Skrivet av: GregS
« skrivet: 23 november 2010, 13:27:15 »
Hi.
I'm running 2.26 on my REGO600.
Only issue is that it's slooooower than hell.
But I guess that is not fixed through an upgrade??
(And besides, I don't have the equipment to prog the curcuit.) :S
Regards,
Greg
Skrivet av: fulda
« skrivet: 11 november 2010, 12:07:56 »
It is worth to upgrade? What do you get with the new firmware?
Hi Ron,
As stated on page - if you have for example rego version MBK, you will have problems with communication (Statlink, IVT@Home, http://rago600.sourceforge.net/) = you can solve this problem.
If you have no any known problem (solved in next version), I can not recommend you to upgrade.
Skrivet av: foreshaw
« skrivet: 30 oktober 2010, 00:49:38 »
Hi,
Regards
Ron
Skrivet av: fulda
« skrivet: 20 mars 2010, 20:55:19 »
Hi All,
If anybody is interested by upgrade of rego software - I have done it. I have upgraded my rego from 3.02 to 3.12.
Here is some notes: http://www.nekropolis.cz/rego6xx/upgrade/
Jindra
  • Dot gäster: 602
