Författare Ämne: F1255 firmware 7312  (läst 399 gånger)
Utloggad mthus
  • Antal inlägg: 35
F1255 firmware 7312
« skrivet: 22 december 2015, 14:34:40 »
Ny firmware till F1255  tummenupp
Version: 7312
Release date: 2015-12-058
Added
  • Support for accessory shunt controlled addition
  • Support for flow meter.
  • Support for Smart home function.
  • Support for sensor BT57 and BT58 for the accessory ground water pump (AXC40) with the possibility to activate min out-temperature.
  • Possibility to choose “one time increase” in menu 2.1 (Temporary luxury).
Changes
  • Smaller adjustments for viewing and managing menus.
  • It is now possible to choose speed ”auto” and speed in standby in menu 5.1.9 (brine pump speed)
  • FLM:
    • Accessory menu FLM 5.3. Can now also set the pump speed.
    • Improved control of FLM cooling; is now controlled by AZ1-BT50 sensor compared to previous heat/ cool sensor BT74 (When upgrade to v7113R3, if FLM cooling is controlled by cool/heat sensor BT74 is must be changed to AZ1-BT50 in AUX-in)
  • Improved system stability
  • Improved alarm management
  • Other minor bug fixes and improvements
Villa, 164kvm + 34kvm byggd 2014 i Skaraborg. Bergvärme NIBE 1255 + FTX
AirPatrol
