430	440	488	1082	-138	6	192	-45	-32768	2030	0	100	-11990	919	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:19:32	9	344	472	460	433	443	491	1085	-137	6	192	-46	-32768	2030	0	100	-11990	920	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:20:32	9	344	475	464	436	445	495	1093	-138	4	192	-47	-32768	2030	0	100	-11990	920	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:21:32	8	344	478	467	440	447	498	1097	-135	11	192	-47	-32768	2030	0	100	-11990	919	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:22:32	8	344	482	470	443	450	500	1101	-133	12	192	-46	-32768	2030	0	100	-11990	868	14	198	15	20	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:23:31	8	344	429	229	446	452	256	1071	-129	42	192	-46	-32768	2030	0	100	-11990	870	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:24:38	8	344	309	224	449	455	253	1021	-145	-22	192	-50	-32768	2030	0	100	-11990	871	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:25:35	8	344	271	223	451	456	251	986	-161	-22	192	-54	-32768	2030	0	93	-11990	871	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:26:35	8	344	259	224	452	456	253	959	-167	-16	192	-59	-32768	2030	0	85	-11990	870	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:27:35	8	344	255	224	453	455	253	938	-170	-10	192	-59	-32768	2030	0	78	-11990	880	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:28:35	8	344	254	224	453	454	253	919	-171	-13	192	-61	-32768	2030	0	71	-11990	850	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:29:35	6	344	254	225	453	453	254	902	-169	-5	192	-59	-32768	2030	0	65	-11990	829	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:30:35	6	344	254	225	453	453	256	887	-167	-5	192	-57	-32768	2030	0	60	-11990	830	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:31:35	6	344	255	226	452	453	256	874	-167	-9	192	-57	-32768	2030	0	55	-11990	829	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:32:35	6	344	256	226	452	453	257	863	-166	-10	192	-57	-32768	2030	0	51	-11990	830	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:33:35	6	345	256	226	452	453	258	853	-168	-5	192	-57	-32768	2030	0	48	-11990	830	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:34:35	6	345	257	227	452	453	258	845	-168	-13	191	-57	-32768	2030	0	44	-11990	830	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:35:35	6	345	257	227	452	453	259	839	-169	-7	191	-58	-32768	2030	0	41	-11990	830	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:36:35	6	345	257	227	452	453	259	835	-169	-11	191	-58	-32768	2030	0	39	-11990	831	14	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:37:35	5	345	258	227	452	453	260	829	-169	-11	191	-57	-32768	2030	0	36	-11990	830	13	198	3	30	0	0	0	0	23693	36431	3846865	797575	479842	72620
2022-11-24	04:38:35	4	345	256	227	451	453	243	820	-164	-3	191	-54	-32768	2030	0	70	-11990	0	13	198	7	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:39:39	4	345	246	228	451	453	234	757	-80	38	192	-14	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:40:39	4	345	243	229	451	453	239	701	-26	68	192	-1	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:41:39	4	345	242	230	451	453	248	661	-10	86	192	11	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:42:39	4	345	241	230	451	453	255	632	-6	98	192	13	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:43:39	4	345	241	231	451	452	261	592	4	127	192	16	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:44:39	4	345	241	231	451	452	263	559	38	147	192	35	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:45:39	4	345	241	232	451	452	264	543	66	150	192	49	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:46:39	4	345	241	234	451	452	264	538	84	149	192	56	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:47:39	5	345	241	238	451	452	263	534	98	150	192	62	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:48:39	6	345	241	241	451	452	262	531	107	150	192	66	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:49:39	6	346	241	246	451	452	262	526	115	152	193	68	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:50:39	6	346	240	250	451	452	261	522	122	156	193	71	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:51:39	6	346	240	254	451	452	260	519	128	159	192	73	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:52:39	6	346	239	258	451	452	259	515	133	163	192	75	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:53:39	8	346	239	261	450	452	259	511	138	165	193	79	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:54:43	8	346	239	263	451	452	258	508	142	168	192	82	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:55:43	8	346	239	266	450	452	258	505	146	172	193	87	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:56:42	8	346	239	268	450	452	257	503	149	174	193	92	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:57:42	8	346	239	269	450	452	257	500	151	177	193	95	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:58:42	8	346	239	270	450	451	257	498	153	180	193	99	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	04:59:42	9	346	239	272	450	452	257	495	155	182	193	100	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:00:42	9	346	239	272	450	451	257	493	156	183	193	103	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:01:42	9	346	239	273	450	451	256	489	157	184	192	106	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:02:42	10	346	239	273	450	451	256	486	158	185	193	107	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:03:42	11	346	239	274	450	451	256	484	159	186	193	109	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:04:42	11	346	239	274	450	451	256	481	159	186	193	111	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:05:42	11	346	239	274	450	451	256	479	159	187	193	112	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:06:42	11	346	239	274	450	451	256	477	160	187	192	113	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:07:42	13	346	239	274	450	451	256	474	161	187	192	115	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:08:42	13	346	239	274	450	451	256	472	161	187	193	116	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:09:46	13	346	239	273	450	451	257	470	162	188	192	117	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:10:46	13	346	239	273	449	451	257	468	163	188	192	118	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:11:46	14	346	239	273	449	451	257	465	163	188	192	120	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:12:46	14	346	239	273	449	451	258	463	163	188	193	121	-32768	2030	0	0	-11990	0	13	198	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:13:46	14	346	239	273	449	451	259	461	164	188	192	121	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:14:46	16	346	239	272	449	451	260	459	164	188	193	122	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:15:46	16	346	239	272	449	450	261	457	164	188	193	123	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:16:46	16	346	239	272	449	451	261	455	164	188	193	124	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:17:46	18	345	239	272	449	451	262	453	165	188	192	125	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:18:46	18	345	239	271	449	451	263	451	165	188	192	126	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:19:46	18	345	238	271	449	450	264	449	165	188	192	126	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:20:46	18	345	238	271	449	450	266	447	165	189	193	126	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:21:46	19	345	238	271	449	450	266	445	166	190	192	126	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:22:46	19	345	238	271	449	450	268	443	165	189	193	126	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:23:46	19	345	238	270	449	450	268	441	166	188	192	127	-32768	2030	0	0	-11990	0	13	197	6	30	0	0	0	183	23693	36431	3846865	797575	479842	72620
2022-11-24	05:24:50	19	345	239	227	449	450	229	440	166	188	192	127	-32768	-32768	0	70	-11990	262	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:25:50	21	345	237	218	448	450	245	573	54	51	192	80	-32768	-32768	0	70	-11990	605	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:26:50	21	345	243	218	448	450	250	551	-55	-72	191	24	-32768	-32768	0	69	-11990	830	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:27:50	21	345	244	218	448	450	243	561	-136	-46	191	-2	-32768	-32768	0	63	-11990	839	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:28:50	21	345	243	218	448	450	246	595	-157	-2	191	-6	-32768	-32768	0	58	-11990	850	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:29:50	21	345	244	218	448	450	247	627	-168	-5	191	-17	-32768	2062	0	53	-11990	860	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:30:50	21	345	244	219	448	450	249	656	-170	-33	191	-26	-32768	2062	0	50	-11990	871	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:31:50	21	344	245	219	448	450	249	680	-172	-5	191	-32	-32768	2062	0	46	-11990	830	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:32:50	21	344	246	219	448	450	249	697	-169	-3	191	-31	-32768	2062	0	43	-11990	810	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:33:50	21	344	247	220	448	450	250	711	-165	-6	191	-32	-32768	2062	0	40	-11990	810	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:34:50	21	344	248	221	448	450	251	723	-165	-6	191	-34	-32768	2062	0	38	-11990	811	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:35:50	21	344	248	221	448	450	252	733	-164	-8	191	-36	-32768	2062	0	36	-11990	810	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:36:50	21	344	249	221	448	450	253	742	-164	-6	191	-36	-32768	2062	0	34	-11990	811	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:37:50	21	344	250	222	448	450	253	748	-163	-10	191	-38	-32768	2062	0	32	-11990	810	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:38:50	21	344	250	222	447	450	254	755	-163	-7	191	-40	-32768	2062	0	30	-11990	810	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:39:54	20	344	251	223	448	450	255	761	-163	-8	191	-42	-32768	2062	0	29	-11990	810	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:40:54	19	344	252	223	447	450	255	764	-162	-5	191	-43	-32768	2062	0	27	-11990	810	13	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:41:54	19	344	252	223	447	450	255	769	-162	-10	191	-44	-32768	2062	0	26	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:42:54	19	344	252	223	447	450	256	773	-163	-3	191	-45	-32768	2062	0	25	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:43:54	19	344	253	224	447	450	256	776	-162	-12	191	-46	-32768	2062	0	24	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:44:54	19	344	253	224	447	449	256	778	-162	-3	191	-46	-32768	2062	0	23	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:45:54	19	344	253	224	447	449	257	780	-162	-10	191	-47	-32768	2062	0	22	-11990	809	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:46:54	18	344	254	224	447	449	257	783	-162	-3	191	-48	-32768	2062	0	21	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:47:54	18	344	254	224	446	449	257	784	-162	-10	191	-48	-32768	2062	0	20	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:48:54	18	344	254	224	446	449	258	785	-162	-3	191	-48	-32768	2062	0	19	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:49:54	18	344	255	225	446	449	258	787	-162	-6	191	-48	-32768	2062	0	19	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:50:54	17	344	255	225	446	449	258	788	-162	-8	191	-49	-32768	2062	0	18	-11990	809	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:51:54	16	344	255	225	446	449	258	788	-162	-6	191	-46	-32768	2062	0	17	-11990	811	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:52:54	16	344	255	225	446	449	259	790	-162	-8	191	-46	-32768	2062	0	16	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:54:01	16	344	255	225	445	449	258	790	-162	-5	191	-48	-32768	2062	0	16	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:54:58	14	344	256	225	445	449	259	790	-162	-6	191	-50	-32768	2062	0	15	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:55:58	14	344	256	226	445	449	259	792	-162	-10	191	-50	-32768	2062	0	15	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:56:58	14	344	256	225	445	449	259	792	-162	-2	191	-52	-32768	2062	0	14	-11990	810	14	196	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:57:58	14	344	256	226	445	449	259	792	-162	-9	191	-52	-32768	2062	0	13	-11990	809	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:58:58	13	344	256	226	445	449	260	793	-162	-4	191	-53	-32768	2062	0	13	-11990	810	14	197	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	05:59:58	13	344	256	226	445	449	260	794	-162	-6	191	-53	-32768	2062	0	12	-11990	810	14	196	3	30	0	0	0	0	23694	36431	3846865	797575	479842	72620
2022-11-24	06:00:58	13	344	257	226	445	448	260	794	-162	-8	191	-54	-32768	2062	0	12	-11990	810	14	197	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:01:58	13	344	257	226	445	449	260	794	-162	-2	191	-55	-32768	2062	0	11	-11990	810	14	197	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:02:58	13	344	257	226	445	449	260	794	-162	-10	191	-57	-32768	2062	0	11	-11990	811	14	197	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:03:58	11	344	257	226	444	448	260	794	-162	-2	191	-57	-32768	2062	0	11	-11990	810	14	197	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:04:58	11	344	257	226	444	448	260	794	-162	-6	190	-57	-32768	2062	0	10	-11990	811	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:05:58	11	344	257	226	444	448	260	794	-162	-8	191	-57	-32768	2062	0	10	-11990	810	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:06:58	11	344	257	226	444	448	260	796	-162	-6	191	-57	-32768	2062	0	10	-11990	810	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:07:58	10	344	257	227	444	448	261	796	-162	-6	190	-57	-32768	2062	0	9	-11990	810	14	197	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:09:05	9	344	257	227	444	448	261	796	-162	-6	191	-58	-32768	2062	0	9	-11990	811	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:10:02	9	344	257	227	443	448	261	796	-162	-5	191	-57	-32768	2062	0	8	-11990	810	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:11:02	9	344	258	227	443	448	261	796	-162	-8	191	-57	-32768	2062	0	8	-11990	810	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:12:02	9	344	258	227	443	448	261	796	-163	-5	191	-57	-32768	2062	0	8	-11990	810	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:13:02	9	344	258	227	443	448	261	796	-163	-7	191	-58	-32768	2062	0	7	-11990	811	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:14:02	8	344	258	227	443	448	261	796	-163	-5	191	-59	-32768	2062	0	7	-11990	811	14	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:15:02	8	344	258	227	443	448	261	796	-164	-8	190	-59	-32768	2062	0	7	-11990	811	13	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:16:02	8	344	258	227	443	448	261	796	-163	-5	191	-60	-32768	2062	0	6	-11990	810	13	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:17:02	8	344	258	227	443	448	261	796	-165	-3	191	-61	-32768	2062	0	6	-11990	809	13	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:18:02	8	344	258	227	443	448	261	796	-165	-10	191	-61	-32768	2062	0	6	-11990	810	13	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	06:19:02	8	344	258	227	442	447	252	794	-164	-3	191	-61	-32768	2062	0	70	-11990	399	13	196	3	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:20:02	6	344	247	228	442	448	233	743	-90	28	191	-18	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:21:02	6	344	242	228	442	447	237	684	-29	59	191	-3	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:22:02	6	344	239	229	442	447	243	644	-10	80	191	8	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:23:02	6	344	238	229	442	447	251	614	-3	95	191	9	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:24:09	6	344	238	229	442	447	257	593	24	109	191	24	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:25:06	6	345	238	229	442	446	259	568	66	127	191	42	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:26:06	6	345	238	230	442	446	260	539	84	151	191	53	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:27:06	6	345	238	232	442	446	260	526	94	152	191	61	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:28:06	6	345	238	236	441	446	259	519	103	152	191	64	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:29:06	6	345	238	240	441	446	258	514	110	155	191	67	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:30:06	6	345	237	244	441	446	258	509	116	158	191	69	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:31:06	7	345	237	249	441	446	257	504	122	163	191	72	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:32:06	8	345	237	252	441	446	256	500	127	166	191	76	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:33:06	8	345	237	255	441	446	255	497	132	168	191	80	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:34:06	8	345	237	258	441	446	255	493	136	172	192	84	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:35:06	8	345	237	260	441	446	254	490	140	174	192	88	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:36:06	8	345	236	262	441	446	253	486	143	176	192	91	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:37:06	9	345	236	264	441	446	253	484	147	178	192	95	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:38:06	9	345	236	265	441	445	253	481	149	181	192	97	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:39:09	9	345	236	266	440	445	252	479	151	182	192	99	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:40:09	9	345	237	267	440	445	252	476	153	183	192	102	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:41:09	10	345	237	267	440	445	252	473	154	184	192	103	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:42:09	11	345	236	268	440	445	251	470	156	185	192	104	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:43:09	11	345	236	268	440	445	251	468	157	186	193	106	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:44:09	11	345	236	268	440	445	250	466	158	186	193	108	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:45:09	12	345	237	268	440	445	250	464	158	186	193	109	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:46:09	13	345	236	268	440	445	250	461	159	187	193	111	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:47:09	13	345	236	268	440	445	250	459	160	187	193	113	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:48:09	13	345	236	269	440	445	250	457	160	187	193	114	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:49:09	13	345	236	268	440	445	251	455	161	187	193	115	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:50:09	14	345	236	268	440	445	251	453	161	188	193	116	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:51:09	14	345	236	269	440	445	252	451	162	188	193	117	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:52:09	14	345	236	269	439	445	252	449	163	188	193	118	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:53:09	15	345	236	268	439	445	253	447	163	188	193	120	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:54:15	16	345	236	268	439	445	254	445	164	188	193	120	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:55:12	16	345	236	267	439	445	255	443	164	188	193	121	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:56:12	16	345	236	267	439	445	256	441	164	188	193	122	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:57:12	18	345	236	266	439	444	257	439	165	188	193	122	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:58:12	18	345	236	266	439	444	258	437	165	189	194	122	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	06:59:12	18	345	235	266	439	444	260	435	165	190	193	123	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	07:00:12	18	345	236	265	439	444	261	433	166	190	193	125	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	07:01:12	19	345	236	265	439	444	262	431	166	190	194	127	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	07:02:12	19	344	235	265	438	444	263	429	166	190	194	128	-32768	2062	0	0	-11990	0	13	196	6	30	0	0	0	183	23694	36432	3846992	797575	479842	72620
2022-11-24	07:03:12	19	344	235	264	438	444	264	427	167	190	194	129	-32768	-32768	0	70	-11990	0	13	196	3	30	0	0	0	0	23694	36432	3846992	797575	479842	72620
2022-11-24	07:04:12	19	344	230	218	438	444	219	427	167	190	194	131	-32768	-32768	0	0	-11400	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:05:12	21	344	224	219	438	444	223	425	167	190	194	132	-32768	-32768	0	0	-11400	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:06:12	21	344	223	220	438	444	226	422	168	190	194	134	-32768	-32768	0	0	-11526	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:07:12	21	344	223	221	438	444	229	420	168	191	194	135	-32768	-32768	0	0	-11654	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:08:12	21	344	223	221	437	444	231	419	168	190	194	137	-32768	-32768	0	0	-11782	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:08:17	21	344	224	222	437	444	234	418	168	191	194	139	-32768	-32768	0	0	-11910	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:09:14	21	344	224	222	437	443	236	416	168	191	194	142	-32768	-32768	0	0	-11990	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:10:14	22	344	224	223	437	444	238	414	168	191	194	144	-32768	-32768	0	0	-11990	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:11:14	22	344	225	223	437	444	240	412	168	191	194	146	-32768	-32768	0	0	-11990	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:12:14	22	344	225	224	437	444	241	410	169	191	194	149	-32768	-32768	0	0	-11990	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:13:14	22	344	226	225	436	444	243	408	169	191	194	150	-32768	-32768	0	0	-11990	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:14:14	22	344	226	225	435	444	246	406	169	191	195	151	-32768	-32768	0	0	-11990	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:15:14	24	344	226	225	435	443	247	404	171	191	196	152	-32768	-32768	0	0	-11990	0	13	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:16:14	24	344	227	226	435	443	248	402	171	192	197	153	-32768	-32768	0	0	-11990	0	14	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:17:14	24	344	227	226	434	444	249	400	172	192	197	153	-32768	-32768	0	0	-11990	0	14	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:18:14	24	344	228	227	432	443	250	398	173	193	198	153	-32768	-32768	0	0	-11990	0	14	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:19:14	26	344	228	227	429	443	252	397	173	193	198	154	-32768	-32768	0	0	-11990	0	14	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:20:14	26	344	228	228	428	444	252	395	174	194	199	155	-32768	-32768	0	0	-11990	0	14	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:21:14	26	344	228	228	418	443	253	393	175	194	200	157	-32768	-32768	0	0	-11990	0	14	196	6	30	0	0	0	0	23695	36432	3846992	797575	479842	72620
2022-11-24	07:22:14	26	344	228	219	394	443	223	393	176	194	200	159	-32768	-32768	0	70	-11990	286	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:23:21	27	344	231	215	362	443	243	518	57	56	200	109	-32768	-32768	0	70	-11990	621	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:24:18	27	343	239	215	332	443	248	513	-53	-66	200	52	-32768	-32768	0	69	-11990	811	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:25:18	27	343	241	215	305	443	242	533	-127	-9	200	24	-32768	-32768	0	63	-11990	821	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:26:18	27	343	241	215	280	443	246	569	-139	15	200	16	-32768	-32768	0	59	-11990	830	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:27:18	27	343	242	215	252	443	247	601	-143	18	202	8	-32768	2027	0	56	-11990	840	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:28:18	27	343	243	215	218	443	248	630	-144	6	203	2	-32768	2027	0	54	-11990	850	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:29:18	27	343	244	216	190	442	249	655	-146	-3	202	-5	-32768	2027	0	51	-11990	860	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:30:18	27	343	245	217	174	443	250	678	-151	-6	200	-11	-32768	2027	0	49	-11990	871	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:31:18	27	343	247	218	168	442	251	698	-154	-5	199	-17	-32768	2027	0	47	-11990	880	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:32:18	27	343	248	219	165	442	252	717	-157	-8	198	-23	-32768	2027	0	45	-11990	890	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:33:18	27	343	249	219	164	442	253	733	-160	-9	198	-26	-32768	2027	0	43	-11990	899	14	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:34:18	27	343	250	220	164	442	254	748	-161	-12	197	-30	-32768	2027	0	42	-11990	911	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:35:18	26	342	251	220	164	441	255	762	-164	-13	197	-34	-32768	2027	0	40	-11990	919	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:36:18	26	342	251	221	165	441	256	775	-167	-10	196	-38	-32768	2027	0	39	-11990	931	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:37:18	26	342	252	221	165	441	257	787	-168	-13	196	-37	-32768	2027	0	38	-11990	939	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:38:21	26	342	253	222	166	441	258	796	-170	-17	196	-42	-32768	2027	0	37	-11990	950	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:39:21	26	343	254	222	166	441	257	805	-171	-12	196	-46	-32768	2027	0	37	-11990	910	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:40:21	26	343	254	222	166	441	257	808	-168	-3	195	-45	-32768	2027	0	36	-11990	899	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:41:21	26	343	254	223	167	441	258	810	-165	-12	195	-46	-32768	2027	0	35	-11990	900	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:42:21	26	343	255	223	167	441	258	812	-166	-8	195	-46	-32768	2027	0	34	-11990	900	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:43:21	26	343	255	223	167	441	258	816	-166	-8	195	-47	-32768	2027	0	33	-11990	900	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:44:21	24	343	255	223	167	441	259	817	-166	-11	195	-48	-32768	2027	0	32	-11990	901	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:45:21	24	343	255	224	167	441	259	819	-166	-12	194	-50	-32768	2027	0	31	-11990	901	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:46:21	24	343	256	224	168	441	260	820	-166	-8	194	-50	-32768	2027	0	31	-11990	899	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:47:21	24	342	256	224	168	441	260	822	-166	-12	194	-50	-32768	2027	0	30	-11990	900	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:48:21	24	342	256	224	168	441	260	823	-166	-12	194	-52	-32768	2027	0	29	-11990	900	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:49:21	22	341	257	224	169	441	260	823	-166	-8	194	-52	-32768	2027	0	29	-11990	900	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:50:21	22	341	257	224	169	441	261	825	-166	-12	194	-52	-32768	2027	0	28	-11990	901	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:51:21	22	341	257	225	171	441	261	825	-166	-12	194	-51	-32768	2027	0	28	-11990	901	15	196	3	30	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:52:21	22	341	255	240	171	440	271	827	-167	-5	194	-52	-32768	2027	0	100	-11990	900	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:53:25	21	341	269	262	175	440	292	835	-166	-7	194	-50	-32768	2027	0	100	-11990	900	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:54:25	21	341	284	268	186	440	301	843	-162	-15	194	-48	-32768	2027	0	86	-11990	901	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:55:25	21	341	294	270	201	439	312	850	-160	-12	194	-48	-32768	2027	0	67	-11990	900	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:56:25	21	341	304	274	215	439	326	858	-159	-14	194	-48	-32768	2027	0	52	-11990	900	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:57:25	19	341	316	277	228	439	342	864	-153	-13	194	-48	-32768	2027	0	41	-11990	899	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:58:25	19	341	329	281	239	439	359	872	-140	-17	194	-50	-32768	2027	0	33	-11990	900	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	07:59:25	19	341	344	286	250	439	379	883	-123	-27	194	-52	-32768	2027	0	26	-11990	920	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	08:00:25	19	341	359	290	258	439	399	897	-118	-28	194	-54	-32768	2027	0	22	-11990	941	15	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	08:01:25	19	342	377	294	266	439	422	913	-118	-32	194	-54	-32768	2027	0	18	-11990	960	16	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	08:02:25	18	342	395	297	273	439	443	931	-119	-38	194	-54	-32768	2027	0	15	-11990	980	16	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	08:03:25	18	343	414	301	280	439	466	952	-121	-42	194	-50	-32768	2027	0	15	-11990	1000	16	196	15	20	0	0	0	0	23696	36432	3846992	797575	479842	72620
2022-11-24	08:04:25	18	343	434	307	286	439	471	971	-123	-44	194	-46	-32768	2027	0	15	-11990	999	16	196	15	20	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:05:25	18	343	444	312	292	440	474	988	-122	-42	194	-34	-32768	2027	0	16	-11990	1000	16	196	15	20	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:06:25	17	343	450	319	297	442	479	1003	-120	-48	194	-21	-32768	2027	0	16	-11990	1000	16	196	15	20	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:07:25	16	343	452	325	304	443	469	1013	-119	-44	194	-16	-32768	2027	0	16	-11990	1000	16	196	15	20	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:08:32	16	343	451	330	311	444	473	1024	-116	-50	194	-13	-32768	2027	0	16	-11990	1000	16	196	15	20	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:09:29	16	343	453	334	318	444	476	1035	-114	-53	194	-9	-32768	2027	0	16	-11990	1001	16	196	15	20	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:10:29	16	343	455	339	325	444	475	1045	-112	-61	194	3	-32768	2027	0	17	-11990	999	16	196	15	20	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:11:29	16	343	456	344	331	444	478	1055	-110	-69	194	14	-32768	2027	0	18	-11990	999	16	196	15	20	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:12:29	15	343	444	239	337	445	279	1051	-104	-65	194	21	-32768	2027	0	70	-11990	1000	16	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:13:29	14	343	317	219	344	445	251	1029	-107	-135	194	24	-32768	2027	0	70	-11990	1000	16	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:14:29	14	343	271	219	348	444	248	1013	-105	-118	193	19	-32768	2027	0	67	-11990	1000	16	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:15:29	14	342	256	219	350	443	248	1000	-107	-128	194	19	-32768	2027	0	62	-11990	1000	16	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:16:29	14	342	251	219	351	442	250	994	-113	-127	194	13	-32768	2027	0	58	-11990	1010	16	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:17:29	14	342	249	219	352	442	250	991	-123	-102	194	2	-32768	2027	0	54	-11990	1020	16	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:18:29	14	342	249	220	352	441	251	991	-137	-86	193	-8	-32768	2027	0	51	-11990	1030	16	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:19:29	14	342	249	221	352	441	252	991	-149	-64	193	-22	-32768	2027	0	48	-11990	1040	16	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:20:29	14	342	250	221	352	440	253	991	-160	-55	193	-30	-32768	2027	0	45	-11990	1050	15	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:21:29	14	342	251	221	351	440	253	991	-166	-56	194	-42	-32768	2027	0	43	-11990	1031	15	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:22:29	14	342	251	222	351	439	253	991	-169	-67	193	-48	-32768	2027	0	40	-11990	1000	15	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:23:35	14	342	252	222	350	439	254	988	-165	-72	193	-50	-32768	2027	0	38	-11990	999	15	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:24:32	14	343	252	223	349	439	254	982	-165	-83	193	-54	-32768	2027	0	36	-11990	999	15	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:25:32	14	343	253	223	349	438	255	980	-158	-92	193	-59	-32768	2027	0	34	-11990	1000	15	196	3	30	0	0	0	0	23696	36433	3847122	797575	479842	72620
2022-11-24	08:26:32	14	343	253	223	348	438	255	977	-157	-105	193	-61	-32768	2027	0	70	-11990	926	15	196	3	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:27:32	14	343	246	224	347	438	229	941	-129	-9	193	-32	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:28:32	14	343	238	225	347	438	234	857	-54	-1	193	11	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:29:32	14	343	236	226	347	437	240	791	-17	36	193	13	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:30:32	13	343	236	227	346	437	250	697	-6	80	193	11	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:31:32	14	343	236	228	346	436	259	625	17	103	193	17	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:32:32	14	343	235	229	346	436	265	580	38	117	193	38	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:33:32	14	343	236	231	346	436	268	557	59	126	193	58	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:34:32	14	343	235	233	346	436	270	553	80	133	193	65	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:35:32	14	343	235	236	346	435	271	556	94	140	193	72	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:36:32	14	343	236	239	346	435	271	559	103	144	193	82	-32768	2027	0	0	-11990	0	15	196	6	30	0	0	0	183	23696	36433	3847122	797575	479842	72620
2022-11-24	08:37:32	14	230	232	224	346	435	225	552	110	147	193	86	-32768	-32768	50	70	-11990	0	15	196	3	30	0	0	0	446	23697	36433	3847122	797575	479842	72620
2022-11-24	08:38:34	14	343	228	223	346	435	226	535	115	158	194	88	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:39:34	14	343	227	224	346	435	231	537	119	163	194	91	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:40:34	14	343	227	224	346	435	234	542	122	163	194	94	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:41:34	14	343	227	225	346	435	237	545	124	165	193	95	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:42:34	15	343	227	225	345	435	239	545	126	168	193	96	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:43:34	16	343	227	226	346	435	241	545	128	169	193	98	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:44:34	16	343	228	226	345	435	243	545	131	171	193	99	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:45:34	16	343	227	227	345	435	244	544	133	172	194	100	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:46:34	17	343	227	230	345	434	246	542	135	172	193	102	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:47:34	18	343	227	233	345	435	248	540	137	173	193	104	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:48:34	18	343	227	237	345	434	248	538	140	173	193	104	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:49:34	18	343	226	240	345	434	249	536	143	174	193	106	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:50:34	18	343	226	244	345	434	250	533	145	175	194	108	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:51:34	19	343	226	248	345	434	250	531	148	176	193	109	-32768	-32768	0	0	-11990	0	15	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:52:34	19	343	226	250	345	434	250	527	151	177	193	109	-32768	-32768	0	0	-11990	0	16	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:53:37	19	343	226	252	345	434	250	525	154	178	193	111	-32768	-32768	0	0	-11990	0	16	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:54:37	21	343	226	254	345	434	250	522	157	178	193	112	-32768	-32768	0	0	-11990	0	16	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:55:37	21	343	226	255	345	433	250	520	158	180	193	113	-32768	-32768	0	0	-11990	0	16	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:56:37	21	343	226	256	345	433	250	517	159	181	193	114	-32768	-32768	0	0	-11990	0	16	196	6	30	0	0	0	0	23697	36433	3847122	797575	479842	72620
2022-11-24	08:57:37	21	343	226	224	345	433	224	517	161	181	193	115	-32768	-32768	0	70	-11990	282	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	08:58:37	22	343	232	216	344	433	246	691	53	34	193	76	-32768	-32768	0	70	-11990	621	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	08:59:37	22	343	242	216	344	433	250	644	-52	-66	192	31	-32768	-32768	0	69	-11990	860	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:00:37	22	343	245	215	344	433	248	653	-134	-62	192	2	-32768	-32768	0	67	-11990	1000	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:01:37	22	343	245	215	344	433	248	689	-170	-42	192	-6	-32768	-32768	0	64	-11990	1011	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:02:37	22	343	245	216	345	433	248	721	-186	-29	192	-5	-32768	2028	0	61	-11990	970	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:03:37	22	343	245	216	344	432	248	743	-185	-23	192	-6	-32768	2028	0	59	-11990	931	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:04:37	22	343	245	218	344	432	248	758	-180	-13	192	-12	-32768	2028	0	55	-11990	889	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:05:37	22	343	245	218	344	432	249	766	-174	-10	192	-23	-32768	2028	0	53	-11990	861	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:06:37	22	343	245	219	344	432	249	771	-169	-6	192	-28	-32768	2028	0	49	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:07:37	23	343	246	219	343	432	251	775	-164	-7	192	-29	-32768	2028	0	47	-11990	830	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:08:39	23	343	247	220	343	432	251	778	-164	-5	192	-30	-32768	2028	0	44	-11990	830	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:09:39	22	342	248	220	343	432	252	780	-163	-13	192	-32	-32768	2028	0	42	-11990	829	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:10:39	22	342	249	221	342	432	253	783	-163	-3	192	-33	-32768	2028	0	40	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:11:39	22	342	249	221	342	431	253	785	-162	-8	192	-34	-32768	2028	0	38	-11990	831	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:12:39	22	342	250	222	341	431	254	787	-163	-8	192	-36	-32768	2028	0	37	-11990	829	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:13:39	22	342	251	222	341	431	255	788	-162	-5	192	-37	-32768	2028	0	35	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:14:39	22	342	251	222	340	431	255	790	-162	-12	192	-37	-32768	2028	0	34	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:15:39	22	342	251	223	339	431	255	792	-162	-3	192	-38	-32768	2028	0	32	-11990	830	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:16:39	22	342	252	223	339	431	256	792	-163	-9	192	-38	-32768	2028	0	31	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:17:39	22	342	252	223	338	431	256	794	-162	-8	192	-40	-32768	2028	0	30	-11990	831	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:18:39	22	342	252	223	337	430	256	796	-162	-5	192	-40	-32768	2028	0	29	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:19:39	22	342	253	223	337	430	257	796	-162	-12	192	-42	-32768	2028	0	28	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:20:39	22	342	253	223	336	430	257	797	-162	-3	192	-42	-32768	2028	0	27	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:21:39	21	342	254	224	335	430	258	797	-162	-6	192	-42	-32768	2028	0	26	-11990	830	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:22:39	21	342	254	224	335	430	258	798	-162	-7	193	-42	-32768	2028	0	25	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:23:46	21	342	254	224	334	430	258	799	-162	-7	193	-42	-32768	2028	0	24	-11990	830	16	196	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:24:43	21	343	254	224	333	429	258	799	-162	-5	192	-44	-32768	2028	0	23	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:25:43	21	343	255	224	333	429	259	799	-162	-7	193	-44	-32768	2028	0	22	-11990	829	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:26:43	21	343	255	224	332	429	259	800	-162	-5	193	-44	-32768	2028	0	22	-11990	830	16	195	3	30	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:27:43	20	343	257	304	331	429	341	811	-161	-50	193	-45	-32768	2028	0	70	-11990	830	16	196	15	20	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:28:43	19	343	314	339	331	429	375	833	-159	2	193	-44	-32768	2028	0	70	-11990	831	16	196	15	20	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:29:43	19	343	352	350	332	428	393	856	-147	5	193	-40	-32768	2028	0	59	-11990	831	16	195	15	20	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:30:43	19	343	372	347	333	428	401	870	-132	-1	194	-38	-32768	2028	0	45	-11990	839	16	195	15	20	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:31:43	19	342	384	350	336	428	419	887	-121	-10	193	-38	-32768	2028	0	35	-11990	859	16	195	15	20	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:32:43	19	342	399	353	341	428	437	904	-112	-8	193	-38	-32768	2028	0	28	-11990	880	16	195	15	20	0	0	0	0	23698	36433	3847122	797575	479842	72620
2022-11-24	09:33:43	19	342	415	357	345	427	457	923	-115	-13	193	-40	-32768	2028	0	25	-11990	899	16	196	15	20	0	0	0	0	23698	36433	3847122	797747	479842	72620
2022-11-24	09:34:43	18	342	430	362	350	427	467	942	-123	-12	193	-41	-32768	2028	0	24	-11990	920	16	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:35:43	18	342	442	368	355	429	472	960	-131	-17	193	-42	-32768	2028	0	25	-11990	929	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:36:43	18	342	450	373	359	431	475	977	-135	-13	193	-44	-32768	2028	0	26	-11990	932	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:37:43	18	342	454	379	364	432	474	991	-143	-12	193	-44	-32768	2028	0	27	-11990	930	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:38:46	18	342	456	385	370	434	478	1003	-149	-10	192	-45	-32768	2028	0	29	-11990	930	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:39:46	18	342	458	390	375	435	478	1015	-150	-9	192	-44	-32768	2028	0	31	-11990	930	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:40:46	16	342	460	395	381	435	478	1023	-150	-12	192	-43	-32768	2028	0	33	-11990	931	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:41:46	16	342	461	401	386	436	479	1032	-149	-4	192	-44	-32768	2028	0	36	-11990	930	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:42:46	16	342	462	408	391	436	479	1040	-148	-3	192	-44	-32768	2028	0	40	-11990	930	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:43:46	16	342	462	403	397	436	474	1045	-148	-3	192	-45	-32768	2028	0	43	-11990	930	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:44:46	16	342	458	401	401	435	472	1049	-148	-12	192	-46	-32768	2028	0	42	-11990	929	17	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:45:46	16	342	457	407	405	433	474	1052	-150	-1	192	-48	-32768	2028	0	43	-11990	930	16	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:46:46	16	342	459	414	408	432	478	1056	-148	-2	192	-48	-32768	2028	0	47	-11990	931	16	195	15	20	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:47:46	16	342	454	248	412	432	290	1046	-148	1	192	-49	-32768	2028	0	70	-11990	930	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:48:46	15	342	324	219	416	432	254	1008	-153	-15	192	-50	-32768	2028	0	70	-11990	928	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:49:46	14	342	275	219	418	432	251	977	-169	-10	192	-56	-32768	2028	0	67	-11990	930	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:50:46	14	342	259	218	420	431	250	953	-175	-24	192	-59	-32768	2028	0	63	-11990	890	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:51:46	14	343	253	219	420	430	250	933	-173	-6	192	-59	-32768	2028	0	58	-11990	860	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:52:46	14	343	251	219	420	430	250	911	-169	-3	192	-54	-32768	2028	0	54	-11990	829	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:53:50	14	343	250	220	420	429	252	895	-164	-3	192	-53	-32768	2028	0	51	-11990	828	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:54:50	14	343	251	221	420	428	252	879	-165	-8	192	-52	-32768	2028	0	48	-11990	830	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:55:50	14	343	251	221	420	428	253	867	-164	-3	192	-52	-32768	2028	0	45	-11990	830	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:56:50	14	343	252	222	420	428	254	855	-165	-10	192	-52	-32768	2028	0	42	-11990	831	16	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	09:57:50	13	343	247	222	419	428	227	827	-134	14	192	-39	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	09:58:50	13	343	238	224	419	427	231	759	-49	54	192	-10	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	09:59:50	13	343	236	225	418	427	238	709	-15	79	193	-3	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:00:50	13	343	235	225	418	427	248	674	-7	94	193	2	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:01:50	13	343	235	228	418	426	254	645	-3	107	193	8	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:02:50	13	343	234	233	418	426	257	606	19	135	193	21	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:03:50	14	343	234	238	418	426	258	574	55	153	193	46	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:04:50	14	343	234	243	418	426	258	559	78	155	194	59	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:05:50	14	343	234	248	417	426	257	553	93	153	194	66	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:06:50	14	343	234	251	417	426	256	547	103	153	194	70	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:07:50	14	343	233	254	417	426	255	543	110	152	194	72	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:08:53	14	343	233	255	417	426	254	538	114	152	194	73	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:09:53	14	343	233	257	417	426	253	534	119	153	194	75	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:10:53	16	343	233	258	417	426	253	530	123	153	194	76	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:11:53	16	343	233	259	417	426	252	525	126	155	194	78	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:12:53	16	343	233	260	416	426	251	522	130	156	194	80	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:13:53	16	343	233	260	416	426	251	519	134	159	194	83	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:14:53	16	343	232	261	416	426	251	516	138	164	195	85	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:15:53	17	343	233	261	416	426	250	513	141	167	195	87	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:16:53	18	343	233	261	416	426	250	509	144	169	195	90	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:17:53	18	343	233	260	416	426	250	507	147	173	195	92	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:18:53	18	343	233	261	415	426	250	504	149	175	195	95	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:19:53	19	343	233	260	414	426	251	501	153	178	194	99	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:20:53	19	343	233	260	413	426	251	499	156	181	195	103	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:21:53	19	343	233	260	413	426	251	497	158	182	195	106	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:22:53	19	343	232	260	413	426	252	494	158	184	194	108	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:23:57	21	343	232	260	413	426	253	492	159	185	194	109	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:24:57	21	343	233	259	413	426	253	489	160	186	194	111	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:25:57	21	343	232	259	413	426	254	485	160	186	194	112	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:26:57	21	343	232	259	412	426	255	483	161	187	194	113	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:27:57	21	343	232	258	412	426	256	481	162	187	194	115	-32768	2028	0	0	-11990	0	16	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:28:57	22	343	232	258	412	426	257	479	163	188	194	117	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:29:57	22	343	232	258	412	426	258	476	163	188	194	118	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:30:57	22	343	232	258	412	425	260	474	164	188	194	120	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:31:57	23	343	232	258	412	425	260	472	164	189	194	121	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:32:57	24	343	232	257	411	425	262	469	164	189	193	121	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:33:57	24	343	232	257	411	425	263	467	164	190	194	122	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:34:57	24	343	232	257	411	425	263	465	165	190	194	123	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:35:57	26	343	232	257	411	425	264	463	165	190	194	123	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:36:57	26	342	232	256	411	425	265	461	165	190	193	125	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:38:03	26	342	232	256	411	425	266	459	165	190	194	123	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:39:00	26	342	232	256	411	425	267	456	165	190	193	123	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:40:00	26	342	232	255	410	425	267	454	166	190	193	123	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:41:00	27	342	232	255	410	425	268	452	166	190	193	125	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:42:00	27	342	232	255	410	425	268	450	166	190	193	125	-32768	2028	0	0	-11990	0	17	195	6	30	0	0	0	183	23698	36434	3847260	797747	479842	72620
2022-11-24	10:43:00	27	343	232	246	410	425	261	448	166	190	193	125	-32768	-32768	0	70	-11990	0	17	195	3	30	0	0	0	0	23698	36434	3847260	797747	479842	72620
2022-11-24	10:44:00	28	343	232	213	410	425	238	576	89	98	193	94	-32768	-32768	0	70	-11990	561	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:45:00	29	343	237	213	410	425	247	564	-31	-55	193	39	-32768	-32768	0	70	-11990	801	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:46:00	29	343	241	213	409	425	240	564	-124	-67	192	9	-32768	-32768	0	65	-11990	840	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:47:00	29	343	238	213	409	425	242	595	-153	10	192	-3	-32768	-32768	0	60	-11990	850	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:48:00	29	343	238	213	409	425	242	627	-164	-7	192	-8	-32768	-32768	0	56	-11990	859	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:49:00	29	342	239	214	409	425	244	655	-167	-19	192	-19	-32768	2034	0	52	-11990	870	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:50:00	29	342	241	214	408	425	246	681	-171	-9	192	-25	-32768	2034	0	50	-11990	869	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:51:00	29	341	242	215	408	425	246	700	-171	-7	192	-28	-32768	2034	0	47	-11990	830	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:52:00	29	341	243	215	408	425	247	714	-168	-1	192	-28	-32768	2034	0	45	-11990	821	17	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:53:05	29	341	244	216	407	425	248	726	-163	-8	192	-30	-32768	2034	0	42	-11990	820	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:54:02	29	341	244	216	407	425	249	735	-164	-3	192	-32	-32768	2034	0	40	-11990	819	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:55:02	29	341	245	218	406	424	249	743	-164	-10	192	-33	-32768	2034	0	38	-11990	820	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:56:02	29	341	246	218	406	424	250	751	-163	-5	192	-34	-32768	2034	0	36	-11990	820	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:57:02	29	341	247	219	405	424	250	758	-163	-8	192	-36	-32768	2034	0	34	-11990	820	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:58:02	29	341	247	219	404	424	251	763	-162	-5	192	-37	-32768	2034	0	33	-11990	821	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	10:59:02	29	341	248	220	404	424	252	767	-163	-6	192	-38	-32768	2034	0	31	-11990	819	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:00:02	29	341	249	220	403	424	253	771	-162	-7	192	-40	-32768	2034	0	30	-11990	821	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:01:02	29	341	249	220	402	424	253	775	-163	-8	192	-41	-32768	2034	0	29	-11990	820	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:02:02	29	341	249	220	401	424	253	778	-162	-6	192	-42	-32768	2034	0	28	-11990	821	18	195	3	30	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:03:02	29	340	250	221	400	424	254	780	-162	-6	192	-44	-32768	2034	0	70	-11990	820	18	195	11	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:04:02	28	340	291	365	399	424	393	810	-160	-42	192	-44	-32768	2034	0	70	-11990	819	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:05:02	27	340	362	392	395	424	427	847	-148	33	192	-40	-32768	2034	0	68	-11990	821	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:06:02	27	340	400	402	393	424	447	877	-135	-5	192	-33	-32768	2034	0	51	-11990	829	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:07:02	27	340	422	406	394	424	461	902	-128	-3	192	-32	-32768	2034	0	47	-11990	850	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:08:07	27	340	438	412	397	426	470	926	-122	0	192	-34	-32768	2034	0	46	-11990	869	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:09:04	27	340	447	418	401	428	474	949	-120	-4	193	-36	-32768	2034	0	47	-11990	892	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:10:04	27	340	454	423	405	429	478	971	-115	-8	193	-38	-32768	2034	0	51	-11990	908	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:11:03	26	340	458	427	409	431	480	991	-120	-10	193	-40	-32768	2034	0	56	-11990	920	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:12:03	26	340	458	420	413	431	473	1008	-114	-3	193	-41	-32768	2034	0	55	-11990	919	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:13:03	26	340	457	425	417	431	475	1022	-108	-5	193	-41	-32768	2034	0	58	-11990	919	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:14:03	26	340	459	431	420	432	479	1035	-105	-8	193	-40	-32768	2034	0	62	-11990	921	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:15:03	26	340	462	437	423	434	481	1045	-107	-1	193	-40	-32768	2034	0	69	-11990	920	18	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:16:03	26	340	464	443	426	436	482	1056	-110	-1	193	-41	-32768	2034	0	78	-11990	920	19	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:17:03	24	340	466	448	429	437	484	1066	-115	2	193	-41	-32768	2034	0	88	-11990	921	19	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:18:03	24	340	468	454	432	439	485	1073	-121	2	192	-41	-32768	2034	0	100	-11990	920	19	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:19:03	24	340	470	459	434	441	490	1080	-129	2	192	-40	-32768	2034	0	100	-11990	920	19	195	15	20	0	0	0	0	23699	36434	3847260	797747	479842	72620
2022-11-24	11:20:03	24	340	473	462	437	444	493	1085	-134	4	192	-41	-32768	2034	0	100	-11990	921	19	195	15	20	0	0	0	0	23699	36435	3847407	797747	479842	72620
2022-11-24	11:21:03	24	340	477	465	440	448	497	1093	-134	9	192	-42	-32768	2034	0	100	-11990	920	19	195	15	20	0	0	0	0	23699	36435	3847407	797747	479842	72620
2022-11-24	11:22:03	24	340	480	469	443	450	500	1097	-132	13	192	-42	-32768	2034	0	100	-11990	920	19	195	15	20	0	0	0	0	23699	36435	3847407	797747	479842	72620
2022-11-24	11:23:10	23	340	484	472	445	452	502	1101	-128	21	192	-40	-32768	2034	0	100	-11990	850	19	195	11	30	0	0	0	0	23699	36435	3847407	797747	479842	72620
2022-11-24	11:24:07	22	340	396	221	448	455	250	1064	-121	49	192	-39	-32768	2034	0	100	-11990	850	19	195	3	30	0	0	0	0	23699	36435	3847407	797747	479842	72620
2022-11-24	11:25:07	22	340	295	220	451	456	247	1012	-142	-21	192	-44	-32768	2034	0	99	-11990	850	19	195	3	30	0	0	0	0	23699	36435	3847407	797747	479842	72620
2022-11-24	11:26:07	22	340	263	219	453	456	246	978	-156	-12	192	-48	-32768	2034	0	92	-11990	850	19	195	3	30	0	0	0	0	23699	36435	3847407	797747	479842	72620
2022-11-24	11:27:07	22	340	253	220	454	456	247	950	-161	-8	192	-50	-32768	2034	0	86	-11990	849	19	195	3	30	0	0	0	0	23699	36435	3847407	797747	479842	72620
