Författare Ämne: Toshiba DaiSeiKai 8 tests  (läst 7491 gånger)
Inloggad jantijanti
  • Antal inlägg: 97
  • Real janti
« skrivet: 01 oktober 2015, 14:29:31 »
Toshiba Artic DaiSeiKai 8 has been tested in Finland. Here is the testresults:
RAS-25G2KVP-ND + RAS-25G2AVP-ND http://www.scanoffice.fi/sites/default/files/u37/vtt-s-04101-15_toshiba_iv.pdf
RAS-35G2KVP-ND + RAS-35G2APV-ND http://www.scanoffice.fi/sites/default/files/u37/vtt-s-04303-15_toshiba_v.pdf
« Senast ändrad: 01 oktober 2015, 14:36:05 av jantijanti »
Utloggad Daikin_
  • Antal inlägg: 2943
SV: Toshiba DaiSeiKai 8 tests
« Svar #1 skrivet: 01 oktober 2015, 16:15:41 »
Interesting to see that Toshiba flagship get beaten in heating capacity @ low outdoor temperature by a Gree unit.
Thought the unit was better.
/D
Inloggad jantijanti
  • Antal inlägg: 97
  • Real janti
Utloggad Chippe
  • Antal inlägg: 125
« Svar #3 skrivet: 15 oktober 2015, 10:48:25 »
More test results RAS-25G2KVP-ND + RAS-25G2AVP-ND:
Fanspeed 4/5 http://www.toshibafinland.com/images/Testit/Toshiba_Arctic_VTT-S-01706-14.pdf
Fanspeed 5/5 http://www.toshibafinland.com/images/Testit/Toshiba_Arctic_VTT-S-03227-14.pdf
Can you please explain, whats the differens between the test at fan speed 4 and fanspeed 4/5. It should be the same setting yet totally different diagrams.
In your first post there is a link to a pdf which says puhaltimen säätöasento: 4
Last post says puhaltimen säätöasento: 4/5 which should be the same fan speed. Still the diagram is totally different.
« Senast ändrad: 15 oktober 2015, 12:10:04 av Chippe »
Inloggad jantijanti
  • Antal inlägg: 97
  • Real janti
« Svar #4 skrivet: 15 oktober 2015, 22:56:43 »
I do not know why there is so big difference in air amounts (dm3/s), last pictures in the reports.
Toshiba refuses to comment the test that was ordered by Scanoffice Oy.
http://www.toshibafinland.com/tiedote
https://translate.google.fi/translate?sl=fi&tl=sv&js=y&prev=_t&hl=fi&ie=UTF-8&u=http%3A%2F%2Fwww.toshibafinland.com%2Ftiedote&edit-text=
In Finland heatpump forum (www.lampopumput.info) I was quessing that pump that Toshiba tested was preproduction model/series (It had T-marking in serial number). It's possibile also that this preproduction versioin does not have plasma filter in it. Some others are quessing that in Scannoffice test the pump had som extra filters installed.  ::)
Anyway, fact is (according Toshiba's own tests) that Toshiba will not give/use full compressor power without full fan speed.
« Senast ändrad: 15 oktober 2015, 23:17:31 av jantijanti »
