Varning - medan du läste inläggen, hann 14 nya svar postas i ämnet. Du kanske bör se över ditt inlägg.
Skrivet av: dala318
« skrivet: 15 juli 2023, 14:56:04 »
Hi, have a H66 up and running but since I have a lot of other ESPHome devices I would like to go over to integrate my Rego600 that way.
Wrote this component https://github.com/dala318/esphome-rego600 but it fails to get the expected response as seen in issue #5.
Have read through this forum but failed to find a connection drawing with only an ESP32/8266 and a TTL level converter. Is that because it won't work?
Skrivet av: Rob Polly
« skrivet: 22 december 2022, 13:53:14 »
Hi Fulda,
First of all thx for all the effort you put into the ReGo 6xx interfacing topic.
Being confronted with the higher energy prices, I moved to a dynamic pricing provider Tibber in The Netherlands.
I recently acquired a H60 to optimize my IVT Greenline C4. After initial contact with Peter Hansson, the H60 supposed to work with the Rego604 v3.04 firmware. Seems however that the H1 interface on the H60, is unable to read some of the read-only (0001-000B and 1A01-1A07) registers correctly. The write registers however can the read and set.
Peter Hansson indicated that he has seen that problem for the ReGo604 before, but does know how to solve it. To me it seems that the interface between the H1 to ReGo604 is working, but for some registers the wrong (Dutch) arguments or addresses might be used?
Do you, or anybody in this threat, have a clue if and how this could be solved for the ReGo604 running v3.04?
Thx,
Rob
Skrivet av: fulda
« skrivet: 11 januari 2022, 15:38:50 »
Sorry for the stupid question, but is a USB-serial converter like this suitable?
https://www.aliexpress.com/item/32829882277.html
ch340 based optocouler for ttl 3.3/5v conversion.
I happen to have one and would prefere not building one, if I can avoid it.
Tnx.
Simply - NO
This one not inverting TxD and do some tricks with power.
Once you are looking for USB connection, you can buy something like THIS or THIS. You have to build optocoupler part (as it is non-standard).
Do not forget, that you will have limited cable length. USB cable is "long one", rego side must be as short as possible.
Skrivet av: GregS
« skrivet: 10 januari 2022, 11:14:18 »
https://www.aliexpress.com/item/32829882277.html?spm=a2g0o.productlist.0.0.3e1459e3ZAUdNg&algo_pvid=73f584c6-e026-4262-9158-f16b1f24c93e&algo_exp_id=73f584c6-e026-4262-9158-f16b1f24c93e-30&pdp_ext_f=%7B%22sku_id%22%3A%2265022245702%22%7D&pdp_pi=-1%3B77.03%3B-1%3B-1%40salePrice%3BSEK%3Bsearch-mainSearch
Tnx.
Skrivet av: fulda
« skrivet: 19 december 2021, 18:01:40 »
OK, section with ESP-01 wifi module is available http://rago600.sourceforge.net/#ESP
Skrivet av: fulda
« skrivet: 16 december 2021, 21:16:17 »
Hello all,
I re-work basic schematic a little. This one is much better than original one.
See figure 1b on page: http://rago600.sourceforge.net/
I prepared chapter for my ESP-01 wifi module, but it take a time to add all materials.
Skrivet av: Boilerplate4U
« skrivet: 20 oktober 2021, 18:41:34 »
Jag kunde inte hitta det officiella modbus-protokollet i den här tråden så jag bifogar den senaste versionen jag fick från IVT-supporten ("Modbus protokoll 5003 v1.4-1-01 2010-05-04.pdf ").
För den som är intresserade kanske det finns användbar info i Husdatas implementation i följande länk: https://otillåten_länk/Download/o309fq2jio/H1%20Manual%2020.01.pdf
Skrivet av: Rickard
« skrivet: 20 oktober 2021, 10:28:06 »
Nice.
I mean that not even optocouplers fully protect against the risks of transients from lightning strikes, that is at least my experience.
But as usual, it is up to the readers to decide if they are willing to take the risk, IF it exists.
Skrivet av: fulda
« skrivet: 20 oktober 2021, 09:10:05 »
Is there built in protection for static electricity and/or thunder and lightning?
I'm not sure I did not miss any point? Can not believe that question is coming from someone who acting as professional.
But my answer is YES, the heatpump is connected using optical interface.
I would recommend  .,;- read before write. in all this thread average once per page is question, if optical interface can be avoided followed by answer, that NO, IT IS NOT POSSIBLE TO SKIP OPTICAL ISOLATION.
Skrivet av: Rickard
« skrivet: 20 oktober 2021, 08:06:09 »
If not, you should all be ware of the increased risk of broken circuit boards and communication devices / computers when attaching external devices with different potentials then the heat pump has.
This is one of many resaons we decided not to attach our Dataloggers to any heatpump interfaces. https://www.energibutiken.se/sv/2-datalogger
And, i think this is one of the reasons heat pump maufacturers has been hesitating to put this kind of interfaces in there devices.
Maybe they have solved most of this problems, i dont know, but i know it needs to be really  great protection in order to avoid this kind of problems.
As one example, i can tell you about all the temp sensors we sell in our web store right now, when the home heating systems are fired up, home owners notice their outdoor sensors has broken due to lighning during summer season.
I guess similar trends can be seen on heatpump circuite boards not working after summer season. especially on heat pumps connected to one or more different stand-alone systems with their own voltage supply.
Skrivet av: fulda
« skrivet: 19 oktober 2021, 21:06:51 »
OK, roughly
My design is more maybe complicated than necessary. I was put ESP-01 on top of heatpump. Inside is not good wifi signal.
I split my device to two parts. Bottom is usual converter with full RS-232 interface, (to be enough noise resistant).
That one as is described here: http://rago600.sourceforge.net/ivt_serial.gif
It is connected by FTP cable to second part (I scar about electric noise from relays and motors).
Second part contain again RS-232 level converter max232 (I had no 3V3 version, than standard one is used + voltage divider), power source by LF33CV and ESP-01 module.
See attached *.ino file. It is very easy, just read every 2 minutes all registers and send them as GET parameters to my grapher on PC.
Skrivet av: lovschal
« skrivet: 19 oktober 2021, 17:44:56 »
Hello Fulda,
I really like Your work and would like to know more about Your ESP-01 project, as I do have this controller in my summerhouse, and are currently adding remote surveillance and control to the house.
So please send me the info You wrote about. It will be greatly appreciated.
Thanks in advance.
Best regards
Lovschal
Skrivet av: fulda
« skrivet: 18 oktober 2021, 14:08:42 »
One small note for those, who trying to connect directly various commercial USB <-> serial convertors or raspberry PI or some other devices like this.
Interface as presented on service connector is not symmetric. One pin is 3V3 (Rx) and one is 5V (Tx) logic, one is inverted (Tx) and second is positive (Rx) logic.
It mean, that to fulfil needs of interface, you need at minimum two inverters (for example two gates of 74HC00; 74HC04 or equivalent) plus logic level converter (at minimum two resistors).
The problem of hardware described at http://rago600.sourceforge.net/ is, that it use optocouplers with wide range of CTR (100-500 %). That mean, you need to adjust resistors R4 and R5 to tailor optocoupler you received. It can be easiest to build at home, using optocouplers with not that wide range. For example PC827-C by Sharp (with CTR: 200-400%). But here is no one interested so much, and for me it mean extra cost, then I do not continue in this part of development.
Skrivet av: fulda
« skrivet: 18 oktober 2021, 13:34:45 »
Hello group.
It look like some time moved forward and I was enforced to done small upgrades of my device. (in meaning interface)
I changed interface to use ESP-01 programmed by Arduino IDE.
I have WiFi connection and can more easily exchange data with my heatpump.
If anyone interested, let me know and I will share all I did.
Skrivet av: annerborn
« skrivet: 23 april 2020, 20:23:54 »
Valde en annan väg istället för HomeLynken, det blev ett arduinogränssnitt istället.
Nu ska man bra skriva ihop lite kod för att prata med Regon.. Någon som gjort detta på Arduino tidigare? :)
Hej sx3000!
Jag tänkte göra detsamma.
Fick du ihop någon arduinokod?
/ Nicke
Skrivet av: sjoste01
« skrivet: 17 januari 2017, 18:11:55 »
Någon som har labview-koden kvar? Jag vet att det är en gammal tråd...
Hejsan!
Som jag nämnt tidigare har jag snickrat ihop en LabVIEW variant baserad på Fuldas eminenta arbete/utforskningar. Jag har fått lite förfrågningar på denna .vi och tänkte att det kunde vara lika bra att lägga ut detta på forumet.
LV projektet kan laddas ner från:
http://data.fuskbugg.se/dipdip/Logger Beta1.llb
I denna hittar ni Logger8.vi som det bara är att klicka på så startar hela programmet. OBS ni måste ha LW 8.5 eller senare!
Obs, jag är ingen programmerare (-> inte så strukturerad programmering) och har snickrat ihop denna .vi på några kväller tidigare i år. D.v.s. detta är en mycket preliminär .vi som antagligen innehåller en del buggar mm och körs på egen risk!
I alla fall så har jag kört denna .vi 10 månader sedan i ~ februari 2010 utan problem (mest irriterande bug är att tidsskalan på grafen långsamt blir mer och mer fel).
Jag har tyvärr heller ingen större möjlighet för supporta, förklaring etc. eftersom jag inte har så mycket tid, och faktiskt antagligen börjar glömma hur jag gjorde mm.
Dock om denna eller delar av denna kod uppdateras / förbättras så berätta gärna :-) Pss om den sprids vidare mm
Tips för att komma igång:
I fliken "Settings and monitor"
* så måste man mata in vilken COM port som tilldelats REGOn.
* Här kan man tala om vart dump/loggfilerna skall hamna och heta.
* Här kan man mata in en FTP adress för HTML graf + data generering (via inbyggd FTP).
* Här kan man mata in e-mail uppgifter om man vill ha email om ett larm har gått.
I fliken "VP Graph" visas de intressanta parametrarna i en graf.
Lycka till och berätta gärna hur det går!
Skrivet av: sx3000
« skrivet: 31 augusti 2016, 20:42:44 »
Mega 2560 med 4 serieportar, varav två anslutningar har optokopplare på en protoshield.
Ena serieporten kommer gå till Regon, andra serieporten kommer gå till en KNX busskopplare, så arduinon kommer få vara en gateway.
Halloj,
Finns det någon komplett lista på adresser och register etc. för Rego 637? (Tror det är 637, the Greenline HT+ C9 från 2007)
Jag tänkte försöka integrera Regon med KNX och visualisera på en panel.
Jag har en multifunktions gateway (Schneider HomeLynk) som bl.a har RS232 (Tx, Rx, GND).
Så jag antar att jag behöver en TTL ==> RS232 omvandlare i mellan.
Eftersom Fuldas program inte fungerar då jag inte kommer köra en PC så behöver jag en lista på adresser/register och allt vad som kan vara intressant så att jag kan få upp siffrorna på min panel.
Tack på förhand!
Skrivet av: PierLar
« skrivet: 01 april 2016, 08:46:21 »
Jag funderar på att bygga ett interface. Funkar detta på Raspberry Pi oxå? eller måste man hålla sig till windows PC?
Min tanke är att köra lite automation med Domoticz via rpi:n
Skrivet av: jidr
« skrivet: 04 mars 2016, 15:35:57 »
Tänkte fel ang priset, den är ju klart billigare.  Kolla med Husdata, kanske det går att köpa enbart omvandlaren utan programvara ?
Jag var så insnöad på deras H10 att jag inte läst ordentligt. De har två varianter på anslutning som skulle passa mig
H1 Interface, lösa, kallade de dem (försökte lägga in en link med det verkar inte ha gått).
Lite dyrare, men garanterat att det fungerar. Lite lockande. Tack för att du fick mig att läsa lite mer noga, vill att det ska gå fort så jag läser inte alltid så noga :)
Skrivet av: Håkke
« skrivet: 04 mars 2016, 14:08:32 »
Ja saken är ju att jag är ute efter kopplingen utan att betala för loggningsprogrammet. Den omvandlare jag länkade till kostar ~350kr medan husdatas lösning kostar 1195kr men då betalar och får jag programvara jag är ointresserad av.
Men tack för att du påtalade hur viktig galvanisk separaion är, då är jag lite mer med i diskussionen om optokopplare och varför folk bygger egna kopplingar, ser ut som att jag får bygga en egen eller skita i hela grejen. Om ingen har en husdata H10 liggandes till salu.
Tror det skall funka ändå för dig tipo874, för att skona elektroniken kan det vara bra att dra en separat jord mellan enheterna innan de kopplas ihop.
Skrivet av: tipo874
« skrivet: 04 mars 2016, 11:24:53 »
Här är en som jag väntar på:
http://www.ebay.com/itm/310676792112?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Den är ju knappast galvaniskt skiljd, men det kanske man kan fixa själv?
Jag skall använda den för att uppgradera ett par gamla routrar till OpenWrt.
Skrivet av: jidr
« skrivet: 04 mars 2016, 11:04:42 »
Det viktiga är att det är galvaniskt separation mellan TTL och RS-232 , detta för att skydda elektroniken i Rego , vilken är känslig.  Priset för omvandlaren du länkade till blir ju klart dyrare än vad Hus-data tar för sin omvandlare inkl loggnings program
Skrivet av: Håkke
« skrivet: 03 mars 2016, 23:11:21 »
Om jag har förstått rätt så är det inte ett RS-232 interface som sitter i Rego6xx, utan ett TTL 5v med db9-kontakt?
Jag är lite tveksam till att löda ihop en själv, kan en sådan här adapter fungera?
http://www.rs232-converters.com/single_usb_to_ttl_converter.htm
Skrivet av: jidr
« skrivet: 03 mars 2016, 14:26:22 »
Skrivet av: sx3000
« skrivet: 05 februari 2016, 22:37:17 »
Halloj,
Tack på förhand!
Skrivet av: purjo__
« skrivet: 21 januari 2016, 08:57:18 »
Förmodligen. Sen skall du ha en dator som tolkar datat och sparar undan saker...
Skrivet av: MrMartin
« skrivet: 21 januari 2016, 08:46:20 »
Ok, ja det är nog enklast så.
Jag hittade en billigare variant på ebay, den borde väl också fungera?
Jag ska kanske starta en ny tråd med mina frågor och funderingar.
Skrivet av: purjo__
« skrivet: 20 januari 2016, 22:42:32 »
Rent tekniskt skulle det säkert gå, men jag vet inte hur enkelt det är.
Det finns färdiga 'generiska' interface att köpa.  T ex http://www.lawicel-shop.se/prod/LAWICEL-CANUSB-Adapter_87941/CAN_8895/SWE/SEK
« skrivet: 20 januari 2016, 21:10:08 »
Ok, tack för svar  tummenupp
En ren spekulation, skulle det gå att modifiera en ELM327 (Som kommunicerar med CANBUS) att hämta mätdata från Rego 800?
Skrivet av: purjo__
« skrivet: 20 januari 2016, 19:16:23 »
Nej, Rego 800 har canbus.
« skrivet: 20 januari 2016, 15:33:57 »
Jag har en IVT 290 AW. Och vad jag har kunnat läsa mig till så är det styrenhet REGO 800. Är det någon som vet om hårdvaran som beskrivs här http://rago600.sourceforge.net/ även fungerar till min värmepump? Jag kan inte hitta någon 9-polig port på min styrenhet.
Mitt önskemål är att få ut värdena till domoticz. Någon som har gjort detta och vill dela med sig?
Tack på förhand!
Skrivet av: Lmf
« skrivet: 05 januari 2016, 01:21:07 »
För den som är intresserad av hemautomation så finns här en modul som är byggd i java till REGO637 på följande länk
Vet inte om man måste ha grundmodulen från Hommatic för att det skall fungera eller om man kan använda den till något eget med en Raspberry.
Skrivet av: Håkke
« skrivet: 14 december 2015, 22:22:48 »
The drawing above seems much simpler to me than:
http://rago600.sourceforge.net/ivt_serial.pdf
I followed this drawing and in reply #57 in this thread I wrote that i doubled the values of R1 and R4 when I got it to work. But it all seem to fall back on which optocoupler being used.   I use A817 and D4V4  PC817 (SHARP) , I guess they are the same, but from different manufacturer.
I sent a PM to you, so have a look at that.
Skrivet av: WolfieSax
« skrivet: 14 december 2015, 21:26:56 »
Thanks Håkke! What do you think of this variant?
http://rago600.sourceforge.net/ivt_ser2a.GIF
with HW specified according to:
http://rago600.sourceforge.net/FAQ.html#HW
Skrivet av: jojomensan
« skrivet: 14 december 2015, 16:02:45 »
Friskt vågat hälften brunnit  ::)
Kopplade in raspberryn med matning från Rego +5V, var bara för nyfiken för att låta bli.
raspberryn startade, gick fint att kommunicera med den via ethernet,, allt verkar ok.
Men, kommunikationen med rego fallerar, jag misstänker att det blir för dåligt med kräm för att raspberryns Tx ska orka upp till 2V som detekteras av rego.
Rego överlevde incidenten utan märkbara skador :)
Ett litet paket med optokopplare mm. ska dyka upp i brevlådan alldeles strax, så det ska göras ordentligt nästa gång ;)
Skrivet av: Håkke
« skrivet: 14 december 2015, 12:58:50 »
Hi guys. I'm trying to read data from the service port of an IVT Greenline HT Plus E9 with a Rego 637 controller.
To do this I'm using a USB to serial adapter RS232 between the Rego 637 and my Raspberry Pi (RPi), however I do not get any data out from the Rego using e.g. screen command. I can see that the USB-adapter is correctly connected to the RPi (/dev/ttyUSB0) using commands:
dmesg
lsusb
As soon as I get some data at all from the Rego 637 I would like to use your Perl script ivt.pl available at:
I read on this Forum that the signals coming from the Rego via the service port are too weak and need to be amplified. Is that true? Moreover I found this schematic for such a suitable interface:
Any hints? Could you please help me out?
Rego interface uses TTL levels 0, or +5V as signal levels, while RS-232 uses +3 to +15 V for a logical "0" and -3 to -15 V for a logical "1" , thus there is no way you can connect an USB / RS-232 converter direct to the Rego DB-9 interface.  You must convert from TTL to Rs-232 and furthermore secure galvanic separation between Rego signal earth and Rs-232 signal earth. (Blowing the Rego unit will be very costly )
Follow the drawing in the link you mentioned and build your own interface. It can be problematic to find the correct values of some resistors, I got mine to work quite good , but it took a lot of patience in order to find the right combination of resistors.  What turns out to work well with the frontdoor detached might not work at all once door is closed as the ambient temperature increases.
« skrivet: 14 december 2015, 00:51:52 »
dmesg
lsusb
Skrivet av: Håkke
« skrivet: 11 december 2015, 23:06:13 »
Bilder på hur Rego ser ut inuti finns här. http://www.nekropolis.cz/rego6xx/inside/
Som du ser finns där 2 st kretskortstrafos, tror knappast dessa är på mer än nån/några VA , så troligen finns nog inte mycket i reserv.  Förmodligen är väl en till för +5V och den andra för nån högre spänning, ev 12 V ? Microkontrollern drivs iaf på 5V och drar bara nån W. Det som i övrigt drar mest ström är nog displayen, ev har den separat strömförsörjning. Bara nåt enstaka relä, i övrigt optokopplare som styr Triac för tillslag av ström till kontaktorer, cirk pumpar och växelventil, så det är inte just någon elektronik som drar mycket ström.
Kan inte utläsa hur pass kraftiga trafos där sitter, men det kan du ju kolla. +5V kan man ju prova att försiktigt lasta ner något med olika motstånd och se om spänningen börjar sjunka. Man kan gå ned till 4.5 V innan kontrollern säger ifrån ( datablad  Philips )  http://www.nxp.com/documents/data_sheet/80C552_83C552.pdf
Tänk på att använda ESD !
« skrivet: 11 december 2015, 14:41:26 »
Är en B+, ska dra 250-330mA, kommer inte att ha något annat än ethernet kabel inkopplat. Men jag har ingen aning om hur mycket man kan dra från Rego, någon som vet?
http://raspi.tv/2014/how-much-less-power-does-the-raspberry-pi-b-use-than-the-old-model-b
https://www.raspberrypi.org/help/faqs/#power
Det kanske finns någon annan spänning att tillgå? +12V eller så, borde gå lika bra med en liten regulator krets...bara jorden är densamma, får kolla upp det.
Skrivet av: Håkke
« skrivet: 11 december 2015, 14:05:04 »
Jag skulle aldrig riskera att skada Rego, utan satsa på optokopplare och TTL- RS232 omvandling. En Raspberri Pi drar väl 0,5 - 1 A (?) och frågan om Regons +5 V har den reserven ?
Kostar inte många kronor att göra ett eget interface, ritning finns via länk tidigare i denna tråd. Skada Regon blir säkerligen dyrt.
« skrivet: 11 december 2015, 13:01:33 »
Gammal tråd, jag vet, men den är för bra för att falla i glömska ;)
Jag tänkte använda en raspberry pi mot serie interfacet med en enkel spänningsdelning för att få ner 5V till 3,3V för att inte bränna raspberryns Rx.
Raspberryn drivs ju av 5V via USB, kan man driva den från Regos +5V?
Då slipper man ju bry sig om galvanisk separation, dom kommer ju att köra mot gemensam jord.
Kommentarer och synpunkter mottages gärna.
Skrivet av: Haggan
« skrivet: 23 mars 2015, 19:26:08 »
Hur har det gått med styrningen av IVT? Jag tänkte prova installera Domoticz nu. Vore nice att kunna styra pumpen också. Kanske vi gemensamt kan klura ut det?
Skrivet av: Haggan
« skrivet: 24 november 2013, 21:55:30 »
Är det kallt när det är kring noll då eller? Står om det i instruktionerna i sådant fall.
Skrivet av: mattsjo
« skrivet: 24 november 2013, 21:38:28 »
Domoticz är bra om man gillar hemautomation men kanske inte lika bra om man mest gillar att logga data.
Jag får se när jag kan bestämma mig för hur jag vill styra pumpen. Det visade sig att det inte alls var så lätt att förstå när det känns kallt och rått inne när man tittar på datan som jag samlar in... Att det regnar ute och är under 5 grader kanske räcker men jag vet inte riktigt och nu har det blivit kallare och då fungerar pumpens reglering bra så då har jag inget problem...
Skrivet av: Haggan
« skrivet: 24 november 2013, 10:23:18 »
Trevligt. Jag har kört talologger och loggat till mysql. Tänkte dra in det i emoncms också men ska kolla på domoticz. Är det bra alltså?
Jag haxade ihop lite snabbt så att man kan styra frontpanelen och ändra på alla inställningar på så vis . Med rätt sekvens knapptryckningar kunde jag slå på extra varmvatten. Det är ju bättre och säkrare att skriva direkt till registrena men finns det en komplett lista?
Skrivet av: mattsjo
« skrivet: 23 november 2013, 17:05:18 »
Jag har byggt stöd för Rego6xx för Domoticz (www.domoticz.com) så man kan läsa ut temperaturer m.m.
Nu tänkte jag ta nästa lite läskigare steg och börja skriva till pumpen... Planen är att skriva till finjusteringsregistret för att på så sett kunna blåsa på lite extra fuktiga höstdagar. Eftersom jag har en massa info tillgänglig i Domoticz så borde jag kunna förutse när det kommer att kännas kallt inne och kompensera för det. Tidigare hade jag tänkt att emulera en innesensor men jag verkar inte få tag på den 1-wire styrda potentiometern så det får bli denna väg...
Genom att bara ändra på finjusteringen tänkte jag att den inte skulle hända så mycket om det blir något fel på skrivningar eller uträkningar...  :)
@Haggan: Vilka register har du provat att skriva till och hur gick det?
Skrivet av: Haggan
« skrivet: 15 november 2013, 07:43:44 »
Nice!
Jag har kört talologger ett bra tag. Men detta är ju lite mera lättviktigt!
Intressant har inte stött på Graphite förut!
Jag har knackat ihop en funktion som gör att man kan skriva till pumpen också. Testade i terminalen och lyckades slå på extra varmvatten! Hojta till om du vill ha lite hjälp?
När jag får tid och råd att skaffa en acctank vill jag kunna styra pumpen med solelsproduktion har 11.25kWh på taket :)
Skrivet av: Magnus Appelquist
« skrivet: 14 november 2013, 22:45:16 »
Gammal tråd, men förmodligen fortfarande aktuellt.
Jag svängde ihop en Pythonsnurra som kan skicka ut data enkelt och lättläst. Den kan även formatera texten direkt för Graphite om man vill grafa med det. Går att få riktigt snyggt om man använder någon av de dashboard som finns till Graphite.
https://github.com/magapp/rego6xx
/Magnus
Skrivet av: Haggan
« skrivet: 09 februari 2012, 09:55:33 »
Intressant.
Jag kan se om jag kan testa dem.
Angående python, jag tänkte ju att jag skulle göra om fuldas perl till lite snyggare python.
Men denna finne har hunnit före.
http://olammi.iki.fi/sw/taloLogger/
Funkar mycket bra men är väldigt jobbigt att konfigurera. Men nu loggar jag både värmepumpen samt väderstationen till mysql.
Stabilt än så länge.
Skrivet av: cleesieboy
« skrivet: 09 februari 2012, 09:01:36 »
Väcker denna gamla tråd till liv igen efter att ha börjat grotta lite i datat från min Bosch-pump (vilket ju är en IVT så borde vara detsamma för även deras pumpar).
Fulda har ju gjort ett kanonjobb med att dokumentera ner register osv, jag tänkte göra några tillägg allt eftersom jag hittar något av intresse.
Register            Funktion
0x024               Inställning sommarlägestemperatur?
0x046               Räknare antal kompressorstarter?
0x048               Gångtid i timmar, radiatoruppvärmning.
0x04A               Gångtid i timmar, tappvattenvärmning
0x049               Verkar även denna hänga ihop med gångtiden, 0-9 är värden jag sett på den hitills, kan det
                        vara gångtid i minuter/6, nollas när en timme räknas upp på 0x048 och 0x04a?
Om någon annan kan verifiera dessa vore det kanon!
Min pump har alltså Rego 637, version 3.6.
