Divisors		10	10	10	10	10	10	10	10	10	10	10	10	10	10	100	1	10	10	10	10	1	1	10	10	10	1	1	1	100	100	10	10
Date	Time	Outdoor temp	Calc. Supply	Supply temp	Return temp	Hot water load	Hot water top	Condensor Out	Hot Gas Temp	Evaporator temp	Suction temp	Exhaust air temp	Vented air temp	BS1 Air flow	Air flow reference	Addition power[kW]	Supply CP speed	Degree minutes	Comp Freq. [Hz]	Outdoor average	Room temp	PCA Base relays	Prio	Current L1 [A]	Current L2 [A]	Current L3 [A]	Alarm number	Comp starts	Comp time [h]	Comp energy [kWh]	Comp en. HW [kWh]	Add.heating[kWh]	Add.hot water[kWh]
2021-01-24	08:49:02	-25	330	329	282	458	477	328	677	-83	49	224	-65	1758	-32768	0	0	-1947	391	-4	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:49:29	-25	330	327	281	458	477	329	677	-83	50	224	-65	1763	-32768	0	0	-1947	390	-4	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:49:59	-25	330	327	281	458	477	329	677	-83	53	224	-65	1770	-32768	0	0	-1950	390	-4	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:50:29	-24	330	327	281	458	477	329	677	-82	55	224	-63	1777	-32768	0	0	-1950	389	-4	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:50:59	-25	330	328	280	458	476	330	677	-81	56	224	-63	1783	-32768	0	0	-1952	390	-4	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:51:29	-24	330	328	281	458	477	330	678	-81	58	224	-63	1788	-32768	0	0	-1952	389	-4	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:51:59	-25	330	328	281	458	477	330	678	-81	59	224	-63	1794	-32768	0	0	-1954	390	-4	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:52:29	-24	330	328	281	458	477	330	678	-80	58	224	-61	1799	-32768	0	0	-1954	389	-4	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:52:59	-24	330	328	281	458	477	330	678	-79	56	224	-61	1804	-32768	0	0	-1956	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:53:29	-24	330	328	281	458	477	330	678	-79	56	224	-61	1808	-32768	0	0	-1956	389	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:53:59	-24	330	328	281	457	476	330	678	-79	55	224	-61	1811	1859	0	0	-1958	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:54:29	-24	331	328	281	458	476	330	677	-79	55	224	-61	1815	1859	0	0	-1958	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:54:59	-24	331	328	281	457	476	330	677	-79	55	224	-61	1818	1859	0	0	-1961	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:55:29	-24	331	328	281	458	476	330	677	-79	55	224	-61	1821	1859	0	0	-1961	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:55:59	-24	331	328	281	457	476	330	678	-79	53	224	-61	1823	1859	0	0	-1964	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:56:29	-24	331	329	281	457	476	330	677	-79	53	224	-61	1826	1859	0	0	-1964	391	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:56:59	-25	331	328	281	457	476	330	677	-80	53	224	-61	1828	1859	0	0	-1967	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:57:29	-25	331	328	281	457	476	330	677	-79	53	224	-61	1829	1859	0	0	-1967	391	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:57:59	-25	331	328	281	457	476	330	677	-79	53	224	-61	1831	1859	0	0	-1970	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:58:29	-25	331	329	281	457	476	330	677	-79	53	224	-61	1833	1859	0	0	-1970	389	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:58:59	-24	331	328	281	457	476	330	677	-79	53	224	-61	1835	1859	0	0	-1973	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:59:29	-25	331	328	281	457	476	330	677	-80	53	224	-61	1835	1859	0	0	-1973	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	08:59:59	-24	331	328	281	457	476	330	677	-80	53	224	-61	1836	1859	0	0	-1976	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	09:00:29	-25	331	328	281	457	476	330	677	-79	53	224	-61	1837	1859	0	0	-1976	390	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	09:00:59	-25	331	328	281	457	476	330	677	-80	53	224	-61	1838	1859	0	0	-1979	389	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	09:01:29	-24	331	328	281	457	476	330	677	-80	53	224	-62	1839	1859	0	0	-1979	389	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	09:01:59	-24	331	328	281	457	476	330	677	-79	53	224	-61	1840	1859	0	0	-1982	389	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	09:02:29	-25	331	328	281	457	476	330	677	-80	53	224	-61	1840	1859	0	0	-1982	389	-5	216	2	30	0	0	0	0	6711	10142	0	0	2940	813
2021-01-24	09:02:59	-24	331	328	281	457	476	292	666	-73	64	224	-58	1839	1859	0	0	-1985	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:03:29	-24	331	309	281	457	476	282	643	-53	83	224	-41	1839	1859	0	0	-1985	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:04:06	-25	331	291	281	457	476	282	622	-33	100	224	-23	1841	1859	0	0	-2010	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:04:36	-25	331	285	282	457	476	282	605	-19	116	225	-10	1844	1859	0	0	-2010	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:05:03	-25	331	283	281	457	476	282	592	-10	128	225	-5	1850	1859	0	0	-2057	0	-5	217	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:05:33	-25	331	282	281	457	476	281	581	-5	139	225	-3	1856	1859	0	0	-2057	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:06:03	-24	331	281	281	457	476	281	572	-3	149	225	-2	1862	1859	0	0	-2106	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:06:33	-24	331	281	280	457	476	280	563	-2	157	225	-1	1868	1859	0	0	-2106	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:07:03	-24	331	280	278	457	476	279	556	-1	164	225	-1	1874	1859	0	0	-2156	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:07:33	-24	331	279	278	457	475	278	548	-1	169	225	-1	1882	1859	0	0	-2156	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:08:03	-24	331	278	277	457	475	277	543	-1	175	225	-1	1890	1859	0	0	-2208	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:08:33	-24	331	277	277	457	475	277	536	-1	180	225	-1	1898	1859	0	0	-2208	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:09:03	-24	331	277	277	457	475	277	531	-1	184	225	-1	1906	1859	0	0	-2262	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:09:33	-25	331	276	276	457	475	276	526	-1	187	224	-1	1914	1859	0	0	-2262	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:10:03	-24	331	276	275	457	475	275	521	-1	190	224	-1	1919	1859	0	0	-2317	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:10:33	-24	331	275	275	457	475	275	517	2	193	224	1	1925	1859	0	0	-2317	0	-5	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:11:03	-24	331	275	274	457	475	274	511	12	195	224	1	1930	1859	0	0	-2373	0	-6	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:11:33	-24	331	274	273	457	474	273	507	27	196	224	4	1935	1859	0	0	-2373	0	-6	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:12:03	-24	331	274	273	457	474	273	502	46	198	224	8	1941	1859	0	0	-2430	0	-6	216	2	10	0	0	0	183	6711	10142	0	0	2940	813
2021-01-24	09:12:33	-24	331	273	272	457	474	272	498	65	199	224	19	1946	-32768	0	0	-2430	0	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:13:03	-23	331	274	271	457	474	301	593	68	86	224	23	1951	-32768	0	0	-2489	399	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:13:33	-23	331	292	270	457	474	300	611	34	90	224	10	1956	-32768	0	0	-2489	400	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:14:03	-23	331	296	269	457	474	297	614	4	55	223	1	1962	-32768	0	0	-2527	410	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:14:33	-23	331	296	270	457	474	297	616	-17	27	223	0	1969	-32768	0	0	-2527	409	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:15:03	-23	331	296	271	457	474	297	618	-39	77	223	-3	1974	-32768	0	0	-2562	420	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:15:33	-24	331	297	271	456	474	302	622	-50	113	223	-3	1980	-32768	0	0	-2562	420	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:16:03	-24	331	300	271	456	474	306	626	-50	118	223	-1	1985	-32768	0	0	-2596	430	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:16:33	-23	331	303	271	456	474	308	628	-50	53	223	-1	1989	-32768	0	0	-2596	429	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:17:03	-23	331	306	271	456	474	309	631	-55	42	223	-1	1994	-32768	0	0	-2623	440	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:17:33	-23	331	307	272	456	474	309	633	-64	72	223	-1	1999	2067	0	0	-2623	439	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:18:03	-24	331	308	272	457	474	313	637	-66	82	223	-2	2003	2067	0	0	-2647	451	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:18:33	-23	331	310	272	456	474	314	640	-67	46	223	-2	2006	2067	0	0	-2647	450	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:18:10	-24	331	312	272	456	474	314	642	-72	35	223	-1	2010	2067	0	0	-2667	459	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:18:40	-23	331	312	272	456	474	314	646	-79	69	223	-3	2013	2067	0	0	-2667	459	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:19:07	-24	331	313	273	456	474	317	650	-80	83	223	-3	2017	2067	0	0	-2686	470	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:19:37	-23	331	315	273	456	474	319	653	-77	56	223	-3	2020	2067	0	0	-2686	471	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:20:07	-24	331	316	273	456	474	318	655	-79	15	223	-5	2022	2067	0	0	-2702	479	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:20:37	-24	331	317	273	456	474	317	658	-88	58	223	-6	2024	2067	0	0	-2702	480	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:21:07	-23	331	316	274	456	474	320	662	-89	83	223	-8	2027	2067	0	0	-2717	491	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:21:37	-23	331	318	274	456	474	322	666	-85	71	223	-12	2029	2067	0	0	-2717	490	-6	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:22:07	-23	331	320	274	456	474	323	667	-84	0	223	-17	2030	2067	0	0	-2730	499	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:22:37	-24	331	321	275	456	474	319	670	-93	43	223	-25	2031	2067	0	0	-2730	500	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:23:07	-23	331	319	275	456	474	322	674	-96	77	223	-34	2033	2067	0	0	-2740	509	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:23:37	-23	331	320	275	456	474	326	678	-92	77	223	-40	2034	2067	0	0	-2740	511	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:24:07	-24	331	323	276	456	474	327	681	-89	0	223	-42	2036	2067	0	0	-2750	510	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:24:37	-23	331	324	276	456	474	323	682	-95	33	223	-47	2037	2067	0	0	-2750	510	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:25:07	-23	331	323	276	456	474	324	687	-100	70	223	-51	2038	2067	0	0	-2757	520	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:25:37	-23	331	323	277	456	474	327	692	-97	78	223	-51	2038	2067	0	0	-2757	520	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:26:07	-23	331	325	277	456	474	330	696	-92	2	223	-50	2039	2067	0	0	-2765	530	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:26:37	-23	331	327	277	456	474	326	697	-98	19	223	-52	2040	2067	0	0	-2765	529	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:27:07	-23	331	325	278	456	474	325	699	-104	63	223	-59	2042	2067	0	0	-2769	530	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:27:37	-24	331	324	278	456	474	328	704	-101	76	223	-58	2044	2067	0	0	-2769	530	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:28:07	-23	331	326	279	456	474	332	707	-96	10	223	-54	2043	2067	0	0	-2776	540	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:28:37	-22	331	328	279	456	474	328	707	-100	15	223	-57	2044	2067	0	0	-2776	539	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:29:07	-22	331	328	280	456	474	327	708	-107	59	223	-62	2044	2067	0	0	-2778	540	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:29:37	-23	331	326	280	456	474	331	712	-104	72	223	-61	2045	2067	0	0	-2778	540	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:30:07	-22	331	328	281	456	474	333	714	-99	6	223	-59	2045	2067	0	0	-2782	550	-6	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:30:37	-22	331	330	281	456	474	331	714	-103	14	223	-60	2046	2067	0	0	-2782	550	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:31:07	-22	331	329	281	456	474	330	717	-110	57	223	-65	2045	2067	0	0	-2783	549	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:31:37	-22	331	329	282	456	474	332	720	-107	69	223	-65	2045	2067	0	0	-2783	549	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:32:07	-22	331	330	282	456	474	336	722	-101	-2	223	-63	2044	2067	0	0	-2785	559	-7	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:32:37	-22	331	332	283	456	474	332	722	-107	17	223	-63	2043	2067	0	0	-2785	559	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:33:15	-22	331	330	283	456	474	332	725	-112	58	223	-68	2042	2067	0	0	-2784	558	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:33:42	-22	331	330	284	456	474	333	728	-109	66	223	-67	2042	2067	0	0	-2784	559	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:34:12	-22	331	331	284	456	474	336	728	-104	-7	222	-64	2042	2067	0	0	-2786	559	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:34:42	-21	331	333	285	455	474	332	729	-109	19	222	-66	2042	2067	0	0	-2786	559	-7	216	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:35:12	-22	331	331	285	456	474	333	732	-114	59	222	-70	2042	2067	0	0	-2784	570	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:35:42	-21	331	331	285	455	474	336	734	-110	65	222	-70	2042	2067	0	0	-2784	569	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:36:12	-22	331	333	286	455	474	339	735	-105	-12	222	-67	2042	2067	0	0	-2784	570	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:36:42	-21	331	336	286	455	474	334	735	-111	19	222	-70	2041	2067	0	0	-2784	570	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:37:12	-22	331	334	286	455	474	334	739	-116	57	222	-73	2040	2067	0	0	-2780	570	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:37:42	-21	331	333	286	456	474	338	740	-112	62	222	-72	2039	2067	0	0	-2780	570	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:38:12	-21	331	335	287	455	474	341	742	-106	-13	222	-68	2039	2067	0	0	-2778	580	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:38:42	-21	331	337	287	455	474	335	742	-113	20	222	-72	2038	2067	0	0	-2778	579	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:39:12	-21	331	335	288	455	474	336	743	-117	55	222	-76	2038	2067	0	0	-2772	580	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:39:42	-21	331	334	288	455	474	339	746	-113	57	222	-74	2038	2067	0	0	-2772	579	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:40:12	-21	331	336	289	455	474	340	746	-108	-16	222	-72	2036	2067	0	0	-2769	581	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:40:42	-20	331	337	289	455	474	336	746	-115	25	222	-74	2035	2067	0	0	-2769	580	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:41:12	-21	331	335	289	455	474	337	750	-118	57	222	-76	2034	2067	0	0	-2763	579	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:41:42	-21	331	336	289	455	474	340	751	-113	54	222	-74	2033	2067	0	0	-2763	580	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:42:12	-21	331	337	290	455	474	342	751	-109	-18	222	-72	2033	2067	0	0	-2758	590	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:42:42	-21	331	339	290	455	474	337	751	-116	24	222	-76	2033	2067	0	0	-2758	590	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:43:12	-20	331	337	290	455	474	338	755	-119	55	222	-79	2032	2067	0	0	-2751	590	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:43:42	-21	331	337	291	455	474	341	756	-114	51	222	-76	2031	2067	0	0	-2751	589	-7	215	2	30	0	0	0	0	6712	10142	0	0	2940	813
2021-01-24	09:44:12	-20	331	338	291	455	474	342	756	-111	-18	222	-74	2031	2067	0	0	-2745	590	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:44:41	-20	331	339	291	455	474	338	756	-118	26	222	-79	2031	2067	0	0	-2745	590	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:45:11	-21	331	337	292	455	474	340	759	-120	56	222	-81	2030	2067	0	0	-2737	590	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:45:41	-20	331	338	292	454	474	343	759	-115	46	222	-79	2029	2067	0	0	-2737	591	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:46:11	-20	331	340	292	454	474	343	759	-111	-19	222	-76	2027	2067	0	0	-2730	590	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:46:41	-21	331	340	293	454	474	339	759	-119	29	222	-80	2025	2067	0	0	-2730	589	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:47:11	-20	331	338	293	454	474	341	763	-120	56	223	-81	2025	2067	0	0	-2721	589	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:47:41	-21	331	339	293	454	474	344	763	-115	46	223	-79	2024	2067	0	0	-2721	590	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:48:19	-21	331	341	293	454	474	344	763	-112	-14	222	-76	2022	2067	0	0	-2713	589	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:48:46	-21	331	341	293	454	474	340	764	-119	31	222	-80	2021	2067	0	0	-2713	590	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:49:16	-20	331	339	293	454	474	342	765	-120	55	222	-81	2020	2067	0	0	-2703	589	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:49:46	-20	331	340	293	454	474	345	766	-115	41	223	-79	2019	2067	0	0	-2703	590	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:50:16	-20	331	342	293	454	474	345	766	-113	-16	222	-76	2017	2067	0	0	-2694	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:50:46	-20	331	342	293	454	474	341	766	-120	29	222	-81	2017	2067	0	0	-2694	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:51:16	-20	331	340	294	454	474	343	768	-121	53	223	-83	2016	2067	0	0	-2683	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:51:46	-20	331	341	294	454	474	346	769	-116	31	222	-81	2016	2067	0	0	-2683	599	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:52:16	-20	331	343	294	454	473	344	769	-115	-11	223	-80	2015	2067	0	0	-2673	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:52:46	-20	331	342	294	454	473	341	769	-122	34	223	-83	2014	2067	0	0	-2673	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:53:16	-20	331	340	295	454	473	343	771	-121	53	223	-83	2012	2067	0	0	-2662	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:53:46	-20	331	341	295	454	473	346	773	-116	22	223	-81	2012	2067	0	0	-2662	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:54:16	-19	331	343	295	454	473	344	771	-116	-3	222	-80	2011	2067	0	0	-2652	599	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:54:46	-20	331	342	295	454	473	342	773	-122	38	223	-83	2009	2067	0	0	-2652	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:55:16	-19	331	341	295	454	473	344	775	-121	51	223	-83	2009	2067	0	0	-2641	599	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:55:46	-20	331	342	295	454	473	347	775	-116	9	223	-81	2007	2067	0	0	-2641	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:56:16	-20	331	344	296	454	473	344	773	-117	-1	223	-81	2006	2067	0	0	-2630	601	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:56:46	-20	331	342	296	454	473	343	775	-123	40	223	-85	2005	2067	0	0	-2630	600	-7	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:57:16	-19	331	341	296	454	473	344	776	-121	52	223	-84	2005	2067	0	0	-2619	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:57:46	-19	331	342	296	454	473	347	776	-115	13	223	-81	2004	2067	0	0	-2619	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:58:16	-20	331	344	296	454	473	344	775	-117	1	223	-80	2003	2067	0	0	-2608	589	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:58:46	-20	331	342	296	454	473	343	776	-122	41	223	-83	2001	2067	0	0	-2608	589	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:59:16	-19	331	341	296	454	473	345	777	-119	52	223	-83	2000	2067	0	0	-2597	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	09:59:46	-19	331	342	297	454	473	347	776	-114	0	223	-79	1998	2067	0	0	-2597	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:00:16	-19	331	344	297	453	473	344	776	-117	0	223	-79	1997	2067	0	0	-2585	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:00:46	-19	331	343	297	453	473	343	776	-123	42	223	-83	1995	2067	0	0	-2585	589	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:01:16	-19	330	342	297	453	473	346	778	-120	53	223	-83	1993	2067	0	0	-2574	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:01:46	-19	330	343	297	453	473	348	778	-114	-9	223	-79	1993	2067	0	0	-2574	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:02:16	-18	330	345	297	453	473	344	778	-118	7	223	-81	1992	2067	0	0	-2561	589	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:02:46	-19	330	343	297	453	473	343	778	-123	45	223	-83	1992	2067	0	0	-2561	589	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:03:20	-18	330	342	297	453	473	346	780	-119	51	223	-82	1990	2067	0	0	-2548	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:03:50	-19	330	344	297	453	473	348	780	-114	-15	223	-79	1988	2067	0	0	-2548	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:04:20	-18	330	345	297	453	473	344	778	-118	7	223	-80	1987	2067	0	0	-2534	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:04:50	-19	330	343	298	453	473	344	780	-123	45	223	-83	1985	2067	0	0	-2534	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:05:20	-18	330	342	298	454	473	347	780	-119	50	223	-83	1983	2067	0	0	-2521	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:05:50	-18	330	344	298	453	473	348	780	-114	-23	223	-79	1981	2067	0	0	-2521	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:06:20	-18	330	345	298	453	473	344	780	-119	16	223	-81	1981	2067	0	0	-2507	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:06:50	-18	330	343	298	453	473	344	780	-122	48	223	-83	1980	2067	0	0	-2507	590	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:07:20	-18	330	343	298	453	473	347	781	-118	45	223	-81	1978	2067	0	0	-2494	580	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:07:50	-18	330	344	298	453	473	347	780	-114	-26	223	-79	1977	2067	0	0	-2494	579	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:08:20	-18	330	344	298	453	473	343	780	-121	20	223	-81	1974	2067	0	0	-2480	580	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:08:50	-18	330	342	298	453	473	345	780	-123	52	223	-83	1972	2067	0	0	-2480	580	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:09:20	-18	330	343	298	453	473	348	781	-117	47	223	-81	1970	2067	0	0	-2468	579	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:09:50	-18	330	345	298	453	473	349	780	-113	-21	223	-76	1969	2067	0	0	-2468	580	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:10:20	-17	330	346	298	453	473	344	780	-119	28	223	-79	1971	2067	0	0	-2453	579	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:10:50	-17	330	344	298	453	473	346	781	-120	56	223	-81	1973	2067	0	0	-2453	581	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:11:20	-18	330	344	298	453	473	349	781	-114	33	223	-76	1971	2067	0	0	-2440	580	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:11:50	-17	330	346	298	453	472	347	780	-113	-16	223	-74	1968	2067	0	0	-2440	579	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:12:20	-17	330	345	298	453	473	342	780	-120	34	223	-79	1966	2067	0	0	-2424	570	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:12:50	-18	330	342	299	453	473	345	780	-119	56	223	-80	1965	2067	0	0	-2424	570	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:13:20	-17	330	343	299	453	472	348	780	-113	27	223	-76	1965	2067	0	0	-2412	570	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:13:50	-17	330	345	299	453	473	347	779	-112	-10	223	-73	1963	2067	0	0	-2412	570	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:14:20	-17	330	345	299	453	473	344	779	-118	35	223	-76	1960	2067	0	0	-2397	570	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:14:50	-17	330	343	299	453	473	346	780	-118	55	223	-79	1957	2067	0	0	-2397	570	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:15:20	-17	330	344	299	453	472	349	780	-112	6	223	-75	1955	2067	0	0	-2384	570	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:15:50	-17	330	345	299	453	472	346	778	-114	-3	223	-74	1952	2067	0	0	-2384	570	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:16:20	-17	330	344	299	453	472	343	778	-120	40	223	-79	1950	2067	0	0	-2368	560	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:16:50	-16	330	342	298	453	472	345	778	-117	55	223	-77	1948	2067	0	0	-2368	559	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:17:20	-17	330	343	299	453	472	348	778	-111	-4	223	-74	1945	2067	0	0	-2356	559	-8	215	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:17:50	-17	330	345	299	453	472	344	776	-114	4	223	-72	1943	2067	0	0	-2356	560	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:18:27	-17	330	343	299	454	472	343	778	-119	43	223	-76	1940	2067	0	0	-2341	559	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:18:57	-16	330	342	299	453	472	346	778	-116	53	223	-76	1938	2067	0	0	-2341	560	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:19:25	-15	330	343	299	453	472	348	778	-110	-16	223	-72	1935	2067	0	0	-2329	560	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:19:55	-16	330	345	299	453	472	344	776	-114	9	223	-72	1933	2067	0	0	-2329	559	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:20:25	-15	330	343	299	453	472	342	776	-119	46	223	-76	1930	2067	0	0	-2314	550	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:20:55	-16	330	341	299	453	472	345	776	-115	53	223	-74	1928	2067	0	0	-2314	550	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:21:25	-15	330	343	299	453	472	347	776	-109	-18	223	-72	1926	2067	0	0	-2303	550	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:21:55	-15	330	344	299	452	472	343	775	-114	13	223	-72	1923	2067	0	0	-2303	550	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:22:25	-15	330	342	299	453	472	343	775	-118	49	223	-74	1921	2067	0	0	-2289	549	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:22:55	-15	330	342	299	452	472	346	776	-113	50	223	-74	1919	2067	0	0	-2289	550	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:23:25	-14	330	343	299	453	472	346	775	-109	-23	223	-70	1916	2067	0	0	-2277	540	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:23:55	-15	330	343	299	452	472	341	773	-115	20	223	-71	1913	2067	0	0	-2277	539	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:24:25	-15	330	341	299	453	472	343	773	-117	52	223	-74	1910	2067	0	0	-2264	540	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:24:55	-14	330	341	299	452	472	345	775	-112	49	223	-72	1907	2067	0	0	-2264	540	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:25:25	-14	330	342	298	452	472	322	765	-102	-10	223	-65	1904	2067	0	0	-2253	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:25:54	-14	330	330	298	452	472	299	738	-75	20	223	-40	1901	2067	0	0	-2253	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:26:24	-14	330	309	297	452	472	298	712	-45	46	223	-18	1900	2067	0	0	-2255	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:26:54	-14	330	301	297	452	472	297	690	-23	69	223	-6	1903	2067	0	0	-2255	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:27:24	-14	330	298	296	452	472	296	673	-12	87	223	-3	1909	2067	0	0	-2284	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:27:54	-13	330	297	295	452	472	296	661	-6	103	224	-1	1914	2067	0	0	-2284	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:28:24	-13	330	296	294	452	472	295	651	-3	117	223	-1	1918	2067	0	0	-2317	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:28:54	-13	330	295	293	452	472	294	641	-2	129	224	-1	1923	2067	0	0	-2317	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:29:24	-13	330	294	292	452	472	293	632	-1	139	224	-1	1928	2067	0	0	-2352	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:29:54	-13	330	292	291	452	472	292	622	-1	149	224	-1	1931	2067	0	0	-2352	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:30:24	-14	330	292	290	452	471	290	607	0	158	224	1	1934	2067	0	0	-2390	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:30:54	-13	330	291	289	452	471	289	594	11	167	224	4	1938	2067	0	0	-2390	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:31:24	-13	330	290	288	452	471	289	583	31	174	223	13	1941	2067	0	0	-2430	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:31:54	-14	330	288	288	452	471	288	574	51	181	223	22	1944	2067	0	0	-2430	0	-8	214	2	10	0	0	0	183	6712	10143	0	0	2940	813
2021-01-24	10:32:24	-13	330	288	287	452	471	287	566	68	185	223	31	1947	-32768	0	0	-2472	0	-8	214	2	30	0	0	0	0	6712	10143	0	0	2940	813
2021-01-24	10:33:02	-13	330	287	287	452	471	314	652	74	102	223	41	1950	-32768	0	0	-2472	540	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:33:32	-12	330	309	286	452	471	325	701	33	65	223	15	1955	-32768	0	0	-2515	550	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:33:59	-13	330	319	284	452	471	324	704	0	2	223	3	1960	-32768	0	0	-2515	550	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:34:29	-13	330	320	284	452	471	318	703	-38	62	223	-3	1966	-32768	0	0	-2525	560	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:34:59	-13	330	318	285	452	470	321	707	-56	98	223	-2	1971	-32768	0	0	-2525	560	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:35:29	-12	330	320	285	452	470	324	708	-62	14	223	-1	1976	-32768	0	0	-2537	560	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:35:59	-12	330	321	285	452	470	321	708	-75	5	222	-3	1980	-32768	0	0	-2537	562	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:36:29	-12	330	320	285	452	470	321	710	-90	53	222	-5	1985	-32768	0	0	-2546	569	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:36:59	-12	330	321	286	452	470	325	713	-94	62	222	-5	1989	-32768	0	0	-2546	571	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:37:29	-12	330	323	287	452	470	327	716	-94	-14	222	-6	1992	-32768	0	0	-2555	570	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:37:59	-12	330	324	287	452	470	324	716	-103	22	222	-10	1996	2047	0	0	-2555	570	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:38:29	-12	330	323	287	452	470	327	720	-109	57	222	-19	2000	2047	0	0	-2561	580	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:38:59	-11	330	325	287	452	470	330	723	-106	53	222	-36	2003	2047	0	0	-2561	580	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:39:29	-11	330	327	288	452	470	330	725	-105	-19	222	-48	2006	2047	0	0	-2566	579	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:39:59	-12	330	328	288	452	470	327	726	-114	32	222	-61	2009	2047	0	0	-2566	580	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:40:29	-11	330	327	288	452	470	330	731	-115	61	222	-66	2011	2047	0	0	-2568	590	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:40:59	-12	330	328	289	452	470	332	734	-110	42	222	-66	2014	2047	0	0	-2568	591	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:41:29	-11	330	329	289	452	470	332	734	-110	-21	222	-67	2015	2047	0	0	-2569	590	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:41:59	-11	330	329	289	452	470	329	737	-119	35	222	-74	2018	2047	0	0	-2569	589	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:42:29	-11	330	329	289	452	470	332	740	-119	62	222	-76	2020	2047	0	0	-2570	590	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:42:59	-12	330	330	290	451	470	335	743	-112	37	222	-74	2022	2047	0	0	-2570	590	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:43:29	-11	330	332	290	452	470	334	743	-112	-18	222	-73	2023	2047	0	0	-2570	600	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:43:59	-11	329	332	290	451	470	332	745	-120	34	222	-80	2024	2047	0	0	-2570	601	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:44:29	-11	329	331	291	451	470	335	748	-121	58	223	-81	2025	2047	0	0	-2567	599	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:44:59	-11	329	332	291	451	470	337	751	-115	22	222	-79	2027	2047	0	0	-2567	601	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:45:29	-10	329	334	291	451	470	335	751	-116	-16	222	-78	2027	2047	0	0	-2563	600	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:45:59	-11	329	333	291	452	470	333	753	-124	37	222	-83	2028	2047	0	0	-2563	601	-8	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:46:29	-11	329	332	292	451	470	336	756	-122	60	222	-83	2029	2047	0	0	-2559	600	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:46:59	-10	329	334	292	452	470	339	758	-115	9	222	-80	2029	2047	0	0	-2559	600	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:47:29	-10	329	336	292	451	470	337	758	-117	-8	222	-81	2028	2047	0	0	-2554	600	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:48:06	-10	329	335	293	451	470	335	759	-124	41	222	-86	2029	2047	0	0	-2554	599	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:48:36	-10	329	334	293	451	470	338	762	-122	57	222	-83	2028	2047	0	0	-2548	600	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:49:03	-11	329	336	293	451	470	340	763	-115	3	222	-81	2028	2047	0	0	-2548	600	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:49:33	-11	329	337	293	451	470	337	763	-118	-4	222	-81	2027	2047	0	0	-2541	600	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:50:03	-10	329	336	293	451	470	336	764	-124	45	222	-86	2027	2047	0	0	-2541	600	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:50:33	-10	329	335	293	451	470	339	766	-121	56	223	-85	2027	2047	0	0	-2534	599	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:51:03	-10	329	337	293	451	470	342	768	-115	-11	222	-81	2027	2047	0	0	-2534	600	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:51:33	-9	329	338	293	451	470	338	766	-119	7	222	-82	2026	2047	0	0	-2526	601	-9	214	2	30	0	0	0	0	6713	10143	0	0	2940	813
2021-01-24	10:52:03	-10	329	337	294	451	470	338	768	-123	45	222	-86	2026	2047	0	0	-2526	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:52:33	-10	329	337	294	451	470	341	769	-120	52	222	-84	2028	2047	0	0	-2518	601	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:53:03	-10	329	338	294	451	470	342	769	-114	-20	223	-81	2028	2047	0	0	-2518	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:53:33	-10	329	339	294	451	470	339	769	-120	15	222	-83	2027	2047	0	0	-2509	601	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:54:03	-10	329	337	295	451	470	339	771	-123	48	223	-86	2027	2047	0	0	-2509	599	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:54:33	-9	329	338	295	451	470	342	773	-119	47	222	-84	2027	2047	0	0	-2501	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:55:03	-9	329	339	295	451	470	343	773	-114	-23	222	-81	2026	2047	0	0	-2501	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:55:33	-10	329	340	295	451	470	339	773	-121	19	222	-84	2025	2047	0	0	-2490	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:56:03	-10	329	338	295	451	470	340	775	-123	50	223	-88	2024	2047	0	0	-2490	601	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:56:33	-9	329	339	296	451	470	343	775	-118	44	222	-83	2024	2047	0	0	-2481	599	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:57:03	-9	329	340	296	451	470	344	775	-115	-20	222	-81	2023	2047	0	0	-2481	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:57:33	-10	329	341	296	451	470	340	775	-122	24	222	-86	2023	2047	0	0	-2469	599	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:58:03	-9	328	339	296	451	470	341	776	-123	50	222	-88	2023	2047	0	0	-2469	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:58:33	-9	328	340	297	451	470	344	778	-118	39	223	-84	2022	2047	0	0	-2458	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:59:03	-9	328	341	297	451	470	344	776	-116	-19	222	-82	2022	2047	0	0	-2458	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	10:59:33	-9	328	341	297	451	470	340	776	-123	27	222	-86	2021	2047	0	0	-2445	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:00:03	-9	328	339	297	451	470	342	778	-123	52	223	-88	2020	2047	0	0	-2445	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:00:33	-9	328	340	297	451	470	345	779	-118	19	223	-84	2020	2047	0	0	-2434	600	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:01:03	-9	328	342	297	451	470	343	778	-118	-12	223	-83	2019	2047	0	0	-2434	599	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:01:33	-9	328	341	298	451	470	340	779	-125	36	223	-88	2018	2047	0	0	-2420	590	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:02:03	-9	328	339	298	451	470	343	780	-123	55	223	-88	2017	2047	0	0	-2420	589	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:02:33	-9	328	341	298	451	470	345	781	-116	24	223	-83	2017	2047	0	0	-2409	589	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:03:10	-8	328	342	298	451	470	343	780	-116	-11	223	-82	2016	2047	0	0	-2409	590	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:03:37	-8	328	341	298	451	470	341	780	-123	38	223	-86	2016	2047	0	0	-2395	590	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:04:07	-8	328	340	298	451	470	343	781	-121	55	223	-86	2015	2047	0	0	-2395	589	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:04:37	-8	328	341	299	451	470	346	781	-115	14	223	-83	2014	2047	0	0	-2383	590	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:05:07	-8	328	343	298	450	470	344	780	-116	-3	223	-81	2012	2047	0	0	-2383	589	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:05:37	-8	328	342	299	451	470	342	780	-122	39	223	-86	2012	2047	0	0	-2368	590	-9	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:06:07	-8	328	341	299	450	470	344	781	-119	51	223	-86	2011	2047	0	0	-2368	591	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:06:37	-8	328	342	299	451	470	346	781	-114	3	223	-82	2009	2047	0	0	-2355	580	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:07:07	-8	328	343	299	450	470	342	780	-116	3	223	-81	2008	2047	0	0	-2355	580	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:07:37	-8	328	341	299	450	470	342	780	-122	44	223	-86	2007	2047	0	0	-2340	580	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:08:07	-8	328	340	299	450	470	344	781	-118	53	223	-84	2006	2047	0	0	-2340	580	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:08:37	-8	328	342	299	450	470	346	781	-112	2	223	-81	2005	2047	0	0	-2328	580	-9	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:09:07	-8	328	343	299	450	470	343	780	-115	0	223	-80	2005	2047	0	0	-2328	580	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:09:37	-9	328	342	299	450	470	341	780	-121	43	223	-83	2004	2047	0	0	-2313	570	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:10:07	-8	328	340	299	450	470	344	781	-117	55	223	-83	2003	2047	0	0	-2313	570	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:10:37	-8	328	341	300	450	470	346	780	-111	10	223	-79	2002	2047	0	0	-2301	570	-9	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:11:07	-8	328	343	299	450	470	343	778	-113	2	223	-79	2000	2047	0	0	-2301	570	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:11:37	-8	327	341	300	450	470	342	778	-118	43	223	-82	2000	2047	0	0	-2286	569	-9	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:12:07	-8	327	340	300	450	470	344	780	-116	55	223	-81	1999	2047	0	0	-2286	569	-9	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:12:37	-8	327	342	300	450	470	346	779	-110	4	223	-79	1998	2047	0	0	-2273	569	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:13:07	-8	327	343	300	450	470	343	778	-113	2	223	-78	1997	2047	0	0	-2273	570	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:13:37	-8	326	341	300	450	470	341	778	-119	45	223	-82	1995	2047	0	0	-2257	561	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:14:07	-8	326	340	300	450	470	344	778	-115	57	223	-81	1994	2047	0	0	-2257	558	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:14:37	-8	326	341	300	450	470	345	778	-109	19	223	-76	1993	2047	0	0	-2243	559	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:15:07	-8	326	343	300	450	470	343	776	-110	-3	223	-75	1992	2047	0	0	-2243	560	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:15:37	-8	326	341	300	450	470	341	776	-116	41	223	-81	1991	2047	0	0	-2226	560	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:16:07	-8	326	340	300	450	470	344	778	-114	56	223	-81	1990	2047	0	0	-2226	559	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:16:37	-8	326	341	300	450	470	344	776	-108	26	223	-76	1989	2047	0	0	-2212	549	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:17:07	-8	326	342	300	450	470	343	775	-108	-4	223	-74	1988	2047	0	0	-2212	550	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:17:37	-8	326	341	300	450	470	341	775	-115	40	223	-79	1987	2047	0	0	-2196	550	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:18:15	-7	326	340	300	450	470	343	775	-113	59	223	-78	1985	2047	0	0	-2196	549	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:18:42	-8	326	341	300	450	470	345	775	-107	33	223	-74	1984	2047	0	0	-2182	539	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:19:12	-7	326	342	300	450	469	343	773	-106	-3	223	-72	1983	2047	0	0	-2182	540	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:19:42	-7	326	341	300	450	470	340	773	-112	40	223	-75	1982	2047	0	0	-2166	539	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:20:12	-8	326	340	300	450	469	343	773	-111	59	223	-75	1982	2047	0	0	-2166	539	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:20:42	-7	326	341	300	450	469	345	773	-105	39	223	-72	1982	2047	0	0	-2152	540	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:21:12	-7	326	342	299	450	469	344	771	-103	-5	223	-70	1981	2047	0	0	-2152	539	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:21:42	-7	326	341	300	450	469	340	769	-110	38	223	-73	1981	2047	0	0	-2136	530	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:22:12	-6	326	339	299	450	469	342	771	-110	61	223	-74	1980	2047	0	0	-2136	529	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:22:42	-6	326	340	300	450	469	343	769	-104	51	223	-70	1979	2047	0	0	-2123	531	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:23:12	-6	326	341	300	450	470	343	768	-101	-9	223	-67	1977	2047	0	0	-2123	529	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:23:42	-7	326	341	300	450	470	339	768	-107	33	223	-69	1976	2047	0	0	-2108	520	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:24:12	-6	326	339	300	450	469	342	768	-108	61	223	-72	1976	2047	0	0	-2108	520	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:24:42	-6	326	339	299	450	469	343	768	-103	57	223	-70	1975	2047	0	0	-2095	520	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:25:12	-6	326	341	299	449	469	344	766	-98	-8	223	-65	1975	2047	0	0	-2095	519	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:25:42	-6	326	341	299	450	469	340	764	-104	29	223	-67	1974	2047	0	0	-2080	519	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:26:12	-6	326	339	299	449	469	340	764	-107	60	223	-70	1974	2047	0	0	-2080	520	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:26:42	-6	326	339	299	450	469	342	764	-102	62	223	-67	1973	2047	0	0	-2067	510	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:27:12	-6	326	340	299	450	469	343	764	-96	-5	223	-63	1973	2047	0	0	-2067	509	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:27:42	-6	326	341	299	450	469	339	763	-101	26	223	-63	1972	2047	0	0	-2053	509	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:28:12	-5	326	338	299	449	469	340	763	-105	60	223	-67	1971	2047	0	0	-2053	510	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:28:42	-5	326	338	299	449	469	342	763	-101	65	223	-65	1971	2047	0	0	-2041	499	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:29:12	-5	326	339	299	449	469	343	761	-94	4	223	-61	1971	2047	0	0	-2041	499	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:29:42	-5	326	341	299	449	469	339	759	-98	22	223	-61	1971	2047	0	0	-2027	500	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:30:12	-5	326	339	299	449	469	339	759	-103	58	223	-65	1970	2047	0	0	-2027	500	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:30:42	-4	325	338	299	449	469	341	759	-100	68	223	-63	1969	2047	0	0	-2014	500	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:31:12	-5	325	339	298	449	469	343	759	-94	23	223	-59	1969	2047	0	0	-2014	500	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:31:42	-4	325	340	298	449	469	340	756	-95	9	223	-59	1968	2047	0	0	-2000	490	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:32:12	-5	325	338	298	449	469	337	756	-102	51	223	-63	1966	2047	0	0	-2000	490	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:32:42	-4	325	337	298	449	469	340	756	-100	71	223	-63	1964	2047	0	0	-1987	491	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:33:16	-4	325	338	298	449	469	342	756	-94	52	223	-59	1963	2047	0	0	-1987	490	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:33:46	-4	325	339	298	449	469	341	755	-92	-1	223	-54	1961	2047	0	0	-1974	480	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:34:16	-5	325	339	298	449	469	337	753	-99	43	223	-58	1960	2047	0	0	-1974	479	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:34:46	-5	325	336	298	449	469	339	754	-100	70	223	-61	1959	2047	0	0	-1960	480	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:35:16	-4	325	337	297	449	469	341	755	-94	65	223	-57	1958	2047	0	0	-1960	479	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:35:46	-4	325	339	297	449	469	341	753	-89	0	223	-52	1956	2047	0	0	-1948	470	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:36:16	-4	325	339	297	449	469	337	751	-94	31	223	-52	1956	2047	0	0	-1948	468	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:36:46	-4	325	336	297	449	469	338	751	-97	66	223	-55	1958	2047	0	0	-1934	470	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:37:16	-4	325	336	297	449	469	340	751	-93	76	223	-53	1959	2047	0	0	-1934	469	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:37:46	-5	325	338	297	449	469	341	750	-87	16	223	-49	1958	2047	0	0	-1923	459	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:38:16	-4	325	338	297	449	469	338	748	-89	22	223	-48	1956	2047	0	0	-1923	460	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:38:46	-4	325	337	297	449	469	337	748	-95	62	223	-50	1956	2047	0	0	-1910	460	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:39:16	-4	325	336	296	449	469	339	748	-92	78	223	-50	1956	2047	0	0	-1910	460	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:39:46	-4	325	337	296	449	469	340	748	-86	27	223	-46	1955	2047	0	0	-1899	460	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:40:16	-4	325	338	296	449	469	338	746	-87	11	223	-43	1956	2047	0	0	-1899	460	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:40:46	-3	325	337	296	449	468	335	745	-94	57	223	-46	1956	2047	0	0	-1886	450	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:41:16	-4	325	334	296	449	469	338	745	-92	80	223	-44	1956	2047	0	0	-1886	450	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:41:46	-3	325	335	296	449	469	340	745	-85	46	224	-40	1957	2047	0	0	-1877	450	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:42:16	-4	325	337	296	449	469	339	743	-84	11	224	-36	1958	2047	0	0	-1877	449	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:42:46	-3	325	337	295	449	469	335	742	-90	55	224	-36	1959	2047	0	0	-1865	440	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:43:16	-3	325	334	295	449	468	337	742	-89	79	223	-35	1960	2047	0	0	-1865	440	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:43:46	-4	325	335	295	449	468	338	741	-83	58	224	-30	1961	2047	0	0	-1856	440	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:44:16	-4	325	336	295	449	469	337	739	-81	6	224	-26	1961	2047	0	0	-1856	440	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:44:46	-3	325	335	295	449	468	334	738	-88	50	224	-28	1962	2047	0	0	-1845	441	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:45:16	-4	325	333	295	449	468	336	739	-88	79	224	-28	1963	2047	0	0	-1845	440	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:45:46	-4	325	334	295	449	469	338	737	-82	72	224	-25	1964	2047	0	0	-1837	430	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:46:16	-3	325	335	294	449	468	338	735	-78	-3	224	-21	1966	2047	0	0	-1837	430	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:46:46	-4	325	335	294	448	468	333	734	-85	43	224	-24	1967	2047	0	0	-1827	429	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:47:16	-3	325	333	294	448	468	335	734	-87	79	224	-25	1968	2047	0	0	-1827	430	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:47:46	-3	325	333	294	449	468	337	734	-81	83	224	-23	1970	2047	0	0	-1819	420	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:48:24	-3	325	334	294	449	468	338	732	-75	5	224	-19	1971	2047	0	0	-1819	420	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:48:54	-4	325	335	294	448	468	334	729	-80	32	224	-19	1972	2047	0	0	-1810	420	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:49:21	-3	325	333	294	448	468	333	729	-85	74	225	-21	1972	2047	0	0	-1810	419	-8	214	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:49:51	-4	325	332	293	449	468	336	729	-80	90	224	-19	1973	2047	0	0	-1802	419	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:50:21	-3	325	333	294	448	468	337	729	-73	32	224	-15	1974	2047	0	0	-1802	421	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:50:51	-3	325	335	293	449	468	335	726	-74	14	224	-15	1975	2047	0	0	-1794	410	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:51:21	-3	325	333	293	448	468	332	726	-81	64	224	-18	1976	2047	0	0	-1794	410	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:51:51	-3	325	331	293	448	468	334	726	-80	91	224	-17	1977	2047	0	0	-1786	410	-8	213	2	30	0	0	0	0	6713	10144	0	0	2940	813
2021-01-24	11:52:21	-4	325	332	293	448	468	336	725	-72	80	224	-15	1978	2047	0	0	-1786	410	-8	213	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:52:51	-3	325	334	293	448	468	337	723	-69	0	224	-13	1979	2047	0	0	-1779	410	-8	213	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:53:21	-3	325	334	293	448	468	332	722	-77	51	224	-17	1979	2047	0	0	-1779	410	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:53:51	-3	325	332	293	448	468	333	722	-79	88	224	-17	1980	2047	0	0	-1770	400	-8	213	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:54:21	-3	325	331	293	448	468	335	722	-73	95	224	-15	1981	2047	0	0	-1770	401	-8	213	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:54:51	-3	325	333	293	448	468	337	720	-66	9	224	-13	1981	2047	0	0	-1764	399	-8	213	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:55:21	-3	325	334	292	448	468	332	719	-71	31	224	-14	1982	2047	0	0	-1764	400	-8	213	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:55:51	-3	325	332	293	448	468	331	718	-77	78	224	-17	1982	2047	0	0	-1755	390	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:56:21	-3	325	330	292	448	468	333	719	-73	100	225	-15	1984	2047	0	0	-1755	389	-8	213	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:56:51	-4	325	331	292	448	468	335	717	-65	74	225	-13	1985	2047	0	0	-1750	390	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:57:21	-3	325	332	292	448	468	335	716	-63	12	225	-13	1987	2047	0	0	-1750	390	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:57:50	-3	325	332	292	449	468	331	714	-71	61	225	-15	1988	2047	0	0	-1743	390	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:58:20	-3	325	330	292	448	468	332	714	-72	95	225	-15	1989	2047	0	0	-1743	391	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:58:50	-3	325	330	292	448	468	334	714	-66	99	225	-13	1989	2047	0	0	-1738	390	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:59:20	-3	325	331	291	448	468	335	713	-60	15	225	-12	1990	2047	0	0	-1738	390	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	11:59:50	-3	325	332	291	448	468	331	711	-66	42	225	-13	1991	2047	0	0	-1732	379	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:00:20	-3	325	330	291	448	468	330	710	-71	85	225	-15	1992	2047	0	0	-1732	379	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:00:50	-3	325	329	291	448	468	333	710	-68	104	225	-13	1993	2047	0	0	-1727	379	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:01:20	-4	325	330	291	448	468	334	710	-60	61	225	-12	1993	2047	0	0	-1727	380	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:01:50	-4	324	332	291	448	467	333	708	-60	21	224	-12	1994	2047	0	0	-1722	380	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:02:20	-3	324	331	291	448	467	330	707	-68	69	225	-15	1994	2047	0	0	-1722	380	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:02:50	-3	324	329	290	448	468	331	707	-69	99	225	-15	1996	2047	0	0	-1715	370	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:03:28	-3	324	329	290	448	468	332	707	-63	102	225	-13	1996	2047	0	0	-1715	370	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:03:55	-3	324	330	290	448	467	333	705	-57	23	224	-12	1996	2047	0	0	-1710	369	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:04:25	-3	324	330	290	448	467	330	704	-62	47	224	-13	1996	2047	0	0	-1710	370	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:04:55	-4	324	329	290	448	467	330	704	-67	87	224	-15	1997	2047	0	0	-1704	370	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:05:25	-3	324	329	290	448	467	332	704	-64	104	224	-13	1997	2047	0	0	-1704	370	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:05:55	-3	324	329	290	448	467	332	702	-58	70	224	-12	1997	2047	0	0	-1699	360	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:06:25	-3	324	330	289	448	467	332	701	-57	21	224	-12	1997	2047	0	0	-1699	360	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:06:55	-4	324	330	289	448	467	328	699	-64	67	224	-13	1998	2047	0	0	-1693	359	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:07:25	-3	324	328	289	448	467	330	699	-66	100	225	-14	1998	2047	0	0	-1693	360	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:07:55	-3	324	328	289	448	467	332	699	-61	107	224	-12	1997	2047	0	0	-1689	360	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:08:25	-3	324	329	289	448	467	332	699	-55	40	224	-11	1997	2047	0	0	-1689	360	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:08:55	-3	324	329	289	448	467	329	696	-57	41	224	-12	1997	2047	0	0	-1684	350	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:09:25	-3	324	329	288	448	467	327	696	-62	82	224	-13	1997	2047	0	0	-1684	350	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:09:55	-3	324	327	288	448	467	329	696	-62	106	224	-13	1996	2047	0	0	-1680	350	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:10:25	-3	324	327	288	448	467	331	696	-56	103	225	-12	1996	2047	0	0	-1680	350	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:10:55	-3	324	329	288	447	467	332	695	-52	28	224	-10	1995	2047	0	0	-1676	350	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:11:25	-3	324	329	288	448	467	329	694	-57	55	224	-11	1995	2047	0	0	-1676	350	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:11:55	-3	324	328	288	447	467	327	692	-62	93	224	-13	1994	2047	0	0	-1671	339	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:12:25	-2	324	326	288	447	467	329	692	-58	111	224	-12	1994	2047	0	0	-1671	338	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:12:55	-3	324	327	288	446	467	330	692	-52	98	224	-10	1994	2047	0	0	-1669	339	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:13:25	-3	324	328	287	446	467	330	691	-49	29	224	-8	1995	2047	0	0	-1669	340	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:13:55	-3	324	328	287	445	467	327	689	-55	65	224	-10	1995	2047	0	0	-1665	339	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:14:25	-3	324	327	287	445	467	327	689	-58	98	224	-11	1994	2047	0	0	-1665	340	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:14:55	-3	324	326	287	445	467	329	689	-55	112	224	-11	1994	2047	0	0	-1663	340	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:15:25	-3	324	326	287	445	467	330	688	-49	83	224	-9	1994	2047	0	0	-1663	340	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:15:55	-3	324	327	287	445	467	329	688	-48	36	224	-8	1994	2047	0	0	-1661	330	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:16:25	-2	324	327	287	444	467	326	687	-53	71	224	-10	1993	2047	0	0	-1661	330	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:16:55	-3	324	325	287	444	467	326	687	-56	102	224	-11	1994	2047	0	0	-1658	330	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:17:25	-3	324	325	286	444	467	328	687	-52	115	224	-10	1994	2047	0	0	-1658	331	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:18:02	-3	324	326	286	444	467	329	685	-47	101	224	-8	1994	2047	0	0	-1657	329	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:18:32	-2	324	327	286	444	467	329	684	-45	40	224	-8	1993	2047	0	0	-1657	330	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:18:59	-3	324	327	286	444	467	327	682	-49	61	224	-8	1993	2047	0	0	-1654	330	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:19:29	-2	324	326	286	444	467	326	682	-54	96	224	-11	1992	2047	0	0	-1654	329	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:19:59	-3	324	325	286	444	467	326	682	-52	114	224	-10	1992	2047	0	0	-1652	320	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:20:29	-3	324	325	286	444	466	327	682	-47	111	224	-10	1992	2047	0	0	-1652	320	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:20:59	-3	324	325	286	444	466	327	681	-43	86	224	-8	1992	2047	0	0	-1651	319	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:21:29	-2	324	325	285	444	466	327	680	-43	51	224	-7	1992	2047	0	0	-1651	319	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:21:59	-2	324	326	285	444	467	325	678	-47	81	224	-7	1992	2047	0	0	-1649	320	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:22:29	-2	324	324	285	444	467	326	678	-49	105	224	-10	1993	2047	0	0	-1649	320	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:22:59	-2	324	324	285	444	466	326	677	-46	112	224	-8	1993	2047	0	0	-1649	320	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:23:29	-2	324	324	285	444	466	326	677	-43	104	224	-8	1994	2047	0	0	-1649	320	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:23:59	-1	324	325	285	444	466	327	675	-41	79	224	-6	1994	2047	0	0	-1649	321	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:24:29	-1	324	325	285	444	466	326	674	-42	64	224	-7	1994	2047	0	0	-1649	320	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:24:59	-2	324	325	285	444	466	324	673	-45	86	224	-8	1994	2047	0	0	-1648	310	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:25:29	-1	324	324	285	444	466	324	671	-46	104	224	-8	1994	2047	0	0	-1648	309	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:25:59	-2	324	323	285	444	466	325	671	-44	109	224	-8	1994	2047	0	0	-1648	309	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:26:29	-1	324	323	284	444	466	325	670	-42	104	224	-6	1994	2047	0	0	-1648	311	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:26:59	-1	323	323	285	444	466	325	669	-40	90	224	-6	1994	2047	0	0	-1649	310	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:27:29	-1	323	323	284	443	466	325	667	-40	80	223	-6	1993	2047	0	0	-1649	310	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:27:59	-2	323	323	284	443	466	325	666	-41	83	223	-6	1993	2047	0	0	-1649	310	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:28:29	-1	323	323	284	443	466	325	664	-41	92	223	-6	1994	2047	0	0	-1649	310	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:28:59	-1	323	323	284	443	466	324	664	-42	99	224	-7	1994	2047	0	0	-1649	309	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:29:29	-1	323	323	284	443	466	324	663	-41	102	224	-8	1994	2047	0	0	-1649	310	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:29:59	-1	323	323	284	443	466	325	663	-41	99	224	-6	1993	2047	0	0	-1649	310	-8	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:30:29	-1	323	323	284	443	466	324	662	-40	94	223	-6	1993	2047	0	0	-1649	310	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:30:59	-1	323	322	284	443	466	323	660	-40	90	223	-6	1993	2047	0	0	-1649	301	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:31:29	-1	323	322	284	443	466	324	659	-40	90	224	-6	1993	2047	0	0	-1649	299	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:31:59	-1	323	322	284	444	466	324	658	-40	92	224	-7	1994	2047	0	0	-1650	300	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:32:29	-1	323	322	284	443	466	324	656	-40	97	223	-6	1994	2047	0	0	-1650	300	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:32:07	-1	323	322	284	443	466	323	656	-40	100	224	-6	1994	2047	0	0	-1651	300	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:32:34	-1	323	322	283	443	466	324	655	-40	102	224	-6	1994	2047	0	0	-1651	299	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:33:04	-1	323	322	283	443	466	324	655	-39	100	223	-6	1995	2047	0	0	-1652	299	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:33:34	-1	323	322	283	443	466	324	654	-39	98	223	-6	1995	2047	0	0	-1652	300	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:34:04	-1	323	322	283	443	466	324	654	-38	96	224	-5	1995	2047	0	0	-1653	300	-8	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:34:34	0	323	322	283	443	466	324	653	-38	95	223	-6	1996	2047	0	0	-1653	299	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:35:04	0	323	322	283	443	466	323	651	-38	95	223	-6	1996	2047	0	0	-1654	299	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:35:34	-1	323	322	283	443	466	323	651	-39	96	223	-6	1996	2047	0	0	-1654	300	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:36:04	-1	323	322	283	443	466	323	650	-38	96	223	-6	1997	2047	0	0	-1655	300	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:36:34	0	323	322	283	443	466	323	650	-38	98	223	-6	1997	2047	0	0	-1655	300	-7	215	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:37:04	-1	323	322	282	443	466	323	649	-39	98	223	-6	1997	2047	0	0	-1656	300	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:37:34	0	323	322	283	443	466	323	649	-38	98	223	-6	1997	2047	0	0	-1656	300	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:38:04	-1	323	321	283	442	466	322	647	-38	99	223	-6	1997	2047	0	0	-1658	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:38:34	-1	323	321	283	443	466	321	646	-38	100	223	-6	1997	2047	0	0	-1658	289	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:39:04	-1	323	320	282	442	466	322	646	-38	102	223	-6	1997	2047	0	0	-1660	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:39:34	-1	323	320	282	443	466	321	645	-37	102	223	-6	1998	2047	0	0	-1660	291	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:40:04	-1	323	320	282	442	466	322	645	-37	102	223	-6	1998	2047	0	0	-1663	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:40:34	0	323	320	282	442	466	322	645	-36	102	223	-6	1998	2047	0	0	-1663	289	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:41:04	-1	323	321	282	442	466	322	643	-36	102	223	-6	1998	2047	0	0	-1666	291	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:41:34	-1	323	321	282	442	466	322	643	-36	102	223	-6	1997	2047	0	0	-1666	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:42:04	0	323	320	281	442	466	322	642	-36	102	223	-6	1997	2047	0	0	-1668	289	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:42:34	0	323	320	281	442	466	322	642	-36	102	223	-6	1997	2047	0	0	-1668	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:43:04	0	323	320	281	442	465	322	642	-36	102	223	-6	1997	2047	0	0	-1671	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:43:34	-1	323	320	281	442	466	322	641	-36	102	223	-7	1997	2047	0	0	-1671	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:44:04	0	323	320	281	442	465	321	641	-36	100	223	-6	1997	2047	0	0	-1674	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:44:34	0	323	320	281	442	466	321	641	-36	102	223	-7	1997	2047	0	0	-1674	289	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:45:04	0	323	320	281	442	465	321	640	-36	102	224	-6	1998	2047	0	0	-1677	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:45:34	-1	323	320	281	442	465	321	640	-36	103	223	-7	1998	2047	0	0	-1677	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:46:04	0	323	320	281	442	465	321	640	-36	102	223	-7	1998	2047	0	0	-1680	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:46:34	0	323	320	281	442	465	321	640	-36	103	223	-7	1998	2047	0	0	-1680	289	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:47:12	0	323	320	281	442	465	321	638	-36	103	223	-8	1998	2047	0	0	-1683	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:47:39	-1	323	319	281	442	466	321	638	-36	102	223	-8	1998	2047	0	0	-1683	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:48:09	0	323	319	280	442	465	321	638	-36	102	223	-8	1998	2047	0	0	-1686	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:48:39	0	323	319	280	442	465	321	638	-36	102	223	-8	1997	2047	0	0	-1686	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:49:09	0	323	319	280	442	465	321	637	-36	102	223	-8	1997	2047	0	0	-1690	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:49:39	0	322	319	280	442	465	321	637	-36	102	223	-8	1996	2047	0	0	-1690	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:50:09	0	322	319	280	442	465	321	637	-36	102	223	-8	1995	2047	0	0	-1693	290	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:50:39	0	322	319	280	442	465	320	637	-36	102	223	-8	1994	2047	0	0	-1693	289	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:51:09	0	322	319	280	441	465	320	637	-36	101	223	-7	1993	2047	0	0	-1696	289	-7	214	2	30	0	0	0	0	6713	10145	0	0	2940	813
2021-01-24	12:51:39	0	322	319	280	441	465	320	636	-36	102	223	-8	1993	2047	0	0	-1696	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:52:09	0	322	319	280	442	465	320	636	-36	102	223	-8	1993	2047	0	0	-1699	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:52:39	0	322	319	280	441	465	320	636	-36	101	223	-8	1992	2047	0	0	-1699	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:53:09	0	322	319	280	441	465	320	636	-36	100	223	-8	1992	2047	0	0	-1702	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:53:39	0	322	319	280	441	465	320	636	-36	100	224	-8	1991	2047	0	0	-1702	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:54:09	0	322	318	280	441	465	319	634	-36	102	223	-8	1990	2047	0	0	-1705	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:54:39	0	322	318	279	441	465	318	634	-36	103	224	-8	1991	2047	0	0	-1705	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:55:09	1	322	317	279	441	465	319	633	-35	105	223	-7	1991	2047	0	0	-1709	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:55:39	0	322	317	280	441	465	318	633	-35	106	223	-7	1991	2047	0	0	-1709	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:56:09	1	322	317	280	441	465	318	633	-34	106	224	-8	1990	2047	0	0	-1714	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:56:39	1	322	317	279	441	465	318	633	-34	106	223	-8	1989	2047	0	0	-1714	279	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:57:09	0	322	317	279	441	464	318	633	-34	106	223	-6	1988	2047	0	0	-1719	279	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:57:39	0	322	317	280	441	465	318	632	-34	104	223	-6	1988	2047	0	0	-1719	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:58:09	1	322	317	279	441	465	318	632	-34	103	223	-7	1988	2047	0	0	-1724	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:58:39	0	322	317	279	441	464	318	632	-34	103	223	-6	1988	2047	0	0	-1724	281	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:59:09	0	322	317	279	441	464	318	632	-34	104	223	-6	1987	2047	0	0	-1729	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	12:59:39	0	322	317	279	441	464	318	631	-34	104	223	-6	1986	2047	0	0	-1729	280	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:00:09	1	322	317	279	441	464	319	631	-34	103	223	-5	1985	2047	0	0	-1734	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:00:39	0	322	317	279	441	464	319	631	-34	102	223	-6	1985	2047	0	0	-1734	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:01:09	1	322	318	279	441	464	319	631	-35	100	223	-6	1985	2047	0	0	-1739	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:01:39	0	322	318	279	441	465	319	631	-35	100	224	-7	1984	2047	0	0	-1739	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:02:14	0	322	318	279	441	464	319	631	-35	100	223	-8	1983	2047	0	0	-1743	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:02:44	1	322	318	279	441	464	319	631	-35	100	223	-7	1983	2047	0	0	-1743	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:03:13	0	322	318	279	440	464	319	631	-36	100	224	-8	1983	2047	0	0	-1747	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:03:43	0	322	318	279	440	464	319	631	-36	100	224	-8	1982	2047	0	0	-1747	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:04:13	1	322	318	279	441	464	319	631	-36	100	224	-8	1982	2047	0	0	-1751	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:04:43	1	322	317	279	440	464	319	631	-36	101	223	-8	1982	2047	0	0	-1751	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:05:13	1	322	317	278	440	464	319	629	-36	100	223	-9	1981	2047	0	0	-1755	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:05:43	1	322	317	278	440	464	319	629	-36	101	223	-8	1981	2047	0	0	-1755	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:06:13	0	322	317	278	440	464	319	629	-36	101	224	-9	1980	2047	0	0	-1760	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:06:43	1	322	317	278	440	464	319	629	-36	102	223	-9	1980	2047	0	0	-1760	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:07:13	0	322	317	278	440	464	319	629	-36	102	224	-8	1979	2047	0	0	-1765	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:07:43	1	322	317	279	440	464	318	629	-36	102	223	-10	1978	2047	0	0	-1765	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:08:13	1	322	317	278	440	464	319	629	-36	102	223	-10	1977	2047	0	0	-1770	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:08:43	0	322	318	278	440	464	318	629	-36	103	224	-10	1977	2047	0	0	-1770	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:09:13	1	322	317	278	440	464	318	629	-36	103	223	-10	1976	2047	0	0	-1775	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:09:43	0	322	317	279	440	464	318	629	-37	103	223	-10	1975	2047	0	0	-1775	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:10:13	1	322	317	278	440	464	319	629	-37	103	224	-10	1975	2047	0	0	-1780	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:10:43	0	322	317	278	440	464	318	629	-36	102	223	-10	1975	2047	0	0	-1780	291	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:11:13	1	322	317	278	440	464	318	629	-36	103	224	-10	1975	2047	0	0	-1785	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:11:43	1	322	317	278	440	464	318	629	-37	102	224	-10	1975	2047	0	0	-1785	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:12:13	1	322	317	278	440	464	319	629	-36	102	224	-10	1974	2047	0	0	-1790	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:12:43	1	322	317	278	440	463	318	629	-36	103	224	-10	1974	2047	0	0	-1790	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:13:13	1	322	317	278	440	464	318	629	-36	103	223	-10	1974	2047	0	0	-1795	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:13:43	1	322	317	278	440	464	318	629	-36	103	224	-10	1973	2047	0	0	-1795	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:14:13	1	322	317	278	440	464	318	629	-37	102	224	-10	1973	2047	0	0	-1800	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:14:43	1	322	317	278	439	464	318	629	-37	103	224	-10	1973	2047	0	0	-1800	291	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:15:13	1	322	317	278	439	463	318	629	-37	102	224	-10	1973	2047	0	0	-1805	291	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:15:43	1	322	317	278	439	464	318	629	-37	102	224	-10	1972	2047	0	0	-1805	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:16:13	1	322	317	278	439	464	318	629	-37	102	224	-10	1972	2047	0	0	-1810	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:16:43	1	322	317	278	439	464	318	629	-37	102	224	-10	1971	2047	0	0	-1810	291	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:17:21	1	322	316	278	439	463	318	629	-37	102	224	-10	1971	2047	0	0	-1816	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:17:48	1	322	316	278	439	463	318	629	-37	102	224	-10	1971	2047	0	0	-1816	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:18:18	1	322	317	278	439	463	318	629	-37	102	224	-11	1970	2047	0	0	-1822	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:18:48	1	322	316	278	439	463	318	629	-37	103	224	-11	1969	2047	0	0	-1822	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:19:18	1	322	317	278	439	463	318	629	-37	102	224	-10	1969	2047	0	0	-1828	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:19:48	1	322	317	278	439	463	318	629	-37	103	224	-10	1968	2047	0	0	-1828	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:20:18	1	321	316	278	439	464	318	629	-37	103	224	-10	1968	2047	0	0	-1834	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:20:48	1	321	316	278	439	463	318	629	-37	102	224	-11	1967	2047	0	0	-1834	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:21:18	1	321	316	278	439	463	318	629	-37	102	224	-10	1967	2047	0	0	-1839	290	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:21:48	2	321	316	278	439	463	319	629	-37	102	224	-11	1967	2047	0	0	-1839	289	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:22:18	1	321	317	278	439	463	319	629	-37	102	224	-10	1966	2047	0	0	-1844	300	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:22:48	1	321	317	278	439	463	319	629	-38	99	224	-10	1965	2047	0	0	-1844	300	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:23:18	2	321	317	278	439	463	319	629	-38	96	224	-12	1964	2047	0	0	-1848	299	-7	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:23:48	1	321	317	278	439	463	319	629	-38	95	224	-12	1963	2047	0	0	-1848	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:24:18	2	321	318	278	439	463	319	629	-39	95	224	-12	1963	2047	0	0	-1851	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:24:48	1	321	317	278	439	463	319	629	-39	95	224	-12	1963	2047	0	0	-1851	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:25:18	2	321	318	278	439	463	319	629	-40	94	224	-12	1963	2047	0	0	-1855	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:25:48	2	321	318	278	439	463	319	629	-40	95	224	-12	1964	2047	0	0	-1855	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:26:18	2	321	318	278	439	463	319	629	-40	96	224	-13	1963	2047	0	0	-1858	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:26:48	2	321	317	278	439	463	319	629	-40	96	224	-13	1963	2047	0	0	-1858	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:27:18	2	321	317	278	438	463	319	629	-40	96	224	-13	1963	2047	0	0	-1862	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:27:48	2	321	317	278	438	463	319	629	-40	96	224	-13	1963	2047	0	0	-1862	301	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:28:18	2	321	317	278	438	463	319	629	-40	96	224	-13	1962	2047	0	0	-1866	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:28:48	2	321	317	278	438	463	319	629	-40	97	224	-13	1961	2047	0	0	-1866	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:29:18	2	321	317	278	438	463	319	629	-40	96	224	-13	1961	2047	0	0	-1870	301	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:29:48	2	321	317	278	438	463	318	629	-40	97	224	-13	1961	2047	0	0	-1870	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:30:18	2	321	317	278	438	463	319	629	-41	96	224	-14	1960	2047	0	0	-1874	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:30:47	2	321	317	278	438	463	319	629	-41	98	224	-14	1960	2047	0	0	-1874	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:31:17	2	321	317	278	438	463	319	631	-41	98	224	-15	1959	2047	0	0	-1878	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:31:47	2	321	317	278	438	463	318	631	-41	97	224	-15	1958	2047	0	0	-1878	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:32:26	2	321	317	278	438	463	319	631	-41	98	224	-14	1957	2047	0	0	-1882	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:32:53	3	321	317	278	438	463	319	631	-41	98	224	-15	1957	2047	0	0	-1882	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:33:23	2	321	317	278	438	463	318	631	-41	97	224	-15	1957	2047	0	0	-1886	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:33:53	3	321	317	278	438	463	319	631	-41	98	224	-15	1957	2047	0	0	-1886	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:34:23	2	321	317	278	438	463	319	631	-42	98	224	-15	1957	2047	0	0	-1890	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:34:53	3	321	317	277	438	463	319	631	-41	98	224	-15	1956	2047	0	0	-1890	301	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:35:23	2	321	317	277	438	463	319	631	-42	98	224	-14	1955	2047	0	0	-1894	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:35:53	3	321	317	278	438	463	319	631	-41	98	224	-15	1954	2047	0	0	-1894	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:36:23	3	321	317	277	438	463	319	631	-42	98	224	-15	1953	2047	0	0	-1898	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:36:53	2	321	317	277	438	463	319	631	-42	98	224	-15	1953	2047	0	0	-1898	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:37:23	2	321	317	278	437	463	319	631	-41	98	224	-15	1953	2047	0	0	-1902	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:37:53	2	321	317	277	437	463	319	631	-42	96	224	-15	1954	2047	0	0	-1902	299	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:38:23	2	321	317	278	437	463	318	632	-42	98	224	-15	1953	2047	0	0	-1906	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:38:53	3	321	317	278	437	463	319	632	-42	98	224	-15	1952	2047	0	0	-1906	301	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:39:23	3	321	317	278	437	463	319	632	-41	96	224	-15	1952	2047	0	0	-1910	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:39:53	2	321	317	278	437	463	319	632	-42	96	224	-15	1952	2047	0	0	-1910	300	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:40:23	2	321	317	278	437	463	319	632	-42	96	224	-15	1952	2047	0	0	-1914	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:40:52	2	321	317	278	437	463	320	632	-42	95	224	-16	1951	2047	0	0	-1914	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:41:22	2	321	318	278	437	463	320	632	-43	94	224	-17	1951	2047	0	0	-1917	311	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:41:52	2	321	318	278	437	463	320	632	-44	93	224	-17	1951	2047	0	0	-1917	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:42:22	2	321	318	277	437	463	320	633	-44	92	224	-17	1950	2047	0	0	-1920	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:42:52	3	321	318	278	437	463	320	633	-44	92	224	-17	1949	2047	0	0	-1920	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:43:22	3	321	318	278	437	463	320	633	-44	91	224	-18	1949	2047	0	0	-1923	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:43:52	2	321	318	278	437	463	320	633	-44	92	224	-19	1949	2047	0	0	-1923	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:44:22	2	321	318	278	437	463	320	633	-44	92	224	-19	1948	2047	0	0	-1926	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:44:52	2	321	318	278	437	462	320	633	-45	91	224	-18	1946	2047	0	0	-1926	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:45:22	2	321	318	277	437	463	320	633	-45	92	224	-19	1945	2047	0	0	-1929	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:45:52	2	321	318	278	437	463	320	633	-45	92	224	-19	1945	2047	0	0	-1929	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:46:22	2	321	318	278	437	463	320	633	-45	92	224	-19	1945	2047	0	0	-1932	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:46:52	2	321	318	278	437	462	320	633	-45	92	224	-19	1944	2047	0	0	-1932	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:47:27	3	321	318	278	437	463	319	633	-46	92	224	-19	1943	2047	0	0	-1935	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:47:57	3	321	318	278	437	462	320	633	-46	92	224	-19	1942	2047	0	0	-1935	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:48:27	2	321	318	278	437	462	320	633	-46	92	224	-19	1942	2047	0	0	-1938	311	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:48:57	2	321	318	278	437	462	320	634	-45	92	224	-19	1942	2047	0	0	-1938	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:49:27	3	321	318	278	437	462	320	634	-46	92	224	-19	1943	2047	0	0	-1941	311	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:49:57	3	321	318	278	437	462	320	634	-46	92	224	-19	1942	2047	0	0	-1941	309	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:50:27	2	321	318	278	436	462	319	634	-46	92	224	-19	1942	2047	0	0	-1944	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:50:57	2	321	318	278	436	462	320	634	-46	92	224	-19	1942	2047	0	0	-1944	310	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:51:27	2	321	318	278	436	462	320	634	-46	92	224	-19	1941	2047	0	0	-1947	311	-6	214	2	30	0	0	0	0	6713	10146	0	0	2940	813
2021-01-24	13:51:57	2	321	318	278	437	462	320	634	-46	91	224	-19	1940	2047	0	0	-1947	310	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:52:27	2	321	318	278	436	462	320	634	-46	92	224	-20	1940	2047	0	0	-1950	309	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:52:57	2	321	318	278	436	462	320	634	-46	92	224	-20	1939	2047	0	0	-1950	310	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:53:27	2	321	318	278	436	462	320	634	-46	91	224	-20	1938	2047	0	0	-1953	310	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:53:57	3	321	318	278	436	462	319	634	-46	91	224	-21	1937	2047	0	0	-1953	310	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:54:27	2	321	318	278	436	462	320	634	-46	91	224	-21	1936	2047	0	0	-1956	311	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:54:57	3	321	318	278	436	462	320	634	-46	91	224	-20	1936	2047	0	0	-1956	310	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:55:27	2	321	318	278	436	462	320	634	-46	91	224	-21	1935	2047	0	0	-1959	309	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:55:57	3	321	318	278	436	462	320	635	-46	92	225	-21	1934	2047	0	0	-1959	309	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:56:27	3	321	318	278	436	462	320	634	-46	92	224	-21	1933	2047	0	0	-1962	310	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:56:57	3	321	318	278	435	462	320	634	-46	92	224	-21	1932	2047	0	0	-1962	310	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:57:27	2	321	318	278	435	462	321	636	-46	91	224	-21	1932	2047	0	0	-1965	319	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:57:57	2	321	319	278	435	462	321	636	-46	90	224	-21	1932	2047	0	0	-1965	319	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:58:27	3	321	319	278	435	462	321	636	-47	90	224	-21	1932	2047	0	0	-1967	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:58:57	2	321	319	278	435	462	321	636	-48	90	224	-22	1932	2047	0	0	-1967	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:59:27	3	321	319	278	435	462	321	636	-48	88	225	-23	1931	2047	0	0	-1969	321	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	13:59:57	3	321	319	278	435	462	321	636	-48	88	224	-23	1931	2047	0	0	-1969	319	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:00:27	2	321	319	278	435	462	321	636	-48	88	224	-23	1930	2047	0	0	-1971	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:00:57	3	321	319	278	435	462	321	636	-48	88	224	-23	1930	2047	0	0	-1971	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:01:27	2	321	319	278	435	462	321	637	-48	87	224	-23	1929	2047	0	0	-1973	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:02:05	3	321	319	278	435	462	321	637	-48	87	224	-23	1928	2047	0	0	-1973	319	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:02:32	3	321	320	278	434	462	321	637	-48	87	224	-23	1927	2047	0	0	-1975	321	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:03:02	2	321	319	278	435	462	321	637	-48	87	224	-23	1927	2047	0	0	-1975	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:03:32	2	321	320	278	434	462	321	637	-48	87	224	-23	1926	2047	0	0	-1976	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:04:02	3	321	320	278	434	462	321	637	-48	87	224	-23	1926	2047	0	0	-1976	319	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:04:32	3	321	319	278	434	462	321	637	-48	87	224	-24	1926	2047	0	0	-1977	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:05:02	3	321	319	278	434	462	321	637	-49	87	224	-24	1925	2047	0	0	-1977	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:05:32	3	321	319	278	434	462	321	637	-49	87	224	-23	1925	2047	0	0	-1979	321	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:06:02	2	321	319	278	434	462	321	637	-49	87	224	-24	1924	2047	0	0	-1979	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:06:32	2	321	320	278	434	462	321	637	-48	88	224	-25	1925	2047	0	0	-1981	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:07:02	2	321	320	278	434	461	321	637	-48	90	224	-24	1930	2047	0	0	-1981	320	-6	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:07:32	3	321	320	278	434	461	321	637	-48	91	223	-23	1934	2047	0	0	-1982	320	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:08:02	3	321	320	278	434	461	322	638	-48	91	224	-23	1938	2047	0	0	-1982	320	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:08:32	3	321	320	278	434	462	321	638	-48	92	224	-23	1942	2047	0	0	-1983	319	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:09:02	2	321	320	278	434	461	321	638	-48	91	224	-23	1944	2047	0	0	-1983	319	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:09:32	2	321	320	278	434	461	321	638	-47	90	223	-23	1944	2047	0	0	-1984	320	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:10:02	2	321	320	278	434	461	321	638	-48	88	224	-23	1942	2047	0	0	-1984	320	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:10:32	2	321	320	278	434	461	321	638	-48	88	224	-25	1940	2047	0	0	-1985	320	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:11:02	2	321	320	278	434	461	321	638	-48	87	224	-25	1938	2047	0	0	-1985	321	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:11:32	2	321	320	278	434	461	321	638	-49	87	223	-25	1935	2047	0	0	-1986	320	-5	214	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:12:02	2	321	320	278	434	461	321	638	-49	87	223	-25	1933	2047	0	0	-1986	321	-5	213	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:12:32	2	321	320	278	434	461	321	638	-50	86	223	-25	1931	2047	0	0	-1987	319	-5	213	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:13:02	2	321	320	279	434	461	321	638	-50	86	223	-25	1929	2047	0	0	-1987	320	-5	213	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:13:32	2	321	320	279	434	461	321	639	-50	84	223	-26	1927	2047	0	0	-1988	321	-5	213	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:14:02	1	321	320	278	434	461	321	639	-50	85	223	-26	1926	2047	0	0	-1988	320	-5	213	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:14:32	1	321	320	278	433	461	321	639	-50	86	223	-26	1925	2047	0	0	-1989	320	-5	213	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:15:02	2	321	320	279	433	461	321	640	-50	86	223	-26	1923	2047	0	0	-1989	320	-5	213	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:15:32	1	321	319	279	433	461	321	640	-50	86	223	-26	1922	2047	0	0	-1990	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:16:02	2	321	320	278	433	461	321	640	-50	84	223	-26	1921	2047	0	0	-1990	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:16:32	1	321	320	278	433	461	321	640	-50	84	223	-26	1920	2047	0	0	-1991	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:17:07	1	321	320	278	433	461	321	640	-50	84	223	-27	1918	2047	0	0	-1991	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:17:37	1	320	320	278	433	461	321	640	-51	83	223	-27	1917	2047	0	0	-1992	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:18:07	1	320	320	279	433	461	321	640	-51	84	223	-27	1916	2047	0	0	-1992	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:18:37	1	320	319	278	433	461	321	640	-51	85	223	-28	1915	2047	0	0	-1992	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:19:07	2	320	319	279	433	461	321	640	-52	85	223	-28	1913	2047	0	0	-1992	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:19:37	2	319	320	278	433	461	321	640	-52	86	223	-28	1912	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:20:07	1	319	319	278	433	461	321	640	-52	86	223	-28	1909	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:20:37	1	319	320	278	433	461	321	640	-52	86	223	-28	1908	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:21:07	1	319	320	278	433	461	321	641	-52	86	223	-28	1907	2047	0	0	-1993	321	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:21:37	1	319	320	278	433	461	321	641	-52	85	223	-28	1906	2047	0	0	-1993	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:22:07	1	319	319	279	433	461	321	641	-52	86	223	-29	1904	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:22:37	1	319	319	278	433	461	321	641	-52	86	223	-28	1903	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:23:07	1	319	319	279	433	461	321	641	-52	86	223	-28	1902	2047	0	0	-1993	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:23:37	1	319	319	279	433	461	321	641	-52	84	223	-29	1902	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:24:07	1	319	320	278	433	461	321	641	-52	86	223	-29	1901	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:24:37	1	319	319	278	433	461	321	641	-52	86	223	-29	1899	2047	0	0	-1993	321	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:25:07	1	319	319	279	433	461	321	641	-52	85	223	-30	1898	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:25:37	2	319	319	278	432	461	321	641	-52	86	223	-30	1897	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:26:07	1	319	319	278	433	461	321	641	-52	87	223	-28	1900	2047	0	0	-1993	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:26:37	1	319	319	278	432	461	321	641	-51	87	223	-28	1902	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:27:07	1	319	319	278	432	461	321	641	-52	86	223	-28	1901	2047	0	0	-1993	321	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:27:37	2	319	320	279	432	461	321	641	-52	85	223	-28	1900	2047	0	0	-1993	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:28:07	2	319	319	279	432	461	321	642	-52	84	223	-28	1899	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:28:37	2	319	319	278	432	460	321	641	-52	84	223	-28	1898	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:29:07	2	319	319	278	432	460	321	642	-52	85	223	-29	1897	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:29:37	1	319	319	278	432	460	321	642	-52	84	223	-29	1896	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:30:07	1	319	319	278	432	461	321	642	-52	84	223	-30	1895	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:30:37	1	319	319	278	432	460	321	642	-52	83	223	-29	1894	2047	0	0	-1993	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:31:06	1	319	319	278	432	460	320	642	-52	84	223	-30	1892	2047	0	0	-1993	321	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:31:36	1	319	319	278	432	460	321	642	-52	83	223	-30	1892	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:32:15	1	319	319	278	432	460	321	642	-52	83	223	-30	1891	2047	0	0	-1993	321	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:32:45	1	319	319	278	432	460	320	642	-52	83	223	-30	1889	2047	0	0	-1993	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:33:12	1	319	319	278	432	460	320	642	-52	83	223	-30	1888	2047	0	0	-1993	321	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:33:42	2	319	319	278	432	460	321	642	-52	82	223	-30	1888	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:34:11	1	319	319	278	432	460	320	642	-53	82	223	-30	1886	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:34:41	1	319	319	278	432	460	321	642	-53	82	223	-30	1885	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:35:11	2	319	319	278	432	460	320	642	-53	82	222	-30	1884	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:35:41	1	319	319	278	432	460	320	642	-53	82	223	-31	1882	2047	0	0	-1993	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:36:11	2	319	319	278	432	460	320	642	-53	82	223	-31	1882	2047	0	0	-1993	321	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:36:41	1	319	319	278	432	460	320	642	-53	82	222	-30	1881	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:37:11	1	319	319	278	432	460	320	642	-54	82	222	-30	1880	2047	0	0	-1993	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:37:41	1	319	319	278	432	460	320	642	-54	82	223	-31	1878	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:38:11	1	319	319	278	432	460	320	642	-54	82	223	-31	1877	2047	0	0	-1993	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:38:41	1	319	319	278	432	460	320	642	-54	82	223	-31	1876	2047	0	0	-1994	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:39:11	1	319	319	278	431	460	320	642	-54	82	223	-32	1875	2047	0	0	-1994	318	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:39:41	1	319	318	278	431	460	320	642	-54	82	223	-32	1874	2047	0	0	-1995	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:40:11	1	319	318	278	431	460	320	642	-54	82	223	-31	1873	2047	0	0	-1995	319	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:40:41	1	319	318	278	431	460	320	642	-54	82	223	-31	1872	2047	0	0	-1996	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:41:11	1	319	318	278	431	460	320	642	-54	82	223	-32	1871	2047	0	0	-1996	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:41:41	1	319	319	278	431	460	320	642	-54	80	222	-32	1870	2047	0	0	-1997	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:42:11	1	319	318	278	431	460	320	642	-54	81	222	-32	1870	2047	0	0	-1997	320	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:42:41	1	319	319	278	431	460	320	641	-54	80	223	-32	1868	2047	0	0	-1998	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:43:11	1	319	318	278	431	460	282	628	-44	92	223	-29	1867	2047	0	0	-1998	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:43:41	1	319	297	278	432	460	278	606	-26	108	223	-18	1866	2047	0	0	-2000	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:44:11	0	319	285	278	431	460	278	587	-14	123	223	-9	1865	2047	0	0	-2000	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:44:41	1	319	280	278	431	460	278	572	-7	135	223	-3	1866	2047	0	0	-2035	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:45:11	1	319	278	278	431	460	278	559	-4	145	223	-1	1869	2047	0	0	-2035	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:45:41	1	319	278	277	431	460	278	549	-2	154	223	-1	1872	2047	0	0	-2076	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:46:11	1	319	278	277	431	460	277	540	-2	161	223	-1	1876	2047	0	0	-2076	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:46:41	1	319	277	276	431	460	276	533	-1	168	223	-1	1882	2047	0	0	-2118	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:47:19	1	319	276	275	431	459	275	525	-1	174	223	0	1888	2047	0	0	-2118	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:47:46	1	319	275	274	431	459	274	519	-1	180	223	-1	1893	2047	0	0	-2161	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:48:16	1	319	275	274	431	459	274	514	-1	184	223	0	1898	2047	0	0	-2161	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:48:46	1	319	274	274	431	459	273	508	-1	187	223	1	1903	2047	0	0	-2206	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:49:16	1	319	273	273	431	459	273	503	0	191	223	1	1907	2047	0	0	-2206	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:49:46	0	319	273	273	431	459	272	499	5	194	223	1	1912	2047	0	0	-2252	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:50:16	0	319	272	272	431	459	272	495	14	196	223	1	1918	2047	0	0	-2252	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:50:46	0	319	272	271	431	459	271	491	25	198	223	1	1925	2047	0	0	-2299	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:51:16	1	319	271	271	431	458	271	486	35	200	223	2	1931	2047	0	0	-2299	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:51:46	0	319	271	270	430	458	270	482	47	203	223	4	1936	2047	0	0	-2347	0	-5	212	2	10	0	0	0	183	6713	10147	0	0	2940	813
2021-01-24	14:52:16	1	319	270	270	431	458	269	478	57	204	223	6	1941	-32768	0	0	-2347	0	-5	212	2	30	0	0	0	0	6713	10147	0	0	2940	813
2021-01-24	14:52:46	0	319	270	269	430	458	289	549	60	117	223	4	1945	-32768	0	0	-2396	330	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:53:16	1	319	284	268	430	458	293	584	36	91	222	1	1949	-32768	0	0	-2396	330	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:53:46	0	319	290	267	430	458	291	588	7	94	223	0	1955	-32768	0	0	-2430	340	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:54:16	1	319	290	267	430	458	291	592	-5	38	222	0	1960	-32768	0	0	-2430	340	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:54:46	0	319	290	268	430	458	293	595	-24	65	222	-1	1964	-32768	0	0	-2459	349	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:55:16	0	319	292	269	430	458	295	599	-37	101	222	-1	1969	-32768	0	0	-2459	350	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:55:46	0	319	292	269	430	458	297	603	-40	121	222	-1	1974	-32768	0	0	-2486	359	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:56:16	0	319	295	268	430	458	299	607	-40	111	222	-1	1980	-32768	0	0	-2486	360	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:56:46	0	320	297	269	430	458	301	610	-40	76	222	-1	1984	-32768	0	0	-2510	370	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:57:16	0	320	299	269	430	458	302	613	-44	63	222	-1	1987	-32768	0	0	-2510	370	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:57:46	0	320	301	269	430	458	304	616	-49	79	222	-1	1991	2040	0	0	-2531	379	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:58:16	0	320	302	269	430	458	305	617	-52	84	222	-1	1994	2040	0	0	-2531	380	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:58:46	0	321	303	269	430	458	306	619	-54	78	222	-1	1997	2040	0	0	-2549	390	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:59:16	0	321	304	269	430	458	307	621	-56	70	222	-1	2001	2040	0	0	-2549	390	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	14:59:46	0	321	305	270	430	458	308	621	-59	65	222	-2	2004	2040	0	0	-2566	400	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	15:00:16	0	321	306	270	430	458	308	622	-61	66	222	-3	2007	2040	0	0	-2566	400	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	15:00:46	0	321	307	270	430	458	310	623	-64	65	221	-3	2011	2040	0	0	-2580	410	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	15:01:16	0	321	308	270	430	458	309	624	-66	64	222	-5	2013	2040	0	0	-2580	409	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	15:01:46	0	321	308	271	430	458	310	626	-68	62	221	-6	2015	2040	0	0	-2593	410	-5	212	2	30	0	0	0	0	6714	10147	0	0	2940	813
2021-01-24	15:02:23	0	321	308	271	430	458	310	627	-69	61	222	-6	2016	2040	0	0	-2593	410	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:02:50	0	321	308	271	430	458	311	629	-71	59	222	-9	2019	2040	0	0	-2606	420	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:03:20	0	321	309	271	430	458	311	631	-72	62	222	-12	2021	2040	0	0	-2606	420	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:03:50	0	321	309	272	430	458	312	633	-74	62	222	-16	2023	2040	0	0	-2618	429	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:04:20	0	321	310	272	430	458	313	635	-75	60	221	-21	2024	2040	0	0	-2618	431	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:04:50	0	321	311	272	429	458	313	637	-76	56	222	-26	2025	2040	0	0	-2629	430	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:05:20	0	321	311	273	430	458	313	640	-76	53	221	-30	2026	2040	0	0	-2629	430	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:05:50	0	321	311	273	429	458	314	641	-78	53	221	-34	2028	2040	0	0	-2639	439	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:06:20	0	321	312	274	429	458	314	643	-80	61	221	-38	2029	2040	0	0	-2639	440	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:06:50	-1	321	313	274	429	458	316	646	-81	63	222	-40	2031	2040	0	0	-2648	451	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:07:20	-1	321	313	274	429	458	316	649	-81	48	222	-42	2032	2040	0	0	-2648	449	-5	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:07:50	-1	321	315	275	429	458	316	650	-82	40	221	-43	2032	2040	0	0	-2655	450	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:08:20	0	321	314	275	429	458	316	653	-85	63	222	-45	2032	2040	0	0	-2655	449	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:08:50	0	321	314	276	429	458	318	656	-85	69	222	-46	2033	2040	0	0	-2662	459	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:09:20	0	321	315	276	429	458	319	658	-83	47	222	-46	2033	2040	0	0	-2662	460	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:09:50	-1	321	317	276	429	458	318	660	-85	18	222	-46	2033	2040	0	0	-2667	460	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:10:20	-1	321	316	277	429	458	316	663	-91	56	222	-50	2033	2040	0	0	-2667	461	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:10:50	0	321	316	277	429	458	319	666	-91	79	222	-51	2033	2040	0	0	-2672	471	-4	213	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:11:20	-1	321	317	277	429	458	321	669	-87	72	222	-50	2034	2040	0	0	-2672	469	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:11:50	-1	321	319	278	429	458	321	670	-85	7	222	-48	2033	2040	0	0	-2676	470	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:12:20	0	321	319	278	429	458	319	673	-92	45	222	-52	2033	2040	0	0	-2676	470	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:12:50	-1	321	318	278	429	458	320	675	-94	75	222	-54	2034	2040	0	0	-2678	480	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:13:20	-1	321	319	279	429	458	323	678	-90	77	222	-54	2035	2040	0	0	-2678	480	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:13:50	-1	321	320	279	429	458	324	680	-87	3	222	-52	2035	2040	0	0	-2680	480	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:14:20	-1	321	321	279	429	458	321	681	-93	27	221	-53	2034	2040	0	0	-2680	480	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:14:50	-1	321	320	280	429	458	321	685	-99	70	222	-59	2032	2040	0	0	-2680	490	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:15:20	-1	321	320	280	429	458	324	688	-95	83	222	-58	2032	2040	0	0	-2680	489	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:15:50	-1	321	322	280	429	458	326	689	-89	22	222	-54	2032	2040	0	0	-2681	490	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:16:20	-1	321	323	280	429	458	324	691	-92	14	222	-54	2035	2040	0	0	-2681	490	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:16:50	-1	321	323	281	429	458	322	694	-99	62	222	-59	2040	2040	0	0	-2679	490	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:17:25	-1	321	321	281	429	458	325	696	-97	87	222	-59	2045	2040	0	0	-2679	490	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:17:55	-1	321	323	281	429	458	328	698	-89	65	222	-54	2047	2040	0	0	-2679	500	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:18:25	-1	321	325	282	428	458	328	698	-88	-5	222	-54	2047	2040	0	0	-2679	500	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:18:55	-1	321	325	282	428	458	323	701	-98	44	222	-59	2046	2040	0	0	-2675	500	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:19:25	-1	321	323	283	428	458	325	703	-100	75	222	-61	2047	2040	0	0	-2675	500	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:19:55	-1	321	323	283	428	458	328	705	-94	72	222	-61	2046	2040	0	0	-2673	499	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:20:25	-1	321	325	283	428	458	328	705	-91	-8	222	-57	2046	2040	0	0	-2673	501	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:20:55	-1	321	326	284	428	458	325	707	-99	34	222	-61	2045	2040	0	0	-2669	500	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:21:25	-1	321	324	284	428	458	326	710	-102	71	222	-63	2044	2040	0	0	-2669	499	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:21:55	-2	321	324	284	428	458	329	711	-97	75	222	-62	2043	2040	0	0	-2666	500	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:22:25	-1	321	326	284	427	458	330	711	-92	-2	222	-59	2042	2040	0	0	-2666	500	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:22:55	-1	321	326	369	427	458	379	720	-98	26	222	-61	2040	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:23:25	-1	321	376	405	427	458	421	736	-100	64	222	-63	2039	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:23:55	-1	321	410	420	426	458	437	750	-93	76	222	-61	2038	2040	0	0	-2661	511	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:24:25	-1	321	429	429	425	458	447	761	-85	75	222	-57	2037	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:24:55	-1	321	439	428	424	457	454	771	-79	73	223	-52	2035	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:25:25	-1	321	445	426	424	457	459	780	-75	70	223	-50	2034	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:25:55	-2	321	451	426	423	457	467	787	-72	65	223	-48	2033	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:26:25	-1	321	457	427	424	458	476	794	-71	59	223	-47	2031	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:26:55	-2	321	464	428	424	458	484	801	-70	58	223	-47	2030	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:27:25	-1	321	471	430	425	458	491	807	-71	61	223	-46	2029	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:27:55	-2	321	477	432	426	458	496	814	-70	62	223	-46	2028	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:28:25	-2	321	482	433	427	458	502	820	-70	62	223	-46	2027	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:28:55	-1	321	488	435	428	458	506	826	-70	65	223	-45	2026	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:29:25	-1	321	493	437	429	459	509	833	-70	66	223	-46	2026	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:29:55	-1	321	497	439	430	459	512	838	-68	68	223	-45	2025	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:30:25	-1	321	500	441	432	460	515	843	-67	70	223	-44	2024	2040	0	0	-2661	511	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:30:55	-1	321	502	443	433	460	517	849	-66	69	223	-44	2024	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:31:25	-2	321	504	444	434	461	519	854	-64	66	223	-42	2023	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:32:02	-2	321	506	446	436	462	521	860	-64	66	223	-42	2022	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:32:29	-2	321	508	448	437	462	522	864	-63	66	223	-42	2022	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:32:59	-2	321	511	449	439	463	524	868	-63	68	223	-41	2022	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:33:29	-1	321	513	451	440	463	525	872	-63	68	223	-40	2022	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:33:59	-2	321	514	452	442	463	527	875	-62	68	223	-40	2021	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:34:29	-2	321	516	454	443	464	526	879	-61	67	223	-40	2020	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:34:59	-2	321	516	455	445	464	527	883	-61	69	222	-40	2020	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:35:29	-2	321	517	453	446	466	524	886	-62	72	222	-40	2020	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:35:59	-2	321	516	455	448	466	525	889	-61	72	222	-40	2019	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:36:29	-2	321	515	457	449	467	526	893	-60	69	222	-38	2019	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:36:59	-2	321	516	458	450	468	526	895	-60	65	223	-38	2019	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:37:29	-2	321	516	460	452	468	526	897	-60	67	222	-38	2018	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:37:59	-2	321	516	462	453	468	526	899	-60	72	222	-38	2018	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:38:29	-2	321	516	463	455	469	527	902	-60	75	222	-38	2018	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:38:59	-1	321	517	465	456	469	529	906	-59	73	222	-38	2017	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:39:29	-2	321	518	466	458	470	530	908	-58	69	222	-36	2017	2040	0	0	-2661	511	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:39:59	-2	321	519	468	459	471	528	909	-57	67	222	-36	2016	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:40:29	-2	321	519	470	460	471	529	911	-58	69	222	-37	2016	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:40:59	-2	321	519	471	461	472	530	914	-58	73	222	-37	2016	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:41:29	-2	321	519	473	462	472	530	916	-57	76	222	-36	2017	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:41:59	-2	321	520	475	463	473	530	919	-56	73	222	-36	2016	2040	0	0	-2661	511	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:42:29	-2	321	520	476	465	474	528	921	-55	69	222	-34	2016	2040	0	0	-2661	509	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:42:59	-2	321	519	478	465	475	530	923	-55	68	222	-34	2016	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:43:29	-3	321	520	479	467	475	528	923	-56	72	222	-35	2015	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:43:59	-2	321	519	481	468	476	530	926	-56	78	222	-35	2015	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:44:29	-2	321	520	482	469	477	528	928	-55	76	222	-34	2015	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:44:59	-3	321	520	484	470	478	531	931	-53	71	222	-34	2015	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:45:29	-2	321	520	487	471	479	530	931	-53	67	222	-34	2015	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:45:59	-3	321	520	488	472	479	528	934	-54	72	222	-34	2014	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:46:29	-2	321	520	490	473	480	528	936	-54	77	221	-33	2013	2040	0	0	-2661	510	-4	213	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:46:04	-3	321	520	491	474	481	530	939	-53	78	221	-34	2012	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:46:34	-3	321	520	493	475	481	529	939	-52	73	222	-33	2010	2040	0	0	-2661	509	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:47:04	-3	321	520	494	476	482	530	941	-51	69	221	-32	2010	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:47:34	-3	321	520	496	477	483	530	944	-52	70	221	-32	2009	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:48:04	-3	321	520	497	477	484	528	944	-52	75	221	-32	2009	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:48:34	-3	321	520	499	478	485	530	946	-52	78	221	-33	2008	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:49:04	-3	321	520	500	479	485	529	949	-52	78	221	-32	2008	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:49:34	-3	321	520	501	480	486	530	949	-51	75	221	-32	2008	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:50:04	-3	321	521	503	481	487	530	952	-50	71	221	-32	2009	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:50:34	-3	321	521	504	482	488	528	953	-50	72	221	-32	2009	2040	0	0	-2661	510	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:51:04	-3	321	520	506	483	489	530	954	-50	75	222	-30	2009	2040	0	0	-2661	511	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:51:34	-3	321	521	507	484	490	528	957	-50	79	221	-30	2009	2040	0	0	-2661	511	-4	212	10	20	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:52:04	-3	321	521	358	485	491	463	948	-51	78	221	-31	2009	2040	0	0	-2661	510	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:52:34	-3	321	427	263	486	491	295	925	-65	92	221	-38	2009	2040	0	0	-2661	510	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:53:04	-4	321	333	256	488	492	293	912	-66	21	222	-40	2010	2040	0	0	-2661	510	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:53:34	-4	321	304	256	489	493	291	897	-73	22	221	-42	2010	2040	0	0	-2661	510	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:54:04	-4	321	294	254	489	493	299	885	-84	67	221	-49	2010	2040	0	0	-2679	510	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:54:34	-3	321	297	254	490	494	303	874	-85	82	221	-52	2011	2040	0	0	-2679	510	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:55:04	-4	321	301	255	491	494	305	862	-82	10	221	-52	2011	2040	0	0	-2702	510	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:55:34	-3	321	304	256	491	494	301	849	-88	29	221	-54	2012	2040	0	0	-2702	509	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:56:04	-4	321	302	256	491	495	300	841	-95	66	221	-59	2012	2040	0	0	-2719	509	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:56:34	-4	321	301	256	492	495	303	833	-92	76	221	-59	2012	2040	0	0	-2719	510	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:57:04	-4	321	302	257	492	495	305	823	-88	12	221	-57	2011	2040	0	0	-2739	519	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:57:34	-4	321	304	258	492	495	302	816	-93	27	221	-59	2010	2040	0	0	-2739	520	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:58:04	-4	321	303	260	492	495	304	809	-98	64	221	-63	2009	2040	0	0	-2756	531	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:58:34	-4	321	303	261	492	495	308	804	-96	71	221	-63	2009	2040	0	0	-2756	530	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:59:04	-4	321	306	263	492	495	312	796	-92	0	221	-61	2010	2040	0	0	-2774	540	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	15:59:34	-4	321	309	265	492	495	309	790	-98	29	221	-63	2010	2040	0	0	-2774	538	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	16:00:04	-4	321	308	266	492	494	311	787	-103	64	221	-67	2010	2040	0	0	-2786	540	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	16:00:34	-4	321	310	268	492	494	314	783	-100	67	221	-67	2010	2040	0	0	-2786	540	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	16:01:10	-4	321	313	269	492	494	317	779	-95	-2	221	-65	2008	2040	0	0	-2797	550	-4	212	2	30	0	0	0	0	6714	10148	0	0	2940	813
2021-01-24	16:01:40	-4	321	315	270	492	494	313	774	-102	30	221	-67	2007	2040	0	0	-2797	550	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:02:07	-4	321	314	271	492	494	316	771	-106	63	221	-72	2007	2040	0	0	-2803	560	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:02:37	-4	321	315	272	492	494	319	769	-103	63	221	-71	2006	2040	0	0	-2803	560	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:03:07	-4	321	318	273	492	494	321	766	-99	-11	221	-70	2006	2040	0	0	-2809	560	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:03:37	-4	321	318	274	492	494	317	763	-106	30	221	-72	2006	2040	0	0	-2809	560	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:04:07	-4	321	317	275	492	493	319	763	-110	63	221	-76	2006	2040	0	0	-2812	570	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:04:37	-5	321	318	276	492	493	322	761	-105	59	221	-74	2005	2040	0	0	-2812	571	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:05:07	-5	321	320	276	492	493	323	759	-102	-12	221	-72	2004	2040	0	0	-2815	570	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:05:37	-5	321	321	277	492	493	320	758	-110	35	221	-76	2003	2040	0	0	-2815	570	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:06:07	-5	321	319	277	492	493	322	758	-112	64	221	-79	2002	2040	0	0	-2815	579	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:06:37	-4	321	321	278	492	493	326	758	-107	47	221	-76	2001	2040	0	0	-2815	580	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:07:07	-5	321	323	279	492	493	326	756	-106	-3	221	-74	2000	2040	0	0	-2815	580	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:07:37	-4	321	324	279	492	493	323	755	-113	41	221	-79	1998	2040	0	0	-2815	580	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:08:07	-5	321	322	280	492	493	326	756	-112	60	221	-80	1997	2040	0	0	-2813	590	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:08:37	-4	321	324	280	492	493	329	756	-108	15	221	-78	1996	2040	0	0	-2813	590	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:09:07	-5	321	326	281	492	493	326	755	-111	5	221	-79	1995	2040	0	0	-2810	590	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:09:37	-5	321	325	281	491	493	325	755	-117	50	221	-83	1993	2040	0	0	-2810	590	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:10:07	-5	321	325	282	492	493	328	756	-115	61	221	-82	1991	2040	0	0	-2806	589	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:10:37	-5	321	326	282	491	493	331	756	-108	9	221	-79	1990	2040	0	0	-2806	590	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:11:07	-5	321	328	283	491	492	327	755	-111	10	221	-79	1988	2040	0	0	-2800	590	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:11:37	-5	321	327	283	491	493	327	756	-116	51	221	-83	1987	2040	0	0	-2800	591	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:12:07	-4	321	326	284	491	492	331	758	-114	57	222	-81	1986	2040	0	0	-2795	600	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:12:37	-5	321	328	285	491	492	332	756	-109	-13	221	-80	1985	2040	0	0	-2795	601	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:13:07	-5	322	329	285	492	492	329	756	-115	19	221	-81	1983	2040	0	0	-2787	600	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:13:37	-5	322	328	286	491	492	330	758	-119	54	221	-86	1982	2040	0	0	-2787	600	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:14:07	-5	322	329	286	491	492	332	759	-115	53	221	-83	1982	2040	0	0	-2781	599	-4	213	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:14:37	-5	322	330	286	491	492	333	759	-111	-24	221	-81	1981	2040	0	0	-2781	600	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:15:07	-5	322	330	287	491	492	330	759	-118	23	221	-84	1979	2040	0	0	-2773	599	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:15:37	-6	322	329	287	491	492	332	761	-121	56	221	-88	1977	2040	0	0	-2773	600	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:16:14	-6	322	329	288	491	492	334	761	-116	43	222	-86	1975	2040	0	0	-2766	600	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:16:41	-6	322	331	288	491	492	334	761	-113	-15	221	-83	1974	2040	0	0	-2766	601	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:17:11	-6	322	331	288	491	492	331	762	-120	34	222	-86	1972	2040	0	0	-2757	599	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:17:41	-6	322	330	289	491	492	333	764	-120	60	222	-88	1971	2040	0	0	-2757	599	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:18:11	-6	322	331	289	490	492	336	764	-113	54	223	-83	1969	2040	0	0	-2749	600	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:18:41	-6	322	333	289	489	492	337	763	-106	14	224	-77	1967	2040	0	0	-2749	599	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:19:11	-6	322	334	290	485	492	335	763	-107	38	225	-76	1966	2040	0	0	-2738	609	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:19:41	-6	322	334	290	478	492	336	764	-107	69	227	-75	1964	2040	0	0	-2738	609	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:20:11	-6	322	334	291	465	491	339	764	-101	65	228	-72	1961	2040	0	0	-2726	610	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:20:41	-6	322	337	291	441	491	339	763	-95	14	229	-65	1959	2040	0	0	-2726	610	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:21:11	-6	322	337	292	410	491	336	761	-99	56	230	-63	1956	2040	0	0	-2711	599	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:21:41	-6	322	335	292	374	491	338	763	-97	83	230	-61	1954	2040	0	0	-2711	600	-4	212	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:22:11	-6	322	335	309	344	491	325	762	-90	22	229	-54	1952	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:22:41	-6	322	341	334	324	491	358	766	-91	40	228	-52	1951	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:23:11	-6	322	354	341	313	491	366	770	-92	75	227	-52	1950	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:23:40	-7	322	362	345	310	491	371	775	-86	49	227	-48	1949	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:24:10	-6	322	368	350	311	490	375	776	-86	18	226	-46	1947	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:24:40	-7	322	371	349	316	490	381	780	-92	70	226	-49	1947	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:25:10	-6	322	377	349	322	490	390	785	-88	79	225	-46	1947	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:25:40	-6	322	384	349	328	489	404	787	-82	11	225	-38	1946	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:26:10	-6	322	394	351	334	489	410	790	-87	44	225	-36	1945	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:26:40	-6	322	401	353	340	489	421	796	-88	73	225	-34	1944	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:27:10	-7	322	409	355	345	489	434	799	-84	7	224	-28	1944	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:27:40	-7	322	419	357	350	489	441	803	-89	37	224	-26	1943	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:28:10	-6	322	428	359	355	489	446	808	-91	77	224	-26	1942	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:28:40	-6	322	433	362	358	490	462	814	-85	40	224	-25	1942	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:29:10	-7	322	442	364	361	489	472	818	-86	22	224	-23	1942	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:29:40	-7	322	453	366	365	489	472	823	-90	73	224	-24	1942	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:30:10	-7	322	459	369	368	489	484	831	-85	75	223	-22	1941	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:30:40	-7	322	464	371	371	489	500	836	-80	-3	223	-19	1939	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:31:17	-7	322	473	373	374	489	498	840	-87	56	223	-21	1938	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:31:44	-6	322	483	376	376	489	498	847	-85	83	223	-22	1939	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:32:14	-6	322	486	379	379	489	507	853	-78	15	223	-19	1939	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:32:44	-7	322	489	382	381	489	510	855	-82	40	223	-7	1939	2040	0	0	-2698	602	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:33:14	-7	322	494	384	384	489	506	862	-84	79	223	-6	1939	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:33:44	-7	322	497	386	386	490	513	867	-78	31	222	-6	1938	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:34:14	-8	322	497	389	388	490	519	870	-80	31	222	-7	1938	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:34:44	-7	322	501	391	390	490	514	875	-83	75	222	-9	1937	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:35:14	-7	322	504	393	393	490	519	881	-78	51	222	-10	1937	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:35:44	-8	322	504	396	395	490	525	883	-78	22	222	-10	1937	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:36:14	-8	322	507	398	397	490	520	888	-83	73	222	-13	1936	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:36:44	-7	322	511	400	400	491	524	893	-78	66	222	-13	1936	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:37:14	-8	322	511	402	402	491	532	895	-77	11	222	-14	1935	2040	0	0	-2698	600	-4	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:37:44	-8	322	513	405	404	492	526	899	-82	66	222	-17	1935	2040	0	0	-2698	601	-4	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:38:14	-8	322	517	407	406	492	530	904	-79	77	222	-19	1934	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:38:44	-8	323	516	409	409	492	537	907	-74	2	221	-17	1934	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:39:14	-8	323	518	411	411	493	536	909	-80	56	221	-21	1933	2040	0	0	-2698	600	-4	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:39:44	-8	323	523	413	413	493	535	914	-80	80	221	-23	1932	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:40:14	-8	323	523	416	415	493	539	919	-74	22	221	-21	1931	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:40:44	-8	323	524	418	418	494	539	919	-77	37	221	-21	1930	2040	0	0	-2698	600	-4	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:41:14	-9	323	527	420	420	494	533	922	-80	75	221	-23	1929	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:41:44	-8	323	525	423	421	495	535	926	-75	57	221	-23	1930	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:42:14	-8	323	523	425	423	495	539	926	-76	15	221	-21	1929	2040	0	0	-2698	600	-4	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:42:44	-8	323	524	427	425	496	530	928	-82	67	221	-23	1929	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:43:14	-8	323	524	430	428	496	533	934	-79	77	221	-23	1928	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:43:44	-9	323	521	432	430	496	540	934	-74	10	221	-22	1927	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:44:14	-9	323	523	434	432	497	536	936	-80	55	221	-23	1925	2040	0	0	-2698	600	-4	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:44:44	-9	323	527	436	434	497	536	939	-79	75	221	-25	1924	2040	0	0	-2698	601	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:45:14	-9	323	525	439	436	497	539	941	-74	30	221	-23	1922	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:45:44	-9	323	526	441	439	498	537	941	-77	33	221	-24	1920	2040	0	0	-2698	601	-4	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:46:17	-9	323	528	444	441	498	532	944	-80	71	220	-26	1918	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:46:47	-9	323	524	447	443	498	536	946	-76	67	221	-25	1917	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:47:17	-9	323	524	448	445	498	539	949	-74	12	221	-24	1915	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:47:47	-10	323	527	450	447	498	534	949	-80	57	221	-26	1914	2040	0	0	-2698	599	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:48:17	-9	323	525	453	449	499	537	952	-79	73	221	-26	1911	2040	0	0	-2698	599	-4	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:48:47	-10	323	525	455	451	499	538	954	-74	25	221	-26	1908	2040	0	0	-2698	600	-4	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:49:17	-9	323	528	458	453	499	535	954	-78	34	220	-26	1904	2040	0	0	-2698	599	-5	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:49:47	-10	323	527	461	456	499	532	957	-80	70	221	-28	1901	2040	0	0	-2698	600	-5	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:50:17	-10	323	523	463	458	499	537	960	-76	65	221	-27	1899	2040	0	0	-2698	600	-5	213	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:50:47	-10	323	525	465	460	499	537	960	-74	12	221	-26	1896	2040	0	0	-2698	601	-5	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:51:17	-10	323	527	468	462	499	532	963	-79	55	221	-28	1894	2040	0	0	-2698	601	-5	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:51:47	-10	323	523	471	464	499	536	965	-78	72	220	-29	1892	2040	0	0	-2698	599	-5	212	10	20	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:52:17	-10	323	523	352	466	499	462	959	-74	33	221	-27	1889	2040	0	0	-2698	600	-5	213	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	16:52:47	-10	323	435	262	468	499	279	931	-78	44	221	-26	1886	2040	0	0	-2698	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:53:17	-11	323	332	257	470	499	258	897	-56	67	221	-13	1883	2040	0	0	-2698	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:53:47	-10	323	283	256	471	499	256	866	-31	86	221	-3	1883	2040	0	0	-2698	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:54:17	-11	323	266	255	472	499	256	837	-16	99	221	-1	1885	2040	0	0	-2740	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:54:47	-11	323	260	254	473	498	254	814	-8	109	221	-1	1888	2040	0	0	-2740	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:55:17	-10	323	257	253	474	498	253	793	-4	118	221	-1	1893	2040	0	0	-2804	0	-5	213	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:55:47	-11	323	255	252	474	498	252	775	-2	125	221	0	1897	2040	0	0	-2804	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:56:17	-11	323	254	252	474	497	252	759	-2	129	221	-1	1902	2040	0	0	-2873	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:56:47	-11	323	253	251	475	497	251	745	-1	133	221	0	1908	2040	0	0	-2873	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:57:17	-11	324	252	251	475	497	250	733	-1	137	221	1	1914	2040	0	0	-2943	0	-5	213	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:57:47	-11	324	252	250	475	496	250	722	0	140	221	1	1919	2040	0	0	-2943	0	-5	213	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:58:17	-12	324	251	249	475	496	249	713	12	143	221	4	1924	2040	0	0	-3016	0	-5	213	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:58:47	-12	324	250	249	475	495	249	710	30	145	221	7	1929	2040	0	0	-3016	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:59:17	-12	324	250	249	475	495	249	705	49	146	221	11	1933	2040	0	0	-3090	0	-5	212	2	10	0	0	0	183	6714	10149	0	0	2940	813
2021-01-24	16:59:47	-11	324	249	249	475	495	249	699	65	149	221	14	1937	-32768	0	0	-3090	0	-5	213	2	30	0	0	0	0	6714	10149	0	0	2940	813
2021-01-24	17:00:17	-11	324	249	249	475	494	278	778	76	93	221	17	1940	-32768	0	0	-3164	599	-5	213	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:00:47	-12	324	276	250	475	494	294	835	34	89	221	1	1945	-32768	0	0	-3164	599	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:01:20	-11	324	289	251	475	494	297	829	-2	20	221	-1	1951	-32768	0	0	-3210	610	-5	213	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:01:50	-11	324	293	253	475	493	295	821	-36	75	221	-3	1957	-32768	0	0	-3210	611	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:02:20	-12	324	293	255	475	493	298	814	-53	89	221	-1	1963	-32768	0	0	-3241	620	-5	213	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:02:50	-11	324	297	257	475	493	301	804	-62	-14	221	-1	1969	-32768	0	0	-3241	620	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:03:20	-11	324	298	257	475	493	297	797	-79	34	221	-2	1975	-32768	0	0	-3268	630	-5	213	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:03:50	-12	324	297	259	475	493	299	794	-90	66	221	-3	1981	-32768	0	0	-3268	629	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:04:20	-12	324	298	260	475	493	304	788	-92	34	221	-3	1986	-32768	0	0	-3295	640	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:04:50	-11	324	302	261	475	493	302	781	-96	4	221	-5	1990	-32768	0	0	-3295	640	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:05:20	-12	324	301	262	475	492	303	780	-106	45	221	-8	1995	2065	0	0	-3317	650	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:05:50	-12	324	303	264	475	492	307	778	-107	56	221	-17	2000	2065	0	0	-3317	650	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:06:20	-12	324	305	265	474	492	310	775	-105	8	221	-37	2005	2065	0	0	-3338	659	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:06:50	-11	324	308	266	474	492	308	771	-110	10	221	-52	2008	2065	0	0	-3338	660	-5	213	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:07:20	-11	324	307	267	474	492	310	773	-117	46	221	-65	2011	2065	0	0	-3354	670	-5	213	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:07:50	-12	324	309	269	474	492	313	771	-116	50	221	-67	2015	2065	0	0	-3354	670	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:08:20	-12	324	311	270	475	492	316	769	-113	-13	221	-69	2018	2065	0	0	-3369	680	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:08:50	-12	324	313	271	474	492	313	769	-119	16	221	-74	2021	2065	0	0	-3369	681	-5	212	2	30	0	0	0	0	6715	10149	0	0	2940	813
2021-01-24	17:09:20	-11	324	312	272	474	492	316	771	-123	46	221	-78	2023	2065	0	0	-3380	690	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:09:50	-12	324	314	273	474	491	318	771	-121	38	221	-79	2025	2065	0	0	-3380	690	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:10:20	-12	324	316	274	474	491	320	769	-119	-17	222	-79	2026	2065	0	0	-3390	700	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:10:50	-11	324	317	275	473	491	318	771	-126	24	221	-83	2028	2065	0	0	-3390	699	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:11:20	-12	324	317	276	473	491	322	773	-127	44	221	-86	2029	2065	0	0	-3397	710	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:11:50	-12	324	319	277	473	491	324	773	-124	27	221	-84	2030	2065	0	0	-3397	710	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:12:20	-12	324	322	278	472	491	325	773	-123	-15	221	-83	2030	2065	0	0	-3401	720	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:12:50	-12	324	322	279	472	491	323	776	-131	27	221	-88	2030	2065	0	0	-3401	719	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:13:20	-12	324	322	280	472	491	326	778	-130	40	221	-90	2031	2065	0	0	-3403	729	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:13:50	-12	324	324	281	472	490	328	780	-127	13	221	-89	2033	2065	0	0	-3403	730	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:14:20	-12	324	326	282	472	490	328	780	-128	-5	221	-90	2034	2065	0	0	-3403	740	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:14:50	-12	324	326	282	472	490	327	783	-133	25	220	-94	2032	2065	0	0	-3403	739	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:15:20	-12	324	326	283	472	490	330	785	-133	9	220	-95	2023	2065	0	0	-3401	740	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:15:50	-12	324	328	284	471	490	329	785	-135	-24	220	-98	2013	2065	0	0	-3401	740	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:16:26	-12	325	327	285	472	490	329	789	-143	17	220	-103	2004	2065	0	0	-3397	750	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:16:53	-12	325	327	286	471	490	331	792	-142	20	220	-105	1995	2065	0	0	-3397	750	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:17:23	-12	325	329	286	471	490	332	794	-141	-34	220	-105	1986	2065	0	0	-3394	750	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:17:53	-12	325	329	287	471	490	330	797	-147	10	220	-109	1978	2065	0	0	-3394	751	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:18:23	-12	325	329	288	471	490	332	801	-148	21	220	-110	1971	2065	0	0	-3390	760	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:18:53	-12	325	330	288	471	490	334	803	-145	-26	220	-110	1963	2065	0	0	-3390	761	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:19:23	-12	325	331	289	471	490	332	805	-149	-11	220	-113	1956	2065	0	0	-3385	770	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:19:53	-13	325	331	289	471	490	333	808	-152	18	220	-115	1949	2065	0	0	-3385	770	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:20:23	-12	325	331	290	471	490	336	810	-149	-5	221	-116	1943	2065	0	0	-3379	771	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:20:53	-12	325	333	291	471	490	335	812	-150	-27	220	-116	1937	2065	0	0	-3379	770	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:21:23	-12	325	333	291	471	490	334	816	-155	11	220	-118	1931	2065	0	0	-3371	781	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:21:53	-13	325	333	292	471	490	337	818	-153	8	220	-120	1924	2065	0	0	-3371	779	-5	212	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:22:23	-13	325	335	292	471	490	337	820	-152	-44	220	-120	1916	2065	0	0	-3363	781	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:22:53	-13	325	334	293	471	490	335	823	-159	0	220	-124	1909	2065	0	0	-3363	781	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:23:23	-12	325	334	293	471	490	338	825	-158	16	220	-125	1903	2065	0	0	-3354	779	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:23:53	-13	325	336	293	470	490	340	827	-154	-34	220	-124	1897	2065	0	0	-3354	780	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:24:23	-13	325	337	293	471	489	338	829	-157	-20	220	-125	1890	2065	0	0	-3343	790	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:24:53	-13	325	336	294	470	490	338	832	-160	8	220	-128	1883	2065	0	0	-3343	790	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:25:23	-13	325	337	294	470	490	340	834	-158	-3	220	-128	1877	2065	0	0	-3332	790	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:25:53	-13	325	338	294	470	490	341	835	-156	-45	220	-126	1872	2065	0	0	-3332	790	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:26:23	-13	325	338	295	470	489	338	837	-162	-8	220	-129	1866	2065	0	0	-3319	790	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:26:53	-13	325	337	295	470	489	340	839	-163	2	220	-131	1860	2065	0	0	-3319	791	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:27:23	-13	325	338	296	470	489	342	841	-159	-44	220	-131	1855	2065	0	0	-3307	791	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:27:53	-13	325	339	296	470	489	339	841	-163	-23	220	-132	1849	2065	0	0	-3307	790	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:28:23	-14	325	338	296	470	489	340	845	-167	4	220	-135	1843	2065	0	0	-3293	789	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:28:53	-13	325	338	297	470	489	343	847	-163	-9	220	-135	1837	2065	0	0	-3293	790	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:29:23	-13	325	340	297	470	489	343	847	-161	-43	220	-133	1831	2065	0	0	-3280	790	-5	213	2	30	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:29:53	-14	325	340	317	469	489	339	849	-166	-7	221	-136	1826	2065	0	0	-3280	790	-5	213	10	20	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:30:23	-13	325	375	413	470	489	443	870	-162	-40	220	-135	1820	2065	0	0	-3280	790	-5	213	10	20	0	0	0	0	6715	10150	0	0	2940	813
2021-01-24	17:30:53	-13	325	426	436	468	489	461	877	-157	-22	221	-132	1815	2065	0	0	-3280	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:31:30	-13	325	443	317	467	489	389	844	-135	11	221	-115	1811	2065	0	0	-3280	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:31:57	-13	325	407	291	465	489	290	812	-99	38	221	-81	1807	2065	0	0	-3280	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:32:27	-13	325	331	293	464	489	293	785	-65	59	221	-46	1804	2065	0	0	-3208	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:32:56	-13	325	304	293	463	489	294	761	-37	77	221	-24	1801	2065	0	0	-3208	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:33:26	-14	325	296	293	462	489	294	741	-19	90	222	-11	1799	2065	0	0	-3230	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:33:56	-14	325	293	292	462	489	293	724	-9	101	221	-3	1798	2065	0	0	-3230	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:34:26	-14	325	292	291	461	489	291	698	-5	112	221	-1	1797	2065	0	0	-3262	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:34:56	-13	325	292	289	461	489	290	671	-3	121	222	-1	1797	2065	0	0	-3262	0	-5	214	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:35:26	-14	325	290	287	461	488	288	648	-1	128	222	-1	1797	2065	0	0	-3296	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:35:56	-14	325	288	286	461	488	286	631	0	136	222	-1	1797	2065	0	0	-3296	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:36:26	-14	325	286	285	460	488	285	616	10	144	222	0	1796	2065	0	0	-3333	0	-5	214	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:36:56	-14	325	285	284	460	488	284	606	27	149	222	2	1795	2065	0	0	-3333	0	-5	213	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:37:26	-14	325	284	283	460	488	283	600	49	151	222	8	1794	2065	0	0	-3373	0	-5	214	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:37:56	-14	325	283	283	460	488	283	596	68	152	222	16	1794	2065	0	0	-3373	0	-5	214	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:38:26	-15	325	283	282	460	488	282	592	83	152	222	26	1793	2065	0	0	-3415	0	-5	214	2	10	0	0	0	183	6715	10150	0	0	2940	813
2021-01-24	17:38:56	-15	325	283	378	460	488	355	587	94	153	222	38	1793	-32768	0	0	-3415	0	-5	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:39:26	-14	325	355	412	459	488	446	775	80	50	222	32	1797	-32768	0	0	-3415	790	-6	213	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:39:56	-14	325	423	437	458	488	476	821	26	22	222	7	1808	-32768	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:40:26	-15	325	459	452	456	486	488	840	-18	70	222	-5	1822	-32768	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:40:56	-15	325	477	459	454	486	497	861	-42	74	222	-1	1836	-32768	0	0	-3415	789	-6	213	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:41:26	-15	325	488	464	453	486	503	875	-56	11	222	-2	1850	-32768	0	0	-3415	790	-6	213	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:41:56	-15	325	493	466	453	486	507	889	-73	48	222	-3	1862	-32768	0	0	-3415	789	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:42:26	-15	325	498	469	453	486	511	904	-79	44	222	-3	1873	-32768	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:42:56	-15	325	502	472	454	486	516	916	-83	27	222	-4	1884	-32768	0	0	-3415	790	-6	213	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:43:26	-15	325	505	475	455	488	518	926	-88	29	222	-6	1895	-32768	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:43:56	-15	325	507	478	457	488	520	938	-92	33	222	-8	1905	2044	0	0	-3415	791	-6	213	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:44:26	-15	325	511	481	459	488	522	948	-94	34	222	-13	1914	2044	0	0	-3415	791	-6	213	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:44:56	-15	325	513	484	461	489	525	957	-95	32	221	-26	1921	2044	0	0	-3415	790	-6	213	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:45:26	-15	325	515	488	463	489	527	965	-96	29	221	-44	1928	2044	0	0	-3415	789	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:46:02	-15	325	517	490	465	490	528	974	-97	31	222	-52	1935	2044	0	0	-3415	789	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:46:29	-15	325	519	493	467	490	530	982	-98	32	221	-57	1941	2044	0	0	-3415	789	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:46:59	-15	325	520	496	470	491	532	991	-99	34	221	-61	1947	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:47:29	-16	325	521	499	472	491	533	997	-98	32	221	-63	1952	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:47:59	-15	325	523	501	474	492	533	1004	-98	30	221	-63	1957	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:48:29	-16	325	523	504	477	492	534	1011	-98	32	221	-65	1962	2044	0	0	-3415	788	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:48:59	-15	325	524	507	479	493	535	1017	-98	34	221	-65	1966	2044	0	0	-3415	791	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:49:29	-15	325	525	509	481	493	536	1022	-98	32	221	-65	1971	2044	0	0	-3415	788	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:49:59	-16	325	528	512	483	493	538	1029	-98	32	221	-65	1975	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:50:29	-16	325	529	514	485	494	539	1034	-98	32	221	-66	1978	2044	0	0	-3415	788	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:50:59	-16	325	530	515	488	494	541	1039	-98	32	221	-67	1980	2044	0	0	-3415	791	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:51:29	-16	325	532	517	490	495	543	1043	-97	30	221	-66	1983	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:51:59	-16	325	534	519	491	496	545	1049	-98	29	221	-67	1984	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:52:29	-16	325	535	520	493	497	546	1052	-98	33	221	-67	1987	2044	0	0	-3415	789	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:52:59	-16	325	537	521	494	498	547	1056	-98	35	221	-67	1989	2044	0	0	-3415	791	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:53:29	-17	325	538	523	495	500	549	1062	-97	35	220	-67	1990	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:53:59	-17	325	540	524	496	501	551	1066	-97	35	221	-67	1991	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:54:29	-16	325	542	526	498	502	553	1070	-96	34	221	-67	1993	2044	0	0	-3415	790	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:54:59	-16	325	543	528	499	503	554	1074	-95	32	220	-67	1994	2044	0	0	-3415	789	-6	214	10	20	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:55:29	-17	326	545	512	500	505	557	1074	-95	32	220	-67	1995	2044	0	0	-3415	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:55:59	-16	326	506	275	501	506	321	1049	-113	44	220	-75	1997	2044	0	0	-3415	790	-6	214	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:56:29	-17	326	372	260	503	507	311	1025	-120	1	220	-83	1998	2044	0	0	-3415	790	-6	214	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:56:59	-17	326	328	261	504	508	307	1001	-124	-17	220	-86	2001	2044	0	0	-3415	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:57:29	-17	326	314	262	505	509	308	984	-135	16	220	-95	2002	2044	0	0	-3415	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:57:59	-17	326	311	262	506	510	313	966	-137	-28	220	-98	2003	2044	0	0	-3415	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:58:29	-17	326	312	264	507	510	312	952	-143	-8	220	-103	2005	2044	0	0	-3430	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:58:59	-17	326	312	265	507	511	314	942	-148	19	220	-106	2006	2044	0	0	-3430	790	-6	214	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:59:29	-17	326	313	265	508	511	316	930	-146	1	220	-105	2007	2044	0	0	-3444	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	17:59:59	-17	326	315	267	508	511	316	920	-146	-15	220	-107	2007	2044	0	0	-3444	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:00:29	-18	326	315	269	508	511	316	911	-149	11	220	-110	2007	2044	0	0	-3455	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:01:06	-17	326	316	271	508	511	319	904	-148	12	220	-109	2007	2044	0	0	-3455	790	-6	214	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:01:33	-18	326	318	273	508	511	322	896	-146	-10	220	-108	2007	2044	0	0	-3465	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:02:03	-17	326	321	275	508	511	323	889	-147	0	220	-110	2006	2044	0	0	-3465	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:02:33	-17	326	322	278	508	511	325	883	-148	9	220	-110	2005	2044	0	0	-3470	791	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:03:03	-18	326	324	279	508	511	328	879	-147	0	220	-110	2005	2044	0	0	-3470	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:03:33	-17	326	326	281	508	511	329	873	-146	-12	220	-110	2004	2044	0	0	-3472	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:04:03	-17	326	327	282	508	511	329	870	-149	0	220	-113	2003	2044	0	0	-3472	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:04:33	-17	326	328	284	509	511	331	866	-150	5	220	-114	2002	2044	0	0	-3470	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:05:03	-18	326	329	285	508	511	332	864	-150	-8	220	-116	2001	2044	0	0	-3470	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:05:33	-18	326	330	285	508	511	332	860	-150	-6	220	-116	2000	2044	0	0	-3467	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:06:03	-18	326	330	286	508	511	332	859	-151	9	220	-116	1999	2044	0	0	-3467	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:06:33	-18	326	331	287	508	511	333	858	-150	2	220	-116	1998	2044	0	0	-3463	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:07:03	-18	326	332	288	508	510	335	853	-148	-16	220	-116	1996	2044	0	0	-3463	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:07:32	-18	326	332	289	508	510	334	853	-151	-4	220	-118	1994	2044	0	0	-3457	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:08:02	-18	326	332	289	508	510	335	851	-152	9	220	-118	1992	2044	0	0	-3457	791	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:08:32	-18	326	333	290	508	510	336	851	-150	-8	220	-117	1990	2044	0	0	-3451	791	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:09:02	-18	326	335	291	508	510	336	849	-150	-14	220	-118	1988	2044	0	0	-3451	791	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:09:32	-18	326	334	291	508	510	336	849	-153	8	220	-121	1986	2044	0	0	-3442	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:10:02	-18	326	335	292	508	509	338	849	-151	2	220	-120	1984	2044	0	0	-3442	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:10:32	-18	326	336	293	508	509	339	847	-149	-13	220	-118	1982	2044	0	0	-3433	789	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:11:02	-19	326	337	293	508	509	338	847	-151	-7	220	-120	1979	2044	0	0	-3433	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:11:32	-18	326	337	293	508	509	339	847	-152	2	220	-121	1976	2044	0	0	-3422	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:12:02	-18	326	337	293	507	509	340	845	-151	-6	220	-121	1973	2044	0	0	-3422	791	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:12:32	-19	326	338	294	507	509	341	845	-150	-13	220	-121	1971	2044	0	0	-3411	790	-6	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:13:02	-19	326	339	294	507	509	340	845	-152	-4	220	-121	1968	2044	0	0	-3411	790	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:13:32	-19	327	339	295	506	509	341	845	-153	1	220	-124	1965	2044	0	0	-3398	790	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:14:02	-19	327	339	296	505	509	342	845	-152	-8	220	-124	1961	2044	0	0	-3398	789	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:14:32	-18	327	340	296	505	509	342	845	-152	-9	220	-124	1958	2044	0	0	-3386	790	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:15:02	-19	327	341	297	504	509	343	845	-152	-6	220	-125	1955	2044	0	0	-3386	789	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:15:32	-19	328	341	297	503	509	343	845	-153	-5	220	-126	1952	2044	0	0	-3372	789	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:16:06	-18	328	341	297	502	508	343	845	-153	-6	220	-126	1949	2044	0	0	-3372	790	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:16:36	-19	328	342	298	501	508	344	845	-153	-6	220	-126	1946	2044	0	0	-3359	790	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:17:06	-19	328	342	298	501	508	344	845	-153	-7	220	-128	1942	2044	0	0	-3359	791	-7	215	2	30	0	0	0	0	6716	10150	0	0	2940	813
2021-01-24	18:17:36	-19	328	342	299	500	508	345	845	-153	-8	220	-129	1939	2044	0	0	-3345	790	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:18:06	-19	328	343	299	499	508	345	845	-153	-12	220	-129	1934	2044	0	0	-3345	790	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:18:36	-19	328	343	299	499	508	345	845	-154	-12	220	-129	1930	2044	0	0	-3330	789	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:19:06	-19	328	343	300	498	508	345	845	-155	-10	220	-130	1925	2044	0	0	-3330	790	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:19:36	-19	328	344	300	498	508	346	846	-156	-9	220	-132	1922	2044	0	0	-3315	789	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:20:06	-19	328	344	301	498	508	346	847	-156	-8	220	-132	1920	2044	0	0	-3315	790	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:20:36	-19	328	344	301	498	508	347	847	-156	-8	220	-132	1916	2044	0	0	-3299	791	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:21:06	-20	328	345	301	497	508	347	847	-156	-10	220	-131	1912	2044	0	0	-3299	790	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:21:36	-20	328	345	302	497	508	347	847	-156	-12	220	-131	1908	2044	0	0	-3283	790	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:22:06	-20	328	345	301	497	508	316	833	-147	2	220	-126	1903	2044	0	0	-3283	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:22:36	-20	328	329	300	496	508	301	803	-120	28	220	-98	1899	2044	0	0	-3266	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:23:06	-19	328	311	300	496	508	300	775	-86	49	220	-62	1897	2044	0	0	-3266	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:23:36	-20	328	303	299	496	508	299	750	-56	67	220	-32	1897	2044	0	0	-3285	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:24:06	-20	328	300	298	495	508	298	730	-33	82	221	-14	1901	2044	0	0	-3285	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:24:36	-20	328	299	297	495	508	297	717	-18	94	221	-6	1904	2044	0	0	-3313	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:25:06	-20	328	297	296	495	508	296	705	-9	103	221	-1	1908	2044	0	0	-3313	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:25:36	-20	328	296	294	495	508	295	694	-5	111	221	-1	1911	2044	0	0	-3344	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:26:06	-20	328	295	293	494	508	293	684	-3	117	221	-1	1915	2044	0	0	-3344	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:26:36	-20	328	293	292	494	507	292	671	-2	123	221	-1	1919	2044	0	0	-3378	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:27:06	-20	328	292	291	494	507	291	655	-1	130	221	-1	1922	2044	0	0	-3378	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:27:36	-20	328	291	290	493	507	290	640	1	139	221	-1	1925	2044	0	0	-3414	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:28:06	-20	328	290	289	493	507	289	627	11	146	221	2	1928	2044	0	0	-3414	0	-7	215	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:28:36	-20	328	289	288	493	507	288	616	30	150	221	12	1930	2044	0	0	-3452	0	-7	216	2	10	0	0	0	183	6716	10151	0	0	2940	813
2021-01-24	18:29:06	-20	328	288	287	493	507	287	607	52	152	221	25	1933	-32768	0	0	-3452	0	-7	215	2	30	0	0	0	0	6716	10151	0	0	2940	813
2021-01-24	18:29:36	-20	328	287	287	492	507	287	612	71	149	221	37	1935	-32768	0	0	-3492	598	-7	215	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:30:06	-21	328	300	286	492	507	341	758	46	58	221	19	1937	-32768	0	0	-3492	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:30:36	-20	328	327	284	492	507	340	768	-2	76	221	0	1941	-32768	0	0	-3516	791	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:31:13	-21	328	333	283	492	507	336	768	-36	1	221	-3	1946	-32768	0	0	-3516	789	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:31:43	-21	328	333	284	491	507	332	768	-68	5	220	-2	1951	-32768	0	0	-3510	790	-7	215	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:32:10	-21	328	330	285	491	506	331	771	-92	30	220	-3	1958	-32768	0	0	-3510	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:32:40	-21	328	329	286	491	506	332	773	-104	-25	220	-5	1964	-32768	0	0	-3508	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:33:10	-21	329	329	286	490	506	329	776	-119	12	220	-8	1969	-32768	0	0	-3508	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:33:40	-21	329	328	287	490	506	332	781	-126	27	220	-13	1975	-32768	0	0	-3508	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:34:09	-21	329	329	288	490	506	333	785	-127	-22	220	-34	1979	-32768	0	0	-3508	789	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:34:39	-21	329	330	289	490	506	332	788	-135	2	220	-59	1983	2036	0	0	-3507	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:35:09	-21	329	330	290	489	506	333	792	-139	24	220	-76	1986	2036	0	0	-3507	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:35:39	-21	329	331	291	489	506	336	796	-137	-26	220	-83	1989	2036	0	0	-3506	790	-7	215	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:36:09	-21	329	333	292	489	506	333	799	-143	-7	220	-91	1993	2036	0	0	-3506	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:36:39	-20	329	332	292	488	506	336	803	-146	29	220	-98	1997	2036	0	0	-3502	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:37:09	-21	329	334	293	488	506	339	807	-142	20	220	-98	1999	2036	0	0	-3502	789	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:37:39	-21	329	337	293	488	506	339	808	-141	-35	220	-98	2001	2036	0	0	-3496	789	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:38:09	-22	329	336	294	488	506	337	812	-147	16	220	-105	2003	2036	0	0	-3496	789	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:38:39	-21	329	337	294	487	506	341	816	-146	29	220	-104	2004	2036	0	0	-3489	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:39:09	-22	329	339	295	486	506	343	818	-141	-8	220	-103	2006	2036	0	0	-3489	791	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:39:39	-21	329	340	295	486	506	341	820	-142	-5	220	-103	2007	2036	0	0	-3479	789	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:40:09	-21	329	339	296	486	506	342	822	-145	21	220	-107	2008	2036	0	0	-3479	790	-7	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:40:39	-21	329	340	296	485	506	344	823	-142	8	221	-105	2008	2036	0	0	-3469	791	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:41:09	-22	329	341	297	485	506	344	823	-142	-12	220	-105	2007	2036	0	0	-3469	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:41:39	-21	329	341	297	485	506	343	825	-146	15	220	-108	2007	2036	0	0	-3457	790	-8	215	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:42:09	-21	329	341	298	484	506	345	827	-144	10	220	-108	2007	2036	0	0	-3457	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:42:39	-22	329	342	298	484	506	346	829	-143	-7	220	-108	2008	2036	0	0	-3445	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:43:09	-22	329	343	299	484	506	345	829	-144	5	220	-110	2007	2036	0	0	-3445	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:43:39	-22	329	343	299	484	506	346	831	-145	9	220	-110	2006	2036	0	0	-3431	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:44:09	-22	329	344	299	483	506	347	831	-144	-12	220	-110	2005	2036	0	0	-3431	789	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:44:39	-22	329	344	300	483	506	346	832	-146	-2	221	-113	2004	2036	0	0	-3416	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:45:09	-22	329	344	300	483	506	347	833	-148	11	221	-116	2003	2036	0	0	-3416	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:45:39	-22	329	345	301	483	506	348	835	-146	-1	220	-114	2001	2036	0	0	-3401	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:46:15	-22	329	346	301	482	506	348	835	-146	-8	220	-114	1999	2036	0	0	-3401	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:46:42	-22	329	346	302	482	506	348	836	-148	3	220	-116	1998	2036	0	0	-3384	791	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:47:12	-22	329	346	302	482	506	349	837	-148	4	220	-117	1997	2036	0	0	-3384	790	-8	215	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:47:42	-22	329	347	302	482	506	350	837	-147	-12	220	-116	1996	2036	0	0	-3367	791	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:48:12	-22	329	347	303	481	506	349	839	-149	-6	221	-118	1995	2036	0	0	-3367	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:48:42	-22	329	347	303	481	506	349	839	-151	8	221	-121	1994	2036	0	0	-3349	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:49:12	-22	329	347	303	481	506	350	841	-149	1	220	-119	1992	2036	0	0	-3349	789	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:49:42	-22	329	348	303	481	506	351	841	-148	-10	220	-118	1992	2036	0	0	-3331	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:50:12	-22	329	348	304	480	506	350	841	-149	-2	221	-120	1990	2036	0	0	-3331	790	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:50:42	-23	329	348	304	480	506	351	843	-150	6	220	-121	1989	2036	0	0	-3312	789	-8	216	2	30	0	0	0	0	6717	10151	0	0	2940	813
2021-01-24	18:51:12	-23	329	348	304	480	506	351	843	-149	1	220	-121	1987	2036	0	0	-3312	790	-8	215	2	30	0	0	0	0	6717	10151	0	0	2940	813
