Ny mjukvara släppt idag.
Den kommer minska på on/off på kompressorn i mellanläget när värmebehovet är lågt. Färre starter helt enkelt!
Det verkar dock tagit bort Fläktsynkdriften som jag lärt mig gilla faktiskt...
Software
Version: 8129R5
Publication date: 19/10/2017
F370_v8129R5.nibe
Ladda ner från nibeuplink.com
Version: 8129R5 Release date: 19/10/2017
Added
• New function AUX-relay: Outdoor air valve. Provides the possibility of using the accessory BSA10 to block supply air heating during summertime to the supply air battery.
Changes
• Increased hysteres between start and stop of the compressor in heating mode. Stop of the compressor changed to calculated flow temp +8K (earlier +3K). Gives a longer operation time for the compressor while the heating demand is small or absent and eliminates the risk of alarm 229 (short operation time).
Version: 8129R2 Release date: 14/06/2017
Added
• Åland added in the country selection menu
• Soft output (AUX) status is now shown in the service info 3.1, only its function was shown before
• SMS is now sent when a Filter alarm occurs
• Alarm 229, short operation time compressor, added
• It is now possible to choose the amount of pulses/kWh or energy/puls for external energy meter
• EME20 added as accessory
• Regulation of a outdoor air damper can be chosen through AUX-output
Changes
• Improved function for Smart Price Adaption in Estonia and Finland
