Skrivet av: katRyt
« skrivet: 03 januari 2012, 13:42:13 »
Technician came today.
There was a problem with the heat sensor.
So, everything was fine with the system but due to incorrect temp readings, it kept shutting down.
Thanks again for all of the help.
« skrivet: 01 januari 2012, 14:24:03 »
I suppose you mean Above vp-out Carl?
Yes...  :-[
Skrivet av: katRyt
« skrivet: 01 januari 2012, 14:14:55 »
Gas Temp is at 40.
Filter was cleaned.  It was rather dirty but did not fix the flow issue.
All pumps are tested and working.  All radiators have been bled to remove any air in the system.
It is working fine on electricity for the moment.
We will have a technician come by and check it out early next week.
We will repost the solution he gives for future people with a similar issue.
Thanks so much for all of the help.
Skrivet av: DKT
« skrivet: 01 januari 2012, 12:40:00 »
OK, we shall try to speak swinglich!
Is it heat gas temperature that is over 70 ºC high?
Its alright then, it should be about 35-40 ºC below VP-out.
Did you clean the filter on brine?
This is probebly the issue.
« skrivet: 01 januari 2012, 08:03:13 »
Skrivet av: katRyt
« skrivet: 31 december 2011, 12:40:32 »
Ooops blev ju lite dumt
ska vara
Brine -- / --  H.gas --. C ' Ute -5
Skrivet av: KatRyt
« skrivet: 31 december 2011, 12:30:33 »
Okej ska skicka ner gubben för att titta...
jag var nere och skrev av lite data/siffror kanske någon kan reda ut, få lite mer kött på benen av
logg
Tot drifttid 62878h
drift komp 55524kWh
Kompr senaste 24h- 8h42 min
Kompr starter senaste 24h 20st
Elvärme drift 20838kWh 1,5 kW
antal alarm sen 24h-2st
larm senast - lågt flöde brine
Diagnos
Kompr - omarkerad Brine omarkerad
Brine --/-- H.Gas --C'UTE -5C
ELP 1,5kW
Framl 20C Bör 51C
Elpanna 59C Bör 58C
Värmepump 20C Bör 55C
Shuntmotor stäng-omarkerad- öppen-omerkerad-
Strömuttag 11A Huvudsäkring 16A
Shuntläge 50%
och under tiden jag skrev detta upptäcktes och rengjordes ett väldigt smutsigt filter!!
Skrivet av: ORAKLET
« skrivet: 31 december 2011, 11:46:21 »
Förmodligen sitter det utanför  på de rör som borde ha svart isolering
Skrivet av: DKT
« skrivet: 31 december 2011, 11:27:53 »
Ok grabbarna har motionerat pumpen utan resultat. De hittar inte filtret dock, är det inannför eller utanför enheten?
Det borde framgå av manualen hur det ser ut. Kan sitta både utanför och i. Har ni kollat att cirk pump till radiatorerna går? Lägg en pinne mot och lyssna med örat mot pinnen.
Skrivet av: KatRyt
« skrivet: 31 december 2011, 11:21:30 »
Skrivet av: ORAKLET
« skrivet: 31 december 2011, 10:36:33 »
Är det hetgasen som blir 70 grader?  eller är dt framledning till element :o
Hetgasen ska vara 35-40 grader varmare än det som går till elementen så 70 grader är ingenting,  detta kan bli 120 grader typ.  stiger framledningen till 70 grader  så måste nog cirkpumpen stå still och kanske att elen ligger i samtidigt.
Skrivet av: KatRyt
« skrivet: 31 december 2011, 10:13:52 »
Som min man sa- They speak mantalk... Svågern är på väg för att läsa och titta på era olika förslag. För jag gör min man väldigt konfunderad när jag försöker översätta. Vi har provat att resetta systemet med att slå av strömmen utan resultat, tempen som syns på displayen går upp till över 70 ºC direkt när den sätts  på igen. Just nu har vi den avstängd eftersom vi inte vågar ha den på med så hög temp.
Skrivet av: Gäst 999
« skrivet: 31 december 2011, 09:36:48 »
får man båda dom larmen så tror jag på att göra den strömlös i 10 min....
Skrivet av: ORAKLET
« skrivet: 31 december 2011, 09:14:15 »
Kanske rensa filtret? Be gubben att rensa det filter som sitter från borrhålen.  Börja där   CTC brukar väl ha lite problem med hetgasen har jag läst. Kolla filtret  och återkom *vinkar*
« skrivet: 31 december 2011, 09:07:48 »
Nej, det gick inte, provade med http://www.ctc-uk.com/ men där fanns bara svenska manualer.  >:(
Lågt flöde brine brukar annars bero på att köldbärarpumpen stannat, lossa panelen och undersök cirkpumpen längst ner till höger. Det sitter en centrumskruv på den, lossa den, sätt dit en skruvdragare och motionera pumphjulet. Den kan komma lite KB-vätska då skruven lossas, så ha en trasa under.
Men om VP:n inte går igång så kan ni värma med reservlägestermostaten, på den gamla modellen är det en ratt uppe till vänster på panelen, vrid till önskad temp, t ex 55 ºC.
På de nyare modellerna så ställer man in detta på elskåpet bakom panelen, jag tror den inte är lika bra graderad där. :-\
Skrivet av: KatRyt
« skrivet: 31 december 2011, 08:51:59 »
Hejsan
Så här på årets sista dag så har den rackarns vp bestämt sig får att trilskas med oss. Det började för ett par dagar sedan med larmet-"Hetgas givare" Okeej! Fram med instruktionsboken. Och står det något förståligt där för en undersköterska. Nej! men att ge instruktionsboken till gubben är lika illa eftersom han är amerikanare och även om han har lite svenska kunskaper så räcker de inte till för detta och jag kan inte översätta tillräckligt bra. Hot gas giver njaaee stämmer inte riktigt. Våra vvs're har troligtvis tagit ledigt över mellandagarna så där fick vi ingen hjälp.
Nu fick vi igår kväll larmet -lågt flöde brine och vp la av helt..eller vi vågar inte ha på den eftersom tempen rusar upp till över 70 ºC då.
Så nu till min fråga/undran-är det någon som vet om det finns instruktioner på engelska (vi har googlat) eller känner att de skulle kunna svara/förklara på engelska om det finns något vi kan göra. Vi inser att vi kanske inte kan göra något förrän på måndag och vardag igen . Så hur låter vi vp vara under tiden, vill ju inte orsaka mer skada till den.
Det är vår första vinter i huset  och vi fick inte direkt någon lektion i hur man tar hand om systemet när vi tog över.
Tacksam för all hjälp vi kan få
  • Dot gäster: 387
